98 Cherokee 4.0 automatic. Came in with a P0123 and a couple of 700 codes. I should have kept documentation on those but I didn't. Changed out a bad TPS test drove and cleared codes. 2 hours after the customer picks it up he returns. It is running rough and does not want to shift. We now have codes P0122, Tps signal low. P0123, TPS signal High. And 89 description unavailable. I have never seen a 2 digit code from Obd II.
Diag. on the codes say do the high first. Followed procedure to the point of replacing the PCM. I did with no changes. The low side proves the same TPS and circuit wiring and replaces the TCM. Which I am now reluctant to do. I believe what ever is causing this Mystery 89 code is the source of my problem.
Tech support for my OTC scanner say its a Chrysler code. Local Chrysler techs say not one of theirs. Any Ideas out there?
It's a glitch, not a real code or anything that I know of or found. Try clearing codes and see if it returns. Chances are it won't. Hope that helps. Gonz
All the wiring proves out . No short to ground, power or each other. Good continuity. Good ground on all components. Solid 5 volts at TPS. 0.6v at idle from sensor 4.7 volt at WOT. No voltage drop from signal at PCM or TCM. And signal is clean and linear with a scope. Still I have codes for High and Low voltage. And this 89. I think there is a valid fault that is not being interpreted correctly by the scanner or PCM.
Try unplugging the Clock spring in the steering column for the Air Bag. It is an known issue on these Models that the Clock spring can affect the Ground for the TPS Circuit and it causes all kinds of drivability issues including P0122 & P0123 Codes.
I know it sounds stupid but just try it and report back to us and let us know what the outcome is.
Thanks
Thanks
Second this, if you have thoroughly tested everything else.
Sorry. Borrowed another scanner came up with a P1694. Changed out the TCM and It shifts now but still sputterrs with P0123 as the only code coming up. Had to push it aside for a bit and will be back on it today.
Turns out that the tech. temped the TCM into place. Once properly installed and grounded the repair was complete. 89 was a code the scanner could not interpret. P1694 also leading to the TCM. Hopefully this helps some one else down the road.
Edited by cdhowell
I've seen 2 other cars before with modules not completely tightened down that was causing issues. Temping as a tech to partially put a car back together to verify repairs before completely reassembling...
      Episode 200 - Balancing Customer Service & Profitability in Auto Repair With Rick White & Mike Himes
      Managing your cash flow can feel overwhelming, but the Profit First system offers a fresh approach to organizing your finances. In this episode of Business by the Numbers, Hunt Demarest, CPA, dives into the pros, cons, and practical applications of Profit First for auto repair shops. Whether you’re new to the system or looking to refine your cash management strategy, this episode is packed with actionable insights.
      What is Profit First? Learn the basic framework of allocating revenue into multiple bank accounts to better manage cash flow. Benefits of Profit First: Understand how it can help you get a clear picture of your cash flow and improve financial decision-making. Challenges to Watch For: Discover why overcomplicating allocations or starting with too many accounts can hinder success. Practical Implementation: Hunt shares a simple three-account system tailored to auto repair --shops for effective cash management. Expert Tips: Adapt the system to your business size and goals, and avoid common pitfalls that lead to failure.
    • By marxautocenter
