I deal with every situation differently. I do have the technician that worked on it previously repair it correctly. Remember, you will have comebacks, appologize to the customer and take care of the bill. I also give the customer coupons for their troubles. If it is a safety concern that is a comeback and it is our fault and not a defective part, I will give the technician a final warning and tell them if it ever happens again he/she will be fired on the spot. If not, I will give him a warning and deduct his time from the last repair. They will learn very quickly to check and recheck their repairs to make sure it is repaired right the first time.
Comebacks can be a real problem. Finding out the root of it is key. Is the tech making mistakes due to lack of training? Caring? Tools? Workflow management? Is it parts quality?
We all have to understand mistakes can happen. Humans are not perfect. However the way the technician reacts to a possible mistake on their end will speak volumes to their character. If you have a tech that has chronic comeback problem you should have a sit down and try to find the root of it. If a tech is in complete denial and/or wants to blame everyone but himself I would say it maybe time for him to go.
I don't know the exact figure of comebacks but I believe the percentage really should be below the 3% overall mark or even lower on total gross labor sales. Don't quote me on that
We have a plan to keep preventable comebacks at a ZERO percent. #1 verify the complaint. Most important step. #2 make repair including the root cause of the problem, #3 verify the complaint is 100% resolved via extensive test drive. If I'm not absolutely sure the problem is solved the car stays until we can verify we fixed it. "Do it right, do it twice. Three times sometimes" is our motto. An example would be a press in bearing, if it's not perfectly smooth we do it again. Sure, good enough will get the customer out the door for a few months but they will come back displeased when it fails at the most inopportune time. OBDII codes get verified with the readiness monitor setting. Anything else is an educated guess. It takes more time to do it this way but it's better than tying up a bay with nonproductive work.
That said we do get some comebacks due to defective parts, that's a warranty issue not a comeback. I had guys who couldn't make a repair stick, they don't work for me anymore. We are all human, I don't worry too much about minor come backs we just take care of it and away they go. Carelessness is not tolerated.
I can say without a doubt every comeback we have had that was our fault was because I let the customer rush us and we skipped a step outlined above.
We are not currently doing this, and it bothers me. Verifying via readiness monitors is the right way to validate a repair.
Do you keep the car overnight for this? Do you have someone drive the car 5-20mi to set O2's and Cat?
We do a minimum of a 10 mile test drive on every job with the exception of oil changes and tire installs. We rarely deal with comebacks. Most of this is the fact we're a 3 person shop and everyone has personal stakes in our performance. I do all the diagnosis work, so I typically will spend longer verifying my diagnosis and repair because I'm the owner. Hourly or book wages as my motivation! My reputation directly represents my compensation!
Sent from my SCH-I605 using Tapatalk
For o2 heater to set we keep the car overnight. Evap we can run in the bay 50% of the time. Normal drive cycle takes about 30 minutes. It tunes us in to what else is wrong with the car too. We only do this on diags. We are a 2 person shop, it gets crazy trust me. Tires, alignment, suspension we test drive about 5 miles but our shop is on the highway so its quick. We do state inspections too so it's not unheard of for someone to leave their car a couple days to get it to pass, its pretty much the norm.
Got one back today, didn't follow my own rule. I put an O2 sensor in because the old one was obviously broken. No need for verification, too time consuming I thought and unnecessary. Easy job. Yup I had an hour today though to work on it free when it came back. Had a separate issue but bottom line is the light came back on because I failed to fix every cause of the original cel complaint. In the customers eyes its got the same problem, which is the light on the dash. I'm guilty of stopping when I found a problem, not all the problems.
Edited by alfredauto
Comebacks due to negligence are not tolerated. This is how customers are lost. Verify all repairs every time.
Thanks, Alfred. I have been considering hiring a guy to shuttle drive, clean the shop, wash cars, etc. This would be another task to add to his list ... a monitor-readiness drive after every CEL repair. Once we move from 4 techs to 5 this spring, I will pull this trigger.
I've heard some shop owners/techs say that comebacks are Job Security-charge them again for something else. That always made me mad.
I always tried to personally road test the vehicles and confirm a quality job in every case. Most comebacks I have seen is due to short cuts or parts failure. When I could not fight for what was right for my customers I "retired".
The most important thing is to take the customers side when a comeback happens. If they say its broke again I believe them and get the car on the lift asap. 9 times out of 10 something else is broke and its a good opportunity to show n tell at least they aren't mad anymore. No matter what they accuse you of smile and get the car in and look, don't even suggest or speculate anything until its on the lift. The techs ego will chase customers away so be careful. I hate comebacks.
I am super sad right now, we had a customer that we have done a couple winterizations for, a couple repairs, couple more auto starts for came in saying their car was overheating at -40 and she thinks the coolant froze (if so our fault for not getting it rich enough) so we take a look at it and there is no coolant in it because the water pump is leaking on a 2005 tahoe with 145k on it. what does she say? She is going to have to talk to her old tech that she used to have before moving here before doing it because she thinks it might be our fault her water pump failed.
Why at this point are we being questioned.
I would ask how old the water pump and see if I could replace at a deal she could not refuse. Always remind customers that a cooling system is like a chainand any weakness may reveal itself.
My reminder with any cooling system work is. "Now that the cooling system is under proper operating pressure, Watch on system parts for any weaknesses. Other cooling system parts, seals, gaskets that were not replaced today may fail in the future under pressure. The customer should maintain a watch on all fluid levels and dash gauges/warning lights. If in doubt bring car by and we will check all fluid levels at no charge"
This does happen. Some customers are easily discouraged. It sounds like you failed to earn her trust somehow? If she is a multi-vehicle customer, just take car of it to try to earn her trust back, but find out what happened for her to lose your trust. Make sure you emphasize that failures just happen, and it wasn't anyone's fault. Good luck!
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Recorded at the 2025 Institute Summit, workplace culture expert Dr. Jessica Kriegel discusses her data-driven framework for boosting business performance through clarity, alignment, and accountability, anchored by her "Results Pyramid," which highlights how beliefs and experiences shape outcomes.
      The discussion unpacks what truly defines organizational culture, the power of storytelling to inspire change, and challenges common generational stereotypes in the workplace, advocating instead for a focus on individual motivations and behaviors. Dr. Jessica Kriegel, Chief Strategy Officer of Workforce and Labor for Culture Partners Dr. Jessica Kriegel is driven by data and defined by results.  She transforms corporate culture for success.  As seen on CNBC, MSNBC, CNN, NBC, FOX Business, New York Times, Wall Street Journal, Forbes, and more,  Jessica is a household name for all workplace, labor, leadership, women in the workplace, and job markets. Her renowned “Culture Equation” was acquired by Culture Partners in 2021, where she is currently Chief Strategy Officer of Workforce and Labor. https://www.jessicakriegel.com/ Show Notes Watch Full Video Episode The Institute of Automotive Business Excellence: https://www.wearetheinstitute.com/ Overview of Dr. Jessica Kriegel (00:00:00) Three-Step Change Equation (00:02:47) Accountability in Business (00:03:31) Results Pyramid Explanation (00:04:11) Beliefs and Experiences (00:05:09) Defining Workplace Culture (00:06:50) Hospital Story for Illustration (00:12:02) Transformative Change Through Storytelling (00:14:09) Culture of Caring (00:15:09) Storytelling in Meetings (00:15:58) Generational Dynamics (00:17:51) Technology Adoption Across Generations (00:20:37) Connecting with Dr. Kriegel (00:22:23)
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Get ready to grow your business with the Automotive Management Network: Find on the Web at http://AftermarketManagementNetwork.com for information that can help you move your business ahead and for the free and informative http://LaborRateTracker.com Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/         Click to go to the Podcast on Remarkable Results Radio
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network This episode focuses on the importance of planning ahead for selling a business in the auto repair industry. Bob Ward stresses that business owners should start identifying and training potential successors early—often from their current team. He walks through a clear four-step process to help with the transition, covering key areas like finding the right fit, determining the business’s value, securing financing, and handling legal requirements. Bob Ward, Perpetual Business, Bob’s Previous Episode HERE. Bob Ward’s Email: bob@wardden.com Show Notes Watch Full Video Episode TST Big Event, March 29th, 2025: https://www.tstseminars.org/ Bob Ward's Ownership Essentials Class April 10-12, Phoenix, AZ: https://perpetualbusiness.co/product/ownership-essentials-phoenix-2025 Importance of Succession Planning (00:00:00) Challenges of Retirement (00:02:23) Value of Transitioning Ownership (00:03:23) Procrastination in Planning (00:05:01) Family Involvement in Succession (00:06:08) Role of Key Employees (00:07:30) Facilitating Ownership Transition (00:08:01) Four Steps to Succession (00:08:27) Retention Strategies (00:10:30) Equity Equivalence Concept (00:11:08) Managing Ownership Changes (00:12:53) Successor Responsibilities (00:15:09) Financing the Purchase (00:16:31) Process Simplification (00:17:31 Successor Concerns (00:21:53) Owner's Perspective on Successors (00:22:22) Missed Opportunities in Succession (00:22:49) Financial Realities for Successors (00:23:14) Perpetual Business Concept (00:28:39) Compatibility Assessment Importance (00:32:57) Essential Career Goals Discussion (00:34:11) Overcoming Fear of Ownership (00:36:40) Identifying the Right Successor (00:37:19) Valuation Metrics Discussion (00:39:36)
      Are you truly a business owner, or just a well-paid employee? In this episode of Business by the Numbers, Hunt Demarest, CPA, dives into the critical distinction between running a business and simply working a high-paying job within your shop. Learn how to measure your hourly rate, assess your true profitability, and make strategic moves to improve your bottom line while working less.
      The difference between being a business owner vs. an overpaid employee How to calculate your true hourly rate (and why it matters) The role of profit in determining business health vs. personal earnings The trade-off between high profit and business independence Practical steps to transition from working in your business to working on your business
      Email Hunt: podcast@paarmelis.com
