Curious how many other shops are paying attention to their 'effective labor rate' in their shop. I heard that industry standard is 90% of your 'standard flat rate'. That sounds great, but I wonder how realistic that really is. Also, how do you personally go about raising effective labor rate at your shop? Did you cut hours paid to technicians for certain jobs? Raise labor rates on menu items?
Mitch Schneider's book, Managing Dollars with Sense, gives a perfect layout of exactly what you're talking about here.
The formula is this:
Productivity = Billed hours / hours available to work (Example: 34.8 billed / 40 hours per week = .87 or 87%)
Average Shop Productivity = Sum of billed hours / Sum of total hours for all techs (Example for 3 techs: (26 + 34 + 44) / (40 + 40 + 40) = 104 / 120 = .87 or 87%
Effective Labour Rate = Labour Rate x Average Shop Productivity (Example: $95 x 87% = $82.65)
These number will fluctuate daily, even hourly.
So yes, what you heard is correct, 90% is a good average shop productivity, compared to the majority of independent shops which are below 70%.
Many shops are actually closer to 55% according to the book - can you survive on barely more then HALF of your labour rate??? ($95 x 55% = $52.25)
Productivity = Profits, plain and simple!
Industry standard from what I've read, is 110% nowadays (average 9 hours billed in an 8 hour day per tech) to have a truly profitable shop.
The book outlines multiple methods for you to figure out what you should set your labour pricing at based on your shop's numbers, rather then basing off other shop rates in your area.
As for increasing productivity, you need good techs, but also good front counter processes (efficiency is purely on the tech's shoulders, but productivity has just as much to do with your service writer, shop layout, tooling etc)
I don't think cutting hours paid for certain jobs actually pertains to this calculation, nor would I feel this would be the morally right thing to do to try to be more profitable. (Profitability should be win-win for your shop and your techs)
Raising labour rates on menu items would have the desired effect (higher labour rate for that job), but I strongly believe that improving productivity would have a far more drastic effect then raising pricing on certain jobs, as it would apply to every tech and every RO.
Productivity is important, but it's equally important to manage the profitability of the work you are doing. We all have loss leaders like oil changes and state inspections. You have to make sure you are getting these done with the cheapest labor possible. We struggle with the master tech who doesn't want to give up the oil change that's on a big ticket so we end up paying him $30 per hour to do lube tech work.
I have not read his books, so this is just me asking an honest question. I see the book was written back in 2003. Do you feel like the figures provided in the book apply to a shop in 2014?
Edited by mmotley
The figures are dated, but the formulas are still the same.
The book actually used $65 as an example labour rate, far below most shops nowadays.
The 110% productivity standard is from other recent (2012+) sources. At the time of the book's printing, it called for 100% productivity.
Here is an article from 2012 that uses 113% productivity as it's example (9 / 8 = 112.5%).
http://www.motor.com/magazine/pdfs/022012_10.pdf
I'm not sure if I'm missing something here, but I always understood effective labor rate as being calculated another way.
Labor sales dollars / flat rate hours paid out to techs
This way, it accounted for your .5 hour oil changes, .5 hour tire rotation, etc. and would give you a figure that represented an average labor rate, or effective labor rate.
A quick google search for 'effective labor rate formula', and I now have about 3-4 different methods of calculating it, none of which are really similar...
There is multiple ways to calculate just about anything.
I found your formula in a dealers edge magazine article, so it could apply to independent shops as well.
Here is another article from 2004 that shows 2 methods of calculating effective labour rate, but focus on Table 2, not Table 1 which is for hourly.
http://www.motor.com/magazine/pdfs/112004_07.pdf
As a side note, this article uses 138% (bill 11 hours per 8 hour day) as a benchmark, which is somewhat unattainable. Future articles do not use the 135% standard, they go back to 113%.
I think the best idea would be to find a formula that you like, and works for your situation.
Hourly and flat rate require different formulas.
Edited by bstewart
I agree. Just to follow up and maybe explain a little more of how I was originally taught effective labor rate, here is a quick youtube video I found...
http://youtu.be/2mDzFLgza3k
Either way, like you said, it's probably best to find a formula that you like and applies to your situation best and stick to it so you can track it.
    • By stevefry
      EOS One
      Introduction and Sponsors (00:00:01) Overview of the podcast and thanks to sponsors RepairPal and App Fuel. Creating a Shared Vision (00:00:10) Brian discusses the importance of establishing a shared vision for the company. Leadership Team Meetings (00:01:13) Details about offsite leadership meetings and the exercise called "the one thing." Feedback and Growth (00:02:08) Brian reflects on receiving feedback from his leadership team and its impact on personal growth. Shifting Mindset on Growth (00:03:07) Brian shares his fears about growth and how he overcame them to embrace larger ambitions. Disney's Service Model (00:04:17) Comparison of Disney's customer service model to his company's approach to client service. Processes and Procedures (00:05:26) Discussion on the importance of processes in maintaining service quality while growing. Inbound Marketing Strategy (00:07:25) Brian explains the effectiveness of inbound marketing in attracting clients. Outbound Sales Shift (00:09:26) Introduction of outbound sales strategies and the team's initial reactions to the change. Creating a Shared Vision Deep Dive (00:10:34) Brian's focus on developing a shared vision after receiving feedback from his leadership team. Researching Shared Vision (00:11:42) Challenges in finding resources on creating a shared vision and discovering related literature. Book Recommendations (00:12:42) Brian reviews two books on vision creation and his thoughts on their content. Simplicity of Creating Vision (00:13:34) Brian concludes that creating a shared vision is simpler than expected, emphasizing clarity. Vision, Mission, and Values Explained (00:14:45) Brian differentiates between vision, mission, and values with a practical example. Big Dreams and Ambitions (00:15:45)  Brian discusses the importance of dreaming big and outlines a fictional company's ambitious goals. Vision, Mission, and Values (00:16:48)  He explains the significance of having a clear vision, mission, and values for a successful organization. Sponsor Message: RepairPal (00:17:48)  Introduction to RepairPal and its services that help auto repair shops attract tech-savvy customers. Sponsor Message: App Fuel (00:18:48)  Overview of App Fuel's customer loyalty app designed for auto service shops to enhance customer retention. Core Values and Their Importance (00:19:57)  Brian shares his realization of the value of core values in decision-making and company culture. Litmus Testing New Hires (00:20:59)  He describes how to evaluate potential hires against the company's vision, mission, and values. Understanding What You Want (00:21:55)  Brian emphasizes the importance of defining personal and business desires beyond just financial goals. Creating a Clear Vision (00:23:51)  Discussion on the necessity of a detailed, clear vision for a business to guide its direction. Proximity to Your Dreams (00:26:56)  Encouragement to immerse oneself in environments that inspire and reflect personal dreams and aspirations. Crafting Your Vision (00:28:50)  Brian advises on the process of creating a vision, emphasizing the need for time and space away from routine.  The Importance of a Clear Direction (00:29:46)  He compares running a business without a clear vision to aimlessly shooting an arrow, highlighting the risks involved. Creating a Target (00:30:41)  Discusses the importance of having a detailed vision as a target for business goals. Vision Details (00:31:37)  Explains the components of a business vision, including specifics about services and operational metrics. Dream Big (00:34:25)  Encourages thinking big without worrying about how to achieve those goals initially. Historical Example: JFK (00:35:32)  Uses JFK's moon landing vision as an example of effective goal-setting and inspiring leadership. Sharing the Vision (00:37:33)  Stresses the need to communicate the vision clearly to the entire team for buy-in. Selling Down the Ladder (00:38:27)  Describes the process of sharing the vision, starting with leadership and moving downwards. Feedback and Buy-In (00:39:19)  Highlights the importance of receiving feedback and fostering genuine buy-in from team members. Repetition of Vision (00:40:12)  Discusses the necessity of repeatedly communicating the vision to ensure team alignment. Crafting the Vision (00:42:20)  Brian reflects on his personal goal to create a detailed vision for his organization. Importance of Shared Vision (00:43:34)  Concludes with the significance of a shared vision for team alignment and achieving business goals.
      Episode 214 - Exploring Leadership & Culture in the Auto Industry with Dori Epstein
      Bonus Episode - Building Community and Changing the Auto Industry with SWAP and Sunrise
