Wanted to get your take on this...
We seem to get a lot of decently tough diagnostic work. This ranges from Engine issues, electrical, unknown collision damage etc.
We are more than capable of finding out most issues however with diagnostics there never is a flat rate. As we know, people HATE HATE HATE buying something that isn't tangible. Repairs alone are something they can't necessarily feel or touch. Diagnostics is a step lower on the ladder where us as repair shops are not repairing anything, just finding out what the problem is. We find sometimes it takes us hours maybe days to track down a problem. If we actually charged true time spent on a vehicle sometimes ROs can come out to the thousands. How do you go about selling and billing this?
I've had customers authorize block times (3-5 hours of diag time) with mixed results. If we still don't find the problem within that time no matter what they agree to they are down right pissed off about paying anything even after being fully aware that there is no guarantee. Maybe they were the wrong type of customer in the first place I don't know.
I find it becomes more of a burden than good business to work on these vehicles. Are these hard diag problems worth just passing along? How do you go about doing that without coming across to the customer like you don't know what your doing?
I contemplate every day how I can just run a suspension/alignment/brake shop and get consistent business LOL. That would be heaven sent!
We just had a BMW 5 series in with similar issue. No start out of the blue. I accepted the job because it's a good customer and I figured the fuel pump was bad. After about 5 or 6 hours of tracking down each code I came to the conclusion that the Theft Module wasn't sending the drive authorization to the computer. Of course the module is dealer only and needs to be programmed so I sent the car back out on the hook to the dealer because I wasn't 100% sure if the module was bad or there was another issue I was ignorant about. The customer was OK with it and the dealer did replace the module and the car was back on the road. Even though my diagnosis was correct I didn't charge the guy anything except the standard one hour fee.
This can be a serious headache in some situations. We've had several jobs that had days of diagnostics and research. They turned out to pay only 4 or 5 hours as we couldn't see charging these people thousands of dollars. These have made some of our best repeat customers though. On the other hand we've got a regular dealer who sends us only the tough jobs and nearly every time, we're able to bill every hour spent to get the repair done.
There's only been a couple of jobs we had to turn away and tell the customer the car just isn't worth the can of worms this one repair is going to open up.
I tend to estimate high. Assume the worst case scenario and add a disclosure to the estimate that we cannot guarantee. If the customer still insists to move forward we'll take the job on. This has really been our only saving grace but it took those two worst case scenarios to come to this method of handling diagnostics.
Anymore we have more headache in this area from the people who think they are going to come in for free diagnostics, that we'll tell them what 's wrong and they can then attempt DIY repairs. I send them to AutoZone.
~Heather
Thanks Heather.
I have tried the disclosure portion of the bill and have had customers sign and verbally agree to my term however they still leave sour OR try to not pay the bill because "their car isn't fixed." This can be very frustrating... almost as frustrating as customers who try to negotiate the bill after they have authorized all repairs and repairs have been completed.
I feel as shops, if we don't find anything at all we shouldn't charge the customer. With that being said, if you look closely enough you can find something. if it comes down to "the pcm needs reprogrammed" then i tell customer we need to start there. Once reprogrammed then we continue checking the other systems. Its all in the wording. There are rare occasions that i have to ship something bc am stumped. Id rather fight my way thru even if take hit on a part that didn't fix it...bc in the end i will have gained the knowledge for the next time. I truely the most money to be made is in diagnostics. Commit to learning new techniques and doing it right and it only gets easier.
      Timestamps:
      (00:00) – Intro
      Quotes
      Tools & Resources Mentioned:
      Final Thoughts:
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Dan Clark explores how emotion surpasses reason in driving action, particularly in sales, emphasizing the power of storytelling to activate specific brain chemicals. He shares personal experiences, including his recovery from paralysis, to illustrate the impact of belief and a strong "why." The conversation delves into societal stigmas around emotional expression, especially for men, and the importance of genuine connection. Clark further explains how leveraging brain chemistry through storytelling enhances influence and strengthens customer relationships. He concludes by stressing that businesses should prioritize deep human connections over mere transactions. Dan Clark, Hall of Fame Keynote Speaker, New York Times Best-Selling Author of 37 Books, Expert in Next-Level Leadership for Teams, Sales, and Life. https://danclark.com/ Show Notes Watch Full Video Episode The Institute of Automotive Business Excellence: https://www.wearetheinstitute.com/ Introduction of Dan Clark (00:00:00) The Importance of Emotion in Memory (00:02:47) Emotion vs. Knowledge in Sales (00:04:17) Statistics on Sales Persistence (00:04:47) The Role of Storytelling in Sales (00:05:13) Social Stigma Around Emotion (00:05:23) Mental Health and Emotional Prosperity (00:06:01) Creating Discomfort for Growth (00:07:05) Asking for Help in Mental Health (00:07:49) The Role of Feelings in Leadership and Sales (00:08:07) The Zone and Brain Chemicals (00:09:11) Emotional Connection in Sports (00:10:06) Impact of Storytelling on Audience (00:12:07) Overcoming Struggles and Emotional Growth (00:16:29) Authenticity and Emotional Expression (00:17:54) The Importance of Belief (00:18:30) Energy and Attraction (00:19:26) Authenticity in Connection (00:19:54) Personal Injury Story (00:20:31) Rock Foundation vs. Rock Bottom (00:21:21) Core Values in Business (00:22:22) The Power of Belief (00:23:08) Asking the Right Questions (00:23:51) Connecting Head and Heart (00:24:36) Physiological Responses to Fear (00:24:49) Storytelling in Sales (00:27:32) Self-Awareness in Customer Service (00:28:29) Identifying with Roles (00:30:22) Heart-to-Heart Connection (00:30:44) Story of Empathy (00:31:07)
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Get ready to grow your business with the Automotive Management Network: Find on the Web at http://AftermarketManagementNetwork.com for information that can help you move your business ahead and for the free and informative http://LaborRateTracker.com Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/
