Ok, before you all begin assaulting and attacking me for being a half ass mechanic...let me explain:
I AM NOT posting this because I make a practice of replacing only one brake rotor or because I want to argue a case in favor of such practice. I, like most of you I imagine, have always been taught and trained to replace/refinish brake rotors ONLY in pairs. NO EXCEPTIONS. Or else the world will explode! haha...ok, well, maybe not the world I guess. But presumably something really bad will happen.
But do any of you ever get asked by the customer WHY you had to replace both rotors when only one was "bad"? What do you tell them? Do you just make something up, spout off the same generic response that your old boss/instructor/teacher/mentor, etc. told to you about how you need rotors of the same thickness for equal stopping force blah blah blah or do you actually KNOW the concrete scientific reasoning behind this "universal truth"? I myself am a little fuzzy on the details. It seems like I am constantly having to explain to customers that I had to replace BOTH brake rotors, but when they ask me why, I don't really know exactly. I'm hoping you guys can help me out with either a detailed explanation or a link to some technical artical that will explain it.
I will also accept personal experience as evidence such as "I tried replacing only one rotor one time and the customer was back the very next week in a full body cast with his lawyer pushing the wheel chair."
Ready: GO
I was taught that it maintains even braking. If the old rotor is thinner it will build heat and thus fade faster than the new one. That in turn will develop a brake pull that could cause loss of control.
I believe this is the correct answer, although I think the potential safety issue is very minimal IMO. Don't forget that you almost always have a slight brake pull due to the crown of the road.
I also think that refinishing/replacing in pairs is to keep both sides wearing at the same rate, so if one is worn out, the other will be soon to follow.
That being said, I work at a heavy duty dealership at the moment, and we regularly replace single rotors on commercial trucks with disc brakes if the other is still within spec.
If I was in your situation, I'd measure the "good" rotor, estimate how much time is left before it fails, and inform the customer.
Educate them to the cost of fixing it now vs returning for another appointment where you have to disassemble that wheel end again.
Obviously recommend changing rotors in pairs, but if they don't want to, I wouldn't press the issue.
If the rotor will last until their next scheduled maintenance, maybe they'd want to have it replaced then, always give your customer the choice.
This is a really good question. I would say 'technically' you can replace just 1 rotor. After all, if the other one is within spec... it's within spec! I would say 'replacing as a pair' is probably more of a good practice, IE Jeff - " If the old rotor is thinner it will build heat and thus fade faster than the new one. That in turn will develop a brake pull that could cause loss of control" .
I would also agree, now that I think about it, that I don't recall reading or hearing any official material say that they should be replaced in pairs... Maybe a quick google search would turn something up?
I think the brake pull is a good answer but could lead to the question of if you think its unsafe then why would you perform that practice and open yourself up for potential law suit after admitting to cust that it could cause loss of control. I usually play the economic card...saves money to do it now. Then let cust decide, assuming rotor is within spec.
i always use things that people can relate to like the LP record and the sun analogy. Heat will warp a record like heat will warp the rotors.. so in this case i tell customers that brake rotors should be replace together because they both have to be the same thickness and then i tell them if they would you ever consider buying only one shoe. if only one shoe gets worn will they just buy that warn shoe? after that what can you say "I under stand, go ahead and replace them.." Done "Change them Bob..."
Edited by uniautoser
I will do one rotor as long as I turn both the rotors for a matching finish. Of course the other rotor needs to be within spec after the refinish. This scenario does not come along often for me.
Most of my clients have never played an LP Record, and if I used that term most would not have a clue what I was talking about. I have not seen one out of its protective sleeve in well over 30 years!!
With that said, When I give a price on performing the brake job on a vehicle that is in the shop with wheels off and inspection finished, I give the price for the brake job. I do not mention pads or more importantly, rotors. I tell them that the price for the front brakes is $388 for example, and that the rear brakes are ok at this time. I would say that on 80% or more of my brake jobs I install new rotors. We do not machine rotors.
Replacing rotors in pairs helps keep consistency in maintenance, and safety. By doing so you remove the guessing game of when you need to do it again, and basically the customer trades some dollars for convenience and certainty.
Kinda, doing light bulbs in pairs, you know, I am sure you had a customer come in for a burned out headlight bulb and a few weeks later he comes in again for the other one.
There are customers that if you explain to them that they may have to comeback for the other bulb, they dispense with the inconvenience and tell you to do both.
      Emily Chung shares her experiences as a female minority shop owner in the automotive industry. She reflects on societal tendencies to highlight differences rather than commonalities. She encourages her peers to engage with her on business-related topics rather than focusing on her gender and ethnicity. Emily Chung, AutoNiche in Markham, ON. Emily’s previous episodes HERE Show Notes:
      Emily's Perspective as a Female Shop Owner (00:00:26) Challenges and Comments Faced (00:00:56) Desire for Business-Focused Conversations (00:01:41) Importance of Leadership and Skills (00:02:29) Understanding Intentions Behind Comments (00:03:52) Common Ground with Male Counterparts (00:04:57) Personal Mindset on Success (00:06:04) Role Model Considerations (00:06:54)
      Thanks to our Partners, Shop Boss and 360 Payments Shop Boss – Shop Management Software built by shop owners for shop owners. It works the way you need it to, right out of the box. Find on the web at https://shopboss.net Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -The Aftermarket Radio Network: https://aftermarketradionetwork.com -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size.
      Today, we’re diving into an essential topic—how to make your brand stand out from the competition. While you may already provide exceptional service, standing out in a crowded market requires a focused strategy. It’s not just about doing good work; it's about showing what makes your shop truly unique.
      We’ll break down the key ways to differentiate your brand, from nailing your customer service to using your core values to your advantage. We’ll also talk about how paying attention to your shop’s appearance and maintaining an active social media presence can make a big difference in how customers see you.
      If you're ready to learn how to make your shop rise above the rest and attract more customers, this episode is for you.
      Building a StoryBrand by Donald Miller : https://storybrand.com/building-a-storybrand-book/
      McCart’s Auto Center - Ratchet and Wrench : https://www.ratchetandwrench.com/shop-life/article/11464229/shop-view-mccarts-auto-center
      https://shopmarketingpros.com/how-to-make-your-brand-stand-out-from-your-competitors/
      Introduction to Brand Differentiation (00:00:10) Brian introduces the topic of brand differentiation for auto repair shops. Understanding Brand (00:02:26) Explains that a brand is more than just a logo; it embodies the overall customer experience. Customer Perception and Reviews (00:04:25) Discusses the importance of customer reviews in identifying what makes a shop unique. Identifying Strengths and Weaknesses (00:05:30) Encourages owners to focus on strengths while addressing weaknesses for better brand differentiation. Concept of a Four-Dimensional Shop (00:06:32) Introduces the idea of a four-dimensional shop, focusing on customer service, quality, timeliness, and price. Timeliness and Price Mindset Shift (00:08:29) Stresses the importance of communication and fair pricing in building a strong brand. RepairPal Sponsorship Mention (00:10:28) Thanks RepairPal for sponsoring and highlights its benefits for auto repair shops. Building Trust with Clients (00:11:26) Emphasizes the need to cultivate trust through social media and transparent communication. Core Values Integration (00:12:23) Explains how core values should be central to the brand and daily operations of the shop. Daily Recognition of Core Values (00:13:19) Describes the implementation of daily recognition for team members based on core values. Core Values and Brand Identity (00:15:19) Discusses how core values, like happiness, differentiate a brand and impact team morale. Outward Appearance of Shops (00:17:18) Emphasizes the importance of a clean and organized environment in shaping brand perception. Customer Perspective (00:19:28) Encourages shop owners to view their business from a customer's angle to identify areas for improvement. Impact of Shop Aesthetics (00:20:35) Explains how the physical appearance of a shop affects customer impressions and overall branding. Importance of Business Name (00:23:10) Highlights the significance of a shop's name in representing its identity and differentiating from competitors. Examples of Effective Names (00:24:03) Provides examples of shop names that effectively convey their unique selling propositions. Role of Logos in Branding (00:27:47) Discusses how a logo serves as a visual representation of a shop and its differentiation Logo Importance (00:28:53) Discussion on effective logo design and its impact on brand representation. Color Theory in Branding (00:29:48) Exploration of how colors influence perceptions and emotions related to a brand. Crafting Your Brand Message (00:30:55) Advice on creating a brand message that resonates with client concerns rather than just shop credentials. Understanding Client Problems (00:31:52) Emphasis on identifying deeper client issues to tailor brand messaging effectively. Book Recommendation: Building a Story Brand (00:32:44) Recommendation of Donald Miller's book for crafting impactful brand messaging. Differentiation in a Competitive Market (00:33:39) Final thoughts on the necessity of standing out in the auto repair industry. Call to Action for Marketing Help (00:34:37) Invitation for listeners to seek marketing assistance from Shop Marketing Pros. Acknowledgment of Sponsors (00:35:36) Thanks to RepairPal for sponsoring the podcast and supporting the auto repair community.
