Seem to be having a problem with our mechanics in going beyond the alloted diagnostic time we are charging.
For example, customer brought in vehicle complaining of engine noise. Charged 1 hr diagnostic time upfront. Told mechanic to start off with basics . Mechanic returned an 1hr later and requested to remove cover to look at timing components (Much more labor & parts involved than initially anticipated) and look at other systems of the vehicle.
How would you handle this situtation? Seems to be a reptitive problem, and I feel we are investing too much time in a diagnostic and might scare away customers with diagnostic time, and ultimately not getting the job.
Thanks for your thoughts and opinions in advance.
Sure, let's say a customer comes in for a engine miss fire.  After verifying the misfire, we will sell a package of tests like this:
- Visual inspection of under hood and related components
- Condition of air filter and fluids? Fuel filter (if applicable)?
- Battery and charging system test
- Scan on board computer, obtain error codes and other key information
- Perform component and system checks, determined by error codes
- Check for factory bulletins and known problems
- Test ignition components, fuel system tests (condition of fuel), cylinder balance, vacuum and back pressure tests
- Isolate engine misfire
- Perform enrichment to rule out lean miss
- take into account miles on engine, age/condition of spark plugs, fuel filter and other service items
- Determine cause for misfire and needed repair
All above for $ XX.XX
(Mr. Customer) If the above reveals that the problem is engine mechanical, we will need to perform the following...
- Perform all above tests and determine engine misfire is a mechanical issue
- Compression test, running compression test, if needed.
- Combustion chamber leak down test, if needed
- Check for internal cylinder head problem
- Check for valve train problem
- Insure engine valve timing is correct
Review all data, report to customer and discuss needed repair
Additional $XX.XX
I think this is the absolute best plan for this industry that's ever been. I have a hard time implementing it but we're working towards it. We've all got to start setting expectations for our customers, of more shops would do this we might see things (in regards to customer relations) would improve!
We have used the diagnostic trees on All Data or Identifix as a sales tool. When we pull the code(for free like the parts stores) we will then print out the tree. We will then show the customer the"tests" we will be performing and letting them know the cost associated with that test. Once we have the results of that test we may have the cause and the repair needed, or we may need to move on to additional testing. The customers may not quite understand what we are doing, but it at least gives them an idea of how the process works to diagnose a car.
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Recorded at the 2025 Institute Summit, workplace culture expert Dr. Jessica Kriegel discusses her data-driven framework for boosting business performance through clarity, alignment, and accountability, anchored by her "Results Pyramid," which highlights how beliefs and experiences shape outcomes.
      The discussion unpacks what truly defines organizational culture, the power of storytelling to inspire change, and challenges common generational stereotypes in the workplace, advocating instead for a focus on individual motivations and behaviors. Dr. Jessica Kriegel, Chief Strategy Officer of Workforce and Labor for Culture Partners Dr. Jessica Kriegel is driven by data and defined by results.  She transforms corporate culture for success.  As seen on CNBC, MSNBC, CNN, NBC, FOX Business, New York Times, Wall Street Journal, Forbes, and more,  Jessica is a household name for all workplace, labor, leadership, women in the workplace, and job markets. Her renowned “Culture Equation” was acquired by Culture Partners in 2021, where she is currently Chief Strategy Officer of Workforce and Labor. https://www.jessicakriegel.com/ Show Notes Watch Full Video Episode The Institute of Automotive Business Excellence: https://www.wearetheinstitute.com/ Overview of Dr. Jessica Kriegel (00:00:00) Three-Step Change Equation (00:02:47) Accountability in Business (00:03:31) Results Pyramid Explanation (00:04:11) Beliefs and Experiences (00:05:09) Defining Workplace Culture (00:06:50) Hospital Story for Illustration (00:12:02) Transformative Change Through Storytelling (00:14:09) Culture of Caring (00:15:09) Storytelling in Meetings (00:15:58) Generational Dynamics (00:17:51) Technology Adoption Across Generations (00:20:37) Connecting with Dr. Kriegel (00:22:23)
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Get ready to grow your business with the Automotive Management Network: Find on the Web at http://AftermarketManagementNetwork.com for information that can help you move your business ahead and for the free and informative http://LaborRateTracker.com Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/         Click to go to the Podcast on Remarkable Results Radio
      Bonus Episode - Mechanic Missteps and Diagnostic Dilemmas With Jake Barnes
