Searched and don't see this topic anywhere:
What is the average length of time that shops use for labor warranties? We for the most part say it's lifetime on labor because we stand behind our work and if we did it wrong, we'll fix it. But I think that some people (!) would take advantage of that fact and that with some types or repairs or work, past a certain point in time, you couldn't prove labor issue, part issue or wear and tear, so what's an acceptable time frame for both customer and shop? 12k/12 month? Interested in hearing how everyone handles this issue.
This is something I've thought of a lot as well. Having a strong warranty and using top quality parts is definitely a great selling feature for you.
I'm guessing most "rat hole" type shops would run a 3 or 6 month warranty.
From what I've seen, the most common would be a 12/12 warranty.
A premium shop using top quality parts could easily offer 24/24 or even more if using dealer parts.
thanks appreciate the feedback. We have a large customer base that has a poor history of vehicle maintenance so I am leaning toward 12/12.
24/24 because we are a part of the Certified Auto Network with Oreilly's. Nationwide and the few times my customers have had to use it on the road, the warranty has worked very well.
I am 30days on used parts with no labor warranty unless purchased seperately from part supplier (engine, transmissions, rear ends etc).
1 Year unlimited miles on brake pads, rotors, starters, alternators, pretty much everything else.
My cliental can be kind of rough with the working class area I am in. Customers always come back trying to warranty stuff that is unrelated to the repair you did. Example I installed a LKQ motor in a Ford Fusion with a 12 month, 12k warranty purchased from LKQ, covers internal lubricated part. Within a year the Alternator went out, customer wanted it warrantied, and one of the accessories pullies started making noise and they wanted that warrantied. Big fuss over everything, but they act like a warranty is bumper to bumper for the next year.
Mario - share your pain. Same situation here. You look under the hood and you own it for life. Trying to avoid those arguments with customers. They want the cheap fix with cheap parts and labor, don't maintain the vehicle and then everything that goes wrong is supposed to be on us. Extremely frustrating and discouraging.
We are 12/12 here. If there is a life time warranty on the part, then we will pass that on to the customer, but they need to pay the labor if it is out of warranty.
A warranty is a positioning statement. It is part of your marketing and risk management. It doesn't matter how long your warranty is, simply factor the cost to cover into cost of operations. Customer perceived coverage is unconditional. If it fails for what ever reason it's on you.
Ive wondered about this in my area. Im 12/12 currently. Thinking of changing it to fit the warranty im given from my suppliers. They have recently changed labor claim warranty to only 90 days. So was considering 90 day labor and 12 parts. But also have considered lifetime warranty options parts and labor. Feedback would be helpful.
My shop is a NAPA AutoCare Center and NAPA provides a 24 month or 24,000 mile nationwide warranty on most parts. So do I. If the part has a lifetime warranty I extend that to the customer as well and tell them the limited poriton is the part is warranted for the life of their ownership of the vehicle but the labor is covered for months. in the event i lose my sanity and install a used part, 30 day part only, NO LABOR. In the event I go insane and install a customer supplied part, NO WARRANTY WHATOSEVER beyond I did the job right. Starter falls out, I didn't do the job right, starter solenoid stops engaging or the solenoid to starter motor wire corrodes but the starter is mounted tight and the cables are clean and secure, I did the job right no warranty. As an example of course.
If your supplier screws you on labor reimbursement you can do one of three things, eat it in the event of a parts failure, hopefully not very often, build your own warranty costs into your rates or find a better supplier who will stand behind you better. NAPA stands behind their AutoCare Centers for the full term of the warranty. It is reimbursed at a reduced rate, I think it's 75% but that's better than 0%.
we offer a 12/12 warranty but nobody reads it. If they have a repeat failure within a year they come back anyway and we fix it. If they have a repeat failure anytime we do our best to make it right for them regardless of time/miles. If it's caused by neglect or brother in law tinkering too bad the customer pays, If it's a parts defect we take care of it and try to get a labor claim. Technician workmanship problems usually show up quickly, like immediately :). Bigger jobs like transmissions come with a 3 year manufacturers parts and labor warranty (at a reduced rate of course), we build it into the estimate. Usually if a part has a recurring failure something else is wrong and we learn from it. Some customers expect too much, like they never check tire pressure and never rotate their tires never fix the loose tie rod and broken springs and cry when they don't get the 60k miles they were promised. We don't give charity. Customer supplied parts come with zero warranty - we try our hardest to talk them out of it but if all else fails we accept their diagnosis, install their parts, and take their money, that's it. Funny story we installed a starter for a guy on a F150, he supplied it. Didn't start before or after, just a loud click. We offered to check into it but He knows it all so he had us put in another one. Same result. He really is an expert so he had us install a 3rd one. Before pulling the 3rd junkyard starter I gave some free diagnostic labor and it turns out the AC compressor was locked up solid.Removed the belt and the starter was good again (I can assume the 1st one was good too along with the new battery he installed and a host of new easy to replace parts under the hood someone put in). He was mad we charged him to R&R 3 starters I'm soft so we made a deal but I shouldn't have.
We do the 30/30, 30 feet or thrity seconds which ever comes first.....lol. Seriously though we also do the 12/12. No warranty on labor or parts if used even if we supply it. I offer that option to my customer but make sure they understand. After reading some of the situations posted above I see a common situation which can usually be avoided if your service writer/counter person does a good job explaining what is and isn't covered when an job is performed. We all have THOSE customers who expect something for free, but once again my service writer handles those situations easily due to the fact that upon the initial job everything we see is documented on the customer invoice. As for what Alfred just typed, we won't let customers tell us to replace parts without US diagnosing. If they wont pay my diag fee then I don't want them as a customer. I have seen first hand who loses when a customer self diagnoses his vehicle and supplies a part. If it doesn't work then the shop who did the work doesn't feel good about the repair and neither does the customer. Those customer usually leave and give negative publicity. Although it wasn't the shops fault, who pays the price when slandered. My .02c
Edited by Chuck
      Why Auto Shops Are DITCHING Aftermarket Parts in 2025?
      Sometimes life just doesn’t slow down, does it? Between running a business, managing a team, and balancing everything else, it’s easy to feel like you’re drowning in tasks. If that sounds familiar, you’re not alone.
      Hi, I’m Kim Walker, and today I’m sharing my personal journey through a season of overwhelm—and how I’m finding my way back to productivity and peace. This episode isn’t just about getting things done—it’s about giving yourself the grace to start where you are and take small, meaningful steps forward.
      So, take a deep breath, grab a notebook, and let’s get organized—because even in the chaos, we’ve got this
      Thank you to our friends at RepairPal for this episode. RepairPal will introduce your shop to new customers through repairpal.com, the largest site for auto repair. Learn more at RepairPal.com/shops.
      Stephen Covey's Time Managment Matrix
      Remarkable Tablet
      Time Blocking
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network In the fifth installment of the "Unstoppable Framework for Auto Shop Owners" series, Maryann Croce, a coach from Small Biz Vantage, shares her expertise on building resilience and effective planning for automotive professionals. Maryann emphasizes the importance of a resilient mindset, proactive planning, and continuous improvement. She offers practical tips, such as creating contingency plans and regularly assessing business processes. Maryann Croce, Small Biz Vantage. Maryann’s previous episodes HERE. Show Notes Watch Full Video Episode Unstoppable Framework for Auto Shop Owners Part 1: Core Values and Vision [RR 997]: https://remarkableresults.biz/remarkable-results-radio-podcast/e997/ Unstoppable Framework for Auto Shop Owners Part 2: Mastering Your Finances [RRR 1004]: https://remarkableresults.biz/remarkable-results-radio-podcast/e1004/ Unstoppable Framework for Auto Shop Owners Part 3: Optimize Processes and Empower Your Team [RR 1012]: https://remarkableresults.biz/remarkable-results-radio-podcast/e1012/ Unstoppable Framework for Auto Shop Owners Part 4: Stay Customer Focused and Flexible [RR 1020]: https://remarkableresults.biz/remarkable-results-radio-podcast/e1020/ Here is the downloadable worksheet link: https://bit.ly/4b0Qvtw Welcome Maryann Croce (00:00:00) Building a Resilient Mindset (00:02:34) Embracing a Growth Mindset (00:04:25) Continuous Improvement (00:11:11) Creating Contingency Plans (00:12:27) Planning for the Unexpected (00:16:33) Daily Practices for Building Resilience (18:32) Creating Daily Habits (19:08) Importance of a Support Network (20:17) Key Lessons from Previous Episodes (22:31) Growth Mindset and Contingency Planning (23:49) Emotional Awareness in Leadership (26:04) Practical Application in Business (27:00) Inclusivity in Learning (28:00) Conclusion of the Series (29:04)
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Get ready to grow your business with the Automotive Management Network: Find on the Web at http://AftermarketManagementNetwork.com for information that can help you move your business ahead and for the free and informative http://LaborRateTracker.com Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/         Click to go to the Podcast on Remarkable Results Radio
      Craig O’Neill, welcomes his friend and communications expert, David Boyd, as our guest.  Listen up to hear the thoughtful conversation between David and Craig across a variety of topics and questions related to the phones skills of your staff, AI use in the world today, and the outlook for the future.
      A key question:  “Will the job of the service advisor still exist?”
      As AI solutions seem to become more and more sophisticated - the question has career advisors wondering this aloud.
      The conversation should be encouraging for anyone who takes their professional role as a service advisor seriously, and the future, according to David and Craig, appears bright.
      According to David, the service advisor is the person we should be empowering further, and developing, as this is the role focused on building relationships.
      The conversation draws on additional points related to what we learned during Covid and the real value of actual connection, as well as some of the pitfalls for what occurs when a productive technician is forced to answer phone calls.
      Listeners will walk away with some practical advice from this episode, and more clear vision for a coachable front counter that is focused on connecting!
      The WOTD Today:
      Affable
      Noun-
      Friendly - good natured - easy to talk to
      Email Craig O'Neill: [email protected] Watch Full Video Episode Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters
