I've been thinking about multiple labour rates for a while, but I wasn't sure if this was viable. (note the numbers are subjective and generalized)
- You've got a lube kid doing oil changes, topping up fluids and washing cars etc. He's paid $15/hr
- You've got an apprentice tech learning, doing basic & intermediate repairs, preventative maintenance and is building his tool inventory. He's paid $24/hr
- You've got a journeyman tech doing high level diagnosis, complicated repairs, and has the most tools and training. He's paid $30/hr
I was thinking why is there only a single labour rate in most shops, whether posted or unposted?
I understand that most shops bill out their LOF and brake repairs as such, not based on hours but a flat fee for the job, but why not standardize it and have multiple labour rates?
Even in states who are forced to post their labour rates, posting your top level rate and having standardized lower rates could benefit?
Using the industry standard 70% margin on labour, you would get the following labour rates:
Lube kid: $15 / .3 = $50/hr
Apprentices: $24/ .3 = $80/hr
Journeymen: $30 / .3 = $100/hr
I've been reading a lot of online articles and blogs about this and finally came across the following:
http://www.autosphere.ca/carcarebusiness/2013/03/28/5-average-shop-labour-rates-now-required/
The critical quote: "The better shops now have in place the following labour rates: 1. Maintenance 2. Diagnostic 3. Reflash 4. Fluid 5. Tire Install. Some shops even have a couple of others due to the type of services they can provide."
I was wondering if anyone does this? If so, how did you set yours up? Do you post multiple rates or are they generally internal?
Maintenance would probably be something like $80/hr in this case, since your top techs generally aren't required.
Industry standard for diagnostics would be $180-200/hr, since it's the most complicated, requires the most training and tools, and also to maintain a proper profit/hr for that bay since there are no associated part sales.
Reflashing I'm not entirely sure but I would think it would be around $125-150/hr for the same reasons as diagnostics, but not being as complicated and take less time.
Fluids would be around $50/hr
Tires $80
General repair would fall under the $100/hr rate
Car wash would be around $50/hr, while having a dedicated detail specialist would command higher rates, but mainly sell packages unrelated to actual time (which is what shops should be doing more of anyways haha)
Anything I'm missing? Anything you folks would like to add or comment on?
Edited by bstewart
We have sub categories for our labor operations, oil changes are $25.00 per hour, State safety inspection 60.00, standard brake work 81.88, A/C Work(not electrical) 84.93, Timing Belts $92.83, Electrical work 99.98, Diagnostic work 119.95 etc. We are not required to post a shop labor rate so it may be an issue in those states that require a posted labor rate.
And what is your "standard" shop rate for normal repairs?
  On 3/27/2014 at 11:04 PM, Tires Too said:
The closest thing to a standard shop rate is $89.67.
Ok that makes sense, I figured it was probably around $85-90.
Any reason that timing belts are done at a 3.5% premium and A/C work is done at a 5.3% reduction vs standard repairs?
The differences seem pretty small, I guess I was wondering why both A/C and timing belts aren't both done at the $89.67 rate?
Your other rates make perfect sense, although your diagnostic rate at a 33.7% premium seems a little low to maintain a good hourly bay revenue? It might work well in your situation though.
On the other hand, kudos to you for actually charging extra for diagnostics! Most shops lose so much money because they don't charge properly for diagnostics.
Edited by bstewart
Our basic rate is derived by using a standard formula in the industry to make a 60% gross profit on fully loaded tech cost. The tweaks are based upon some marketing considerations(Brake work, state inspections), difficulty of the work(oil change services, fluid services - lower, diagnostic - higher). This is an attempt to be competitive on services that are "Marketed" in our area and also to maximize revenue in areas that are less price sensitive and/or more difficult. It is a "First Step" in the process.
Right on, sounds like you really put a lot of thought and planning into this!
Great job, it sounds like you're on the right track then.
  • 5 months later...
Hi,
Noobie here. I was wondering if you utilize any type of incentive compensation for your techs. How would these different labor rates impact their incentive compensation.
Any guidance is appreciated.
DG
This may.be good idea. Typically i have 1 labor rate $85/hour. I tweak charges by changing the hour time i charge for certain things. I post that my labor time is based on labor guide AND technician experience. So if i feel alldata time is deceptive ill adjust the time (hours) that i charge for thr job. I dont price match. If im cheaper or more expensive its all fine. There are many shops in raleigh big and small. But not many that have good rep for diagnosing properly. So i use that to my advantage. Im not free nor cheap. You pay to have me. But yes i lose on something like oil change at .3 because only make $20 versus $25 or so. I agree that may be good idea for different rate for diagnostics bc does take more to do typically. But i combat that by not capping my diag charge out at 1 hour. If im chasing electrical issue or multiple codes then i need to be compensated. Usually meet customer somewhere in middle so is fair on both ends.
      April 15th is behind us — but your tax strategy shouldn’t stop there. In this episode, Hunt Demarest, CPA at Paar Melis, shares exactly what auto repair shop owners need to be doing based on how their tax season wrapped up. Whether you filed early, waited until the last minute, or punted with an extension, Hunt helps you take the right steps now to avoid penalties, reduce next year’s bill, and keep your shop’s finances dialed in.
       In this episode, you’ll learn:
      Why filing an extension isn’t always a problem — but failing to plan ahead is The costly myth about tax extensions that trips up even seasoned shop owners What to do now if you owed a big tax bill or got a refund The IRS’s rules on estimated taxes and why ignoring them leads to penalties Smart financial habits every shop owner should adopt after tax season ends
      Tariffs might sound like a foreign concept—until they hit home. In this episode of Business by the Numbers, Hunt breaks down the real-world impact tariffs can have on your auto repair shop, using a powerful shop-vs-shop analogy to explain rising costs, disappearing jobs, and economic ripple effects. Whether you're in the weeds of part pricing or just trying to make sense of the news, this episode gives you the context you need.
      Here’s what you’ll learn in this episode:
      Why tariffs are making headlines—and how they could impact part costs in your shop What the “free market” really looks like when safety and environmental regulations aren’t equal The economic chain reaction that can crush local businesses and communities How tariffs influence pricing, profits, and technician availability in the long term A breakdown of how the U.S. tax system evolved from tariffs to income taxes—and why that matters now
      What if your auto repair shop is losing money every single day — and you don’t even know it? In this episode, Hunt sits down with Alex Saladna, CEO of Wicked File, to talk about the hidden financial leaks happening in shops just like yours and how AI is helping owners plug those holes fast. From missed parts and uncredited returns to unauthorized purchases, we dive deep into how real shop owners are using Wicked File to save thousands of dollars and hundreds of hours every month.
      Whether you're a single-location shop or managing multiple rooftops, this episode shows you why "doing it manually" might be costing you way more than you think.
      Alex Saladna, WickedFile
      In this Episode, you'll learn:
      How Alex's family-owned shop lost $180,000 in just 6 months — and what sparked the creation of Wicked File The real financial leaks you're probably missing — and why statement reconciliation isn’t enough Why even large, well-staffed shops fall behind on parts reconciliation How AI-powered tools like Navigator help shop owners instantly spot problems and improve profitability What one multi-shop owner did to increase net profit by 15% in just one month
      “Do I have enough to retire?”
      What You'll Learn:
      In this episode:
