Anybody have educational or informational brochures or flyers that they use to explain to customers the issues involving repairing leaks in systems especially coolant and oil leaks? We run into issues for instance when fixing a valve cover gasket leak in a BMW and the customer returns a couple weeks later stating car is still leaking. Now the oil filter housing is leaking and the customer is ticked because we didn't fix his leak. Now we explained to the customer before we did the valve cover gaskets that there was potentially additional leaks we couldn't see due to the amount of oil all over the motor and/or after the leak was fixed, there was the chance that the since we sealed the system if there was a "weak" spot somewhere else it would probably cause a another leak at that other location. After several, "you never told me that" scenarios we include a disclaimer on the invoices.
We were thinking a FYI flyer or brochure would be a help. Something that we gave to customers when they pick up their vehicles after one of these repairs - sort of like a "What to expect after a leak repair". Does anyone use this type of handout at their shops? it would be great to have more of this stuff in the download section.
Great idea, Jeff. We use dye but mostly on difficult to spot leaks. I like the preventative thing and will discuss that option with my partner. I'm for anything that keeps us out of the defensive position!
  On 3/28/2014 at 12:23 PM, Jeff said:
I verbally inform before the repair, then include it on the invoice. And I always add dye after a visible leak repair. This shows the customer we are proactive and it helps to show a different leak (or an incorrect repair :blink: ). Many times I will pick up an additional leak after the road test. This lets us inform the customer of additional needed repairs before there issues at delivery. A perfect example...had a 7 series BMW that had a monster leak on the right valve cover. Performed repair and advised customer we added dye. Nothing had shown up on the road test. Week later owner calls to say there were leaks showing in the drive again. Returned top find a leak on the right front timing cover. By adding the dye I was able to show them that the leak was not the same as the prior repair.
Brilliant!
For a couple bucks worth of dye on every leak repair (which would be billable of course, "we used dye to confirm that the leak is gone"), you've removed all the risk of comebacks for repairing a new leak that popped up in the same vicinity!
Anyone know long will dye last before breaking down or loses its fluorescence in an engine?
Edited by bstewart
The dye idea is great!!
When we speak to customers on oil leaks, I explain to them that we fix oil leaks from top to bottom. Since gravity will do its thing, it hard to determine with 100% certainty sometimes. I never usually have problems with oil leaks, coolant leaks on the other hand are INSIDIOUS. Many a time we have fixed a leak, pressure tested, bled, test drove and everything was gravy. Customer takes the car, ends up getting another leak or some other component in the cooling system went bad. This happens a lot when customers either overheat their vehicles or went a loooonnnngggggg time without servicing their cooling systems. On BMWs especially, we recommend to PREVENTATIVELY replace certain components such as water pumps, t-stats, hoses, radiators, expansion tanks. Most people don't take the advice though or they have thousands of dollars in other repairs that take precedent.
      Is your shop struggling with fewer repair orders and dropping sales? It may not be about losing customers—your clients could just be driving less. In this episode of Business by the Numbers, Hunt Demarest, CPA, walks you through a real-life example of how customer driving behavior (and simple mileage tracking) revealed critical insights for a struggling $2M shop. Learn how to use your own data to better understand your customer base, track hidden metrics, and adjust your strategy—before your bottom line takes another hit.
      In this episode:
      Why fewer visits doesn’t always mean fewer customers How to calculate mileage trends using your shop management system The difference between customers and repair orders (hint: it matters) How remote work and economic shifts impact car care habits How to conduct a customer behavior audit—without creeping them out Action steps to track spending per mile and make smarter business decisions
      Email Hunt: podcast@paarmelis.com
      Hunt examines technician cost management within automotive repair shops shop management systems. He explores the issue of inaccurately reported labor costs, which frequently misrepresent the true financial health of the business.
      Hunt discusses the underlying reasons for this discrepancy, and how they calculate technician compensation. The episode talks to various methodologies that can be employed to rectify these inaccuracies, ensuring that shop owners possess a more precise understanding of their financial obligations.
      The objective of this episode is to empower our listener with actionable insights that can lead to improved profitability and operational efficiency in their businesses.
      Takeaways:
      The podcast discusses the critical issue of accurately recording technician costs in shop management systems, which is often miscalculated, leading to significant profit discrepancies. The episode emphasizes the importance of revising technician cost methods to reflect true expenses, thereby enhancing financial transparency and operational efficiency. Listeners are urged to assess their current payroll structures and make necessary adjustments to ensure more precise financial forecasting. Understanding the relationship between productivity and payroll costs is vital for maintaining profitability, with practical strategies provided to achieve this.
