I have a question, I hired a guy to work for me that was supposed to have diesel repair certification. I put him on a few simple jobs the first week to test him, he did fine. I then put him on a harder job, this job labor hours booked at 22, should have it done in two days tops. Well after he was still working on it on day three I had my shop manager start to watch him more closely. When he still was not finished on day five for multiple issues that had to be redone twice and they still were not right, I let him go.
I then put my best tech on it to get it buttoned up. After a few hours he came to me and showed me several issues that were wrong, along with several broken or bent parts that have to replaced, lines that were kinked and no teflon tape on the connections, loose bolts and missing bolts. For safety's sake I had him tear it all down and go completely through it. He just came to me and showed me that he had broken a part of the oil gland on the head of this truck, now the bad thing is that the broken piece of the head cannot be found, so the entire motor has to come out and be broken down to see where that broken piece has landed.
NOW my question is this, do I have any legal recourse to go after this guy for the damages he caused, cause we are talking about thousands of dollars now, or am I just screwed?!
Good help is hard to find. Keeping good help is just as hard. The loss in your case is just that... a loss. Not much you can do about it. I could write story after story about the "help" but, I shy away from that because I don't want to see the general public taking an even dimmer view of our trade. This is something we as shop owners have to police from in-house.
Hire right, do what's right for your business....even if that means you have to eat a few jobs. I have had to eat lots and lots of stuff over the years, and as long as there is somebody between me and the final consumer (ie...the tech) you've got to keep on your toes. The sloppy mechanic won't be the one taking the heat, they'll just quit, get fired or simply move on to another shop.
Keep this guys name handy just in case he tries to use you as a reference. Tell the next shop owner the straight scoop. That way we'll all know what kind of character you let go.
Sorry to hear stuff like this... but it is...what it is.
That really sucks to hear that I cant go after him, but at least I can warn other shops about him. You know you try live an honest and good life, be kind and friendly and this is what you get for your trouble. You hire a person to do a job and pay them to do that job, you don' expect to have to go and hold their hand every step of the way. Hmmm maybe I will find him in a dark alley and explain the facts to him a little more clearly....SO FRUSTRATED!!!
I guess the worst part is that I had a sign he wasn't any good the week before, but since we are so busy, I ignored the warning and gave him another chance, now I am paying dearly for that mistake. Even when I brought him into the office to discuss the issue he completely denied that he did anything wrong. What a standup guy....NOT!!
If you don't mind me asking what was the job on? What did he damage? Any photos? Makes me feel better about accidently letting one slip out without a test drive and issues still present! lol
It was on a F350 6.0 Diesel. The question is what didn't he damage...I have about $1000.00 in parts so far, if it wouldn't fit the right way he would just bend or tweak it till it did, before we found the broken off part in the head now the entire engine has to come out (that means pull the cab=20+ hours) and be completely gone through till we find that broken piece of the head, inside the motor somewhere and hope it has not caused major damage, and the motor also now has an internal oil leak, probably from a cut O ring on either an injector or an oil tube under the HPOP. This just keeps getting better and better!! I got pics but dont know how to post them on here.
The sad thing is that I thought I was helping one of our vets, who served our country.
The 6.0l has a steep learning curve but once you get them figured out there no bad at all. I have a ton of 6.0l parts that are known good if it helps at all. A lot of techs seem to struggle with a 6.0l hard start and there's a ton of known issues in the first place. As far as bending parts that's just ridiculous. Those are trucks that we work on pretty regularly so anything I can do to help let me know!
Just something I wanted to add,
I don't mean to get off subject but thought it was worth mentioning.
I'm guessing it was a head job at 22 hours billed, if he didn't remove the cab in the first place no wonder he bent stuff lol!
If you do a lot of these it might be worth setting a standard procedure for this job where everyone's got the same idea about how the job goes down. Removing the cab is the only efficient way to do those type of jobs! Hopefully I didn't cross a line with this, just wanted to throw that out there.
NO!! thats one of the biggest issues, it was not a head job, just injectors, EGR cooler and oil cooler= Bulletproof kit. Why he was all the way into the HPOP is still a mystery to me, we finally found the internal leak is was the STC fitting, it was not tight and the O ring was damaged.
Our best guess is when he was installing the injectors, the rail didn't go on smoothly and he used force to make it fit and thats when the head got damaged. We thought we were going to have to pull the motor but we found the broken part of the head lodged in between a spring and the landing, Thank God for that, I was not looking forward to eating any more on this job. Its going back together today and hopefully will be delivered tomorrow.
wow! That's pretty rough! Anything I can do to help let me know!
Injectors egr cooler and oil cooler should be done 1.5 day at most, High Psi Oil pump would be for an stc fitting repair kit. We do alot of work on these, a compentent mechanic can pull the cab on one in 3 hrs. If you need an odd ball part I prolly have it
Travis
Travis appreciate the offer, but thank god its over and behind us now. He was hiding behind his army training but he was really totally incompetent. Every vehicle he touched came back for one reason or another. We had to eat a lot of crow to salvage our reputation, but it's all good now.
      Introduction to the Episode (00:00:01) Brian Walker introduces the podcast and guest, Hallie Wassinger, discussing the importance of Google Local Services Ads. Overview of Google Local Services Ads (00:02:53)  Hallie explains the recent availability of Google Local Services Ads for auto repair shops across the U.S. Historical Context of Local Services Ads (00:03:25)  Discussion on the past availability of Google Guaranteed Ads and their expansion to auto repair shops. Current Availability and Limitations (00:04:38)  Hallie details the current state of Local Services Ads for tire shops and their limited availability. Cost Structure of Local Services Ads (00:05:34)  Introduction to the pay-per-lead model, highlighting its differences from traditional Google Ads. Service Categories for Auto Repair (00:06:45) Hallie outlines the specific services auto repair shops can advertise under Local Services Ads. Lead Generation Process (00:07:44)  Explanation of how leads are generated through phone calls or messages via the Local Services Ads dashboard. Ongoing Maintenance of Ads (00:08:31)  Discussion on the necessity of monitoring and rating leads to optimize the ad performance. Success Stories from Beta Testing (00:10:55)  Brian shares a success story from Chris Cotton, highlighting low lead costs achieved through Local Services Ads. Lead Cost Insights (00:11:39)  Hallie provides average lead cost data, emphasizing the effectiveness of the ads for auto repair shops. Visibility of Local Services Ads (00:12:18)  Brian describes how Local Services Ads appear prominently in search results, enhancing visibility. Google Screened vs. Google Guaranteed (00:13:02)  Hallie explains the differences between Google Screened and Google Guaranteed, focusing on their application processes. RepairPal Sponsorship Message (00:14:27)  Brian thanks RepairPal for sponsoring the episode and discusses the benefits of being in their certified network. App Fueled Sponsorship Message (00:15:32)  Brian introduces App Fueled, promoting their customer loyalty app for auto repair shops. Verification Process for Shops (00:16:33)  Hallie outlines the verification process for shops to join Google Local Services Ads, including necessary checks. Verification Steps for LSA (00:16:50)  Overview of the verification process for auto repair shops applying for Google Local Services Ads. Challenges with Specialty Shops (00:19:14)  Discussion on difficulties specialty shops face with Google Local Services Ads targeting. Specialization in Google Ads (00:20:03)  Insights on why specialized shops may benefit more from traditional Google Ads. Opportunities with LSA (00:22:05)  Exploration of the current opportunities available for shops using Google Local Services Ads. Cost Benefits of LSA (00:23:13)  Comparison of lead costs between Google Local Services Ads and traditional Google Ads. Importance of Google Business Profile (00:24:29)  Discussion on how optimizing Google Business Profiles impacts LSA ad performance. Role of Reviews in SEO (00:27:40)  Emphasis on the significance of keywords in customer reviews for improving visibility. Optimizing Photos for LSA (00:29:42)  Best practices for managing and updating photos in Google Local Services Ads. Pricing for LSA Management (00:31:01)  Details on the costs associated with managing Google Local Services Ads for shops. Introduction to LSA (00:33:47)  Discussion on the performance of Google Local Services Ads and how to get started. Discovery Call Process (00:34:15)  Details on scheduling a discovery call and assessing local competition for LSA. Final Thoughts on LSA (00:34:38)  Emphasis on the importance of early adoption of LSA for auto repair shops. Self-Management of LSA (00:34:40)  Advice on running LSA independently, highlighting the required time and dedication. Closing Remarks (00:35:29)  Thanking listeners and sponsors, and encouraging engagement with the podcast.
      Introduction to the Podcast (00:00:01)  The podcast begins with a welcome message from the host, Brian Walker. Guest Introduction (00:00:10)  Brian introduces co-host Kim and guest Doug DeLuca, owner of Boca Auto Fix. Overview of Boca Auto Fix (00:00:51)  Doug shares details about his auto repair shop, including its location and age. Hiring an Apprentice (00:01:09)  Doug discusses the recent hiring of an apprentice and the journey leading to this decision. Challenges in Hiring (00:02:13)  The speakers reflect on the difficulties shop owners face in finding and hiring young talent. Marketing Journey Begins (00:03:02)  Discussion shifts to Doug's initial marketing efforts and his involvement in content creation. Background in Technology (00:04:07)  Doug explains his previous technology background and how it influenced his approach to marketing. Learning SEO and Marketing (00:04:45)  Doug describes his self-taught journey in SEO and digital marketing after opening his shop. Realizing Marketing Needs (00:06:14)  Doug reflects on his initial assumptions about marketing and the reality of attracting customers. Understanding SEO Basics (00:08:09)  Doug shares his insights on SEO and the learning process involved in mastering it. Frameworks in Marketing (00:10:25)  The conversation explores the use of frameworks in both auto repair and marketing strategies. Adopting "They Ask, You Answer" (00:11:23)  Doug discusses his experience with the "They Ask, You Answer" philosophy in content creation. Writing Blogs for Customer Engagement (00:12:21)  Doug explains how he uses customer inquiries to create relevant blog content for his shop. Experience at a Quick Lube (00:13:29)  Doug shares his firsthand experience at a quick lube to highlight differences in service quality. Experience Comparison (00:14:06) Doug shares his experience of visiting a competitor's shop to understand customer perception and service quality. Proactive Client Advocacy (00:14:57) The team discusses the importance of guiding potential clients to the right service provider based on their needs. Sponsorship and Marketing Tools (00:16:13) Brian introduces RepairPal, highlighting its benefits for attracting new customers and building trust. Customer Loyalty Apps (00:17:51) Brian discusses the advantages of using App Fueled to create customer loyalty programs for auto repair shops. Incognito Visits (00:18:20) Doug talks about visiting a competitor's shop incognito to gain insights without revealing their identity. Collaboration Over Competition (00:19:09) The speakers explore the idea of referring customers to other shops and building relationships in the industry. Challenging Competition Norms (00:20:20) Brian reflects on inviting competitors to the podcast, emphasizing collaboration over traditional competition. Marketing Involvement (00:22:42) Doug explains the ad hoc nature of their marketing efforts and the role of social media in their strategy. Community Involvement (00:27:41) Doug shares their family's volunteer work and how it integrates with their business's social media presence. Engaging the College Market (00:28:51) Doug discusses how 30% of his clients are college students and their marketing strategies. Collaborating with Local Professors (00:31:18) Doug shares his experience working with a marketing professor for student analysis of his business. Challenges of Seasonal Demand (00:32:24) Discussion on the impact of seasonal changes on business demand and local marketing efforts. Starting with Marketing (00:34:02) Doug advises new shop owners to listen to podcasts and conduct online research for marketing. SEO as a Long-Term Strategy (00:35:08) Doug explains the importance of SEO and its long-term benefits for business growth. Understanding Competition (00:36:44) Doug emphasizes the need to analyze competition and not assume marketing strategies will work universally. The Importance of Data (00:39:08) Doug highlights the role of data in assessing marketing effectiveness and making informed decisions. Nuances of Market Dynamics (00:41:14) Discussion on how geographical and seasonal factors affect marketing strategies in auto repair. Client Avatar and Marketing Alignment (00:42:13) Doug explains the significance of understanding the ideal customer for effective marketing strategies.  Overcoming Diagnostic Fee Challenges (00:43:09) Discussion on how Doug has adjusted his approach to diagnostic fees to improve customer conversion. The Importance of Evaluation Fees (00:43:40) Discussion on the role of evaluation fees and their impact on shop maturity. Improving Customer Communication (00:44:09)  Insights on enhancing customer explanations regarding services and processes. Coaching and Competitive Analysis (00:45:03)  How coaching helped refine service policies and improve customer relations. Content Creation and Marketing Strategy (00:46:32)  The significance of creating content for customer engagement and marketing. Duck Duck Jeep Initiative (00:47:05)  Fun marketing strategy involving ducks to engage with the local Jeep community. Value of Customer Feedback (00:48:46)  Importance of understanding customer inquiries and improving service based on feedback. Contact Information for Doug DeLuca (00:49:29)   Doug shares how listeners can reach him for further inquiries.
