Hi everyone,
I was wondering if anyone here does follow ups if so what is your success with them? What do you talk about, how long do you wait to follow up, are you mentioning recommended service? Also do you call to confirm appointments or just if they are not showing up?
Thanks
I do call some customers that are new about 15 days after a repair. I ask them if their vehicle is running good and too make sure they were satisfied with our service. EVERY person I called was totally shocked that I called. They said they have received letters but never a call. They loved the call. I don't turn the call into a hard sell, but do tell them if they need anything or just have a question about their vehicle don't hesitate to call. I will be more than happy to answer any question.
Follow-up calls are a great thing. One more way of showing that you appreciate their business and are concerned about their satisfaction with the service you performed. It also gives them the opportunity to let you know if there is a problem that maybe they would have never otherwise came back for. We keep it short and simple and don't try to sell anything. Anybody that I have talked to about doing this has always given positive results
Edited by Gary A
Recommended services are the lifeline of my shop. Kinda goes along with Low cost oil changes and people complaining about not doing well off of them.
Do You use a crm ? Send out Recommended services emails and letters to the customers with no email's or did not open your emails?
I'd like to see some examples of letters everyone's using. We've got all data manage and can use their stock forms but Microsoft no longer sells the older word that all data works with so that part of the program is useless. Considering doing it manually but don't really like their letters.
Every ticket has a reminder or recommendation.
Preventive maintenance saves money and extends the life of your car.
Substantial Oil leak at vacuum pump seal car should not be driven .If you must check oil level every trip.
Front brake pads below 3 mm .Rear brake pads are worn below 2 mm and need to be replaced.New brake pads are about 10-12mm and can be used till 5mm of thickness.
Rear brakes pads are low .Replace pads before your brake rotors start scoring and you will save. Brake fluid needs shows too much moisture (6%) and should be changed..
Your strut mounts have play and should be replaced. Worn strut mounts will cause premature accelerated tire wear.
Change oil on 03-01-14 or at * 27,004 miles,whichever comes first
ERIC XXXX
Re: 2002 Volkswagen GTI
Dear Valued Customer,
This letter is sent out periodically to remind you of repairs / maintenance needed for your VW or AUDI to insure a
safe, reliable car.
Regarding your 2002 Volkswagen GTI
We recommend the following repairs:
Recommendation made on 12/21/14
Replace- ***Your valve cover gasket is leaking oil which deteriorates plastic and rubber parts on the engine. The
timing belt which is hidden under a cover can skip a couple of teeth and damage the engine, due to engine oil
deteriorating the belt. Low engine oil level can cause serious damage to your engine .Flanges & seals can be
damaged by oil seepage and cause coolant leaks.
Recommendation made on 12/21/13
Replace- ***Front brake pads are worn and need to be replaced to avoid dangerous braking situations.
Replace- ***Your strut mounts have play and should be replaced. Worn strut mounts will cause premature
NEED A RIDE? Call for availability.
Our hours of operation are Monday through Saturday 8:00 AM to 5:30 PM.
For after hours pickup or drop off please contact your service advisor.
****LIKE us on Facebook.com/XXXXXXXXXX and receive $10.00 off next service.****
Sincerely,
XXXXX XXXXXXX AND team XXXXXX
We print it from mitchell and trifold it with 2 coupons on one side. One of the coupons is a $49.95 low cost synthetic oil change .
Hope this example helps.
Edited by GermanCArDEpot.com
      EOS One
      Introduction and Sponsors (00:00:01) Overview of the podcast and thanks to sponsors RepairPal and App Fuel. Creating a Shared Vision (00:00:10) Brian discusses the importance of establishing a shared vision for the company. Leadership Team Meetings (00:01:13) Details about offsite leadership meetings and the exercise called "the one thing." Feedback and Growth (00:02:08) Brian reflects on receiving feedback from his leadership team and its impact on personal growth. Shifting Mindset on Growth (00:03:07) Brian shares his fears about growth and how he overcame them to embrace larger ambitions. Disney's Service Model (00:04:17) Comparison of Disney's customer service model to his company's approach to client service. Processes and Procedures (00:05:26) Discussion on the importance of processes in maintaining service quality while growing. Inbound Marketing Strategy (00:07:25) Brian explains the effectiveness of inbound marketing in attracting clients. Outbound Sales Shift (00:09:26) Introduction of outbound sales strategies and the team's initial reactions to the change. Creating a Shared Vision Deep Dive (00:10:34) Brian's focus on developing a shared vision after receiving feedback from his leadership team. Researching Shared Vision (00:11:42) Challenges in finding resources on creating a shared vision and discovering related literature. Book Recommendations (00:12:42) Brian reviews two books on vision creation and his thoughts on their content. Simplicity of Creating Vision (00:13:34) Brian concludes that creating a shared vision is simpler than expected, emphasizing clarity. Vision, Mission, and Values Explained (00:14:45) Brian differentiates between vision, mission, and values with a practical example. Big Dreams and Ambitions (00:15:45)  Brian discusses the importance of dreaming big and outlines a fictional company's ambitious goals. Vision, Mission, and Values (00:16:48)  He explains the significance of having a clear vision, mission, and values for a successful organization. Sponsor Message: RepairPal (00:17:48)  Introduction to RepairPal and its services that help auto repair shops attract tech-savvy customers. Sponsor Message: App Fuel (00:18:48)  Overview of App Fuel's customer loyalty app designed for auto service shops to enhance customer retention. Core Values and Their Importance (00:19:57)  Brian shares his realization of the value of core values in decision-making and company culture. Litmus Testing New Hires (00:20:59)  He describes how to evaluate potential hires against the company's vision, mission, and values. Understanding What You Want (00:21:55)  Brian emphasizes the importance of defining personal and business desires beyond just financial goals. Creating a Clear Vision (00:23:51)  Discussion on the necessity of a detailed, clear vision for a business to guide its direction. Proximity to Your Dreams (00:26:56)  Encouragement to immerse oneself in environments that inspire and reflect personal dreams and aspirations. Crafting Your Vision (00:28:50)  Brian advises on the process of creating a vision, emphasizing the need for time and space away from routine.  The Importance of a Clear Direction (00:29:46)  He compares running a business without a clear vision to aimlessly shooting an arrow, highlighting the risks involved. Creating a Target (00:30:41)  Discusses the importance of having a detailed vision as a target for business goals. Vision Details (00:31:37)  Explains the components of a business vision, including specifics about services and operational metrics. Dream Big (00:34:25)  Encourages thinking big without worrying about how to achieve those goals initially. Historical Example: JFK (00:35:32)  Uses JFK's moon landing vision as an example of effective goal-setting and inspiring leadership. Sharing the Vision (00:37:33)  Stresses the need to communicate the vision clearly to the entire team for buy-in. Selling Down the Ladder (00:38:27)  Describes the process of sharing the vision, starting with leadership and moving downwards. Feedback and Buy-In (00:39:19)  Highlights the importance of receiving feedback and fostering genuine buy-in from team members. Repetition of Vision (00:40:12)  Discusses the necessity of repeatedly communicating the vision to ensure team alignment. Crafting the Vision (00:42:20)  Brian reflects on his personal goal to create a detailed vision for his organization. Importance of Shared Vision (00:43:34)  Concludes with the significance of a shared vision for team alignment and achieving business goals.
      Check out their podcast here: https://autorepairmarketing.captivate.fm/ If you would like to join their private Facebook group go here: https://www.facebook.com/groups/autorepairmarketingmastermindIn
      In this episode of "The Weekly Blitz," host Chris Cotton is joined by special guests Caroline Legrone and Kim Walker from Shop Marketing Pros to delve into the critical necessity of having a robust marketing plan for auto repair shops. The discussion centers around the pivotal role that a well-structured marketing strategy plays in the success and sustainability of these businesses.
      Chris, Caroline, and Kim explore the multifaceted aspects of marketing planning, emphasizing the importance of leveraging historical data to gain insights into the business's performance over time. By analyzing this data, shop owners can pinpoint slow periods and develop proactive marketing strategies that align with local events and seasonal trends, thereby optimizing their outreach efforts.
      Caroline Legrone underscores the significance of understanding past performance metrics, which can provide invaluable information for future planning. She explains how historical data can reveal patterns and trends that are crucial for making informed marketing decisions. This approach not only helps in identifying potential challenges but also in capitalizing on opportunities that may arise.
      Kim Walker, on the other hand, offers practical insights into the creation of a comprehensive marketing calendar. She shares her expertise on how to systematically plan marketing activities throughout the year, ensuring that the shop remains visible and engaged with the community. Kim's advice includes tips on scheduling promotions, aligning campaigns with local happenings, and maintaining a consistent presence across various marketing channels.
      Throughout the episode, the conversation is geared towards empowering shop owners to take control of their marketing efforts. By doing so, they can ensure sustained growth and foster stronger community engagement, even during traditionally slow periods. The episode serves as a call to action for auto repair shop owners to prioritize their marketing strategies, highlighting the long-term benefits of a well-executed plan.
      Introduction and Importance of Marketing (00:00:09)
      Chris Cotton introduces the episode and emphasizes the need for a marketing plan in auto repair businesses.
      Guest Introductions (00:01:11)
      Chris welcomes Caroline Legrone and Kim Walker from Shop Marketing Pros to the podcast.
      Discussion on Car Count Issues (00:01:48)
      Chris expresses concern over shop owners complaining about low car counts and the lack of planning.
      Identifying Seasonal Trends (00:02:32)
      Kim discusses common excuses for slow periods and the importance of recognizing seasonal trends.
      Understanding the Marketing Calendar (00:04:23)
      Caroline explains the significance of analyzing past performance to create an effective marketing calendar.
      Proactive Marketing Strategies (00:06:11)
      Kim shares insights on developing marketing plans based on historical data and identifying slow periods.
      Creative Marketing Solutions (00:07:25)
      Kim describes a unique marketing strategy developed around the local state fair to attract customers.
      Importance of Planning Ahead (00:09:27)
      Kim emphasizes the necessity of proactive planning rather than reacting to slow days.
      Timing for Event Promotions (00:12:30)
      Discussion on how far in advance to plan marketing strategies for events like the state fair.
      Community Calendar Considerations (00:14:09)
      Caroline advises checking community calendars to align marketing efforts with local events.
      Adjusting Marketing Budgets (00:16:19)
      Kim discusses the importance of reallocating marketing budgets based on seasonal trends.
      Applicability to Different Locations (00:16:27)
      Chris challenges the notion that marketing strategies are only relevant to local events, encouraging broader application.
      Yearly Planning for Marketing (00:17:09)
      Caroline stresses the importance of yearly planning for marketing strategies, even if starting late.
      Setting Holiday Schedules (00:18:49)
      Chris shares his approach to planning marketing around holiday closures as a starting point for the year.
      Here are the extracted timestamps and their corresponding titles from the podcast episode transcription segment:
      Importance of Planning (00:19:14)
      Chris emphasizes the need for shop owners to have a structured marketing plan.
      Blocking Time for Planning (00:19:40)
      Kim advises shop owners to set aside undistracted time in October for planning.
      Using a Big Calendar (00:20:17)
      Kim suggests using a large calendar to visualize important dates and events affecting marketing.
      Analyzing Performance Data (00:22:25)
      Kim discusses breaking down historical data to identify busy and slow times for better planning.
      Setting Realistic Goals (00:24:20)
      Caroline stresses the importance of setting achievable marketing goals based on past performance.
      Understanding Marketing Budgets (00:26:17)
      Kim explains how to determine an appropriate marketing budget based on desired growth.
      Plan with the Pros Conference (00:28:49)
      Caroline introduces the "Plan with the Pros" event aimed at helping shop owners create marketing plans.
      Event Success and Expansion (00:31:01)
      Kim shares the success of last year's event and plans for expanding this year's attendance.
      Facebook Group for Marketing Support (00:33:15)
      Caroline details the Auto Repair Marketing Mastermind group for shop owners to connect and share insights.
      Final Thoughts on Marketing (00:37:02)
      Caroline encourages shop owners to create marketing calendars and utilize available resources for success.
      Do It Scared (00:37:51)
      Encouragement to start marketing despite fears of making mistakes or not knowing how to begin.
      Getting Started (00:38:11)
      Emphasis on taking action; "done is better than perfect" and scheduling time away from the shop.
      Perspective on Fear (00:38:22)
      Discussion on the urgency of creating a marketing calendar to avoid business decline.
      Final Thoughts and Thanks (00:38:41)
      Closing remarks and encouragement to utilize marketing pros for effective growth strategies.
      Sponsorship Shout-Out (00:39:11)
      Promotion of Shop Marketing Pros as the recommended marketing partner for auto repair businesses.
      Closing Remarks (00:39:11)
      Encouragement to maintain a positive mindset and a farewell from Coach Chris Cotton.
