Hi everyone,
I was wondering if anyone here does follow ups if so what is your success with them? What do you talk about, how long do you wait to follow up, are you mentioning recommended service? Also do you call to confirm appointments or just if they are not showing up?
Thanks
I do call some customers that are new about 15 days after a repair. I ask them if their vehicle is running good and too make sure they were satisfied with our service. EVERY person I called was totally shocked that I called. They said they have received letters but never a call. They loved the call. I don't turn the call into a hard sell, but do tell them if they need anything or just have a question about their vehicle don't hesitate to call. I will be more than happy to answer any question.
Follow-up calls are a great thing. One more way of showing that you appreciate their business and are concerned about their satisfaction with the service you performed. It also gives them the opportunity to let you know if there is a problem that maybe they would have never otherwise came back for. We keep it short and simple and don't try to sell anything. Anybody that I have talked to about doing this has always given positive results
Edited by Gary A
Recommended services are the lifeline of my shop. Kinda goes along with Low cost oil changes and people complaining about not doing well off of them.
Do You use a crm ? Send out Recommended services emails and letters to the customers with no email's or did not open your emails?
I'd like to see some examples of letters everyone's using. We've got all data manage and can use their stock forms but Microsoft no longer sells the older word that all data works with so that part of the program is useless. Considering doing it manually but don't really like their letters.
Every ticket has a reminder or recommendation.
Preventive maintenance saves money and extends the life of your car.
Substantial Oil leak at vacuum pump seal car should not be driven .If you must check oil level every trip.
Front brake pads below 3 mm .Rear brake pads are worn below 2 mm and need to be replaced.New brake pads are about 10-12mm and can be used till 5mm of thickness.
Rear brakes pads are low .Replace pads before your brake rotors start scoring and you will save. Brake fluid needs shows too much moisture (6%) and should be changed..
Your strut mounts have play and should be replaced. Worn strut mounts will cause premature accelerated tire wear.
Change oil on 03-01-14 or at * 27,004 miles,whichever comes first
ERIC XXXX
Re: 2002 Volkswagen GTI
Dear Valued Customer,
This letter is sent out periodically to remind you of repairs / maintenance needed for your VW or AUDI to insure a
safe, reliable car.
Regarding your 2002 Volkswagen GTI
We recommend the following repairs:
Recommendation made on 12/21/14
Replace- ***Your valve cover gasket is leaking oil which deteriorates plastic and rubber parts on the engine. The
timing belt which is hidden under a cover can skip a couple of teeth and damage the engine, due to engine oil
deteriorating the belt. Low engine oil level can cause serious damage to your engine .Flanges & seals can be
damaged by oil seepage and cause coolant leaks.
Recommendation made on 12/21/13
Replace- ***Front brake pads are worn and need to be replaced to avoid dangerous braking situations.
Replace- ***Your strut mounts have play and should be replaced. Worn strut mounts will cause premature
NEED A RIDE? Call for availability.
Our hours of operation are Monday through Saturday 8:00 AM to 5:30 PM.
For after hours pickup or drop off please contact your service advisor.
****LIKE us on Facebook.com/XXXXXXXXXX and receive $10.00 off next service.****
Sincerely,
XXXXX XXXXXXX AND team XXXXXX
We print it from mitchell and trifold it with 2 coupons on one side. One of the coupons is a $49.95 low cost synthetic oil change .
Hope this example helps.
Edited by GermanCArDEpot.com
      Understanding Women's Perspectives In Your Communication #podcast #autorepairbusiness
      In this episode of The Weekly Blitz, Coach Chris Cotton from Auto Fix Auto Shop Coaching delves into the increasingly prevalent issue of "ghosting" within the auto repair industry's hiring process. Ghosting, a term that describes the sudden cessation of communication by either job applicants or businesses without any prior explanation, has become a significant challenge for both parties involved.
      Coach Chris begins by examining the underlying reasons for this trend. On the applicant's side, factors such as receiving multiple job offers, feeling overwhelmed by the job search process, or simply deciding that a particular position is not the right fit can lead to ghosting. From the business perspective, a lack of structured follow-up processes, being inundated with applications, or changes in hiring needs can result in businesses inadvertently ghosting candidates.
      The impact of ghosting is profound, affecting both job seekers and business owners. For job seekers, being ghosted by potential employers can lead to feelings of frustration, confusion, and a lack of closure, which can be demoralizing and impact their confidence in the job market. For business owners, ghosting by candidates can disrupt hiring timelines, lead to wasted resources, and create gaps in staffing that affect operations.
      To address these challenges, Coach Chris offers several strategies aimed at mitigating the occurrence of ghosting. He emphasizes the importance of clear communication throughout the hiring process. This includes setting expectations from the outset, providing timely updates to candidates, and being transparent about the hiring timeline and decision-making process.
      Furthermore, Coach Chris highlights the role of empathy in improving hiring practices. By understanding the pressures and challenges faced by job seekers, businesses can tailor their communication and engagement strategies to be more supportive and considerate. This approach not only reduces the likelihood of ghosting but also enhances the overall candidate experience.
      The episode concludes with practical tips for auto repair shop owners to refine their recruitment processes. These include implementing structured follow-up procedures, utilizing technology to manage applications efficiently, and fostering a company culture that values open and honest communication. By adopting these strategies, auto repair shops can improve their hiring outcomes, reduce the frustration caused by ghosting, and build stronger, more reliable teams.
      The Rise of Ghosting (00:01:05)
      Discussion on the troubling trend of ghosting in the hiring process and its impacts.
      Why Ghosting is Increasing (00:02:16)
      Exploration of the reasons behind the rise of ghosting, including job market dynamics.
      Employee Perspective on Ghosting (00:03:16)
      Insights into why job seekers ghost employers, including feeling undervalued and overwhelmed.
      Business Owner Perspective on Ghosting (00:05:41)
      Challenges business owners face when candidates ghost them, including time and financial losses.
      The Importance of Communication (00:08:03)
      Emphasis on the need for better communication and transparency in the hiring process.
      Impact on Business Reputation (00:09:00)
      How consistent ghosting can negatively affect a business's reputation and public image.
      Strategies to Reduce Ghosting (00:09:30)
      Suggestions for both parties to improve communication and reduce ghosting occurrences.
      Creating a Welcoming Interview Process (00:10:05)
      Advice on how to create a respectful and engaging interview environment for candidates.
      Follow Through After Interviews (00:11:05)
      Importance of following through with candidates to maintain professionalism and opportunities.
      Conclusion and Acknowledgments (00:12:03)
      Wrap-up of the episode, encouragement for listeners, and thanks to the sponsor.
      Navigating Business Success After Achievements #podcast #autorepairbusiness #automotivebusiness
