Joe I say with all respect I have stayed away from the mentioned brand at least for a decade. And i'm talking full line. This type products often get installed into systems that carry a high safety risk as well as the BREAK DOWN WITHE ZOMBIES DRAMA your ears will hear next work day from your customer. :angry::angry: ps. Let the customer have a choice to buy related B) system parts and flushes, such as pump and hoses, tie rod ends, wheel alignment, etc
Frogfinder B)
Had a distributor in a Taurus from cardone, installed had no spark. Using DSO found the pip waveform didn't even resemble the old one. Replaced it with a ford pickup and it fired right up. Got ahold of a guy at cardone and not only did he have no clue what a waveform was he also gave a very nice pre-rehursed speech about who how I could return the part to the store for a refund lol
Sent from my DROID RAZR using Tapatalk 2
  On 9/5/2013 at 12:57 PM, xrac said:
The problem is that sometimes your run into a situation that Cardone is the only one offering anything other than a o.e.m. part.
Been burned too many times by the reman guys, I have honed my skills to sell the oem part and at least make a 35% margin.
Live and learn, redoing work for free is no fun, and chasing dollars from vendors is neither.
My Supplier and I had a long talk today about parts quality brand preferrence. He stated he has been approched from several clients about comeback and or never leave parts issues.
I told him Cardone is the major supplier I stay away from. They have lousy client service and technical staff . We had a dodge pickup that came from another shop , they installed a rack and pinion and could not align properly and threw thier hands up.
Upon inspection could get steering wheel straight but only a few threads on tie rod left . We inspected for proper new tie rod ends found to be right, Cardone hot line wanted us to inspect steering shaft to make sure no issue. After a few frustrating days working with Cardone and others. I asked my Tech to pull the sector shaft or imput shaft and rotate it one Align perfect with proper amount of turns.
With all this said I pushed Cardone for lost time claim and inspect thier racks on this model , We got another to make sure was just only one that happened to clocked wrong and the new one was clocked wrong.
Cardoen Technical Department was to get in a like and kind pickup and have thier product tested and compared to. Al From Cardone was to accomplish I Followed up in a Few months always blew me off.
The really disturbing issue is they said when they go to rebuild items they buy an item from a recycling yard and use a template. So with that said if they get a salvage part someone has altered they our going to rebuild to those specs. This Al was a trip.
The client was unhappy due to thier was out of pocket expense Cardone and the parts house the other shop used, So we were not a winner .
Gues what almost a year later the client come in Rack Leaking, No problem Well Guess what We had to clock that rack input shaft.
As spoken here Cardone is one of the few players left? so it does put installers in a situation.
I guess it would not be so bad if manufactures would give us some credit not all of the industry screws up parts and is our faults - just many manufactures do the trash can test and say no credit deserved.
In Closing - After 33years I cannot believe how they do not have pepole in place and unwilling or suprised when we send in a claim with wave forms before and after , digital pictures , vidieo , We recently Taped a noise with our phone before changing an idler pulley defect.They do not know how to answer.
We had a fuel pump claim turned down nothing wrong they said. Puts out volume perfect. I called them Did you read why it was returned- Was not running conditon was gas gauge issue did not read full when full. Guy goes oh!!.
My belief is the manufactuer and parts house should have a portal to file a claim and insert documents , pictures , print outs and contact person so if thier is a concern all the info is not going through 4 - 5 pepoles hads to get mistruded.AND IS HELPING THE GREEN EFFORT.
I'm really surprised most folks on here are using A1 parts (really, not just A1, but aftermarket period). I know I'm fairly new to running a business, but my experience in working on cars has taught me a valuable lesson. Cheap aftermarket parts are just that...CHEAP. There is a reason why the Original Equipment Manufacturer parts last 80,000+ miles. And if they aren't lasting that long, the car manufacturer is putting pressure on the OEMs to fix the design flaw and make it right.
Also, make sure you know the difference between aftermarket, OE spec, and OEM.
Aftermarket is just that. Doesn't mean its cheap, it just means it's not factory. It's probably not gonna perform the same as the original. It might last longer or perform better. Or it might not... Also, aftermarket is sometimes the only option you have (particularly on older cars).
OE spec (built to OE spec, etc). This is a very arbitrary statement. OE spec could just mean dimensions. Or materials. Or appearance. Point is, you don't really know what they mean and the manufacturer of the part isn't really being held to any certain standard or inspection process. I know one could argue that the customer is holding them to a standard, but a few angry customers is nothing like GM or Chrysler or Nissan calling them up after a multi-million dollar contract and saying the parts they received are failing. Really, this category is the same as aftermarket, but there seems to be a line of products that advertise they are 'OE quality". They usually aren't.
OEM parts. Original Equipment Manufacturer. These are parts from companies that originally manufactured them for the car when they rolled off the line. They usually are manufactured to the specs provided by the car manufacturer and have the most R&D behind them. You don't necessarily have to get these from the dealership either. Many of these parts are available directly from the manufacturer. I.E. Toyota gets a lot of their parts made by Denso. A Toyota air filter literally has Denso still written on the air filter. Same with the oil filter. Same with O2 sensors, etc... Point is, you can sometimes get OEM parts directly from them at a discount, instead of going to the dealership.
I know some will say I'm just a fan of OEM parts, and that is partially true. Only because of the success I have had with them. I have dealt with struts that don't fit, new modules that won't communicate, seals that are the wrong size, and parts that are just boxed/labeled wrong. Yes, I have had issues with brand new OEM parts, but not at the rate of aftermarket parts. I also understand that there is a significant price difference between the 2. Personally, I just don't see the extra profit being worth the headache and loss of customer trust.
I have given customers the option of using aftermarket parts from Autozone, Oreilly, Napa, etc... I just make sure to let them know of the possible issues with cheaper aftermarket parts and that the warranty on repair will not be the same as when I use OEM parts (also gets printed on the RO). If you aren't doing this, I would say be ready to assume responsibility for the part failure. At least that's how the customer is going to see it. They brought you their car to be fixed because you are supposed to know how to fix them. This includes knowing what parts to use.
Just my 2 cents. I'm sure everyone has a different opinion on the matter as most of us all have some sort of loyalty to one brand, distributor, parts guy, or whatever. A lot of this comes from experience working at a parts store, independent shop, and dealership. Hope I didn't step on anyone's toes.
Edited by mmotley
My problem with oem is the fact their trying to price indys out. Our local dealers have been open about the fact that they've been told to price indys out of thenoem market.
Wow, that's pretty crazy! Best advise I can offer is aggressively seek out the parts direct from the OEM (the Denso/Toyota example I gave earlier).
As far as Cardone (the original topic), that's a bummer to hear about their quality. Even being aftermarket, that kind of performance is unacceptable. In this case, do you simply change brands for that specific component or go to a completely different parts supplier? Also, how did you handle the customer that lost their steering? I imagine 'I'm sorry' can only go so far with a situation like this.
I have been in a vehicle that lost steering and I ended up going into oncoming traffic on the interstate, not cool ! This was a fleet vehicle for a rescue team and needless to say I won't drive that vehicle anymore since it almost killed me.
  On 10/5/2013 at 7:53 PM, Joe Marconi said:
The last thing I want to do is to support the new car dealerships and give up on the aftermarket companies. In all fairness, Cardone reps have called me with these issues and they invited me to their next tech council meeting. They know they have problems and do not want to loose the confidence of the independent repair shops.
I don't know how this race to bottom with respect to pricing started. Maybe is our fault, maybe not. I really don't know. But with low prices came low quality.  I have been around the block more than I care to share, and I can tell you a rotor in 1990 was not the same as it is today. And it cost anywhere from 50 to 90 bucks, or more.
Now we are getting rotors that are made in China, shipped in containers across the ocean and it cost 17 dollars? Really? This is a good thing? And most shops wonder why their gross profit dollars is eroding more and more. We made more gross profit dollars years ago then today. I am talking GP Dollars here. Not percentages. The percentage you are making is the same, but I pay my bills with dollars not percentages.
We all need to get back to quality. I hope this country wakes up. I don't want to bash other countries like China, but it is clear that too much of what they produce is inferior. And we are putting these parts on our customer cars, our family cars and friend's cars.
It has got to stop.
The said thing is their producing what the people of this country are asking for, cheap and now. We've moved away from quality, away from interest how things get made, built and repaired and into how things get paid for.
Not everyone is big enough or specialized enough to buy from OE suppliers or wholesale distributors like WorldPac. So that is not a viable solution. As for Oe parts lasting 80,000 miles or more, tell that to the old lady with the Chrysler 300M with 33,000 miles on it and the tie rod ends that I wouldn't drive out of my parting lot with. Both sides, and her car was out of warranty by time. Or the fellow who's PT Loser had loose ball joints just over 40K, his other PT Loser had a bad wheel bearing just under 50K. Or the lady with the Hyundai and with a bad ball joint (left side, not even the curbside)that was bad in 30K. You know you can find all sorts of reasons and all kinds of examples, but OE parts, and it doesn't matter what manufaturer all have problems of one kind or another. Otherwise we wouldn't have successful specialty shops servicing only Toyota/Lexus or Honda/Acura cars. And not all of us are in areas where we can specialize only in one make or manufacturer, we have to expand. Some shops even have to work lawn tractors, boats and jet skis to have enough work. To buy from OE supplies or large wholesalers they just aren't big enough.
This is true, and I agree for the most part. However, it sounds to me that if Cardone was a car manufacturer and was experiencing these kinds of problems, they would be issuing a recall, much like many car manufacturers do. When a problem is that common (like what Joe is talking about), car Manufacturers can be forced to issue a recall. Aftermarket part manufacturers are not held to the same government rules and regulations of liability.
I'm not saying they are perfect (if they were, there would be no warranty work being done at a dealership), but I think most of us would gamble on a factory OEM part then we would aftermarket. Why? Because of experiences like Joe is having with the steering rack. Does this mean I am saying use OEM everytime? Of course not, you would loose too much business, profit, and on older cars, it isn't always available.
It's really up to you and your customer where you get your parts. I was just trying to offer the idea of maybe sourcing your parts from the same place the dealer gets them. It's not always possible, but in some cases you can save a lot of money and get a good quality part. After all, we aren't stuck with just O'Reilly or Autozone.
      Overcoming Guilt (00:03:04)
      chris autofixsos.com
      Want to make your shop’s marketing stand out this May? Join Brian Walker and Caroline LeGrand as they break down creative ways to engage your audience, plan your content, and connect with your community.
      In this episode, they’ll share creative campaign ideas, fun social media prompts, and practical ways to highlight your team, engage customers, and boost brand awareness. Plus, get inspiration for using national holidays like National Skilled Trades Day, Road Trip Day, and even Pizza Party Day to keep your content fresh and relevant.
      Don’t miss this opportunity to simplify your marketing and make a real impact. Tune in now and start planning content that connects!
      Days of the Year
      National Calendar
      Introduction to the Episode (00:00:01)  Brian and Caroline introduce the podcast and thank RepairPal for their support. Preparing for May Marketing (00:01:16)  Discussion on planning marketing strategies for May, emphasizing the importance of advance preparation. General Marketing Themes (00:02:00)  Overview of summer-related topics, tax return spending, and pre-trip inspections for vehicles. Motorcycle Safety Awareness Month (00:03:17)  Highlighting the importance of motorcycle safety and tips for drivers and riders. Military Appreciation Month (00:03:39)  Encouraging auto repair shops to give back to military personnel throughout May. Teacher Appreciation Week (00:04:34)  Ideas for showing gratitude to teachers, including small gestures and discounts. National Pet Week (00:05:50)  Encouragement to engage customers by sharing pet photos on social media. Celebrating Various Appreciation Weeks (00:07:05)  Discussion on multiple appreciation weeks in May and the importance of selecting key themes. Learn to Ride a Bike Day (00:08:04)  Suggestions for community engagement by helping kids learn to ride bikes. National Skilled Trades Day (00:09:00)  Promoting skilled trades and hosting events to educate youth about automotive careers. Star Wars Day (May the 4th) (00:10:26)  Fun marketing ideas related to Star Wars Day for engaging customers. National Odometer Day (May 12th) (00:11:42)  Ideas for a fun contest involving vehicle odometer readings to engage customers. RepairPal Certification (00:13:14)  Discussion on becoming RepairPal certified and the benefits for auto repair shops. App Fueled Introduction (00:14:18)  Overview of a customer loyalty app designed for auto service shops. National Lost Sock Memorial Day (00:14:54)  Encouragement for creative engagement ideas related to this fun holiday. Military Appreciation Month (00:15:06)  Suggestions for acknowledging military families and providing discounts. National Dance Like a Chicken Day (00:15:59)  Call to action for engaging with customers through fun activities. Check Your Wipers Day (00:16:27)  Importance of checking wipers before summer travel and educating clients. National Pizza Party Day (00:18:05)  Highlighting the fun of pizza party day and community engagement. Armed Forces Day (00:18:28)  Ideas for honoring military personnel and their contributions. Memorial Day Awareness (00:18:46)  Discussion on the solemn nature of Memorial Day and appropriate observances. National Road Trip Day (00:19:34)  Emphasis on preparing vehicles for summer road trips and inspections. National Rescue Dog Day (00:20:13)  Celebrating rescue pets and their connection to the auto repair community. World Marketing Day (00:20:48)  Encouragement to appreciate and promote effective marketing efforts. Paws and Pistons Campaign (00:22:41)  Combining pet care with auto services for community engagement. Prepping for Road Trip Day (00:24:51)  Continued focus on educating customers about road trip preparations. Engagement Ideas (00:25:34)  Encouragement to share personal stories and engage customers creatively.
      Auto Repair Marketing Mastermind (00:26:01)  Invitation to join the Facebook group for sharing marketing ideas and support.
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network "Enrollment is getting people to do what it is you want them to do, but for their reasons." Learn how to build a strong, motivated team in the service aftermarket industry by focusing on employee engagement and personal responsibility. This discussion covers key topics such as understanding what drives your employees, hiring for character, and using empathy to enhance workplace dynamics. You'll also explore the want-problem-solution framework and how adapting to different communication styles can boost productivity and job satisfaction. Gain valuable insights on motivating employees by aligning their personal goals with company success. Krystal Zellmer, VP at Klemmer Leadership and Character Development. Krystal’s previous episodes HERE Show Notes Watch Full Video Episode Welcome Krystal Zellmer (00:00:00) The Concept of Enrollment (00:02:36) Sales and Enrollment Connection (00:03:36) Leadership by Example (00:05:30) Understanding Company Culture (00:06:49) Hiring as a Sale (00:07:24) Personal Responsibility in Leadership (00:09:22) Dealing with Mistakes (00:10:43) Passion for the Industry (00:11:54) The Importance of Enrollment (00:12:20) What's in it for Them? (00:13:02) Fragmented Changes in Business (00:14:30) Improving Enrollment Skills (00:19:14 Understanding Wants (00:20:14) Identifying Problems (00:21:11) Ownership and Responsibility (00:22:30) Enrolling Team Members (00:23:15) Finding Individual 'Why' (00:25:01) Hiring for Character (00:27:45) Competence vs. Character (00:28:24) Understanding Team Dynamics (00:30:19)s. Building Relationships (00:30:57) Empathy vs. Sympathy (00:34:41) Awareness of Personal Challenges (00:38:22) Effective Communication Styles (00:40:04) The Importance of Shifting Communication (00:41:51) Utilizing DISC for Better Relationships (00:42:19) Personal Responsibility in Communication (00:42:54) Breaking Down Communication Barriers (00:44:43)
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Get ready to grow your business with the Automotive Management Network: Find on the Web at http://AftermarketManagementNetwork.com for information that can help you move your business ahead and for the free and informative http://LaborRateTracker.com Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/         Click to go to the Podcast on Remarkable Results Radio
