I am probably a bit different than most folks here. I am not a professional mechanic and do not intend to be. I have been planning opening my garage heavily for about a year. Few years ago went back to school to take as many business and accounting classes and have learned alot. I am currently working with some successful mentors which have been a great help but wanted to ask this community(which seems very respectable) that I have been following for some time.
What is the must have equipment for general repair shop start up? We plan on focusing on european makes because of lack of local support but I know a lot of the major (non diagnostic) equipment is universal. A list of the core required equipment that “you” see necessary would be appreciated.
Thanks in advance.
Edited by mccannable
Scan tool and digital storage oscilloscope are both a must. Dealer level scan tools are a big plus. Good tire machine and balancer adds more ability to keep the customer in your shop. Lifts of course. Its hard to say what the shop supplies and the tech supplies but oil drains and tanks are owner responsibility.
Sent from my DROID RAZR using Tapatalk 2
I would account for the small things as well like compressed air, AC machine, brake lathe( or not depending), plan and budget for a subscription to mitchell, all data or identifix, two post lift/lifts etc.
What they said... And a EVAP smoke machine, alignment machine, a hydraulic press, look into not just lifts but low profile lifts if euro will be your specialty. And you best get the uber nice tire changer due to the euro wheels. Get ready to drop 75-100k quick, then even more as needed and things progress.
If Euros are going to be your speciality, you'll be dumping a lot of money into the odd specialty tool you'll need for suspension components, bushings & ball joints, engine timing tools, and all kinds of specialty jobs. Its hard to put a price tag on this stuff since you'll eventually come across a car (monthly at least) you'll need some other unique tool.
thanks for all the advice. my list, which should have been included in first post, included:
-2 lifts
-trans jack
-press
-tanks for waste oil
-compressor
-oil catch
-floor jacks
this list is the hold off until after first few months or as needed
- brake lathe (main mentor recommend against)
- fluid exchangers
- ac diagnostic equipment(what i now the least about)
- tire chaning/wheel balancing (do not, at this time, plan on tires)
also planned on subscriptions to all data/identifix and a plethora of scan tools/factory clone tools. This is a big area of opportunity as there are many options. Besides my GT1 tool I will probably start with autoenginuity as it looks for the start up.
and then from the suggestions:
- digital storage oscilloscope
- evap smoke machine
- specialty suspension tools
- alignment machine - alot of shops around sub out alignments, not sure if they are missing out or are being wise.
a great mechanic is our biggest concern.
cutting rotors for other shops and diy'ers sounds like a great idea.
-floor fans, i see your point
-cutting torch
-drum micrometer, seems pricey. do you guy still see alot of drum brakes?
-battery charger(fortunately i already own one)
-jump box
pos system we have decided on garage partner per our mentors recommendation.
Torches are a good one, can't live w/o them. I wouldn't buy a lathe, cutting rotors for the most part is a thing of the past. The metals in the rotors anymore just don't hold up. We have the machines as do many shops in our area but there is nowhere to get rotors turned. No one will do it, just not worth it IMHO.
-cutting torch
-jump box
A couple of tips for hiring a mechanic
Ask for references obviously. Certifications such as ASE is helpful ... if nothing else it at least shows they care about their field of expertise to take the tests. Back when I would hire people in I had a little pre-test that I would ask them to take before they turned in their application. A couple of abbreviations, some standard terms, a few trick questions, and a couple of laughable type answer questions. They had to fill the test out without the aide of a helper or internet. Ya can't take it home and bring it back. The reason for this is you're after their "first" reaction to the questions ... this is important especially when they are talking to a customer. The wrong thing said to a customer at the wrong time can be devastating to your bottom line.
It helps weed out the "wanna-be" mechancis.
A typical question was something like: What does TPS stand for? things like that. Then I would put a couple of question in there that "if" they have been around a lot they might know the answer. Such as, (This was an ASE question years and years ago) What manufacturer requires removing the spare tire to gain access to the starter?" answer... Subaru
Then I'd have a real dumb question like: "How many wiper blades on a 1983 Corvette?" a. 1 b. 2 c. 3 d. none
answer... none. (There was no Corvettes in production in 1983 only two were ever made as prototypes)
      Tariffs might sound like a foreign concept—until they hit home. In this episode of Business by the Numbers, Hunt breaks down the real-world impact tariffs can have on your auto repair shop, using a powerful shop-vs-shop analogy to explain rising costs, disappearing jobs, and economic ripple effects. Whether you're in the weeds of part pricing or just trying to make sense of the news, this episode gives you the context you need.
      Here’s what you’ll learn in this episode:
      Why tariffs are making headlines—and how they could impact part costs in your shop What the “free market” really looks like when safety and environmental regulations aren’t equal The economic chain reaction that can crush local businesses and communities How tariffs influence pricing, profits, and technician availability in the long term A breakdown of how the U.S. tax system evolved from tariffs to income taxes—and why that matters now
      Alex Saladna, WickedFile
