Battin' a Thousand
The batter steps up to the plate, takes a hand full of dirt and rubs his hands and the bat. He takes a few scrapes with his feet from the batter’s box while digging in with his cleats. He then gives the pitcher the evil eye and sets his bat ready to take whatever the pitcher is going to throw at him. The catcher gives the signs, the pitcher nods his head. He takes a quick look to first base makes his wind up and then lets the ball fly to home plate. The batter takes a swing... “Pop” the ball is in the catcher’s glove.
“Steee---rike!!!” yells the umpire.
Somewhere there is an announcer telling the crowd the count while a statistician is writing down the results of the pitch, and calculating the batter's average. With baseball if you can manage to get a hit 5 out of 10 times you’re up to bat… you’re doing outstanding. Achieving a perfect hitting record on the other hand, may never happen in baseball, but in the auto repair business (and most every other field of play) batting a thousand is not a goal it's a requirement.
Every job that comes into the service bay is another attempt at keeping that perfect score. Come-backs, bad diagnosis, faulty parts and the like are not what any service person wants to deal with. To keep that perfect score going you have to overcome those obstacles and get the job done right before sending the customer’s car around the bases. Unlike the highly paid professional ball player who is never going to achieve that perfect score the highly trained mechanic has to knock it out of the park each and every time.
There's a lot of talk in the industry about how some service advisers/writers and shop owners want a quick “off the cuff” diagnosis and repair rather than waiting for the results of a lengthy-time consuming diagnostic procedure. A mechanic may have a general idea of what is wrong but it still takes proper testing to determine the correct course of action to make the repair. I don't know where this idea came from that every mechanic has the correct answer to ever problem simply by listening to the description given to them by the customer or service writer. It's not like we (mechanics) know what kind of pitch is being hurled at us each and every time.
I'm sure the pro ball player could “up” his stats if he knew exactly what kind of pitch was coming across the plate. As it is, he has to make a quick decision, make the right swing, and make contact. In the repair world, analyzing the pitch is the key to a successful outcome. Diagnostics is what makes the difference. Especially on today's vehicles with their interconnected systems, multi-layered computer controls, and the occasional “oops” from a previous botched repair, these all have to be sorted out before the repair is made. This takes time, diagnostics takes time, and time is money.
When I hear that a shop isn't charging for diagnostic time it tells me they are either under estimating the value of proper diagnostics or believe they are good enough to read the catcher’s signals and in some way already know what pitch is being thrown. Taking a couple of swings at a repair and not diagnosing anything is like standing in the batter’s box blindfolded. I'd call that a foul ball waiting to happen for sure.
It’s important to examine a problem, diagnose as needed and not swing at every pitch that you’re given. In the long run, from the consumers standpoint, a shop that takes the time to diagnose a vehicle correctly may sound more expensive at first when you walk up to the service counter, but chances are you won’t be picked off at 2nd base because you have to spend more cash, buy even more parts that you probably didn’t need, while trying to solve the problem at those shops that don’t see a need in proper diagnostic time.
A new player entered the field; it was a job from one of the body shops I do business with. This 2013 Ford Escape was almost ready to go home, however the air bag light wouldn't go off. That's when I was called to plate.
“We can sell this job today if you can get this taken care of. We’ve struck out so far,” the owner of the body shop told me.
“I’ll see what I can do,” I told him.
The first thing I did was check out what codes were in the system. There was only one code. B0095-11 (Right front impact sensor fault – sub code “shorted to ground”). Since it was in a front collision I took my first swing up to bat by checking to see if the wires were smashed or cut. Strike one... the wires are fine, wrong colors though, need to check that a little further. OK, let's try something else... is the connector damaged or the sensor itself in anyway a problem. Strike two... now this is getting serious. Did the module fail? Is there more to this story? Where's the next pitch coming from?
A little more snooping around and a bit more in-depth studying of the wiring diagram I think I've got the answer. Very close to the impact sensor is another sensor with the exact same type of connector. The real tell-tale was the wire colors. It looks like when they put the car back together they inadvertently switched the two connectors. (Pretty dumb to have the same type of connectors so close together under the hood... but it ain't the first time I've seen a curve ball like this.) I switched the leads and then went back into the system to clear the code. (With most of these newer systems you not only have to clear the code but you also have to “reboot” the computer by turning the key off before attempting the next “at-bat”.)
Well, this batter is ready, the catcher has thrown down the sign, the computers and connections on the playing field are ready to go. All that's left is the pitch. I turned the key and the pitch is on its way. The warning lights come on, the air bag light stayed on for its required amount of time and then.... went off. No codes present and the rest of the systems checked out fine. Yep, I took my swing, and it’s a long, long high flyer… it looks like…yes… yes it is… it’s a “HOME RUN!”
Here's a perfect example of the diagnostics taking longer than the actual repair. The way I see it, diagnostic is the mechanics swing at bat, and it's just as important as the actual repair. After spending the time to research a problem only to find out that it was a simple connector doesn’t diminish the time already spent to find out it was just a connector.
Mechanics get paid to fix a car, that’s what we do, diagnosing a problem is part of it, and good diagnostic work will keep ya battin’ a thousand.
Oh boy...it's been a while....I can feel my anxiety level rise.
It is truly amazing how customers expect us to be perfect. Doctors aren't even revered that way!
Our feet are held to fire each day. And we all know how we go the extra mile, even when it results in unbillable hours, just to
get it right.
Thanks Gonzo, just when I thought this would be a relaxing weekend, you bring this up...
(just kidding, great article, as always...It would not be Saturday without the Gonzo Report!)
It's my pleasure to mess with your weekend Joe. Thanks for the comments...
I try to vary the stories each week just so ya never know what I'll write about next.
Keeps ya guessing. Keeps ya coming back.
Thanks again.
      Getting involved in your community is powerful, but how do you share your efforts without sounding boastful? There’s a fine line between successful and selfish self-promotion, and in this episode, Brian and Kim Walker discuss how to highlight your work with authenticity and gratitude—not ego.
      We’ll discuss framing your message to focus on the cause, aligning community service with your company culture and purpose, and sharing stories that connect and inspire rather than just promote. Plus, we’ll share real-life examples—like our team’s work with Our Daily Bread Food Bank—and how to encourage others to get involved.
      Tune in now to learn how to support your community while staying humble and making a real impact!
      Start with Why - By Simon Sinek
      Commission Mankind
      Introduction to the Episode (00:00:10) Brian introduces the podcast and the topic of community involvement. Topic Suggestion Acknowledgment (00:00:34) Brian mentions Doug DeLuca's suggestion for the episode topic. Sponsor Acknowledgment (00:01:00) Brian thanks RepairPal for sponsoring the episode. Technical Issues Discussion (00:01:30) Brian and Kim discuss technical issues and Brian's experience with braces. Community Involvement Concerns (00:03:44) Kim shares a friend's hesitation about promoting community involvement due to fear of appearing boastful. Successful vs. Selfish Promotion (00:05:44) Discussion about the fine line between effective promotion and self-promotion. Promoting Community Engagement (00:07:24) Kim emphasizes the importance of spacing out promotional posts about community involvement. Starting with Gratitude (00:07:46) Kim suggests starting messages about community involvement with expressions of gratitude. Importance of "Why" (00:09:09) Discussion on the significance of explaining the reasons behind community involvement. Examples of Community Involvement (00:09:15) Brian and Kim share experiences of their community service activities. Promoting Community Work (00:11:25) Brian discusses the importance of promoting community service to demonstrate business values. Messaging about Community Involvement (00:12:21) Kim provides examples of how they communicate their community involvement on social media. Team Engagement in Community Work (00:14:20) Brian reflects on the team's connection with community members during service activities.  Closing Sponsor Acknowledgment (00:15:14) Brian thanks RepairPal again for supporting the episode. Community Engagement Strategies (00:15:26)   Discussion on how RepairPal helps auto shops gain customers through certification and fair pricing. Customer Loyalty Apps (00:16:25)  Introduction of App Fueled, a customer loyalty app designed for auto service shops. Highlighting Community Work (00:17:11)  Tips on emphasizing organizational missions instead of personal achievements in community involvement. Authentic Community Involvement (00:17:54)   The importance of sharing community efforts without seeking personal recognition or return. Sharing GoFundMe Campaigns (00:18:51)  Encouragement to promote charitable causes without boasting about personal donations. Industry-Specific Support (00:19:16)  Discussion on giving back to the auto repair industry and local communities. Respecting Privacy in Sharing (00:19:39)  The balance between sharing community involvement and respecting the privacy of those served. Educating Marketing Teams (00:22:43)  The need to guide marketing teams on how to portray community involvement authentically. Collaborating with Other Organizations (00:24:17)  Benefits of partnering with local businesses for community service efforts. Celebrating Local Teams (00:25:38)  Highlighting local sports teams and community events to promote goodwill. Telling the Story of Donations (00:27:40)  Importance of sharing the personal connection behind charitable contributions. Personal Anecdotes from Mission Trips (00:28:28)  Sharing impactful stories from mission trips to illustrate the importance of community support. Personal Anecdote on Community Support (00:29:29)  Kim shares a personal story about supporting organizations that assist her brother with disabilities. Encouragement to Join Facebook Group (00:30:44)  Kim invites listeners to join their Facebook group for further engagement and community building. Request for Podcast Reviews (00:31:03)  Brian asks listeners to leave reviews for the podcast, emphasizing the importance of feedback. Closing Remarks and Sponsorship Acknowledgment (00:31:36)  Brian concludes the episode, thanking sponsors and encouraging listeners to tune in next week.
      In this episode, Craig is concise as he reflects on the timeless wisdom of Martin Luther King Jr. and how his principles of nonviolent conflict resolution remain highly relevant today. Inspired by recent readings of King’s works, specifically his iconic Letter from Birmingham Jail, Craig explores how these lessons can be applied to resolving conflicts in everyday life—even in situations as modern as addressing negative reviews.
      This thoughtful discussion acknowledges the historical context of King’s writings while highlighting their enduring value in promoting understanding, negotiation, and meaningful resolution.
      Key Points Discussed:
      Craig’s Appreciation for MLK’s Legacy: Acknowledging King’s brilliance as a leader, communicator, and writer, Craig emphasizes the enduring relevance of his concepts and principles. The Four Steps of a Nonviolent Campaign (as outlined in Letter from Birmingham Jail):
      Collection of Facts: Ensure injustices are present and verified. Negotiation: Open dialogue with a willingness to find common ground. Self-Purification: Prepare yourself to act constructively and maintain the ability to return to negotiation. Direct Action: Take deliberate action aimed at fostering a return to negotiation.
      The Word of the Day:
      Unfettered.
      Adj - Not controlled by anyone or anything.  Uninhibited
      Modern Applications:
      Craig draws parallels between these steps and common missteps in conflict resolution today, such as skipping fact-gathering and jumping straight to retaliation—like leaving a low review without understanding the full story. He discusses how these missed steps can lead to escalation rather than resolution.
      Takeaways for Listeners:
      People care about how much you know only after they know how much you care. Applying MLK’s principles to situations like resolving a customer complaint or an unjust review can model constructive engagement and encourage others to seek facts, negotiation, and resolution.
      This episode is a thoughtful tribute to King’s enduring legacy and a practical guide for applying his lessons to resolve conflicts with empathy and integrity.
      Links & Resources:
      Letter from Birmingham Jail by Martin Luther King Jr.
      Join Craig as he unpacks these timeless lessons and their power to transform the way we approach conflicts in our personal and professional lives.
      Curious about how BNI can transform your auto repair shop's success? Discover the secrets to building powerful referral networks, creating meaningful connections, and turning BNI meetings into your most valuable sales opportunity.
      In this episode, Brian and Kim Walker sit down with BNI expert Steve Hand to explore how BNI can help you fill your bays, streamline your networking, and grow your business through strategic partnerships. From finding the perfect chapter to mastering the art of specific referrals, you'll learn actionable tips for making the most of your BNI membership.
      Ready to elevate your shop’s networking game and drive more customers through your doors?
      Hit play now and unlock the potential of BNI for your business!
      https://www.bni.com/
      https://www.linkedin.com/in/shand/
      https://trianglebni.com/en-US/index
      Introduction to BNI (00:00:10) Brian introduces the podcast and welcomes Steve Hand, a BNI expert. Reconnecting After Years (00:00:52) Steve and Brian reminisce about their long-standing friendship and connection. The Importance of BNI (00:01:55) Discussion on why BNI is essential for auto repair businesses and its benefits. Understanding BNI (00:02:32) Steve explains what BNI is and how it helps businesses succeed through collaboration. Weekly Sales Meetings (00:03:14) Steve emphasizes BNI meetings as crucial weekly sales meetings for businesses. Looking for Opportunities (00:03:28) Steve discusses how to identify potential customers during networking. Building Relationships (00:05:38) Importance of personal connections and understanding each other’s backgrounds in BNI. 1-to-1 Meetings (00:06:21) Brian and Steve talk about the significance of one-on-one meetings in BNI. Activating Relationships (00:07:30) Steve shares strategies for nurturing relationships to enhance networking effectiveness. Referral Processes (00:08:19) Steve explains how to recognize opportunities for referrals within your network. Gratitude to RepairPal (00:09:17) Brian thanks RepairPal for sponsoring the episode and highlights its benefits. Personal Experiences in BNI (00:10:16) Kim shares her experience of being in two separate BNI groups with Brian. Themed Referral Campaigns (00:10:59) Steve discusses the effectiveness of themed referral campaigns in BNI. Trial and Error in Networking (00:11:41) Steve reflects on learning through trial and error to improve referral requests. Sticking to a Campaign (00:12:42) Steve explains the importance of consistency in referral campaigns for better results. Story of a Soccer Mom (00:13:01) Discussion about a successful vehicle repair story involving a soccer mom. BNI Presentation Challenges (00:13:14) Addressing difficulties in creating unique 62-second presentations for BNI meetings. Finding the Right Market (00:14:21) A pizza shop owner shifts focus from weddings to catering for pharmaceutical reps. Starting BNI Groups (00:15:56) Advice for shop owners interested in starting BNI groups in their towns. County Lines and BNI (00:16:28) Understanding how county lines affect the establishment of BNI chapters. Becoming a Connector (00:17:18) Benefits of starting a BNI group and becoming a key connector in the community. Choosing the Right BNI Group (00:17:56) Guidance on selecting the right BNI chapter in areas with multiple options. Finding Suitable BNI Chapters (00:19:17) Encouragement to use the official BNI website for locating chapters. Collaboratin Among Non-Competing Businesses (00:20:24) Discussion on how non-competing businesses can collaborate effectively within BNI. Value of BNI Membership (00:23:02) Addressing common objections regarding the financial and time investment in BNI. Success Stories from BNI (00:24:45) Highlighting a general contractor's significant business growth through BNI participation. Introduction to BNI Benefits (00:25:28) Discussion on how a mechanic benefited from being part of a BNI group. Overview of BNI Meetings (00:26:06) Description of the typical structure and agenda of a BNI meeting. Networking Process (00:26:54) Explanation of how networking occurs during BNI meetings, including introductions. Referrals and Testimonials (00:27:48) Insight into how referrals are shared and the importance of accountability in BNI. Tips for Effective Networking (00:28:39) Advice on being specific when asking for referrals and networking. Public Speaking Growth (00:30:15) Personal experiences on how BNI helped individuals improve public speaking skills. Visitor Experience in BNI (00:31:30) Encouragement for newcomers to visit BNI chapters before committing to membership. Contact Information for BNI (00:32:10) Details on how to reach Steve Hand for inquiries about BNI in North Carolina. Closing Remarks (00:32:45) Appreciation for the guest and sponsor, and a call to action for listeners.
      Thanks to our partner, RepairPal. Visit the Web HERE
      Thanks to our Partner, NAPA Auto Care Recorded at the NAPA Autotech Training Research Center in Canton, OH, Tracy Capriotto and Bill Weaver from NAPA Autotech Training take listeners through an in-depth, hands-on training session focusing on the safe handling and disassembly of high voltage battery pack, specifically from a Chevrolet Bolt. With the increasing prevalence of these vehicles, it is essential for automotive professionals to stay informed and equipped to handle the challenges that come with servicing them. Bill Weaver, NAPA Autotech Trainer. Listen to Bill’s previous episodes HERE Show Notes Watch Full Video Episode NAPA Autotech: https://www.napaautotech.com/learn High Voltage Battery Pack Overview (00:00:16) Importance of EV Training (00:00:36) Safety Gear and Protocols (00:00:54) Understanding Arc Flash Protection (00:02:23) Preparation for Battery Disassembly (00:04:06) Manufacturer's Instructions for Disassembly (00:05:36) Types of Bolts Used (00:07:06) Voltage Levels in the Battery Pack (00:08:18) Gasket Removal Techniques (00:09:12) Revealing the Battery Pack Interior (00:09:56) High Voltage Battery Characteristics (00:11:29) Safety Preparations and Voltage Readings (00:12:51) Meter Testing Setup (00:15:26) Importance of PPE and Tools (00:17:44) Coolant and Battery Interaction (00:20:00) Voltage Measurement Process (00:21:55) Battery Energy Control Module Explanation (00:25:02) Importance of Following Service Manuals (00:26:39) Understanding Battery Cell Configuration (00:29:58) Importance of Electrical Knowledge (00:31:01) Safe Practices in Battery Disassembly (00:32:49) Concerns with Damaged Electric Vehicles (00:36:23) Upcoming AAPEX Event in Vegas (00:38:08)
      Thanks to our Partner, NAPA Auto Care Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -The Aftermarket Radio Network: https://aftermarketradionetwork.com -Special episode collections: https://remarkableresults.biz/collections         Click to go to the Podcast on Remarkable Results Radio
