I HAVE NOT HAD THAT PROBLEM SO FAR, MAYBE I'M USING A BETTER QUALITY AFTERMARKET CAT?
Same here, I've never had a vehicle come back after installing an after market cat. Keep the government out.
Knowing how the catalytic converter works and how the catalyst monitor works, why would any shop install a catalytic converter noticeably smaller than the original? That seems like an invitation for problems. I don't replace many converters and when I do I use NAPA converters which are Walker. I have only had one cat code after a replacement but I was never allowed to diagnose it. It was a Toyota Sienna van and the original had fallen out of the pipe due to the studs rotting off so I don't know if the oxygen sensor was faulty or the new converter was at fault. All other replacements were successful after the first direct fit replacement converter.
As for government intrusion, like with anything else, if it is done properly and with reason it can be of benefit. If it is a knee-jerk reaction then unintended consequences are too be expected.
Since the law passed we installed about 80% less cats than usual. They get a price from us for $1000 or whatever the CARB compliant costs to install and then they go to Joes unregistered garage and get a $60 universal welded in. I refuse to do it so they go somewhere else, sucks but I can't afford to risk a fine. We never had a problem with the Walker direct fit OBDII compliant cats which aren't cheap to begin with but the CARB ones are nuts.
We typically install Walker replacements and to date we have only had one comeback that was due to a failed converter. Was replaced under warranty and away he went, still hasn't had any issues. Might want to get a closer look at all these jobs and see if there is/was an underlying issue. Hard to believe numerous cats have gone bad for absolutely no reason....
Ugh, please, no more gov't regulations and/or laws!!! Let the free market work it out!
Joe, if you stop buying the cheap CATS, those companies stop receiving income... and eventually go out of business and/or increase the quality of their product. Yes, it is tempting, but eventually you gotta learn to stop touching the stove. You've been burned.
      In this episode, Matt dives deep into the world of leadership, drawing an interesting parallel between basketball and the world of auto repair.
      In this episode, Matt discusses:
      The significance of March Madness and The Shot—not the Michael Jordan moments you might expect, but the shot in the 1992 NCAA tournament between Duke University and the Kentucky Wildcats. Insights into Coach Mike Krzyzewski's (Coach K) leadership style, particularly during high-pressure moments, and how it parallels the leadership needed in running a shop. How Coach K's calm, confidence, and ability to empower his players to take ownership in crucial moments played a pivotal role in Duke's success. The importance of leadership that encourages autonomy, confidence, and creating an environment where your team can thrive and make decisions that align with your vision. A breakdown of Christian Laettner's mindset during the game and how the Duke team overcame a seemingly lost situation with just 2.1 seconds left on the clock.
      Matt takes us through the dramatic ending of the game and how Coach K's simple yet powerful leadership moment shaped the outcome, drawing lessons for managers and leaders in the aftermarket industry.
      This episode isn't just for basketball fans; it's for anyone looking to inspire leadership and develop a high-performing team. By trusting your people, giving them autonomy, and showing calm, quiet confidence, you can help your team overcome challenges and come out on top.
