Zombie Cars
“Brains, Brains, we need Brains!”
Zombie cars? What’s a zombie car? Way back when we used points and condensers and later the basic electronic ignition systems cars didn’t need brains (ECM – Electronic Control Module), but that all changed in the mid 70’s on some imports and pretty much on everything else by the time the 80’s came around. Some of these brains were only cursory and didn’t actually control the car, but merely watched for emission issues, while others played a major role in the actual ignition spark or fuel delivery systems.
Most of the engines in those early years of electronics still used the same basic distributor setups (with a few exceptions) as their earlier counterparts that used the old tried and true points and condenser type of ignition systems. On those older models it was rather easy to slap a different distributor in it or change it over to electronic ignition, (which worked quite well by the way). These days, well, it’s not that easy. These computer systems have become so involved into the engine controls and other related systems that it’s nearly impossible to bypass the fuel or ignition systems. However, there are still a lot of people out there with low mileage cars from that early era that have kept them parked alongside of the garage or hung on to them for some sentimental reason. Some (very few) are in great shape, others… well, they look like zombies already.
What makes them zombies? The brain… the brain… they need brains! Just this past week I had several of these faded paint monstrosities lined up in the parking lot. (They never come alone… always in a pack.) For starters an old dilapidated 1986 Dodge pickup with a slant six. This old rusted, tilting to one side relic had been at another shop for a tune-up but, as the story was told to me by the owner, the other shop tried to start it when a fuel line ruptured and caught the old truck on fire. Luckily, they managed to get it out, but the damage was already done. The main harness from the firewall to the distributor, coil, charging system, blower motor, oil sending unit, temp. sender, and the starter wiring were completely melted into an unrecognizable mass of plastic and copper. It was my job to bring this dilapidated hulk back to life. The problem was the spark control computer was shorted out and unusable. Worse yet, the brain was discontinued eons ago and no replacement parts were available. This zombie needs a brain, and there doesn’t seem to be an easy way to get one. Seemed to me, a better idea was to do away with the electronic brain and refit the old slant six with a simpler ignition system than what it originally had. A lobototomy if you will. (Dr. Frankenstein would be envious.)
Then there’s this 2002 Mustang that needs a new BCM (Body Control Module). Call the dealer, call the parts warehouse, call everybody! Anybody! Is there a brain for this car? Nope, discontinued. Seems this BCM is a rather rare brain out there in zombie land. At the same time this was going on in comes a 1982 Ford Bronco with the original Variable Venturi carburetor still on it. Ok, not a brain, but just as bad. Trying to find a suitable replacement these days is a challenge. Ten or twenty years ago this would be no problem finding parts or conversion kits for it, but not today. This is going to take a bit of time to get these zombies back on the road.
This trend of bringing back the dead looks like it’s only going to continue with the economy in the shape it’s in. In some ways, I believe the manufacturers have thought this out long before there was a potential of these cars becoming zombies. Even though the car might physically still be in fair shape the components themselves are not readily available to bring these rolling dead back to life.
In my youth it was nothing for me and a few friends to grab an old car out of a junk yard, throw a few shots of gas down the carburetor, add a few wires and a fresh battery and fire that old thing up. The rust would fly, the engine would clatter, and the exhaust would roar. Those days are long gone now. Cars could be dead for a very long time in that salvage yard or behind the shed and easily brought back to life in those days. Nowadays, the engine and other mechanicals hold up a lot longer than years ago. Even the body and interior can hold up pretty good, but the electronics are not as friendly with the ravages of time, temperature, and the weather.
These zombies seem to be coming out of hiding more often than ever before. Reviving some of these early electronic zombies may happen, but on the other hand, it may be a futile effort. The truth of the matter is… these resurrections are not as easy to do as it was so many years ago. There are countless problems that have to be overcome to bring some of these rusted heaps back amongst the living, especially if you’re in area that requires emission testing. Just trying to bypass some of those early electronic brains when a replacement part can’t be found can be a real challenge. Some never make it and eventually die from the lack of a brain, while others wander aimlessly from shop to shop still searching for their elusive electronic gray matter.
Even after you manage to find a brain for these living dead vehicles it’s likely something else is going to go wrong. After being cast aside for so long all the hoses, belts, and gaskets have dried up. Something will or is about to fall off all by itself. Just as soon as one of these zombie mobiles makes an attempt to join the living something will undoubtedly come tumbling to the shop floor. Whether it’s coolant, oil, a belt, or a pressure hose off of the power steering, something is not going to stay in place. Just like in every zombie movie I’ve ever watched, one of them always has an arm or leg falling off. It sure seems that these zombie cars follow right along with that same affliction.
It’s safe to say, these relics of the early electronic era of the automotive world are in some respects the car equivalent to a zombie, half dead, half alive…and in search of a brain they may never find. So don’t be surprised if you’re at the next traffic light when an old faded-rusty-dented car with a shattered windshield, screeching brakes, and plumes of smoke that seem to follow it no matter where it goes, comes to a stop next to you. It’s just another car beginning its transformation into a “ZOMBIE CAR”.
Sometimes I wonder where I get these ideas for stories... must be a lot of late night TV or something. LOL
What a fun article, very enjoyable. One question; How many techs these days even know what a variable venturi carb is? When I worked for Ford in the 70s, I remember going to a training course on those VV carbs, not fun.
I have no idea what it is.
Told you Gonzo... many techs (and some shop owners) probably never heard or saw a Ford/Lincoln Variable Venturi Carburetor.No
Now I know we're both getting old Joe. ROFL
The story reminds me of the term "Frankenstein cars" Cars fixed or built from peices. How about a story on that Gonzo?
Cool idea, I'll work on that one.
      Introduction to the Episode (00:00:01) Brian Walker introduces the podcast and guest, Hallie Wassinger, discussing the importance of Google Local Services Ads. Overview of Google Local Services Ads (00:02:53)  Hallie explains the recent availability of Google Local Services Ads for auto repair shops across the U.S. Historical Context of Local Services Ads (00:03:25)  Discussion on the past availability of Google Guaranteed Ads and their expansion to auto repair shops. Current Availability and Limitations (00:04:38)  Hallie details the current state of Local Services Ads for tire shops and their limited availability. Cost Structure of Local Services Ads (00:05:34)  Introduction to the pay-per-lead model, highlighting its differences from traditional Google Ads. Service Categories for Auto Repair (00:06:45) Hallie outlines the specific services auto repair shops can advertise under Local Services Ads. Lead Generation Process (00:07:44)  Explanation of how leads are generated through phone calls or messages via the Local Services Ads dashboard. Ongoing Maintenance of Ads (00:08:31)  Discussion on the necessity of monitoring and rating leads to optimize the ad performance. Success Stories from Beta Testing (00:10:55)  Brian shares a success story from Chris Cotton, highlighting low lead costs achieved through Local Services Ads. Lead Cost Insights (00:11:39)  Hallie provides average lead cost data, emphasizing the effectiveness of the ads for auto repair shops. Visibility of Local Services Ads (00:12:18)  Brian describes how Local Services Ads appear prominently in search results, enhancing visibility. Google Screened vs. Google Guaranteed (00:13:02)  Hallie explains the differences between Google Screened and Google Guaranteed, focusing on their application processes. RepairPal Sponsorship Message (00:14:27)  Brian thanks RepairPal for sponsoring the episode and discusses the benefits of being in their certified network. App Fueled Sponsorship Message (00:15:32)  Brian introduces App Fueled, promoting their customer loyalty app for auto repair shops. Verification Process for Shops (00:16:33)  Hallie outlines the verification process for shops to join Google Local Services Ads, including necessary checks. Verification Steps for LSA (00:16:50)  Overview of the verification process for auto repair shops applying for Google Local Services Ads. Challenges with Specialty Shops (00:19:14)  Discussion on difficulties specialty shops face with Google Local Services Ads targeting. Specialization in Google Ads (00:20:03)  Insights on why specialized shops may benefit more from traditional Google Ads. Opportunities with LSA (00:22:05)  Exploration of the current opportunities available for shops using Google Local Services Ads. Cost Benefits of LSA (00:23:13)  Comparison of lead costs between Google Local Services Ads and traditional Google Ads. Importance of Google Business Profile (00:24:29)  Discussion on how optimizing Google Business Profiles impacts LSA ad performance. Role of Reviews in SEO (00:27:40)  Emphasis on the significance of keywords in customer reviews for improving visibility. Optimizing Photos for LSA (00:29:42)  Best practices for managing and updating photos in Google Local Services Ads. Pricing for LSA Management (00:31:01)  Details on the costs associated with managing Google Local Services Ads for shops. Introduction to LSA (00:33:47)  Discussion on the performance of Google Local Services Ads and how to get started. Discovery Call Process (00:34:15)  Details on scheduling a discovery call and assessing local competition for LSA. Final Thoughts on LSA (00:34:38)  Emphasis on the importance of early adoption of LSA for auto repair shops. Self-Management of LSA (00:34:40)  Advice on running LSA independently, highlighting the required time and dedication. Closing Remarks (00:35:29)  Thanking listeners and sponsors, and encouraging engagement with the podcast.
      Thanks to our Partners, NAPA TRACS, and Today's Class Recorded at the 45th annual Mobile Air Climate Systems Conference (MACS 2025) in Orlando, Florida, the focus is on the critical topic of leak detection in automotive air conditioning systems. Two main leak detection methods are compared: dye leak detection, which uses fluorescent dyes and UV lights for visual identification, and electronic leak detection (ELD), which uses sensors to detect refrigerants. The discussion also covers the compatibility of these methods with various refrigerants, including those used in electric vehicles, and explores the advantages and disadvantages of each approach. John Godden, Production Operations Manager, Spectronics Corporation Matt Farel, Business Development- Service Tools, Inficon Show Notes Watch Full Video Episode MACS Training Event & Trade Show: https://macsmobileairclimate.org/ National Automotive Service Task Force (NASTF): https://wp.nastf.org/ Koura: https://www.kouraglobal.com/ Honeywell: https://www.honeywell.com/us/en Leak Detection Discussion (00:00:00) Importance of Air Conditioning (00:02:12) Heat Pump Systems (00:03:03) Complementary Technologies (00:04:09) Tracers in Manufacturing (00:04:44) Visual vs. Electronic Detection (00:05:33) Safety of Refrigerants (00:07:50) Importance of UV Light (00:08:21) Using Multiple Detection Methods (00:09:33) Verifying Repairs (00:10:52) Preference in Detection Methods (00:12:06) Market Trends in Leak Detection (00:13:00) The Importance of Shop Management Systems (00:13:53) Training and Customization of Napa Trax (00:14:33) Leak Detection Methodologies (00:15:40) Dye Compatibility with Refrigerants (00:16:20) Tracer Gas Leak Detection (00:17:54) EVs and Leak Detection Challenges (00:19:45) Advancements in Leak Detector Technology (00:21:52) New Developments in Dye Products (00:23:38) Transition to Natural Refrigerants (00:24:29)
      Thanks to our Partner, NAPA TRACS NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Thanks to our Partner, Today's Class Optimize training with Today's Class: In just 5 minutes daily, boost knowledge retention and improve team performance. Find Today's Class on the web at https://www.todaysclass.com/ Connect with the Podcast: -The Aftermarket Radio Network: https://aftermarketradionetwork.com -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on X: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/
    • By Zenoo
      Hi my name is Zenas and I am 26 years old from Alberta, Canada. I started my own automotive repair shop in December 2023. After running it for 1 year I made a little bit of profit. I needed some advice on how I could increase it. Its a 3 bay shop with two 2 post hoists and one 4 post hoist with alignment. I am the only mechanic in the shop as I can't afford to hire anyone at this point. I am charging about $120 per hour for the labor and very minimal mark up on parts. The shop had no customer base when I got it so it took me sometime to build returning customers. If I try to increase the prices on parts the customers run away. Seems like they are calling around the city and going to the cheapest person. My monthly over head cost is about $7000. Whatever I make in a month goes back into next month's rent. Any advices on how to manage this properly from other shop owners?
