Mechanic's Eye - - - Everyone has a touch of it, mechanic's just use it more often.
Mechanic’s Eye
When your livelihood is primarily working with your hands, they become an extension of your eyes. Feeling around corners, finding odd placed bolts, and examining the area where your eyes can’t reach are all part of the job requirement in the automotive field. Learning to “see” with the tips of your fingers is a trait every seasoned mechanic is familiar with. Being able to place an open end wrench into a cavity, and only use the tip of one finger to locate the nut or bolt are just some of the ways mechanics for generations have solved, or perhaps cut the hours on a job.
The mechanic’s eye isn’t just at the tip of his fingers; it’s the ability to reason through a problem, and come up with a solution that will get the job done faster and more efficiently than what is described in the service manuals. If mechanics always followed the engineering instructions on how things needed to be removed or replaced, there’s a good chance a lot of repairs would have been slowed to a crawl. As a mechanic, I appreciate the efforts of all those dedicated engineers, but in the field some things work better when we, (mechanics)… well… let’s say… cut a few corners.
I don’t like to call them “short-cuts”, they do save time in most cases, but it’s more of a way of examining a problem and figuring out the easiest solution. There are several reasons for all of this fuss. In some instances it’s to avoid marring the paint or finish to the car, or causing more problems with the number of other unrelated components that need to be removed. I, for one never like those jobs that require the mechanic to disassemble an entire section of the car just to change one component. Finding ways of combating these before they become issues is part of having that “mechanic’s eye”.
Here’s a simple test of your “mechanic’s eye”. Stand at a doorway where you can reach around to the opposite side of the wall. Stand close enough to the edge of the doorway trim where you can still reach both hands around the corner. Now take a bolt and nut, place the head of the bolt flat against the other side of the wall from where you are standing, and with the other hand screw on the nut. Don’t look around the corner, don’t lean around the wall… you stay on one side, the bolt and nut on the other. Can you do it? I know you’ll try it. If you have to fumble around a bit… you need some practice. If you can do it on the first try… you’ve got that mechanic’s eye for sure.
Some time ago, well… many years ago, the old Camaros had an issue with the blower motor when it came time to replace it. The blower motor was actually tucked in the far corner behind the inner fender. (Several other GM products were like this, too.) You could possibly get all the bolts and screws out of it, but it wasn’t going to come out of the hole. By proper procedure guidelines you were either to remove the fender, or the inner fender to gain access. In those days the inner fender wasn’t plastic like they are today, and it took a lot of effort to wriggle that hunk of metal out of there. So, what did the mechanic come up with? Cut an access hole into the inner fender and remove the blower that way, then make a patch for the inner fender. Soon after this became the standard practice, a patch piece was developed (I suppose by the engineering department) with detailed instruction on how to cut out the inner fender.
Nowadays, it’s plastic, plastic… and more plastic, and even more hidden components than ever before. That “mechanic’s eye” is just as important today (if not more) as it was back then. Plastic has a tendency to snap, not bend out of the way like the metal body parts of the older vehicles, which makes the job even tougher when it comes to moving things around. Just the other day I had a 2001 Cadillac in that wouldn’t change from the floor vents to the defroster. It was the mode actuator acting up. From under the driver’s side of the dash I could just make out the mode actuator, but only a glimpse of it. If you look up the labor time on this job you’ll find it requires removing the entire dash out of the way. (Practically an all day job.) However, if a mechanic has some dexterity and willing to reach you can do the job in no time. You just have to have that “mechanic’s eye” to get it done. Like many of these situations, you have a pretty good idea of the location of the screws, the shape of the part, and how it comes off, but ya just can’t see the screws or the part. You’ve got to trust the end of your fingers, as your mind’s eye puts the puzzle together.
After taking the three screws out that secure the actuator to the housing, the only thing left to do is remove the radio and use that opening as a way to pry the old actuator off of the housing using a large, flat screw driver. Mind you, the tension on which part of the plastic parts, and where you are placing the tip of the screw driver is all done by feel. Is this technique by the book? Nope. Can it be done? Yep. Just takes that mechanic’s eye on the tip of your finger to do it.
There are so many examples of reaching into an engine cavity or behind a dash that it’s impossible to list them all. Any seasoned tech can probably tell you a thousand ways they have worked on a project, and then suddenly have a “Eureka” moment of a way to simplify the repair, even though it isn’t mentioned in the step by step procedures. It could make the entire job easier, and all it took was some good old fashion ingenuity.
I’m constantly listening up for any new techniques that other mechanics have come up with to solve some sort of problem in the field. Whether it’s from an internet forum, convention, trade magazine, or emails … anything to make my job easier. The more you know, the better prepared you’ll be to tackle some of these odd problems. As a mechanic we all have the same goal in mind, “Finish a job as efficiently and as quickly as possible with the least amount of disturbance to the rest of the vehicle.” And that takes a little more than just a quick glance at a problem… that takes a mechanic’s eye.
To me this is an important part of being a mechanic you may have all the schooling in the world but unless you have that mechanics eye you may not ever be as good as you really could be.
Take a cheap #2 phillips head screwdriver. Cut the end off and weld it back to the screwdriver at a 90 degree angle so that you have about a 1/4 inch offset. You've just made the tool to take out a Lexus RX300 blend door actuator without removing the dash.
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Dan Clark explores how emotion surpasses reason in driving action, particularly in sales, emphasizing the power of storytelling to activate specific brain chemicals. He shares personal experiences, including his recovery from paralysis, to illustrate the impact of belief and a strong "why." The conversation delves into societal stigmas around emotional expression, especially for men, and the importance of genuine connection. Clark further explains how leveraging brain chemistry through storytelling enhances influence and strengthens customer relationships. He concludes by stressing that businesses should prioritize deep human connections over mere transactions. Dan Clark, Hall of Fame Keynote Speaker, New York Times Best-Selling Author of 37 Books, Expert in Next-Level Leadership for Teams, Sales, and Life. https://danclark.com/ Show Notes Watch Full Video Episode The Institute of Automotive Business Excellence: https://www.wearetheinstitute.com/ Introduction of Dan Clark (00:00:00) The Importance of Emotion in Memory (00:02:47) Emotion vs. Knowledge in Sales (00:04:17) Statistics on Sales Persistence (00:04:47) The Role of Storytelling in Sales (00:05:13) Social Stigma Around Emotion (00:05:23) Mental Health and Emotional Prosperity (00:06:01) Creating Discomfort for Growth (00:07:05) Asking for Help in Mental Health (00:07:49) The Role of Feelings in Leadership and Sales (00:08:07) The Zone and Brain Chemicals (00:09:11) Emotional Connection in Sports (00:10:06) Impact of Storytelling on Audience (00:12:07) Overcoming Struggles and Emotional Growth (00:16:29) Authenticity and Emotional Expression (00:17:54) The Importance of Belief (00:18:30) Energy and Attraction (00:19:26) Authenticity in Connection (00:19:54) Personal Injury Story (00:20:31) Rock Foundation vs. Rock Bottom (00:21:21) Core Values in Business (00:22:22) The Power of Belief (00:23:08) Asking the Right Questions (00:23:51) Connecting Head and Heart (00:24:36) Physiological Responses to Fear (00:24:49) Storytelling in Sales (00:27:32) Self-Awareness in Customer Service (00:28:29) Identifying with Roles (00:30:22) Heart-to-Heart Connection (00:30:44) Story of Empathy (00:31:07)
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Get ready to grow your business with the Automotive Management Network: Find on the Web at http://AftermarketManagementNetwork.com for information that can help you move your business ahead and for the free and informative http://LaborRateTracker.com Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/
      Introduction to the Podcast (00:00:01)  The podcast begins with a welcome message from the host, Brian Walker. Guest Introduction (00:00:10)  Brian introduces co-host Kim and guest Doug DeLuca, owner of Boca Auto Fix. Overview of Boca Auto Fix (00:00:51)  Doug shares details about his auto repair shop, including its location and age. Hiring an Apprentice (00:01:09)  Doug discusses the recent hiring of an apprentice and the journey leading to this decision. Challenges in Hiring (00:02:13)  The speakers reflect on the difficulties shop owners face in finding and hiring young talent. Marketing Journey Begins (00:03:02)  Discussion shifts to Doug's initial marketing efforts and his involvement in content creation. Background in Technology (00:04:07)  Doug explains his previous technology background and how it influenced his approach to marketing. Learning SEO and Marketing (00:04:45)  Doug describes his self-taught journey in SEO and digital marketing after opening his shop. Realizing Marketing Needs (00:06:14)  Doug reflects on his initial assumptions about marketing and the reality of attracting customers. Understanding SEO Basics (00:08:09)  Doug shares his insights on SEO and the learning process involved in mastering it. Frameworks in Marketing (00:10:25)  The conversation explores the use of frameworks in both auto repair and marketing strategies. Adopting "They Ask, You Answer" (00:11:23)  Doug discusses his experience with the "They Ask, You Answer" philosophy in content creation. Writing Blogs for Customer Engagement (00:12:21)  Doug explains how he uses customer inquiries to create relevant blog content for his shop. Experience at a Quick Lube (00:13:29)  Doug shares his firsthand experience at a quick lube to highlight differences in service quality. Experience Comparison (00:14:06) Doug shares his experience of visiting a competitor's shop to understand customer perception and service quality. Proactive Client Advocacy (00:14:57) The team discusses the importance of guiding potential clients to the right service provider based on their needs. Sponsorship and Marketing Tools (00:16:13) Brian introduces RepairPal, highlighting its benefits for attracting new customers and building trust. Customer Loyalty Apps (00:17:51) Brian discusses the advantages of using App Fueled to create customer loyalty programs for auto repair shops. Incognito Visits (00:18:20) Doug talks about visiting a competitor's shop incognito to gain insights without revealing their identity. Collaboration Over Competition (00:19:09) The speakers explore the idea of referring customers to other shops and building relationships in the industry. Challenging Competition Norms (00:20:20) Brian reflects on inviting competitors to the podcast, emphasizing collaboration over traditional competition. Marketing Involvement (00:22:42) Doug explains the ad hoc nature of their marketing efforts and the role of social media in their strategy. Community Involvement (00:27:41) Doug shares their family's volunteer work and how it integrates with their business's social media presence. Engaging the College Market (00:28:51) Doug discusses how 30% of his clients are college students and their marketing strategies. Collaborating with Local Professors (00:31:18) Doug shares his experience working with a marketing professor for student analysis of his business. Challenges of Seasonal Demand (00:32:24) Discussion on the impact of seasonal changes on business demand and local marketing efforts. Starting with Marketing (00:34:02) Doug advises new shop owners to listen to podcasts and conduct online research for marketing. SEO as a Long-Term Strategy (00:35:08) Doug explains the importance of SEO and its long-term benefits for business growth. Understanding Competition (00:36:44) Doug emphasizes the need to analyze competition and not assume marketing strategies will work universally. The Importance of Data (00:39:08) Doug highlights the role of data in assessing marketing effectiveness and making informed decisions. Nuances of Market Dynamics (00:41:14) Discussion on how geographical and seasonal factors affect marketing strategies in auto repair. Client Avatar and Marketing Alignment (00:42:13) Doug explains the significance of understanding the ideal customer for effective marketing strategies.  Overcoming Diagnostic Fee Challenges (00:43:09) Discussion on how Doug has adjusted his approach to diagnostic fees to improve customer conversion. The Importance of Evaluation Fees (00:43:40) Discussion on the role of evaluation fees and their impact on shop maturity. Improving Customer Communication (00:44:09)  Insights on enhancing customer explanations regarding services and processes. Coaching and Competitive Analysis (00:45:03)  How coaching helped refine service policies and improve customer relations. Content Creation and Marketing Strategy (00:46:32)  The significance of creating content for customer engagement and marketing. Duck Duck Jeep Initiative (00:47:05)  Fun marketing strategy involving ducks to engage with the local Jeep community. Value of Customer Feedback (00:48:46)  Importance of understanding customer inquiries and improving service based on feedback. Contact Information for Doug DeLuca (00:49:29)   Doug shares how listeners can reach him for further inquiries.
