They Come In Threes
Good things, bad things, they just can’t show up all by themselves; not just once, hardly ever twice, nope… always in threes. At least it seems that way. Why, I don’t know… it just does, I guess. Whether it’s a great day of easy going jobs at the repair shop, or something at the house, you can almost count on the threes. It’s like there’s some sort of buddy system going on with all this chaos.
Take the other day when I got my big mower out of the garage. I always make it a habit to check the tire pressure, oil and gas before I start mowing. Sure enough, I’m low on the go juice, well… might as well fill it up, oh wait minute… that tire…it’s not low… it’s flat! Oh geez… Ok, gotta take care of that too. Oh, no… what’s this? It’s a broken stabilizer bar for the mowing deck. Now how did that happen? Sheared the bolt clean off. I’ll have to weld that back together before I go anywhere. As usual I had a few choice “words” to say about the whole thing, which brought the wife out to see what all the commotion was about. She just shook her head as she walked back inside.
After I finished mowing and put the tractor away, I couldn’t help but notice a strong fuel smell coming from it. Oh geez, the gas cap is missing. Crud, I didn’t screw it back on tight; now I’ve got to take that long slow walk through the yard trying to find the missing cap. (More grumbling and choice words again). I found the cap lying on the ground just a few feet from where I filled up. (Lucky)
Anyway, that ended the debacle at the house. It’s Monday morning again, and I’m back at the office. Cars were already lined up outside. I was expecting a pretty good turn out this morning. Based on all the calls I received the week before, I was counting on a pretty productive day. The very first job was a no start on a 2006 Chevy truck with an 8.1 liter. The scanner was my first choice, since I could hear the fuel pump hum as I turned the key. The Tech II beeps were loud and clear in the still morning air as I stood out in the parking lot gathering the information. I went straight to the service codes section … “No Codes Present”.
I thought to myself, “What in the world is going on here? No codes?”
I cranked the engine again… nothing. Ok, now what!? Back up a couple of screens to the data section and crank the engine again, this time watching the cam and crank signals. Neither budged. It’s probably a bad crank or cam sensor… or both. Might as well run back in and grab the scope to check the wave patterns, since this truck’s computer seems to think everything is just hunky-dory.
I’ll bet if this PCM could talk right now it would probably be saying something like, “Hey, what’s your problem? Everything is fine here; me (the PCM) and all the sensors are just sitting around have a good time. Don’t see what all the fuss is about.” (Stupid computer…! Doesn’t even know when it should be telling me something important. A service code would be nice right about now. But, no… that would be too easy.) Well, it did end up being the cam and crank sensor, even though that pesky PCM didn’t seem to care.
It didn’t stop there. Later, another job came in with an A/C problem. This one was a 2008 Acura. The pressure levels were good enough to kick the compressor on, but no clutch engagement. I’ll try talking to this car with a scanner. Oh, would ya look at that… it says, “Everything is fine, no codes here. Don’t know what your problem is, we’re all having a great time under the hood.” (A few choice words seemed appropriate right about now.)
This is crazy; two jobs in a row where the computer is supposed to be helping me diagnose the problem are both saying there is no problem? A little more checking and a few more choice words I had it solved. (Had to go through the instrument control module that’s where all the A/C information was at. The prints referred to the instrument cluster as the “Instrument Control Module”. As if checking for an A/C signal by way of the cluster wasn't confusing enough already, you had to go and rename the dang thing.) It turned out to be bad compressor after all of that. Still no codes, though.
I thought I was done, done with all these weird problems… but no… they come in threes don’t they? Now it’s this 1998 Chevy van’s turn. This van had the propensity to shift all the way to high gear, before it even passed 30mph. It wasn’t a harsh shift, it wasn’t a slip… it just shifted super-fast. My buddy Jeff, over at the transmission shop checked it out earlier, and determined that it was an electrical problem. This didn’t sound easy to diagnose… but like Jeff said, “If it was easy, I wouldn’t be bringing it to you.” (Remind me to thank you later, Jeff.)
The first thing I did after a test drive was scan it. Oh please…not again… are you kidding me? It’s another no codes present scenario. I swear I heard a little snicker from this van’s computer.
As if it was saying, “Don’t know what to tell ya, we’re all fine in here.” (You know there are times I think those little electrons are just laughing at me.) At this point I’m thinking an internal computer glitch, but I better play it safe and try to recalibrate, or at least see if there’s an update for the PCM. There was, so I downloaded the info into the van’s PCM.
Another drive test… no change. Codes? … Seriously you thought there would be codes? NOT! After removing the PCM it wasn’t hard to spot the water damage inside the unit. After installing the new PCM a code popped up. Wow… a code? A real code! Hmm, transmission TCC solenoid. The Tech II couldn’t activate the solenoid either. I better call Jeff. By now we both had enough of this job, and after a brand new (not reman’d) PCM was installed, neither one of us were thinking it could be a bad computer… must be the solenoid. But, it wasn’t the TCC solenoid; it was the brand new computer. (Choice words again… they seem to be popping up more frequently, have ya noticed?). Another computer, another reprogram, (Third time programming the same van, by the way) … finally… everything is working.
What should I expect next? Maybe some more brand new “bad” parts? Maybe it’s Jeff’s turn for wacky repairs. Maybe … it’s another lawnmower fiasco? Maybe I should start triple checking things instead of double checking. Who knows? But, like my buddy Jeff tells me, “Whatever it is… good or bad. They come in threes you know.”
That crank sensor on those 8.1's ain't a picnic to get out either. Barely enough room to get a few fingers down to the sensor, and barely enough room between the head and the firewall to get it out. Dang thing is about 6 inches long, slender, and in there tight. Grrr!
      Introduction to the Episode (00:00:01) Brian Walker introduces the podcast and guest, Hallie Wassinger, discussing the importance of Google Local Services Ads. Overview of Google Local Services Ads (00:02:53)  Hallie explains the recent availability of Google Local Services Ads for auto repair shops across the U.S. Historical Context of Local Services Ads (00:03:25)  Discussion on the past availability of Google Guaranteed Ads and their expansion to auto repair shops. Current Availability and Limitations (00:04:38)  Hallie details the current state of Local Services Ads for tire shops and their limited availability. Cost Structure of Local Services Ads (00:05:34)  Introduction to the pay-per-lead model, highlighting its differences from traditional Google Ads. Service Categories for Auto Repair (00:06:45) Hallie outlines the specific services auto repair shops can advertise under Local Services Ads. Lead Generation Process (00:07:44)  Explanation of how leads are generated through phone calls or messages via the Local Services Ads dashboard. Ongoing Maintenance of Ads (00:08:31)  Discussion on the necessity of monitoring and rating leads to optimize the ad performance. Success Stories from Beta Testing (00:10:55)  Brian shares a success story from Chris Cotton, highlighting low lead costs achieved through Local Services Ads. Lead Cost Insights (00:11:39)  Hallie provides average lead cost data, emphasizing the effectiveness of the ads for auto repair shops. Visibility of Local Services Ads (00:12:18)  Brian describes how Local Services Ads appear prominently in search results, enhancing visibility. Google Screened vs. Google Guaranteed (00:13:02)  Hallie explains the differences between Google Screened and Google Guaranteed, focusing on their application processes. RepairPal Sponsorship Message (00:14:27)  Brian thanks RepairPal for sponsoring the episode and discusses the benefits of being in their certified network. App Fueled Sponsorship Message (00:15:32)  Brian introduces App Fueled, promoting their customer loyalty app for auto repair shops. Verification Process for Shops (00:16:33)  Hallie outlines the verification process for shops to join Google Local Services Ads, including necessary checks. Verification Steps for LSA (00:16:50)  Overview of the verification process for auto repair shops applying for Google Local Services Ads. Challenges with Specialty Shops (00:19:14)  Discussion on difficulties specialty shops face with Google Local Services Ads targeting. Specialization in Google Ads (00:20:03)  Insights on why specialized shops may benefit more from traditional Google Ads. Opportunities with LSA (00:22:05)  Exploration of the current opportunities available for shops using Google Local Services Ads. Cost Benefits of LSA (00:23:13)  Comparison of lead costs between Google Local Services Ads and traditional Google Ads. Importance of Google Business Profile (00:24:29)  Discussion on how optimizing Google Business Profiles impacts LSA ad performance. Role of Reviews in SEO (00:27:40)  Emphasis on the significance of keywords in customer reviews for improving visibility. Optimizing Photos for LSA (00:29:42)  Best practices for managing and updating photos in Google Local Services Ads. Pricing for LSA Management (00:31:01)  Details on the costs associated with managing Google Local Services Ads for shops. Introduction to LSA (00:33:47)  Discussion on the performance of Google Local Services Ads and how to get started. Discovery Call Process (00:34:15)  Details on scheduling a discovery call and assessing local competition for LSA. Final Thoughts on LSA (00:34:38)  Emphasis on the importance of early adoption of LSA for auto repair shops. Self-Management of LSA (00:34:40)  Advice on running LSA independently, highlighting the required time and dedication. Closing Remarks (00:35:29)  Thanking listeners and sponsors, and encouraging engagement with the podcast.
      n this episode of "The Weekly Blitz," Coach Chris Cotton delivers insightful guidance tailored specifically for auto repair shop owners. He delves into the effects of spring break on sales, underscoring the significance of having a well-planned marketing calendar to effectively navigate and prepare for seasonal slowdowns that can impact business. Chris enriches the discussion by sharing a personal anecdote about dealing with an aftermarket warranty issue, illustrating the critical importance of maintaining customer trust and satisfaction, even when it presents financial challenges for the business. This story serves as a reminder of the long-term value of prioritizing customer relationships and integrity.
      Additionally, Chris provides an exciting update on Project Alpha, a shop he acquired, showcasing its remarkable turnaround in financial performance. He details the innovative staffing strategies implemented, which have contributed to the shop's success and growth. These strategies not only improved efficiency but also fostered a positive work environment, setting a benchmark for other shop owners to follow.
      The episode is proudly sponsored by Shop Marketing Pros, a company that specializes in providing marketing solutions tailored for auto repair shops. Their expertise helps shop owners enhance their visibility and reach, ensuring they stay competitive in the ever-evolving market.
      **Spring Break Challenges (00:01:05)**
      In this segment, Chris delves into the seasonal challenges faced by repair shops during the spring break period. He explains how the influx of vacations and travel plans leads to a noticeable dip in sales, as fewer customers seek repairs during this time. To counteract this trend, Chris emphasizes the importance of having a well-structured marketing calendar. By planning promotions and outreach efforts in advance, repair shops can better navigate the slow season and maintain a steady flow of business.
      **Doing What's Right for Customers (00:06:31)**
      Chris shares a compelling personal experience that underscores the significance of exceptional customer service. He recounts a situation where he had to make a tough decision to prioritize the needs of a customer over immediate profit. This story highlights the long-term benefits of building trust and loyalty by consistently doing what's right for customers. Chris argues that by putting customers first, businesses can foster stronger relationships and ultimately achieve greater success.
      **Project Alpha Update (00:10:26)**
      In this update, Chris provides an in-depth look at the progress of Project Alpha, the shop he recently acquired. He discusses the financial performance of the shop, noting significant improvements in revenue and profitability since the acquisition. Chris also outlines the operational changes implemented to enhance efficiency and customer satisfaction. From streamlining processes to upgrading equipment, these improvements have positioned the shop for continued growth and success in the competitive market.
      The TRUTH About Business Coaching That Companies Don't Wants You to Know!
      Email Hunt: podcast@paarmelis.com
      Email Matt: mattfanslowpodcast@gmail.com Diagnosing the Aftermarket A - Z YouTube Channel
