Never Enough Tools - - - - - Tools, tools, tools... Ya never have enough.
Never Enough Tools
Ah, tools… one of my favorite things. Tools are what separate us from the rest of the planet’s occupants. You know, we’ve all seen some primate on a nature show use a stick to get at some food, or otters use a rock to break open an abalone shell. Chances are you might have even seen a bird that has figured out how to use a small stone to break into an egg. But, none of them can match the ability of man and his far reaching capabilities to mold his environment with his creative mind and opposable thumbs.
In a mechanic’s world tools are everything. From the roll around floor jack to the high tech scanners we use. Tools are everywhere, and most mechanics have more than a passing interest in them. There’s hardly a mechanic I know who doesn’t like taking a little break from all the grease and grime for a browse through the tool trucks. At times, just to get a glimpse of some of those shiny new wrenches in their little boxes is enough for some tool connoisseurs, while others want to collect them all. There’s a tool for every conceivable job, and as a mechanic you’ll more than likely use most of them at some point in time. Sure, once in a while you’ll lose a socket or manage to break something. All that means is another trip to the tool truck to find a replacement, and an even better chance to gaze at all the other tools you’ve just got to have.
It doesn’t take long before the investment into tools and tool storage units becomes astronomical. I know my collection has far surpassed my meager tool box. I’ve ended up with several separate tool boxes just to keep everything in order. There are things I just don’t have room for in a tool box anymore, I keep the scanners in one area, and there are shelves for all the ball joint tools, radiator pressure tools, A/C refrigerant identifiers, leak tester, compression gauges, strut removing clamps, axle bearing pullers, and the countless other specialty items I use from time to time.
Although it might seem like I’ve got every tool I’ll ever need, (the wife thinks I do) hardly so; there’s still gadgets that I don’t have… or can’t bear to spend the cash on some of those super expensive tools that you just don’t use but once in a while. So what do I do? The same thing most everyone else does in the business… you fabricate your own. I’ve got some rather creative homemade tools stashed away in a few drawers myself. Some I’ve used several times, while others were made for just one special job. One particular tool is the door alignment tool for GM trucks. The tool is really expensive, and it’s not something I need every day, but when the need arises it’s nice to be able to realign a sagging door for a customer. I made one out of a small diameter axle shaft, and with a little welding and bending, I made an exact copy of one. It works just as well as if I had bought it off of the tool truck. (Looks just like the real deal too.)
While some homemade tools were created to save a few bucks, other homemade tools just seem to work easier or better for me than a store bought tool. Like the heater hose release tool for Ford products. I’m not sure what they were thinking when they put those blasted connectors so close to the firewall and then give you this little piece of plastic to wedge in there to release the retaining spring. I wonder if those engineers have ever tried to stretch across the top of the engine with their feet dangling in midair, while wrestling with that confounded contraption. I took a piece electrical conduit about the same size as the heater hose lines and cut it lengthwise, then welded the two pieces onto small swivels which I then welded to an old pair of brake spring pliers. Now I can simply lean over the fender slip it over the heater hose, clamp down on it lightly, and with a little push and shove, off comes the hose. Works better than that @?#A$! piece of plastic!
Of course there are those cut down sockets, bent wrenches, ground down screwdrivers and countless other wacky things you have to come up with to get a certain job done. The only problem I have now is that I look into the drawer full of this stuff and I’ve forgotten what some of them are for. It doesn’t matter, chances are they will get re-bent, re-ground, and re-welded into some other useful tool. Needless to say, I hardly ever throw any tool out… broken or not, you never know what you might need next.
When it comes to electronic tools, well… that’s a whole different scenario. Kinda hard to repurpose some of those, but I’ve managed to give a few obsolete tools a second life. I had an old (very early) Bosch injector tester that was missing most of the special cords and manuals. It sat in a dusty corner for years. Then one day when I had nothing else to do I tore it apart and used the large volt meter out of it as a wall mounted meter behind a work bench. Handy for sure, and it’s large enough to read from across the table. (It’s still there by the way.)
I know I’m not the only one out there who tries to make do with whatever you have on hand rather than buying every conceivable tool there is. An old friend of mine who owned a VW repair shop was like that. This guy had the knack of creating some of the goofiest looking tools I’ve ever seen. If you didn’t know any better you’d think some of his creations were just a piece of junk with a couple of screws welded onto it. But you’d be wrong. He had a hand made tool for just about any situation you could encounter on those old bugs. To me… it was pure genius at work, a real marvel of mechanical aptitude and homegrown savvy. If he had an idea that might make a job easier, that was more than enough incentive for him to create some new gizmo for the task.
Tools… … … the right tool, for the right job, it’s a never ending quest for the professional mechanic. You’re always seeking something that will make the next job easier; whether you buy it or make it yourself, there’s one thing for sure… you never have enough tools.
I forgot to mention one other problem when you have so many tools, so many tool box and separate locations for stuff... you tend to forget what you actually have, or at least I do.
I was pulling out some axle bearings a few weeks ago and I grabbed my small puller... yanked, and yanked on that blasted bearing before it finally came out. I kept saying to myself, "Man, I need to get a longer, heavier puller." Then a week or so later I was looking for something else and what did I spy on the top shelf.... the big puller and a case full of the different sized bearing pullers for axle bearings..... AND... the box is clearly marked IN BIG LETTERS... AXLE BEARING PULLER KIT. What goober I am. Hey, at least I get a GOLD star for finding it. LOL
      Brian and Parker dive into how strategic marketing investment can drive real growth for auto repair shops. Parker shares how increasing his marketing spend transformed his business, leading to record-breaking profits and industry recognition. They discuss why many shop owners hesitate to spend more on marketing and how cutting back can actually slow growth.
      They break down the balance between brand-building and direct response marketing, highlighting how both contribute to long-term success. Parker shares insights from industry peer groups and how analyzing successful shops’ financials helped him refine his own strategy. They also explore how even small adjustments in marketing spend can make a big impact.
      They explain what it takes to turn marketing into a growth engine, from increasing car count to boosting profitability. With real-world insights and proven strategies, they make the case for why now is the time for shop owners to commit to smarter marketing investments.
      Declined repairs don’t have to be lost revenue. AppFueled’s call center schedules follow-up calls and equips your team with everything they need to close the deal. Get started now at appfueled.com
      VISION Hi-Tech Training & Expo
      Introduction to the Episode (00:00:01) Brian Walker introduces the podcast and guest, Hallie Wassinger, discussing the importance of Google Local Services Ads. Overview of Google Local Services Ads (00:02:53)  Hallie explains the recent availability of Google Local Services Ads for auto repair shops across the U.S. Historical Context of Local Services Ads (00:03:25)  Discussion on the past availability of Google Guaranteed Ads and their expansion to auto repair shops. Current Availability and Limitations (00:04:38)  Hallie details the current state of Local Services Ads for tire shops and their limited availability. Cost Structure of Local Services Ads (00:05:34)  Introduction to the pay-per-lead model, highlighting its differences from traditional Google Ads. Service Categories for Auto Repair (00:06:45) Hallie outlines the specific services auto repair shops can advertise under Local Services Ads. Lead Generation Process (00:07:44)  Explanation of how leads are generated through phone calls or messages via the Local Services Ads dashboard. Ongoing Maintenance of Ads (00:08:31)  Discussion on the necessity of monitoring and rating leads to optimize the ad performance. Success Stories from Beta Testing (00:10:55)  Brian shares a success story from Chris Cotton, highlighting low lead costs achieved through Local Services Ads. Lead Cost Insights (00:11:39)  Hallie provides average lead cost data, emphasizing the effectiveness of the ads for auto repair shops. Visibility of Local Services Ads (00:12:18)  Brian describes how Local Services Ads appear prominently in search results, enhancing visibility. Google Screened vs. Google Guaranteed (00:13:02)  Hallie explains the differences between Google Screened and Google Guaranteed, focusing on their application processes. RepairPal Sponsorship Message (00:14:27)  Brian thanks RepairPal for sponsoring the episode and discusses the benefits of being in their certified network. App Fueled Sponsorship Message (00:15:32)  Brian introduces App Fueled, promoting their customer loyalty app for auto repair shops. Verification Process for Shops (00:16:33)  Hallie outlines the verification process for shops to join Google Local Services Ads, including necessary checks. Verification Steps for LSA (00:16:50)  Overview of the verification process for auto repair shops applying for Google Local Services Ads. Challenges with Specialty Shops (00:19:14)  Discussion on difficulties specialty shops face with Google Local Services Ads targeting. Specialization in Google Ads (00:20:03)  Insights on why specialized shops may benefit more from traditional Google Ads. Opportunities with LSA (00:22:05)  Exploration of the current opportunities available for shops using Google Local Services Ads. Cost Benefits of LSA (00:23:13)  Comparison of lead costs between Google Local Services Ads and traditional Google Ads. Importance of Google Business Profile (00:24:29)  Discussion on how optimizing Google Business Profiles impacts LSA ad performance. Role of Reviews in SEO (00:27:40)  Emphasis on the significance of keywords in customer reviews for improving visibility. Optimizing Photos for LSA (00:29:42)  Best practices for managing and updating photos in Google Local Services Ads. Pricing for LSA Management (00:31:01)  Details on the costs associated with managing Google Local Services Ads for shops. Introduction to LSA (00:33:47)  Discussion on the performance of Google Local Services Ads and how to get started. Discovery Call Process (00:34:15)  Details on scheduling a discovery call and assessing local competition for LSA. Final Thoughts on LSA (00:34:38)  Emphasis on the importance of early adoption of LSA for auto repair shops. Self-Management of LSA (00:34:40)  Advice on running LSA independently, highlighting the required time and dedication. Closing Remarks (00:35:29)  Thanking listeners and sponsors, and encouraging engagement with the podcast.
      n this episode of "The Weekly Blitz," Coach Chris Cotton delivers insightful guidance tailored specifically for auto repair shop owners. He delves into the effects of spring break on sales, underscoring the significance of having a well-planned marketing calendar to effectively navigate and prepare for seasonal slowdowns that can impact business. Chris enriches the discussion by sharing a personal anecdote about dealing with an aftermarket warranty issue, illustrating the critical importance of maintaining customer trust and satisfaction, even when it presents financial challenges for the business. This story serves as a reminder of the long-term value of prioritizing customer relationships and integrity.
      Additionally, Chris provides an exciting update on Project Alpha, a shop he acquired, showcasing its remarkable turnaround in financial performance. He details the innovative staffing strategies implemented, which have contributed to the shop's success and growth. These strategies not only improved efficiency but also fostered a positive work environment, setting a benchmark for other shop owners to follow.
      The episode is proudly sponsored by Shop Marketing Pros, a company that specializes in providing marketing solutions tailored for auto repair shops. Their expertise helps shop owners enhance their visibility and reach, ensuring they stay competitive in the ever-evolving market.
      **Spring Break Challenges (00:01:05)**
      In this segment, Chris delves into the seasonal challenges faced by repair shops during the spring break period. He explains how the influx of vacations and travel plans leads to a noticeable dip in sales, as fewer customers seek repairs during this time. To counteract this trend, Chris emphasizes the importance of having a well-structured marketing calendar. By planning promotions and outreach efforts in advance, repair shops can better navigate the slow season and maintain a steady flow of business.
      **Doing What's Right for Customers (00:06:31)**
      Chris shares a compelling personal experience that underscores the significance of exceptional customer service. He recounts a situation where he had to make a tough decision to prioritize the needs of a customer over immediate profit. This story highlights the long-term benefits of building trust and loyalty by consistently doing what's right for customers. Chris argues that by putting customers first, businesses can foster stronger relationships and ultimately achieve greater success.
      **Project Alpha Update (00:10:26)**
      In this update, Chris provides an in-depth look at the progress of Project Alpha, the shop he recently acquired. He discusses the financial performance of the shop, noting significant improvements in revenue and profitability since the acquisition. Chris also outlines the operational changes implemented to enhance efficiency and customer satisfaction. From streamlining processes to upgrading equipment, these improvements have positioned the shop for continued growth and success in the competitive market.
      The TRUTH About Business Coaching That Companies Don't Wants You to Know!
