Geek With Attitude - - - - Your attitude doesn't match your intelligence.
Geek With Attitude
Now I realize I'm only a mechanic, and not an Ivy League scholar, and I may not qualify as the next inductee into MENSA, but I'm still a pretty smart guy. Oh, I may not know all there is to know about every single make and model out there, but I have enough background and technical ability to solve just about anything that goes wrong with the modern car. But, for some people the mere thought that a mechanic might actually have a few brain cells just baffles them to no end.
A few weeks ago I got a call from a guy, who (to the best of my dim witted abilities could tell), was having a problem with his truck. He told me that he pulled all the fuses, and was still having a battery drain issue he couldn't find. He even took it to another shop and wasn't happy with their results, so he was going to give me a chance at it based on a friend's recommendation.
"Bring it in tomorrow, and I'll get it checked out for you," I told him.
The next day a 98 Nissan pickup with 150,000 miles on the odometer was waiting for me. After getting the owner's information, I went over what he wanted me to do. Little did I know this guy had all the answers already. Not only the answers, but several ideas as to what was causing his problem. This particular guy was a full-fledged computer geek with more than a little attitude to go along with it. Not only did he think he was dead right about everything, but that every mechanic out there was nothing more than a knuckle dragging grease monkey with the IQ of a walnut. The more he told me about the problem the more I knew I was in for a long afternoon. Seems everything that was ever wrong with the car from the day he bought it was leading up to the moment the battery went dead. But, of course, it's not dead now... that takes a month before it would happen.
"A month?" I asked.
Oh, he had an answer for that too. It all started with the front crankshaft seal. The seal was leaking, and it leaked all over the alternator, so he had the seal changed along with a new alternator and battery. (Both the alternator and the battery came from one of those cheapo depot places; imagine where the seal came from.) A month went by before the car wouldn't start again. The seal was leaking too, but not nearly as bad.
"Hmm," I said, sitting at the service counter thinking this whole thing through, "You say it takes a month before it won't start? Are you driving it much?"
"Yes," he said, "Every day."
This didn't add up, something else is wrong with the car. As I tried to explain to him that if a car is driven every day, and starts perfectly fine,but then all of a sudden it goes "click-click" it tells me there is something else wrong, and it's probably not a battery drain issue.
"Leave it with me, and I'll check it out," I told him,
Apparently, Mr. Geekdumb doesn't have a clue how a car works, other than where to put the gas and which way the key turns. Not that I'd hold that against him, a lot of people don't know a thing about their transportation. It's just that most people don't try to sound like they do, especially while standing in front of somebody that just might.
Once I had the truck in the shop it turned out to be a classic problem; the battery bolts were tightened down as far as they could go, but I could easily pull the cables off the battery without any effort at all. The charge output and parasitic draw tests showed no signs of any problems. As for the seal leak. Well, if you've been around cars with high miles and poor maintenance you've probably seen this before. The PCV valve was clogged. Without that, no ventilation for the lower end, and of course, a back pressure builds up and that pressure has to go somewhere... usually out a seal, and the front seal is one of the usual places for it to go.
Explaining all this to the computer nerd turned out to be a whole lot tougher than I thought possible. How one person can act and think that they are so smart, but can't see the logic behind the explanation is beyond me. The more I tried to explain, the more this guy asked even more bizarre questions.
I gave him the run down on the battery clamp issues, "Yes, a loose battery clamp can make the car not start. Sometimes you'll get one quick turn of the starter then nothing, not even a dome light. Other times you'll get a "click" which is what your car sounds like. This can also stop or restrict the alternator charge output from entering the battery."
"So, that's why my dash lights don't work?"he asked.
"There's no relationship between the charge output and the dash lights. That's a separate problem. Most likely the rheostat," I said.
"Well, what about the switch on my dome light, it doesn't work. I'm positive that is due to the front seal and the PVC you mentioned."
"Sir, it's a PCV not PVC, "Positive Crankcase Ventilation" is what it stands for, and no, it has nothing to do with your dome light."
"So I have two PCV's in the car?"
"No, just one."
"So where's the PVC?"
"That would be in your house most likely. Most homes have PVC plastic piping."
"So, now you're telling me I don't have two PCV's?"
"I never said you had two."
This went on, and on. My frustration level was getting to my MAX level, and I'm about to tell this guy just where he can put his PCV and his PVC. But, after lengthy deliberations he eventually decided to have me at least fix something...one thing…change the battery clamps. He had the solution for the dash lights, dome light, PCV, and the front seal. I apparently don't understand,or fail to comprehend how all his other problems are related to the dead battery.
He showed up later that day to pay for the clamp replacement, and it wasn't hard to tell this guy had an ego driven "micro"chip on his shoulder. He wasn't about to have some lowlife mechanic explain the physics of the internal combustion engine to such an astute individual as himself.
His parting comments as he walked out the door said it all.
"I work on highly technical and advanced systems on home and business computers that are far above the complexities of anything you'll ever see. I'm better off fixing my own car, because I have a degree, and my intelligence level is far superior than any mechanic."
Really? That's the best you got?
Better luck insulting me next time, fella…leaving is probably the smartest thing you've done so far… don't let the door hit ya on the way out.
Don't just love it how these guys tell you what is wrong before you have even looked at it because they read about such and such on the internet and it comes that their solution is a million miles from what is actually going on.
These high and mighty types can be the biggest pain. There so busy telling you how, that a tech can get side tracked and never find the how or why.
The best thing is just to tell the tech, "I have to jump start it", or "It's not charging" something like that. But some people just can't make life simple you know.
You can never forget about some guy fixing the car. I think he's one of them. LOL One of my favorite stories... "Some Guy" LOL
I used to work at a Dodge dealership that was near a Pratt & Whittney ( rocket science ) facility. Used to love it when these guys brought their cars in. Manuals all flagged and nots in the side bars. They already knew what was wrong with the vehicle but just wanted it confirmed with our "computers". Yea all in a days work! I think a lot of them were buddies with Some Guy (remember him? )
      Want to make your shop’s marketing stand out this May? Join Brian Walker and Caroline LeGrand as they break down creative ways to engage your audience, plan your content, and connect with your community.
      In this episode, they’ll share creative campaign ideas, fun social media prompts, and practical ways to highlight your team, engage customers, and boost brand awareness. Plus, get inspiration for using national holidays like National Skilled Trades Day, Road Trip Day, and even Pizza Party Day to keep your content fresh and relevant.
      Don’t miss this opportunity to simplify your marketing and make a real impact. Tune in now and start planning content that connects!
      Days of the Year
      National Calendar
      Introduction to the Episode (00:00:01)  Brian and Caroline introduce the podcast and thank RepairPal for their support. Preparing for May Marketing (00:01:16)  Discussion on planning marketing strategies for May, emphasizing the importance of advance preparation. General Marketing Themes (00:02:00)  Overview of summer-related topics, tax return spending, and pre-trip inspections for vehicles. Motorcycle Safety Awareness Month (00:03:17)  Highlighting the importance of motorcycle safety and tips for drivers and riders. Military Appreciation Month (00:03:39)  Encouraging auto repair shops to give back to military personnel throughout May. Teacher Appreciation Week (00:04:34)  Ideas for showing gratitude to teachers, including small gestures and discounts. National Pet Week (00:05:50)  Encouragement to engage customers by sharing pet photos on social media. Celebrating Various Appreciation Weeks (00:07:05)  Discussion on multiple appreciation weeks in May and the importance of selecting key themes. Learn to Ride a Bike Day (00:08:04)  Suggestions for community engagement by helping kids learn to ride bikes. National Skilled Trades Day (00:09:00)  Promoting skilled trades and hosting events to educate youth about automotive careers. Star Wars Day (May the 4th) (00:10:26)  Fun marketing ideas related to Star Wars Day for engaging customers. National Odometer Day (May 12th) (00:11:42)  Ideas for a fun contest involving vehicle odometer readings to engage customers. RepairPal Certification (00:13:14)  Discussion on becoming RepairPal certified and the benefits for auto repair shops. App Fueled Introduction (00:14:18)  Overview of a customer loyalty app designed for auto service shops. National Lost Sock Memorial Day (00:14:54)  Encouragement for creative engagement ideas related to this fun holiday. Military Appreciation Month (00:15:06)  Suggestions for acknowledging military families and providing discounts. National Dance Like a Chicken Day (00:15:59)  Call to action for engaging with customers through fun activities. Check Your Wipers Day (00:16:27)  Importance of checking wipers before summer travel and educating clients. National Pizza Party Day (00:18:05)  Highlighting the fun of pizza party day and community engagement. Armed Forces Day (00:18:28)  Ideas for honoring military personnel and their contributions. Memorial Day Awareness (00:18:46)  Discussion on the solemn nature of Memorial Day and appropriate observances. National Road Trip Day (00:19:34)  Emphasis on preparing vehicles for summer road trips and inspections. National Rescue Dog Day (00:20:13)  Celebrating rescue pets and their connection to the auto repair community. World Marketing Day (00:20:48)  Encouragement to appreciate and promote effective marketing efforts. Paws and Pistons Campaign (00:22:41)  Combining pet care with auto services for community engagement. Prepping for Road Trip Day (00:24:51)  Continued focus on educating customers about road trip preparations. Engagement Ideas (00:25:34)  Encouragement to share personal stories and engage customers creatively.
      Auto Repair Marketing Mastermind (00:26:01)  Invitation to join the Facebook group for sharing marketing ideas and support.
      Matt Fanslow and Margaret Light, a Licensed Marriage and Family Therapist and Certified Sex Therapist in the state of Minnesota, discuss a recent murder-suicide within the automotive community. They discuss the alarming statistics surrounding such events, emphasizing the significant role of domestic violence as a predictor. The conversation explores risk factors, including untreated mental illness, access to firearms, and the dynamics of control within relationships. Finally, they offer practical advice and resources for identifying warning signs and seeking help for individuals at risk.
      Matt Fanslow, an ASE certified Master Automotive Technician, reviews a YouTube video reacting to Google's top questions about car problems. Matt provides his expert insights and clarifications on topics ranging from car batteries, vibrations, and parasitic drains to more complex issues involving EVAP systems and the importance of proper diagnostics. Additionally, he offers commentary on the importance of ongoing training for technicians, skill gaps in the industry, and the economics behind charging for diagnostic work. Matt combines humor and professional knowledge to educate viewers on both basic and advanced automotive questions.
      React Video (00:00:00) Google's Top Questions (00:01:20) Why Does My Car Battery Keep Dying? (00:01:26) Vibration When Stopping (00:03:10) Why Does My Car Shake When I Drive? (00:04:57) Squeaking When Turning (00:08:32) Shaking When Accelerating (00:10:09) Bad Smell from AC (00:11:44) Shaking When Braking (00:14:52) Gas Leaks and Evaporative Emission Systems (00:15:38) Importance of Oil in Engines (00:17:59) Napa Auto Tech Training Programs (00:20:49) Causes of Car Overheating (00:22:04) Why Cars Need Gas (00:23:39) Reasons for Cars Burning Oil (00:24:01) Backfiring and Misfires in Cars (00:26:05) Expiration of Car Seats (00:27:14) Mechanics' Pricing and Value (00:28:20) Why Mechanics Wear Gloves (00:30:42) Mechanics and Chemicals (00:31:44) Mechanics' Pay (00:31:59) Skill Levels in Auto Repair (00:32:06) Wage Misconceptions (00:33:29) Honesty in the Trade (00:35:09) Uniforms and Image (00:36:39) Charging for Diagnostics (00:39:44) Comparing Auto Repair to Other Professions (00:42:12) What Mechanics Do (00:43:36) Hourly Rates and Costs (00:45:58) How do mechanics get paid? (00:47:26) Flat rate pay explained (00:47:37) Charging for diagnostics (00:52:36) The demand for mechanics (00:54:41) Passion for automotive work (00:57:00) Certifications and training (00:59:04) Handling car emergencies (01:00:39) Dealing with car recalls (01:01:29) What to do if a car is stolen (01:02:03) Carbon Monoxide Concerns (01:03:13) What to Do If Your Car Is Hit While Parked (01:04:24) Insurance Company Guidance (01:04:40) Reacting to Answers and Feedback (01:05:07)
      RepairPal.com/shops
