Has anyone tried the copper/nickel brake lines. I was always under the assumption that brake fluid absorbed copper, in addition to moisture.
Joe,
I hate to say that we have been using it for years, but I never thought about the brake fluid absorbing copper. I will have to find out about that. As far as using it, we have been very happy with it, it bends easily, flairs nicely and resist rusting.
Russ
The Copper Nickle Alloy line has been out for some time now, and it is all I will use at the shop, I don't even stock steel line.
- It does not rust
- It is difficult to kink
- It is easy to bend
- It is easier to cut & flare
It is the one product where there are no negatives, not to mention it is only $4 more a roll through my supplier then traditional steel line.
I have never heard of these lines absorbing brake fluid and I have never had one customer complain about break fluid loss. Copper may absorb brake fluid (?) but this is Copper Nickle Alloy, not a standard copper line.
While on the subject of easy to work with lines, and rust resistant lines, another excellent product that is easy for technicians to work with and will not rust again are the SUR&R nylon/plastic Fuel Line kit. It gives you all the common fuel line fittings (but improved design, easy to disconnect, no more disconnect tools) and the appropriate size line and compression fittings to do nylon patches on steel lines (if only a section is rusted out), or to run complete lines from the tank to the engine.
It saves a lot of time from having to source OE replacement lines, is safer and more professional then high pressure rubber with high pressure fuel clamps, and it will not degrade like rubber over the years, and it will never rust! I will never run metal fuel lines again, and all of my patches are done with this stuff.
I prefer steel lines of coarse, however on the other hand I keep a roll o the copper/nickel on had for those tedious jobs with little space to work. Just like we had to fab alot of line on a car the other day and I was easier to use the c/n.
ATS covered it, all lines are made with copper. The process of rolling the metal into lines is a procedure of wrapping and welding copper and steel and other alloys. Bundy tubes or Bundy pipes, are a type of double-walled low-carbon steel tube manufactured by rolling a copper-coated steel strip through 720 degrees and resistance brazing the overlapped seam in a process called Bundy Welding. It may be zinc- or terne- coated for corrosion protection. It has been used in automotive hydraulic brake lines, for cars manufactured in the USA, since the 1930s.
Interestingly a 1969 study by the SAE recommended the replacement of Bundy tube with 90-10 copper-nickel alloy (UNS C70600 or Kunifer pipe) because of the corrosion concerns. The Kunifer pipe concept has since been adopted by European automakers Volvo, Rolls-Royce, Lotus, Aston-Martin, Porsche and Audi. Bundy pipe retains the advantage higher rigidity, which means less volume expansion under pressure.
As to Joe's concerns, brake fluid does not absorb copper. Rather it simply is a carrier of copper particulate that is abraded off the lines as the fluid deteriorates. The slipping additives and anti corrosives are the first item to break down in the fluid, based on aggressiveness of the driver and age of vehicle. We have no way of telling when the happens so techs must test with our Copper Test Strips ( www.BrakeTestStrip.com ), they instantly ready the Copper concentration in PPM (parts per million). A copper content of 200 ppm or greater indicates a depletion of corrosion inhibitors in the brake fluid, so reach 200 and you need to flush per MAP's UICS procedures.
It is a known fact that brake fluid is designed to protect against corrosion of the system materials it contacts, and that those corrosion inhibitors deplete over time. Additionally, test data shows that this increased presence of copper contamination predetermines the rapid growth of iron contamination and corrosion that has been shown to impede future brake system performance. The valves in ABS pumps just love copper and the platting process that takes place over time is the number one cause of pressure failure.
Hope this information helps, it is critical to replace brake fluid before it looses it protective additives. Please let me know if you need brake strips for testing the fluid, we can offer you a special price since you are members of ASO. Note they we just brought out the newest strip, you can now determine the type of brake fluid in the system, 3, 4, 5, or mixes that must be removed and replaced.
Thanks for this site Joe and the ability to bring tech info all who are members. Please let me know if anyone has additional questions or comments on this subject.
Gary
1(800) 266-4497
Here is a great article about the addition of Copper, Zinc, Nickel and other alloys used over the years...
Worldwide Data On Wear
In 1965, 251,000 automobile accidents in the USA involved brake failures. In that same year, at a major meeting of the Society of Automotive Engineers (SAE), the problem of brake loss due to steel tubing damage was identified as both dangerous and costly. By 1969, the SAE published a study, Hydraulic Brake Line Corrosion: An Initial Investigation of the Problem (A.G. Imgram and D.K. Miner, Paper 690530, Mid-Year Meeting, May 1969). Indications were clear: corrosive deterioration of steel brake tubing created maintenance problems and could be a hazard to safety. The report revealed that steel brake tubing was highly erratic after 4-6 years in service. It also identified copper-nickel alloy C70600 tube as outstandingly superior to conventional steel brake line tubing in laboratory salt-spray-exposure burst tests. Copper and four copper alloys also out-performed the double wrapped steel tubing in the tests.
Sweden, with a national program of vehicle inspection since the mid 1960s, has been a consistent source of the most accurate data on the problem. The Swedes frequently ban vehicles from the road due to badly corroded steel brake tubing. As in the USA, roads in Sweden during the winter are salted for snow and ice removal.
In spite of corrosion-retarding coatings that are applied in accordance with specifications requiring a minimum coating weight per square foot of tubing surface area (not an overall coating thickness), little protection may result in local areas.
Since the 1970s, observed brake tubing faults have diminished with improved coatings. Still, in 1988, over 90,000 Swedish vehicles failed testing due to damaged steel brake tubing, most of which was corrosion related. West Germany, which instituted mandatory vehicle inspections in 1970, has collected data in line with Sweden. Data from the United Kingdom reveal 20% failure rate of brake systems. However, there is no indication of what part of that is attributable to tubing damage.
Fig01.jpgFigure 1. Results of brake tubing inspections of Volvo vehicles with different brake tubing materials.
The Swedish data cover the period during which Volvo upgraded the material it used for brake tubing. Prior to 1971, Volvo had used terne coated steel tubing. In 1971 they changed the coating to zinc. The zinc coating was eventually supplemented by epoxy, and in 1976, Volvo adopted copper-nickel alloy C70600. In Figure 1, the performance of these four materials are compared on the basis of the percentage of observed occurrences of corrosion damage to brake tubing over 12 years of service. Copper-nickel is shown as the most reliable material by far.
Users of copper-nickel brake tubing in addition to Volvo include world-class vehicle manufacturers like Rolls Royce, Lotus, Aston Martin, Porsche and, most recently, Audi. Copper-nickel is also used in military, fire fighting and other heavy vehicles
Ive been asking my local vendors for years to carry test strips! Now I have a source! Thanks for the great info!
Please send me an email or give us a call on the 800 number and I will be glad to help you get some test strips for your shop. They really are the only way to know exactly when to change brake fluid and eliminate any liability on the shops part, they are the only MAP and BAR approved or endorsed test.
We also manufacture test strips for all Radiator fluids, your can check them out at..
Additionally our OE Approved FluidRx program tests fluids in transmissions, power steering units, differentials and motor oil right in your shop and in just 1 to 2 minutes.
Talk to you soon, I look forward to being of assistance.
Gary
P.S. Love NC, we have summer cabin on east side of Asheville up near Warren Wilson College.
We're not that far from there, we're in Blowing Rock.
I'll pm you my email tonight!
Thanks for such a great article!
      Thanks to our Partners, Shop Boss, and 360 Payments Recorded at the ASTA Expo, Gerard Tonno from NAPA Autotech discusses being an "automotive Einstein." He emphasizes the importance of critical thinking, passion for auto repair, and effective use of resources and tools in diagnostics. He highlights the necessity of understanding basic electrical principles, conducting thorough visual inspections, and practicing with diagnostic tools. Gerard Tonno, NAPA Autotech Training Show Notes: Watch Full Video Episode ASTA EXPO: https://astaexpo.com/ NAPA Autotech: https://www.napaautotech.com/learn Thoughts on Being an Automotive Einstein (00:00:28) The Importance of Passion (00:02:03) Utilizing Online Resources (00:02:54) Visual Inspection Skills (00:04:34) Foundational Knowledge in Electricity (00:05:41) Understanding Pinpoint Tests (00:06:43
      Shop Boss – Shop Management Software built by shop owners for shop owners. It works the way you need it to, right out of the box. Find on the web at https://shopboss.net Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/             Click to go to the Podcast on Remarkable Results Radio
      Thanks to our Partners, AAPEX, NAPA TRACS, and Automotive Management Network Scott Brown shares his profound journey through significant health challenges, specifically his battle with bladder cancer. Scott reflects on the lessons learned from his experiences, emphasizing the importance of living in the moment and preparing for the future. He discusses the emotional impact on his family, the illusion of control, and the necessity of succession planning. Scott’s story is a powerful reminder of life's unpredictability and the need to cherish each day, encouraging listeners to take proactive steps in their personal and professional lives. Scott Brown, Cardinal Plaza Shell, Springfield, VA. Scott’s previous episodes HERE Show Notes Watch Full Video Episode The Illusion of Control (00:03:25) The Diagnosis Revelation (00:04:21) Assessing Succession Plans (00:06:52) Health Challenges and Recovery (00:07:41) Living One Day at a Time (00:08:25) The Impact on Loved Ones (00:10:56) Long-Term Family Planning (00:12:10) The Copper Beech Tree Metaphor (00:14:05) The Importance of Values and Legacy (00:16:07) Succession Planning in Business (00:20:36) Competitive Advantage Discussion (00:22:28) Emotional Impact of Health Challenges (00:26:24) Busyness as an Idol (00:28:39)
      Thanks to our Partners, AAPEX, NAPA TRACS, and Automotive Management Network Set your sights on Las Vegas in 2024. Mark your calendar now … November 5th-7th, 2024. AAPEX - Now more than ever. And don’t miss the next free AAPEX webinar. Register now at http://AAPEXSHOW.COM/WEBINAR NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Get ready to grow your business with the Automotive Management Network: Find on the Web at http://AftermarketManagementNetwork.com for information that can help you move your business ahead and for the free and informative http://LaborRateTracker.com Connect with the Podcast: -The Aftermarket Radio Network: https://aftermarketradionetwork.com -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on X: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections             Click to go to the Podcast on Remarkable Results Radio
      In this episode of "The Weekly Blitz," Coach Chris Cotton from Auto Fix Auto Shop Coaching delves deep into the crucial role of coaching in the auto repair industry. He discusses how coaching enhances performance, accountability, and long-term success for shop owners, service advisors, and technicians. Chris shares insights on the benefits of having a coach, including improved business strategies, goal-setting, and overcoming challenges. He emphasizes that coaching is a valuable investment, leading to significant returns and sustainable growth.
      Throughout the episode, Chris elaborates on the transformative power of coaching, illustrating how it can turn struggling shops into thriving businesses. He provides real-world examples of shops that have seen remarkable improvements in efficiency, customer satisfaction, and profitability after implementing coaching strategies. Chris also touches on the importance of personalized coaching, tailored to address the unique needs and goals of each shop, ensuring that the guidance provided is relevant and actionable.
      Moreover, Chris highlights the role of coaching in fostering a positive work culture. He explains how regular coaching sessions can boost team morale, enhance communication, and create a cohesive environment where everyone is aligned with the shop's vision and objectives. By fostering a culture of continuous improvement, coaching helps shops stay ahead of industry trends and adapt to changing market demands.
      The episode encourages listeners to consider coaching to elevate their business and achieve excellence in the competitive auto repair landscape. Chris underscores that investing in coaching is about immediate gains and building a foundation for sustained success. He invites shop owners to take the first step towards transformation by exploring coaching opportunities, ultimately leading to a more prosperous and resilient business.
      Introduction and Podcast Overview (00:00:22)
      Coach Chris Cotton introduces the podcast and its focus on insights for auto repair businesses.
      Coaching Importance (00:01:16)
      Discussion on the significance of coaching for business owners and its impact on performance.
      Performance Through Coaching (00:02:23)
      Coached individuals consistently outperform those who go it alone, highlighting the value of accountability.
      The Role of Accountability (00:03:31)
      Accountability is crucial for achieving goals, ensuring follow-through on commitments.
      Perspective in Coaching (00:04:27)
      Coaching provides perspective, helping clients see the bigger picture amidst daily challenges.
      Long-Term Investment in Coaching (00:06:22)
      Coaching is a process that requires time, focusing on sustainable change rather than quick fixes.
      Commitment to Improvement (00:07:18)
      Successful coaching fosters a commitment to continuous improvement and resilience in tough times.
      Conclusion and Call to Action (00:08:20)
      Encouragement for listeners to embrace coaching for personal and business growth, emphasizing the importance of progress.
      In this episode of "The Weekly Blitz," Coach Chris Cotton discusses overcoming adversity, especially in the auto repair business. He emphasizes the importance of mindset, contrasting a fixed mindset with a growth mindset. Coach Chris offers practical tips for building resilience, such as shifting perspectives, controlling responses, leveraging support systems, cultivating adaptability, and practicing self-reflection. He shares personal experiences to illustrate how adversity can be a transformative experience. Sponsored by Shop Marketing Pros, the episode highlights the role of effective marketing in business success. Overall, it serves as a motivational guide for navigating and thriving through life's challenges.
      Introduction to Adversity (00:00:04)
      Coach Chris Cotton introduces the theme of overcoming adversity in personal and professional life.
      Understanding Adversity (00:01:03)
      Discussion on the inevitability of adversity and its various forms in life and business.
      Mindset Matters (00:02:12)
      Exploration of fixed vs. growth mindsets and their impact on handling challenges.
      Building Resilience (00:03:30)
      Key strategies for cultivating resilience during tough times and learning from adversity.
      Shifting Perspectives (00:04:39)
      Importance of viewing adversity as part of personal growth and embracing discomfort.
      Control Your Response (00:05:51)
      Emphasizing the need to focus on controllable aspects during adversities.
      Leverage Support Systems (00:06:08)
      Encouragement to seek help from mentors and loved ones when facing challenges.
      Cultivating Adaptability (00:06:30)
      The necessity of being flexible in thinking and actions to thrive through adversity.
      Self-Reflection (00:07:08)
      Encouraging regular self-reflection on lessons learned from past adversities.
      Personal Experience (00:07:30)
      Coach Chris shares his journey of transitioning from shop owner to coach amidst challenges.
      Pressure and Growth (00:08:08)
      Discussion on how adversity shapes character and fosters personal and professional growth.
      Key Takeaways (00:08:30)
      Practical advice on acknowledging, acting, embracing uncertainty, and reflecting on adversity.
      Final Thoughts (00:09:10)
      Encouragement to choose resilience and transformation in the face of life's challenges.
