Second Hand Lyin' - - - Second hand information ain't nothing like First Hand knowledge
Second Hand Lyin'
Second hand information can be misleading, even totally wrong. There's always a chance it might be correct, but I wouldn't count on it. It depends on where that information came from to start with. In the automotive repair business if a car was checked out with any degree of accuracy, the information is probably good… But if the person giving that info to the next person can't explain it in a way they both understand, then the results are not going to be as truthful as they could be.
Do you remember when we were kids in school we would form a line, and you said something to the first person, who then passes it on to the next person, so on and so on? Only to have the original information be completely different by the time it gets to the other end? The same thing can happen with a car problem when more than one person is involved in getting the information to the person at the end of the line… and who's usually on the end of the line?… the mechanic.
Just the other day a driver tell his company dispatcher his truck wasn't getting any heat out of the driver's side vents. By the time it got to the shop the entire story was reversed to, "There's no cold air coming out of the passenger side". Really had me wondering what was actually wrong, until I talked to the driver myself.
Take the information given when buying a used car. Occasionally there's a little white lie about the condition of the car,maybe not on purpose, but rather from the grape vine of information being passed along. Of course, selling the car is the goal and informing the prospective buyer of any faults is important, but the car may have problems,and the explanation of those problems might have been twisted around to the point it's not even close to the truth anymore.
By the time the buyer has their chance to take the car to their mechanic, nine chances out of ten there will be some discrepancies between the two explanations. Now the issue becomes "who's right". The owner of the vehicle will almost always side with their mechanic,while the buyer will lean towards their own. All this information gets passed back and forth from mechanic to owner,buyer to mechanic, mechanic back to buyer, and buyer back to owner. This only leads to even more misunderstandings. To avoid any further confusion, the best bet is to have the last guy tell the first guy and everyone else in between.
A few weeks ago I had a problem come up regarding the condition of a car that was up for sale. It was a '97 Buick with low mileage, and had been sitting for nearly 8 years without much attention in a garage. The owner's father-in-law bought the car new before he passed away, and as far as the son-in-law was told by the rest of the family, everything was in tiptop shape. It definitely was clean, dent free,great paint and not a blemish to the interior. As with any of these "moth balled" cars, the first thing that was an issue was the battery. Leaving a battery sit for that long it's natural to have the battery sulfated by now. (Sulfating happens when the lead active material reacts with the sulfate from the electrolyte forming a hard leadsulfate surface on the plates. When there is no active lead material left, and no sulfate in the electrolyte the battery becomes completely discharged. Keeping a battery charged will reduce the amount of hardened material on the plates.)
The owner had it towed to a garage to have the battery replaced. After the new battery was installed, it took a few cranks for the engine to start. After a few coughs and shudders the engine purred like new, however the service light was on. (Which seemed to be the major concern for both seller and the buyer). But, by the time the car arrived at my shop the engine codes had been cleared from the PCM by the mechanic who installed the battery. All I had to go on was the second hand information that the owner over heard from the mechanic who worked on the car.
"The mechanic told me it might need a tune-up, or something," the owner proudly tells me.
It's that "something" that bothered me. A tune-up, maybe… I'm thinking old gas myself, but what's a "something"? It really doesn't matter at this point as the buyer jumps into the conversation and says, "Do a complete checkup for me,and let me know if it's worth what they want for it."
There were numerous small problems to deal with, and a few major issues as well. Everything from an ABS light staying on (which neither party mentioned)to a very poorly repaired alternator main positive lead. With the car in the service bay you could hear the alternator whine grow louder and louder the longer the car ran, but at the battery terminals there was hardly anything in the way of a noticeable alternator output. Between the alternator and the battery was a large homemade connection that was hot enough to fry an egg on. This was causing a rather large voltage drop between the alternator and the battery. In fact the electrical tape surrounding it was almost completely melted off.
After explaining the ABS problem, air conditioning, wiring issues, and all the other problems I found while checking it out, it was clear to me they were not going to purchase the car. (Just too many problems to deal with for them.) The owner, on the other hand, once he finds out what I found wrong with his "tiptop" shape car he's going to blow a gasket, and I'm sure I'll be on the receiving end of his frustration at the service counter.
Needless to say, before I could show the owner any of the results I had a very upset individual at the service counter.
"I was told everything was in perfect working order," the buyer shouts at me.
"Do you want to see what I found out? It would be a lot easier to show you," I told him.
As I showed him the actual conditions, his doubts about what he was told regarding the condition of the car came into question. It was only then that he knew he should have had a mechanic check it out, rather than relying on the second hand information he was told by the family.
Digging through the maze of hearsay information is what a professional technician does every day. Explaining firsthand can reduce the chances of the information being skewed by someone else's explanations. But you know, people are still going to interpret what anyone says into what they thought they heard.
So, the next time someone tells you something, and it just doesn't sound right, find out for yourself first hand, just to be on the safe side. That secondhand information may not be as truthful as you think.
I had one last week that had a leaking A/C compressor. Be it, a slight leak but a leak for sure. I told the guy it would work great until enough refrigerant and oil leaked out of the compressor seals.
This guy then calls his wife (in the lobby) and tells her, "The compressor is fine, he just checked it out... that last guy didn't know what he was talking about. It doesn't need changed, it's fine."
and ya wonder where I get the ideas for the next articlescool.gif.... geee... just go to work, they will come. LOL cool.gif
      Matt Fanslow welcomes mobile diagnostic technician Rich Falco to explore the intriguing parallels between poker strategies and automotive diagnostics.
      Watch Full Video Episode Discussion on Poker (00:01:02) Evolution of Poker Strategies (00:02:22) Game Theory and Diagnostics (00:04:35) Common Misunderstandings (00:12:07) Real-World Diagnostic Scenarios (00:13:26) Electric Vehicle Training (00:15:46) Power Window Diagnosis (00:16:44) Poker Predictions (00:18:05) Understanding Poker Players (00:19:01) Reading Opponents (00:20:14) Experience in Diagnostics (00:22:03) The Importance of Training (00:23:22) Shop Culture Changes (00:26:09) Technology in Poker (00:30:21) AI and Diagnostics (00:31:08) Access to Training Resources (00:32:07) Young Technicians' Knowledge (00:33:05) Poker vs. Automotive Diagnostics (00:33:24)
      Episode 190 - Hacking Incidents and Protecting Client Information With Cavan Robinson of Vehlo
      Thanks to our Partners, AAPEX, NAPA TRACS, and Automotive Management Network Recorded at the 2024 ASTA Expo, Carm Capriotto introduces Ryan Ragan, the newly appointed executive director of the Automotive Service and Tire Alliance (ASTA). The discussion dives into Ryan's diverse background in non-profits, biomedical fields, healthcare, and international trade associations. Ryan shares his observations on the automotive industry's challenges, particularly technician turnover, and outlines his plans to enhance training programs and engage younger generations. Emphasizing the importance of face-to-face interactions and community outreach, Ryan aims to foster a strong, supportive network within the ASTA organization. Show Notes Watch Full Video Episode ASTA EXPO: https://astaexpo.com/ Importance of Face-to-Face Interactions (00:02:01) Ryan's Background (00:03:30) Challenges in the Automotive Industry (00:05:09) Youth Engagement Initiatives (00:06:54) Perceptions of Vocational Training (00:08:36) Industry Outreach (00:09:26) Millennials and Career Paths (00:12:46) Future Plans for the Association (00:14:24) Transparency in the Automotive Industry (00:15:09) Military Background Impact (00:17:23) Observations from ASTA Expo (00:18:07) Member Engagement and Feedback (00:19:42)
      Thanks to our Partners, AAPEX, NAPA TRACS, and Automotive Management Network Set your sights on Las Vegas in 2024. Mark your calendar now … November 5th-7th, 2024. AAPEX - Now more than ever. And don’t miss the next free AAPEX webinar. Register now at http://AAPEXSHOW.COM/WEBINAR NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Get ready to grow your business with the Automotive Management Network: Find on the Web at http://AftermarketManagementNetwork.com for information that can help you move your business ahead and for the free and informative http://LaborRateTracker.com Connect with the Podcast: -The Aftermarket Radio Network: https://aftermarketradionetwork.com -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on X: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix – Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O’Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/             Click to go to the Podcast on Remarkable Results Radio
      Thanks to our Partners, Shop Boss, and 360 Payments Recorded at the ASTA Expo, Gerard Tonno from NAPA Autotech discusses being an "automotive Einstein." He emphasizes the importance of critical thinking, passion for auto repair, and effective use of resources and tools in diagnostics. He highlights the necessity of understanding basic electrical principles, conducting thorough visual inspections, and practicing with diagnostic tools. Gerard Tonno, NAPA Autotech Training Show Notes: Watch Full Video Episode ASTA EXPO: https://astaexpo.com/ NAPA Autotech: https://www.napaautotech.com/learn Thoughts on Being an Automotive Einstein (00:00:28) The Importance of Passion (00:02:03) Utilizing Online Resources (00:02:54) Visual Inspection Skills (00:04:34) Foundational Knowledge in Electricity (00:05:41) Understanding Pinpoint Tests (00:06:43
      Shop Boss – Shop Management Software built by shop owners for shop owners. It works the way you need it to, right out of the box. Find on the web at https://shopboss.net Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/             Click to go to the Podcast on Remarkable Results Radio
