1 member has voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
The growth of the Internet has changed the way many places do business and has certainly effected the automotive service industry as well. Much of Internet technology is good, allows information to be readily available, streamlines information and workflow. Before I came back to automotive service I spent 10 years working in web based software development, so I think all of this is a good thing. What I don't like is the business model that most automotive parts manufacturers have adopted. If I simply google most part numbers I get from local suppliers I can get them cheaper online through places like Amazon and Rockauto. There are a few serious offenders like Gates, Standard Motor, Dorman ect. Most times I can find these products significantly cheaper in terms of my cost than my stocking suppliers. Now here is the issue, I don't think that my price is to high, I think the Internet price is to low. I understand that there is value added to a local supplier. Parts are in stock, there are operational and carrying costs, all which add value and cost to the local supplier. What I don't like is that large manufacturers don't support this segment of their customer base. There should be minimum retail pricing that the manufacturer allows which should be no less than the jobber price recommended by the manufacturer, it would be great if it were something like 10% over jobber. This would protect supply chain and the aftermarket service shops while still allowing the DIY to buy off the Internet. Its a hard sell at times when we're making slim margins on parts but the customer looks online, sees a price and thinks we're screwing them. Case in point, TCK271 Gates T-belt kit, cost me $144, list is $362, Amazon sells this for $92 shipped! I sell to the customer for $217, the lowest I can go without slitting my wrists.
How do you deal with this problem, how often do you run into it?
The way I handle it is to not install a customer provided part. In the end you are responsible for the part regardless. say no warranty if it comes down to it in a court you are indeed liable. Weed out the bottomfeeders and thrive. fyi I will put on ppls wipers or install there bulbs but at no cost but brake pads, timing belts or anything else nope.
You are right, I don't remember where but I was reading just recently that regardless of your statement and the customer's acceptance that there is no warranty, any court will hold you to an "implied warranty." Basically according to the article it comes down to you charged the customer to XXX. The customer paid you to do XXX. The customer is entitled to "fair value" of XXX. Now as I read it that only applies to your workmanship and when yo install their part you are accepting it as viable and that becomes part of your workmanship as it is your professional assessment that the part is proper. Now in Michigan we do not have to provide a warranty and if we do it must be in writing on the work order in order for it to be enforceable. But this does not absolve a shop of responsibility to a customer to provide fair value in that if you installed a water pump and it leaked on the hoist then you have to do it again at no charge. If it starts leaking three months later, well then it's their baby and they get to hassle with the part supplier, unless you screwed up and didn't tighten a hose clamp, clean the gasket surface right or such.
IF I install customer supplied parts I have it on the work order and they initial by it that I only warrant my labor for the initial installation was done properly and according to the vehicle manufacturer's guidelines. The statement also spells out, in no uncertain terms that if the part fails after they leave the shop that there is no warranty expressed or implied regarding the part and associated labor to replace the part should it prove defective in the future. It probably would not stand up in court, but at least the judge should see that the customer knew and understood that they were accepting the risk of a faulty part. Typically I charge a higher labor rate and that drives these people away. I have however secured a few good customers by accepting their customer supplied part job when they thought they could do it but then decided it was wiser to have someone else do it. I respect people who want to do it themselves for the satisfaction, especially when they identify their limitations and stop before they make a bigger problem. The ones I have zero respect for are the one who want to get the part themselves because it's cheaper. Even had one guy ask me, "Well I'm gonna get it at NAPA, same place you do so why can't I get it and have you install it and save some money?" I told him I would be delighted to install his part, but the labor would be $ZZZ instead of $XXX. He decided he didn't like my attitude. He didn't like my attitude that I am in business to serve people who value my services, professionalism, integrity, dedication and expertise. People who value me enough to trust me to select the right parts, do the job the right way, and charge the right price for the quality and so I will still be in business next year when they need more service. Yep he didn't like my attitude. Fine, I didn't like his "You're charging me too much because I can screw it up cheaper than if you do it right" attitude either.
My issue here is not the customer bringing parts to me. We deal with that in a different way, I usually simply ask them if they would bring eggs to a diner. The issue at hand is one of customer perspective. If a customer leaves and googles parts on their bill, or is just interested and has done so before hand and see that the price I charge them is 2 or three times what they can buy it for online, they believe that I must have gotten a better price than the online price, since I'm in the industry. They then think that I screwed them. That is the problem.
Exactly of course a steak is cheaper at the store then the resturaunt but you cannot bring your owm. Im the same way you cant bring your own. Im nice in the way i present it ususally but I refuse to do it. Its the way I choose to do it. Is it correct? Its all a matter of opinion. Same with giving quotes over the phone I refuse to do it cause I know I cannot give an accurate $ I may give a ball park but I am not going to low ball it get it in tear it down and call with 1k more needed. After a while we have weeded out the bottom feeders and its allowed me to give better service to the better customers. When times were slow we were not and I am happy about that.
This problem has become bigger for us in San Diego. We get it regularly. The only real way I see to solve this issue is Labor rates have to increase to compensate for the loss of profit. My parts profit has gone down 5% over the past two - three years because of this (and with the parts companies increasing their costs.) I really feel like the parts companies aren't thinking ahead with their philosophy and if many auto repair shops go out of business they are going to take a hit, although their have been many parts companies that have gone out of business already.
I think the smart shop owners will do what they have to in order to survive and labor rates will increase naturally as a result, as our parts profits decrease. It's harder for a customer to justify labor rate than it is for them to justify why your part you sold them is $90 less online, same brand. etc. This is how plumbers, electricians, and others get away with charging more per hour than many of us do. I have been slowly ratcheting up my labor rate with very little squawking. However, raise your parts prices to your customers and watch the complaints start.
Now matter how you slice it and dice it at the end of the month we need to be profitable. Next time somebody complains about part prices I'm going to try moving the part profit over to labor and see what happens.
      April 15th is behind us — but your tax strategy shouldn’t stop there. In this episode, Hunt Demarest, CPA at Paar Melis, shares exactly what auto repair shop owners need to be doing based on how their tax season wrapped up. Whether you filed early, waited until the last minute, or punted with an extension, Hunt helps you take the right steps now to avoid penalties, reduce next year’s bill, and keep your shop’s finances dialed in.
       In this episode, you’ll learn:
      Why filing an extension isn’t always a problem — but failing to plan ahead is The costly myth about tax extensions that trips up even seasoned shop owners What to do now if you owed a big tax bill or got a refund The IRS’s rules on estimated taxes and why ignoring them leads to penalties Smart financial habits every shop owner should adopt after tax season ends
      Bonus Episode - Creating Chaos Through Impulsive Business Decisions With Tannar and Kassiady Markham
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Mauro Stara from 6packceo.com shares powerful strategies for staying strong, sharp, and energized as a business owner. He breaks down common myths about health and highlights the importance of a personalized approach to well-being. Key areas of focus include the essential roles of sleep, nutrition, and stress management in promoting longevity and a high-quality life.
      Mauro offers practical tips for optimizing sleep by aligning with your circadian rhythm, managing light exposure, timing meals strategically, and maintaining proper electrolyte balance. He encourages listeners to treat their health like they would their car, prioritizing regular care and attention to ensure a longer, more energized life.
      Show Notes Watch Full Video Episode The Institute of Automotive Business Excellence: https://www.wearetheinstitute.com/ Overview of Dr. Jessica Kriegel (00:00:00) Three-Step Change Equation (00:02:47) Accountability in Business (00:03:31) Results Pyramid Explanation (00:04:11) Beliefs and Experiences (00:05:09) Defining Workplace Culture (00:06:50) Hospital Story for Illustration (00:12:02) Transformative Change Through Storytelling (00:14:09) Culture of Caring (00:15:09) Storytelling in Meetings (00:15:58) Generational Dynamics (00:17:51) Technology Adoption Across Generations (00:20:37) Connecting with Dr. Kriegel (00:22:23)
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Get ready to grow your business with the Automotive Management Network: Find on the Web at http://AftermarketManagementNetwork.com for information that can help you move your business ahead and for the free and informative http://LaborRateTracker.com Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/         Click to go to the Podcast on Remarkable Results Radio
      Episode 213 - Navigating The Family Business With Joseph Schindler
      Check out their podcast here: https://autorepairmarketing.captivate.fm/ If you would like to join their private Facebook group go here: https://www.facebook.com/groups/autorepairmarketingmastermindIn
      In this episode of "The Weekly Blitz," host Chris Cotton is joined by special guests Caroline Legrone and Kim Walker from Shop Marketing Pros to delve into the critical necessity of having a robust marketing plan for auto repair shops. The discussion centers around the pivotal role that a well-structured marketing strategy plays in the success and sustainability of these businesses.
      Chris, Caroline, and Kim explore the multifaceted aspects of marketing planning, emphasizing the importance of leveraging historical data to gain insights into the business's performance over time. By analyzing this data, shop owners can pinpoint slow periods and develop proactive marketing strategies that align with local events and seasonal trends, thereby optimizing their outreach efforts.
      Caroline Legrone underscores the significance of understanding past performance metrics, which can provide invaluable information for future planning. She explains how historical data can reveal patterns and trends that are crucial for making informed marketing decisions. This approach not only helps in identifying potential challenges but also in capitalizing on opportunities that may arise.
      Kim Walker, on the other hand, offers practical insights into the creation of a comprehensive marketing calendar. She shares her expertise on how to systematically plan marketing activities throughout the year, ensuring that the shop remains visible and engaged with the community. Kim's advice includes tips on scheduling promotions, aligning campaigns with local happenings, and maintaining a consistent presence across various marketing channels.
      Throughout the episode, the conversation is geared towards empowering shop owners to take control of their marketing efforts. By doing so, they can ensure sustained growth and foster stronger community engagement, even during traditionally slow periods. The episode serves as a call to action for auto repair shop owners to prioritize their marketing strategies, highlighting the long-term benefits of a well-executed plan.
      Introduction and Importance of Marketing (00:00:09)
      Chris Cotton introduces the episode and emphasizes the need for a marketing plan in auto repair businesses.
      Guest Introductions (00:01:11)
      Chris welcomes Caroline Legrone and Kim Walker from Shop Marketing Pros to the podcast.
      Discussion on Car Count Issues (00:01:48)
      Chris expresses concern over shop owners complaining about low car counts and the lack of planning.
      Identifying Seasonal Trends (00:02:32)
      Kim discusses common excuses for slow periods and the importance of recognizing seasonal trends.
      Understanding the Marketing Calendar (00:04:23)
      Caroline explains the significance of analyzing past performance to create an effective marketing calendar.
      Proactive Marketing Strategies (00:06:11)
      Kim shares insights on developing marketing plans based on historical data and identifying slow periods.
      Creative Marketing Solutions (00:07:25)
      Kim describes a unique marketing strategy developed around the local state fair to attract customers.
      Importance of Planning Ahead (00:09:27)
      Kim emphasizes the necessity of proactive planning rather than reacting to slow days.
      Timing for Event Promotions (00:12:30)
      Discussion on how far in advance to plan marketing strategies for events like the state fair.
      Community Calendar Considerations (00:14:09)
      Caroline advises checking community calendars to align marketing efforts with local events.
      Adjusting Marketing Budgets (00:16:19)
      Kim discusses the importance of reallocating marketing budgets based on seasonal trends.
      Applicability to Different Locations (00:16:27)
      Chris challenges the notion that marketing strategies are only relevant to local events, encouraging broader application.
      Yearly Planning for Marketing (00:17:09)
      Caroline stresses the importance of yearly planning for marketing strategies, even if starting late.
      Setting Holiday Schedules (00:18:49)
      Chris shares his approach to planning marketing around holiday closures as a starting point for the year.
      Here are the extracted timestamps and their corresponding titles from the podcast episode transcription segment:
      Importance of Planning (00:19:14)
      Chris emphasizes the need for shop owners to have a structured marketing plan.
      Blocking Time for Planning (00:19:40)
      Kim advises shop owners to set aside undistracted time in October for planning.
      Using a Big Calendar (00:20:17)
      Kim suggests using a large calendar to visualize important dates and events affecting marketing.
      Analyzing Performance Data (00:22:25)
      Kim discusses breaking down historical data to identify busy and slow times for better planning.
      Setting Realistic Goals (00:24:20)
      Caroline stresses the importance of setting achievable marketing goals based on past performance.
      Understanding Marketing Budgets (00:26:17)
      Kim explains how to determine an appropriate marketing budget based on desired growth.
      Plan with the Pros Conference (00:28:49)
      Caroline introduces the "Plan with the Pros" event aimed at helping shop owners create marketing plans.
      Event Success and Expansion (00:31:01)
      Kim shares the success of last year's event and plans for expanding this year's attendance.
      Facebook Group for Marketing Support (00:33:15)
      Caroline details the Auto Repair Marketing Mastermind group for shop owners to connect and share insights.
      Final Thoughts on Marketing (00:37:02)
      Caroline encourages shop owners to create marketing calendars and utilize available resources for success.
      Do It Scared (00:37:51)
      Encouragement to start marketing despite fears of making mistakes or not knowing how to begin.
      Getting Started (00:38:11)
      Emphasis on taking action; "done is better than perfect" and scheduling time away from the shop.
      Perspective on Fear (00:38:22)
      Discussion on the urgency of creating a marketing calendar to avoid business decline.
      Final Thoughts and Thanks (00:38:41)
      Closing remarks and encouragement to utilize marketing pros for effective growth strategies.
      Sponsorship Shout-Out (00:39:11)
      Promotion of Shop Marketing Pros as the recommended marketing partner for auto repair businesses.
      Closing Remarks (00:39:11)
      Encouragement to maintain a positive mindset and a farewell from Coach Chris Cotton.
