1 member has voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
The growth of the Internet has changed the way many places do business and has certainly effected the automotive service industry as well. Much of Internet technology is good, allows information to be readily available, streamlines information and workflow. Before I came back to automotive service I spent 10 years working in web based software development, so I think all of this is a good thing. What I don't like is the business model that most automotive parts manufacturers have adopted. If I simply google most part numbers I get from local suppliers I can get them cheaper online through places like Amazon and Rockauto. There are a few serious offenders like Gates, Standard Motor, Dorman ect. Most times I can find these products significantly cheaper in terms of my cost than my stocking suppliers. Now here is the issue, I don't think that my price is to high, I think the Internet price is to low. I understand that there is value added to a local supplier. Parts are in stock, there are operational and carrying costs, all which add value and cost to the local supplier. What I don't like is that large manufacturers don't support this segment of their customer base. There should be minimum retail pricing that the manufacturer allows which should be no less than the jobber price recommended by the manufacturer, it would be great if it were something like 10% over jobber. This would protect supply chain and the aftermarket service shops while still allowing the DIY to buy off the Internet. Its a hard sell at times when we're making slim margins on parts but the customer looks online, sees a price and thinks we're screwing them. Case in point, TCK271 Gates T-belt kit, cost me $144, list is $362, Amazon sells this for $92 shipped! I sell to the customer for $217, the lowest I can go without slitting my wrists.
How do you deal with this problem, how often do you run into it?
The way I handle it is to not install a customer provided part. In the end you are responsible for the part regardless. say no warranty if it comes down to it in a court you are indeed liable. Weed out the bottomfeeders and thrive. fyi I will put on ppls wipers or install there bulbs but at no cost but brake pads, timing belts or anything else nope.
You are right, I don't remember where but I was reading just recently that regardless of your statement and the customer's acceptance that there is no warranty, any court will hold you to an "implied warranty." Basically according to the article it comes down to you charged the customer to XXX. The customer paid you to do XXX. The customer is entitled to "fair value" of XXX. Now as I read it that only applies to your workmanship and when yo install their part you are accepting it as viable and that becomes part of your workmanship as it is your professional assessment that the part is proper. Now in Michigan we do not have to provide a warranty and if we do it must be in writing on the work order in order for it to be enforceable. But this does not absolve a shop of responsibility to a customer to provide fair value in that if you installed a water pump and it leaked on the hoist then you have to do it again at no charge. If it starts leaking three months later, well then it's their baby and they get to hassle with the part supplier, unless you screwed up and didn't tighten a hose clamp, clean the gasket surface right or such.
IF I install customer supplied parts I have it on the work order and they initial by it that I only warrant my labor for the initial installation was done properly and according to the vehicle manufacturer's guidelines. The statement also spells out, in no uncertain terms that if the part fails after they leave the shop that there is no warranty expressed or implied regarding the part and associated labor to replace the part should it prove defective in the future. It probably would not stand up in court, but at least the judge should see that the customer knew and understood that they were accepting the risk of a faulty part. Typically I charge a higher labor rate and that drives these people away. I have however secured a few good customers by accepting their customer supplied part job when they thought they could do it but then decided it was wiser to have someone else do it. I respect people who want to do it themselves for the satisfaction, especially when they identify their limitations and stop before they make a bigger problem. The ones I have zero respect for are the one who want to get the part themselves because it's cheaper. Even had one guy ask me, "Well I'm gonna get it at NAPA, same place you do so why can't I get it and have you install it and save some money?" I told him I would be delighted to install his part, but the labor would be $ZZZ instead of $XXX. He decided he didn't like my attitude. He didn't like my attitude that I am in business to serve people who value my services, professionalism, integrity, dedication and expertise. People who value me enough to trust me to select the right parts, do the job the right way, and charge the right price for the quality and so I will still be in business next year when they need more service. Yep he didn't like my attitude. Fine, I didn't like his "You're charging me too much because I can screw it up cheaper than if you do it right" attitude either.
My issue here is not the customer bringing parts to me. We deal with that in a different way, I usually simply ask them if they would bring eggs to a diner. The issue at hand is one of customer perspective. If a customer leaves and googles parts on their bill, or is just interested and has done so before hand and see that the price I charge them is 2 or three times what they can buy it for online, they believe that I must have gotten a better price than the online price, since I'm in the industry. They then think that I screwed them. That is the problem.
Exactly of course a steak is cheaper at the store then the resturaunt but you cannot bring your owm. Im the same way you cant bring your own. Im nice in the way i present it ususally but I refuse to do it. Its the way I choose to do it. Is it correct? Its all a matter of opinion. Same with giving quotes over the phone I refuse to do it cause I know I cannot give an accurate $ I may give a ball park but I am not going to low ball it get it in tear it down and call with 1k more needed. After a while we have weeded out the bottom feeders and its allowed me to give better service to the better customers. When times were slow we were not and I am happy about that.
This problem has become bigger for us in San Diego. We get it regularly. The only real way I see to solve this issue is Labor rates have to increase to compensate for the loss of profit. My parts profit has gone down 5% over the past two - three years because of this (and with the parts companies increasing their costs.) I really feel like the parts companies aren't thinking ahead with their philosophy and if many auto repair shops go out of business they are going to take a hit, although their have been many parts companies that have gone out of business already.
I think the smart shop owners will do what they have to in order to survive and labor rates will increase naturally as a result, as our parts profits decrease. It's harder for a customer to justify labor rate than it is for them to justify why your part you sold them is $90 less online, same brand. etc. This is how plumbers, electricians, and others get away with charging more per hour than many of us do. I have been slowly ratcheting up my labor rate with very little squawking. However, raise your parts prices to your customers and watch the complaints start.
Now matter how you slice it and dice it at the end of the month we need to be profitable. Next time somebody complains about part prices I'm going to try moving the part profit over to labor and see what happens.
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network This episode focuses on the importance of planning ahead for selling a business in the auto repair industry. Bob Ward stresses that business owners should start identifying and training potential successors early—often from their current team. He walks through a clear four-step process to help with the transition, covering key areas like finding the right fit, determining the business’s value, securing financing, and handling legal requirements. Bob Ward, Perpetual Business, Bob’s Previous Episode HERE. Bob Ward’s Email: [email protected] Show Notes Watch Full Video Episode TST Big Event, March 29th, 2025: https://www.tstseminars.org/ Bob Ward's Ownership Essentials Class April 10-12, Phoenix, AZ: https://perpetualbusiness.co/product/ownership-essentials-phoenix-2025 Importance of Succession Planning (00:00:00) Challenges of Retirement (00:02:23) Value of Transitioning Ownership (00:03:23) Procrastination in Planning (00:05:01) Family Involvement in Succession (00:06:08) Role of Key Employees (00:07:30) Facilitating Ownership Transition (00:08:01) Four Steps to Succession (00:08:27) Retention Strategies (00:10:30) Equity Equivalence Concept (00:11:08) Managing Ownership Changes (00:12:53) Successor Responsibilities (00:15:09) Financing the Purchase (00:16:31) Process Simplification (00:17:31 Successor Concerns (00:21:53) Owner's Perspective on Successors (00:22:22) Missed Opportunities in Succession (00:22:49) Financial Realities for Successors (00:23:14) Perpetual Business Concept (00:28:39) Compatibility Assessment Importance (00:32:57) Essential Career Goals Discussion (00:34:11) Overcoming Fear of Ownership (00:36:40) Identifying the Right Successor (00:37:19) Valuation Metrics Discussion (00:39:36)
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Get ready to grow your business with the Automotive Management Network: Find on the Web at http://AftermarketManagementNetwork.com for information that can help you move your business ahead and for the free and informative http://LaborRateTracker.com Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/         Click to go to the Podcast on Remarkable Results Radio
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network This episode covers the critical role and impact of AI on marketing, the importance of persona marketing, and effective branding strategies. Learn about "watering holes," referring to identifying where potential customers spend their time online and offline, and how to effectively use persona marketing to target specific demographics. Dan stresses the importance of branding and community involvement, asserting that successful shops prioritize building brand recognition and relationships within their local areas. He also warns about trusting AI implicitly, referencing instances of AI being inaccurate. Dan Vance, Shop Dog Marketing.com Show Notes Watch Full Video Episode TST Big Event, March 29th, 2025: https://www.tstseminars.org/ Shop Dog Marketing at Shop Dog Marketing.com. "Want to see your auto repair shop thrive? Let Shop Dog Marketing be your guide. Our customer-first approach, combined with AI-driven creative content, ensures top rankings. Introduction to the Episode (00:00:00) AI in Marketing (00:01:02) The Importance of Networking (00:02:02) Consumer Behavior and Marketing (00:04:04) Bullet Points vs. Detailed Content (00:05:54) Creating Memorable Customer Experiences (00:06:32) Identifying Customer "Watering Holes" (00:08:29) Privacy Concerns in Marketing (00:09:41) The Rise of Persona Marketing (00:10:55) AI's Impact on Search Results (00:11:59) The Role of AI in Marketing Strategies (00:13:08) Caution with AI Information (00:14:12) Human Element in Marketing (00:17:34) Client Review Analysis (00:18:46) Women’s Expectations in Service (00:21:20) Impact of Professional Image (00:22:57) Targeting Ideal Customers (00:25:12) Purposeful Marketing Strategies (00:25:43) The Need for Customer Understanding (00:26:26) AI’s Role in Content Creation (00:28:07) Changing Landscape of AI (00:28:29) User Behavior and Decision Making (00:31:11) Branding in the Automotive Industry (00:31:55) Community Involvement for Branding (00:32:57) Conclusion and Call to Action (00:34:38)
      Thanks to our Partners, NAPA TRACS, and Today's Class Recorded at the 45th annual Mobile Air Climate Systems Conference (MACS 2025) in Orlando, Florida, this episode dives into the evolving world of thermal management in vehicles. Our panel discusses the shift from traditional air conditioning to a more advanced approach, driven by the growing complexity of modern vehicles, especially EVs. They explore why maintaining optimal temperatures for batteries, electric motors, and other components is just as critical as passenger comfort. The conversation also covers alternative refrigerants, particularly blends, as a way to boost efficiency, reduce environmental impact, and adapt to changing battery technologies. With these advancements, the need for technician training and industry adaptation is greater than ever. Our experts emphasize the importance of collaboration across the industry to ensure a smooth transition and deliver effective solutions for both OEMs and aftermarket service providers.
      Adam Kimmel, Koura, [email protected] Ryan Kooiman, Director of Training, Standard Motor Products. Ryan’s previous episodes HERE. Chuck Abbott, Global Marketing Manager, Koura Show Notes Watch Full Video Episode MACS Training Event & Trade Show: https://macsmobileairclimate.org/ National Automotive Service Task Force (NASTF): https://wp.nastf.org/ Koura: https://www.kouraglobal.com/ Honeywell: https://www.honeywell.com/us/en Introduction and Sponsors (00:00:00) Evolution of Thermal Management (00:02:28) Consultative Role of Shop Owners (00:02:10) Rise of Thermal Management Specialists (00:03:08) Importance of Battery Temperature Control (00:03:46) Impact of Electric Compressors (00:05:45) Training on Thermal Management (00:12:19) Future of Refrigerants (00:09:52) Concerns with Flammable Refrigerants (00:11:04) Thermal Management in Electric Vehicles (00:14:04) Training Demand for Electric Vehicle Systems (00:15:26) Battery Chemistry and Future Developments (00:17:02) Shifting Priorities in Funding (00:18:27) Changing Thermal Management Needs (00:18:57) Service Recommendations for Blends (00:19:18) Collaboration in Industry (00:19:58) New Components in AC Systems (00:20:50) Complexity of Thermal Management Systems (00:22:15) Career Opportunities in Automotive Technology (00:23:06) Investing in New Refrigerant Machines (00:24:30) Consumer Benefits of Blend Refrigerants (00:25:05) Leakage Characteristics of Blends (00:26:14) Future of Refrigerant Machines (00:27:35) Importance of Thermal Management Knowledge (00:29:02) Final Thoughts on Education and Collaboration (00:32:57)
      Thanks to our Partner, NAPA TRACS NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Thanks to our Partner, Today's Class Optimize training with Today's Class: In just 5 minutes daily, boost knowledge retention and improve team performance. Find Today's Class on the web at https://www.todaysclass.com/ Connect with the Podcast: -The Aftermarket Radio Network: https://aftermarketradionetwork.com -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on X: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/
