Not sure if anyone here uses or used the Compnine site. But it is back up
Compnine
it is great for viewing build sheets for vehicles with the RPO sheets removed or damaged. it is cheap and a great tool in the automotive world.
Great for finding fuel tank sizes,build dates (for those painted over stickers), suspension packages, assembly plant location, brake packages (lovely GMT 800 trucks).
only $25 a month for 300 searches, cant beat that. Beats waiting for your dealer if they are busy......
Here are the results for my truck
Vehicle: JIMMY 4 DR
Year: 1998
Build Date: 1997-11-13
UN0 RADIO,AM/FM,STEREO,SEEK/SCAN,COMPACT DISC,AUTO TONE,CLOCK,ETR STEREO W/CD PLAYER(UN0)
UP8 RADIO,PROVISIONS FOR STEREO INSTRUMENTATION STEREO RDO PROVISIONS(UP8)
U16 TACHOMETER,ENGINE TACH(U16)
U73 ANTENNA,FIXED FIXED ANT(U73)
U89 WIRING HARNESS,5-WIRE TRAILER 5 WIRE TRLR HARN(U89)
VXS VEHICLE - COMPLETE
V54 CARRIER,ROOF LUGGAGE(PAINTED) PAINTED RF LUGG CARR(V54)
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
WDV WARRANTY WAIVER - PARTIAL DEDUCTIBLE
XBG TIRE FRONT P235/70R15 WOL R/PE ST TL ALS 102S TIRE(XBG)
YBG TIRE REAR P235/70R15 WOL R/PE ST TL ALS 102S TIRE(YBG)
YC5 DECOR PACKAGE,COMFORT AND CONVENIENCE,#5 (MID LEVEL) DECOR PKG #5(YC5)
YD3 AXLE FRONT (BASE EQUIP) FOR SCHEDULING GVW PLATE FRT AXLE(YD3)
YD5 SPRING,FRONT(BASE EQUIPMENT) FRT SPRING(YD5)
YD6 SPRING,REAR(BASE EQUIPMENT) RR SPRING(YD6)
ZBG TIRE SPARE P235/70R15 WOL R/PE ST TL ALS 102S SPARE TIRE(ZBG)
ZM8 PACKAGE,ELECTRIC TAILGATE RELEASE AND REAR DEFOGGER ELEC T/GATE REL & RR DEFG PKG(ZM8)
ZQ3 DRIVER CONVENIENCE PACKAGE II(MERCHANDISING OPTION) DRVR CONVENIENCE PKG(ZQ3)
ZQ6 DRIVER CONVENIENCE PACKAGE III DRVR CONVENIENCE PKG III(ZQ6)
ZW7 CHASSIS PACKAGE,PREMIUM SMOOTH RIDE PREMIUM SMOOTH RIDE CHAS PKG(ZW7)
ZY1 COLOR COMBINATION SOLID SOLID PAINT COMBO(ZY1)
Z88 GMC TRUCK G M C(Z88)
1SE PACKAGE OPTION 05 (1SE)
1SZ PACKAGE OPTION- (1SZ)
12H TRIM COMBINATION CLOTH, GRAPHITE (12H)
12I INTERIOR TRIM GRAPHITE (12I)
41U EXTERIOR COLOR,PRIMARY (41U)
EXTERIOR COLOR,PRIMARY,BLACK (41U)
6WH COMPONENT FRT LH COMPUTER SEL SUSP (6WH) SUSP(6WH)
7WH COMPONENT FRT RH COMPUTER SEL SUSP (7WH) SUSP(7WH)
AG1 ADJUSTER FRT ST POWER, MULTI-DIRECTIONAL, DRIVER MULTI-DIRECTIONAL PWR D/SEAT ADJR(AG1)
AJ1 GLASS,DEEP TINT(REAR SIDE WINDOWS AND REAR DOOR WINDOW) DEEP TINTED GLS(AJ1)
AP9 NET,CONVENIENCE CONVENIENCE NET(AP9)
AU0 LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYSTEM) REMOTE ENTRY LK CONT(AU0)
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)
AV5 FRONT HIGH BACK BUCKET SEAT FRT HIGH BACK BKT ST(AV5)
AXP VIN IDENT POSITION, MULTI- PURPOSE VEHICLE MULTI-PURPOSE VEHICLE VIN POSITION(AXP)
A31 WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31)
WINDOW,POWER OPERATED,ALL DOORS PWR WINDOWS(A31)
A78 ADJUSTER,FRT ST BK MAN RECLINING,PASSENGER AND DRIVER MAN RECL ST BACK ADJR(A78)
B30 CARPET,FLOOR AND WHEELHOUSE FLR CPT(B30)
B84 ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING BODY SI MLDG(B84)
C25 WIPER SYSTEM,REAR WINDOW RR WDO WPR(C25)
C3T GVW RATING 5350 LBS 5350 GVWR(C3T)
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60)
DAY PLANT CODE MORAINE, OH, GM T&B MORAINE,OH PLANT CODE(DAY)
DD8 MIRROR,INSIDE,REARVIEW,TILT,AUTOMATIC,LIGHT SENSITIVE I/S RR VIEW MIR,LIGHT SENSITIVE(DD8)
DH2 MIRROR,INSIDE, ILLUMINATED,LH & RH,WITH DUAL SUNSHADE ILLUM S/S MIR(DH2)
DK2 MIRROR,OUTSIDE,RH & LH REMOTE CONTROL,ELECTRIC,LH DEFOG(PAINTED) ELEC R/CON HTD PAINTED O/S MIR(DK2)
DK6 CONSOLE,ROOF RF CNSL(DK6)
D07 CONSOLE,FRONT COMPARTMENT FLOOR(CUSTOM) CUSTOM F/CMPT FLR CNSL(D07)
EVA TEST DVT, EVAP EMISSION REQUIREMENT EVAP EMISSIONS REQUIRED(EVA)
E55 GATE,END END GATE(E55)
FF6 ARM,TORSION BAR SPRING ADJUST,LH TORS BAR ADJ ARM(FF6)
FF7 ARM,TORSION BAR SPRING ADJUST,RH TORS BAR ADJ ARM(FF7)
GU6 AXLE,REAR,3.42 RATIO 3.42R(GU6)
JC1 BRAKE VAC POWER, 4 WHL DISC, 5,500 LBS BRAKE VAC PWR(JC1)
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
K60 GENERATOR,100 AMPERE 100 AMP(K60)
L35 ENGINE,4.3L(4.3W),CPI,V6,90 DEG 4.3W(L35)
M30 TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC 4-SPD A/TRANS(M30)
NB7 EMISSION SYSTEM CALIFORNIA, TLEV TLEV CALIF EMIS(NB7)
NG1 EMISSION CERTIFICATION,GEOGRAPHICALLY RESTRICTED CERTIFICATION RESTRICTED EMIS CERTIFICATION(NG1)
NP1 TRANSFER CASE,ELECTRONIC SHIFT,TWO SPEED ELEK SHFT TRFER CASE(NP1)
NP5 STEERING WHEEL,LEATHER WRAPPED LEATHER WRAPPED STRG WHL(NP5)
N33 STEERING COLUMN,TILT TYPE TILT STRG COL(N33)
N40 STEERING,HYDRAULIC(NON-VARIABLE) NON-VARIABLE P/S(N40)
N90 WHEEL,15X7(CAST ALUMINUM) AL WHL(N90)
QBG TIRE ALL P235/70R15 WOL R/PE ST TL ALS 102S TIRE(QBG)
RSA RESTRAINT - FRT SEAT, 208, AUTO, PASSIVE
RYJ COVERING,CARGO AREA,RETRACTABLE RETRACTABLE CARGO CVR(RYJ)
R8W CONTROL - SALES ITEM NO. 72
R9Z CONTROL - SALES ITEM NO.100
SLL SOLD ORDERS SOLD ORDER(SLL)
TFE SALES INCENTIVE - COMMITMENT PLUS
T61 LIGHTING,DAYTIME RUNNING DAYTIME RUNNING LGT(T61)
Edited by FxsX24
      Alex Saladna, WickedFile
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network This episode covers the critical role and impact of AI on marketing, the importance of persona marketing, and effective branding strategies. Learn about "watering holes," referring to identifying where potential customers spend their time online and offline, and how to effectively use persona marketing to target specific demographics. Dan stresses the importance of branding and community involvement, asserting that successful shops prioritize building brand recognition and relationships within their local areas. He also warns about trusting AI implicitly, referencing instances of AI being inaccurate. Dan Vance, Shop Dog Marketing.com Show Notes Watch Full Video Episode TST Big Event, March 29th, 2025: https://www.tstseminars.org/ Shop Dog Marketing at Shop Dog Marketing.com. "Want to see your auto repair shop thrive? Let Shop Dog Marketing be your guide. Our customer-first approach, combined with AI-driven creative content, ensures top rankings. Introduction to the Episode (00:00:00) AI in Marketing (00:01:02) The Importance of Networking (00:02:02) Consumer Behavior and Marketing (00:04:04) Bullet Points vs. Detailed Content (00:05:54) Creating Memorable Customer Experiences (00:06:32) Identifying Customer "Watering Holes" (00:08:29) Privacy Concerns in Marketing (00:09:41) The Rise of Persona Marketing (00:10:55) AI's Impact on Search Results (00:11:59) The Role of AI in Marketing Strategies (00:13:08) Caution with AI Information (00:14:12) Human Element in Marketing (00:17:34) Client Review Analysis (00:18:46) Women’s Expectations in Service (00:21:20) Impact of Professional Image (00:22:57) Targeting Ideal Customers (00:25:12) Purposeful Marketing Strategies (00:25:43) The Need for Customer Understanding (00:26:26) AI’s Role in Content Creation (00:28:07) Changing Landscape of AI (00:28:29) User Behavior and Decision Making (00:31:11) Branding in the Automotive Industry (00:31:55) Community Involvement for Branding (00:32:57) Conclusion and Call to Action (00:34:38)
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Get ready to grow your business with the Automotive Management Network: Find on the Web at http://AftermarketManagementNetwork.com for information that can help you move your business ahead and for the free and informative http://LaborRateTracker.com Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/         Click to go to the Podcast on Remarkable Results Radio
      Thanks to our Partners, NAPA TRACS, and Today's Class Recorded at the 45th annual Mobile Air Climate Systems Conference (MACS 2025) in Orlando, Florida, this episode dives into the evolving world of thermal management in vehicles. Our panel discusses the shift from traditional air conditioning to a more advanced approach, driven by the growing complexity of modern vehicles, especially EVs. They explore why maintaining optimal temperatures for batteries, electric motors, and other components is just as critical as passenger comfort. The conversation also covers alternative refrigerants, particularly blends, as a way to boost efficiency, reduce environmental impact, and adapt to changing battery technologies. With these advancements, the need for technician training and industry adaptation is greater than ever. Our experts emphasize the importance of collaboration across the industry to ensure a smooth transition and deliver effective solutions for both OEMs and aftermarket service providers.
      Adam Kimmel, Koura, [email protected] Ryan Kooiman, Director of Training, Standard Motor Products. Ryan’s previous episodes HERE. Chuck Abbott, Global Marketing Manager, Koura Show Notes Watch Full Video Episode MACS Training Event & Trade Show: https://macsmobileairclimate.org/ National Automotive Service Task Force (NASTF): https://wp.nastf.org/ Koura: https://www.kouraglobal.com/ Honeywell: https://www.honeywell.com/us/en Introduction and Sponsors (00:00:00) Evolution of Thermal Management (00:02:28) Consultative Role of Shop Owners (00:02:10) Rise of Thermal Management Specialists (00:03:08) Importance of Battery Temperature Control (00:03:46) Impact of Electric Compressors (00:05:45) Training on Thermal Management (00:12:19) Future of Refrigerants (00:09:52) Concerns with Flammable Refrigerants (00:11:04) Thermal Management in Electric Vehicles (00:14:04) Training Demand for Electric Vehicle Systems (00:15:26) Battery Chemistry and Future Developments (00:17:02) Shifting Priorities in Funding (00:18:27) Changing Thermal Management Needs (00:18:57) Service Recommendations for Blends (00:19:18) Collaboration in Industry (00:19:58) New Components in AC Systems (00:20:50) Complexity of Thermal Management Systems (00:22:15) Career Opportunities in Automotive Technology (00:23:06) Investing in New Refrigerant Machines (00:24:30) Consumer Benefits of Blend Refrigerants (00:25:05) Leakage Characteristics of Blends (00:26:14) Future of Refrigerant Machines (00:27:35) Importance of Thermal Management Knowledge (00:29:02) Final Thoughts on Education and Collaboration (00:32:57)
      Thanks to our Partner, NAPA TRACS NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Thanks to our Partner, Today's Class Optimize training with Today's Class: In just 5 minutes daily, boost knowledge retention and improve team performance. Find Today's Class on the web at https://www.todaysclass.com/ Connect with the Podcast: -The Aftermarket Radio Network: https://aftermarketradionetwork.com -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on X: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/
