Trust
It’s an important word; it’s one I hear a lot behind the counter at the repair shop. “I know you’ll treat me right, because I trust what you do.” Seems to be a common “comfort” word tossed around when people talk about different types of service work. I’ve always wondered how deep that level of comfort goes when it comes to solving unusual automotive problems, or when there is a communication breakdown. There’s also a level of trust the service provider has to gain too, keep in mind that trust goes both ways.
A new customer comes in the shop for some repair. They’ve been sent to the repair shop by someone they trust, such as a friend or another repair shop. This friend or repair shop has enough “trust” in my abilities, so they have no problem referring this new customer to me. But, there is still the trust that has to be built up with the new customer, and can the two of us communicate to a degree that we can get to the bottom of the trouble without any miss-communication?
This time it’s a 1985 Nissan 300z with more problems than you can shake a stick shift at. Not in the greatest condition, but for the most part it was all there. Some are cosmetic and not that serious, while some things need attention right now.
“I replaced a fuseable link with a piece of regular wire, and it will only run for about 5 minutes, and then the engine quits. Also, my wife moved the seat forward, and now it doesn’t move at all. So I need you to find out what’s wrong,” the 300z owner tells me.
I had a few questions to ask them of course, did the seat quit after, or before the fuse link blew? How do you start it once it dies? Do you have to jump it? Does it start right back up? Are there any other signs that the engine is about to die, like gauges, lights, or any rough running? All of which was described in enough detail that I “trusted” I was getting the right answers to form a hypothesis of what was going on.
The owner informed me the fuse link blew after the seat was moved, and the engine started acting up after he changed the fuse link. It sounded like a poorly fitting fuse link at this point. The next thing to do was to verify all of the information with a thorough examination of the car and the wiring diagrams. It all seemed to match the story.
By the next morning I had an estimate on the needed repairs and I got the job approved. First off… replace the non-fuse link wire with a proper one. The seat, well that was another issue. All the wires under the seat were green and rotted apart. The main positive lead was completely mangled and showed signs that it had arced across the bracket that originally held the wiring harness. One look over head explained all of the green gunk on the wires. It’s a T-top car, being an 85 model there’s no doubt that at one time or another the tops could have been off during a rain storm.
I replaced the fuseable link, and then removed the seat (not so easy since the seat doesn’t move and access to the bolts can be difficult). While I’m repairing the seat I might as well tackle the “run for 5 minutes and then stall” problem. The car ran perfectly for over two hours, while I repaired the leads to the seat and checked out the rest of the car. The only thing I saw that was a problem was the radiator cap had a cracked gasket, and as soon as the car warmed up the coolant started to leak out of the cap. Easy fix, just replace the cap.
All said and done… the car ran beautifully. I took it around the block a couple of times and didn’t find anything else serious enough to be concerned with. Oh, there’s more to do… but, it all can wait for a later date. I called the customer and told them I was done with it, and they could pick it up anytime they’d like.
Now, it’s no surprise to me that a 25+ year old car is going to have more problems. It’s not a new car, and with the experiences that I’ve had on these Z cars in the past I made sure the customer understood it as well.
The owner picked the car up the next day, and told me he had just bought the car for his wife. He also told me how much he appreciated the work I’ve done, but was concerned there was probably some major short (electrically) in the car that caused everything from the radiator cap to crack, to the seat stop working. About now, my “trust” of this guy’s original explanations of the problem is getting pretty thin. The more I tried to explain the two problems were not related the less “trust” he had in me… he “knew” it was a short. (Trust me… this guy didn’t have all four wheels on the ground.)
Usually when a customer starts to self-diagnose things a certain lack of trust starts to develop between the mechanic and the owner. This was no different. The next day I get a call from the wife. After driving a few miles the car died, then restarted, died, and restarted again. The original problem, the money they already spent, and the now “revised” problem was the topic of discussion.
“I don’t know who to trust… I think I need to find another mechanic who can find out what’s wrong with my car, or maybe I’m just going to sell it. Which do you think I should do?” You know, there’s a part of me that wants to tell him where to put this car, but then the sensible part of me says, “Bring it in, and I’ll look at “that” problem, and trust me… I can solve it now that I know the real issue.”
Several weeks later, they brought the car back, and a new fuel pump and filter took care of the problem.
Saying the wrong thing or being descriptive in the wrong way only leads to more confusion when it comes to car repair. (From both sides of the counter) There are so many factors in a car that can cause a problem and not being up front with the explanation only makes things worse.
I’ve changed my approach at the counter now. I don’t ask them, “So, what’s wrong with the car?” Instead, I ask them, “How did you arrive at the conclusion there’s something wrong? Was it after you drove the car? Was it after something was done to the car? Is it because something doesn’t work? What’s not functioning like it’s supposed to?”
You’ll have to trust me on this one; it works a lot better than just asking, “What’s wrong?”
There are times in this crazy world of automotive repair that you neither win or lose. Trust has a lot to do with it. When the customer doesn't trust you... you're done. When you don't trust the customer, well, the mechanic may have a tougher time solving the problem and getting paid for the work.
Keep those comments coming, always love to hear from everyone. Gonzo
That's pretty much the whole point of this article. The "trust" is a two way street. Intermittent problems is one thing, failure to explain the problem correctly is another. Since the car was in no condition to take the owner for a ride to describe the problem the whole testing and evaluations were based on "He said" and I had to trust the customers explanation. Oops...my bad... should've known better. As usual, most first time customers are not likely to tell you everything, and even more likely not to tell you every detial if they have already been to another shop. They don't want to have to stand there and explain the whole thing over and over again. For some reason I think... they think all techs talk the same language... Wrong! I can't trust the last techs answers and diagnostics if he didn't fix the problem. Chances are it would only lead to a wild goose chase and never solve the problem anyway. I can't trust their judgement and I sure don't trust the last techs answers. It's back to the infamous line, "I don't know who to trust" a two sided problem for sure.
  On 4/14/2012 at 1:15 PM, xrac said:
Gonzo dealing with customers and "trust" can sometimes drive you crazy. In situations like you described when there is an intermitten problem is when "trust" is destroyed. All one can do is tell them I fixed the fusable link and the seat problem and I have experienced no dying issue. Maybe that was the problem maybe not. Don't be suprised if the dying issue reappears but it didn't occur while it was here in the shop or on our test drives. We have learned to hedge more and more on all our repairs because you never know about cars.
    • By stevefry
      I have a client looking to sell their Auto Body Shop in Monteagle TN called Lakeside Collision. He is asking $1,500,000 and the property did a little over $1,200,000 last year. Profitable business with lots of equipment and inventory, newer paint booth and includes 2 lots and 2 buildings with 8 bay doors.
      Also have another client looking for an Auto Body business to purchase in Davidson County (Nashville) TN. Looking for a shop with the business and the real estate.
      In this episode, we’re diving into the powerful concept of creating a shared vision and how a lack of clarity could be holding your shop back from real growth.
      I’ll walk you through what I learned in a deep dive after my own leadership team challenged me to cast a vision that reaches every level of our company. We’ll talk about how to get out of the “small thinking” trap, how to define your goals with laser precision, and why your employees need to see, feel, and believe in the same future you do.
      Plus, I’ll share real tools, like how to craft your vision statement, how to communicate it across your team, and how to create a business where everyone’s pulling in the same direction.
      If you want to stop playing small and start building something truly great, this episode is for you.
      Thank you to our friends at RepairPal for providing you this episode. RepairPal will help you grow your auto business and you can learn more at RepairPal.com/shops.
      Declined repairs don’t have to be lost revenue. AppFueled’s call center schedules follow-up calls and equips your team with everything they need to close the deal. Get started now at appfueled.com
      EOS One
      Vivid Vision: A Remarkable Tool For Aligning Your Business Around a Shared Vision of the Future - Cameron Herold
      The Vision Driven Leader - Michael Hyatt
      Stop Delaying Your Dreams: Time to Take Action
      Introduction and Sponsors (00:00:01) Overview of the podcast and thanks to sponsors RepairPal and App Fuel. Creating a Shared Vision (00:00:10) Brian discusses the importance of establishing a shared vision for the company. Leadership Team Meetings (00:01:13) Details about offsite leadership meetings and the exercise called "the one thing." Feedback and Growth (00:02:08) Brian reflects on receiving feedback from his leadership team and its impact on personal growth. Shifting Mindset on Growth (00:03:07) Brian shares his fears about growth and how he overcame them to embrace larger ambitions. Disney's Service Model (00:04:17) Comparison of Disney's customer service model to his company's approach to client service. Processes and Procedures (00:05:26) Discussion on the importance of processes in maintaining service quality while growing. Inbound Marketing Strategy (00:07:25) Brian explains the effectiveness of inbound marketing in attracting clients. Outbound Sales Shift (00:09:26) Introduction of outbound sales strategies and the team's initial reactions to the change. Creating a Shared Vision Deep Dive (00:10:34) Brian's focus on developing a shared vision after receiving feedback from his leadership team. Researching Shared Vision (00:11:42) Challenges in finding resources on creating a shared vision and discovering related literature. Book Recommendations (00:12:42) Brian reviews two books on vision creation and his thoughts on their content. Simplicity of Creating Vision (00:13:34) Brian concludes that creating a shared vision is simpler than expected, emphasizing clarity. Vision, Mission, and Values Explained (00:14:45) Brian differentiates between vision, mission, and values with a practical example. Big Dreams and Ambitions (00:15:45)  Brian discusses the importance of dreaming big and outlines a fictional company's ambitious goals. Vision, Mission, and Values (00:16:48)  He explains the significance of having a clear vision, mission, and values for a successful organization. Sponsor Message: RepairPal (00:17:48)  Introduction to RepairPal and its services that help auto repair shops attract tech-savvy customers. Sponsor Message: App Fuel (00:18:48)  Overview of App Fuel's customer loyalty app designed for auto service shops to enhance customer retention. Core Values and Their Importance (00:19:57)  Brian shares his realization of the value of core values in decision-making and company culture. Litmus Testing New Hires (00:20:59)  He describes how to evaluate potential hires against the company's vision, mission, and values. Understanding What You Want (00:21:55)  Brian emphasizes the importance of defining personal and business desires beyond just financial goals. Creating a Clear Vision (00:23:51)  Discussion on the necessity of a detailed, clear vision for a business to guide its direction. Proximity to Your Dreams (00:26:56)  Encouragement to immerse oneself in environments that inspire and reflect personal dreams and aspirations. Crafting Your Vision (00:28:50)  Brian advises on the process of creating a vision, emphasizing the need for time and space away from routine.  The Importance of a Clear Direction (00:29:46)  He compares running a business without a clear vision to aimlessly shooting an arrow, highlighting the risks involved. Creating a Target (00:30:41)  Discusses the importance of having a detailed vision as a target for business goals. Vision Details (00:31:37)  Explains the components of a business vision, including specifics about services and operational metrics. Dream Big (00:34:25)  Encourages thinking big without worrying about how to achieve those goals initially. Historical Example: JFK (00:35:32)  Uses JFK's moon landing vision as an example of effective goal-setting and inspiring leadership. Sharing the Vision (00:37:33)  Stresses the need to communicate the vision clearly to the entire team for buy-in. Selling Down the Ladder (00:38:27)  Describes the process of sharing the vision, starting with leadership and moving downwards. Feedback and Buy-In (00:39:19)  Highlights the importance of receiving feedback and fostering genuine buy-in from team members. Repetition of Vision (00:40:12)  Discusses the necessity of repeatedly communicating the vision to ensure team alignment. Crafting the Vision (00:42:20)  Brian reflects on his personal goal to create a detailed vision for his organization. Importance of Shared Vision (00:43:34)  Concludes with the significance of a shared vision for team alignment and achieving business goals.
    • By MikesPlaceAuto
      Hello from Montana. Longtime mechanic/technician, first-time shop owner. Reaching out to many sources for information and advice. Small shop in rural setting, specializing in electrical and electronics. Thanks for any good words. Mike
      Revolutionize Your Shop
