WON'T HOLD YA TO IT ----- ------ ----- Really? ya won't hold me to it? then why ask?
WON'T HOLD YA TO IT!
Being a specialty shop I'm usually not the first place most people will stop at for repairs. More than likely they'll have gone to their "regular" mechanic to try and solve a problem, or checked around with people they know as to where to try and get their car repaired. Sooner or later somebody will mention my name and they'll make it over to my shop.
The only problem I run into now is the fact they have already spent so much money on repairs, and their budget is so tight they want me to go as easy as possible on the cost of the repair. But, before they came to my shop a budget wasn't a problem, but now with all their money spent… they want me to hold to a certain price. This next price shopper was no different.
A guy comes into the office with a dash gauge problem on his Ford pickup. He starts out with the same old introduction line I've heard a zillion times before: "I've been here, I've been there and nobody can find out what's wrong… everyone I've talked to says you're the man to see who can find it."
The story goes that it will blow the 10 amp gauge fuse as soon as you install one, but he's found that if he puts a 25 amp fuse in it will last a day or two. (Good Grief… this is already sounding bad.) A lot of parts have been changed and a lot of things have been tried. It's been to several other shops but nothing has ever solved the problem. All of them eventually recommended that he stop by my shop. (I'm thinking to myself, "Gee dude? After you went to the first shop and they told you to come here, then you went to the next shop and they told you the same thing, then a third, and… seriously dude…how many shops did ya actually go to before you showed up here?")
Needless to say, he was out of cash, out of patience, and still without working gauges in his truck. Now it's my turn to tackle the problem, or … is it……
"I need and estimate on how much it will cost to repair it," he asked me.
"Well, sir, without knowing where the problem is, or what is causing the problem, I'll have to check a few things to be able to pinpoint what the cause is."
"You've obviously done these before, so how much did those cost?"
"Your results may not be the same as the last one I did, because I'm pretty sure the last couple of them that I've done didn't try a 25 amp fuse in place of a 10 amp. So, you might be in for a little more work than the usual repair."
"How can that make the problem worse, it's just a fuse?"
I explained, (as best as I could) why an oversize fuse was not a good idea… but it wasn't getting thru to him. He didn't or wouldn't except an explanation that didn't include a dollar amount in the answer.
"Just give me a range of what it could cost," he insistently asked.
"Ok, well, how about 1 dollar to a thousand," I said, getting a little chapped at his badgering questions.
"Oh, you can give me a closer guess than that. I won't hold ya to it of course."
(The classic "won't hold ya to it" line… sure, you won't.)
"Ok then, it usually runs between 200 to 500 but, it could run a lot less, or it could run a lot more depending on the actual damage I find."
"So you think it will cost around 500.00 bucks then?"
Apparently I have lost my ability to explain things in English, and apparently when I give a variable of two numbers the "won't hold ya to it" number is the higher one, and not a penny more. I guess I didn't make myself clear… oh, I forgot… he's not going to hold me to it so it's safe to say 500.00 bucks is a good number. Awesome, now I won't have to worry about the inevitable argument I'll have once (if ever) I finish the job. Because you know… the actual price may vary.
"Ok, what would be the worst case scenario?" he asks.
By this time I've pretty much figured out that this guy isn't about to leave the truck with me. Either because of the cost or the fact he's not getting the answers he wants. To me, when someone starts asking all these questions it's a sign that they don't trust you… they are really only trying to find a number that they can use to compare at the next shop they'll be stopping at. All the references in the world don't help a bit when the old wallet is doing the talking. Because it still comes down to who's the cheapest. References, quality of repair, and answering all their questions, still doesn't add up to a job in the shop, plain and simply… it's cost. At this point, I know I've lost the job, his trust and my trust of him isn't there. I might as well end this with a little flare of my own.
"Well, let's see… how much did ya pay for the truck?" I asked.
"I paid over 10 grand for it, but what does that have to do with it?
"Let's think about this for a second… If you have ruined the wiring to the point that the overall cost of repairs will exceed the value of the truck then I would say the worst case scenario would be… replace the truck. It's just a harmless joke sir, not that it would happen to your truck, however, I've had a few that it was actually possible with the amount of damage I've found."
Well that pretty much sealed the deal. That little answer snapped his last fuse. This guy is heading out the door. There's no doubt about it. Even with all the referrals, the detailed diagnostics procedures that I explained to him, the fact that I knew that more damage could be done by changing to a higher amperage fuse, still didn't bring the job into the shop. I guess trying to hold my feet over the fire with a "I won't hold ya to it price" was still out of his budget.
There's no doubt I didn't hit it off with this guy, and quite frankly sometimes that's a good thing, I'm not trying to win them all. Man, it would have been a good paying job too if I could have only found a price that this guy could afford. Next time I run across another situation like this I'm going to ask them this question,"Ok, what can you afford? I realize you have spent a ton of money with all these other shops and nothing has been done. So why don't you give me a number that will work… … … … Oh and don't worry… … … … I won't hold ya to it." :)
People never cease to amaze me. After a while you need to just learn to take it all in stride... you're not going to win every battle or make every customer a long life friend. At least after reading a few of my stories you'll get a smile and figure out you're not the only one that has seen somebody like this. Have a Great day!
I think you're right... but... I won't hold ya to it... LOL
Gonzo, the second I read the title, I went running for the meds. What a story. All too familiar for shop owners. I just love when someone says, "Hey, I just spent a lot of money at other shops and they could not fix it, so don't charge me a lot to fix it correctly". Do they realize what they are saying?
Funny and sad at the same time, I think many shop owners will pop a fuse reading this one!
thanks Frank... Sounds like you've ran across one of those guys whos out to take advantage of the free stuff and nothing more. Hate that when it happens.
And I thought it was just my shop that the wacky ones come too. You hit this one on the nail, when something like this happens to me and they walk out I KNOW I am better off. We all know how these type of things can take that ugly turn. Not worth it to deal with.
By the way I got your book in the mail this week, "loose nut" is a great read every shop owner can relate too for sure. Now if you can get Joe Blow to read it maybe our lives will be a little better. LOL.
Thanks for your comments Gary. I hate to repeat myself, but then.... that's pretty much what my stories and articles do. (Re-tell shop encounters)
When I started my shop I thought I was the only one who ran across all these wacky people, it wasn't til' years later and after talking to other shop owners that it wasn't true... EVERYBODY gets them.
The biggest stress relief I ever had in business was finding that out. So writing the stories and situations down provide not only a little entertainment for everyone else but I'm hoping the same sort of stress relief that I discovered after talking to other shop owners.
I hope it's working, and I'm glad ya like the book.
To comment another reader, "Everone from the tech to the customer should read this book, there's a lesson in there for all of us." How true...
      Introduction to the Episode (00:00:01) Brian Walker introduces the podcast and guest, Hallie Wassinger, discussing the importance of Google Local Services Ads. Overview of Google Local Services Ads (00:02:53)  Hallie explains the recent availability of Google Local Services Ads for auto repair shops across the U.S. Historical Context of Local Services Ads (00:03:25)  Discussion on the past availability of Google Guaranteed Ads and their expansion to auto repair shops. Current Availability and Limitations (00:04:38)  Hallie details the current state of Local Services Ads for tire shops and their limited availability. Cost Structure of Local Services Ads (00:05:34)  Introduction to the pay-per-lead model, highlighting its differences from traditional Google Ads. Service Categories for Auto Repair (00:06:45) Hallie outlines the specific services auto repair shops can advertise under Local Services Ads. Lead Generation Process (00:07:44)  Explanation of how leads are generated through phone calls or messages via the Local Services Ads dashboard. Ongoing Maintenance of Ads (00:08:31)  Discussion on the necessity of monitoring and rating leads to optimize the ad performance. Success Stories from Beta Testing (00:10:55)  Brian shares a success story from Chris Cotton, highlighting low lead costs achieved through Local Services Ads. Lead Cost Insights (00:11:39)  Hallie provides average lead cost data, emphasizing the effectiveness of the ads for auto repair shops. Visibility of Local Services Ads (00:12:18)  Brian describes how Local Services Ads appear prominently in search results, enhancing visibility. Google Screened vs. Google Guaranteed (00:13:02)  Hallie explains the differences between Google Screened and Google Guaranteed, focusing on their application processes. RepairPal Sponsorship Message (00:14:27)  Brian thanks RepairPal for sponsoring the episode and discusses the benefits of being in their certified network. App Fueled Sponsorship Message (00:15:32)  Brian introduces App Fueled, promoting their customer loyalty app for auto repair shops. Verification Process for Shops (00:16:33)  Hallie outlines the verification process for shops to join Google Local Services Ads, including necessary checks. Verification Steps for LSA (00:16:50)  Overview of the verification process for auto repair shops applying for Google Local Services Ads. Challenges with Specialty Shops (00:19:14)  Discussion on difficulties specialty shops face with Google Local Services Ads targeting. Specialization in Google Ads (00:20:03)  Insights on why specialized shops may benefit more from traditional Google Ads. Opportunities with LSA (00:22:05)  Exploration of the current opportunities available for shops using Google Local Services Ads. Cost Benefits of LSA (00:23:13)  Comparison of lead costs between Google Local Services Ads and traditional Google Ads. Importance of Google Business Profile (00:24:29)  Discussion on how optimizing Google Business Profiles impacts LSA ad performance. Role of Reviews in SEO (00:27:40)  Emphasis on the significance of keywords in customer reviews for improving visibility. Optimizing Photos for LSA (00:29:42)  Best practices for managing and updating photos in Google Local Services Ads. Pricing for LSA Management (00:31:01)  Details on the costs associated with managing Google Local Services Ads for shops. Introduction to LSA (00:33:47)  Discussion on the performance of Google Local Services Ads and how to get started. Discovery Call Process (00:34:15)  Details on scheduling a discovery call and assessing local competition for LSA. Final Thoughts on LSA (00:34:38)  Emphasis on the importance of early adoption of LSA for auto repair shops. Self-Management of LSA (00:34:40)  Advice on running LSA independently, highlighting the required time and dedication. Closing Remarks (00:35:29)  Thanking listeners and sponsors, and encouraging engagement with the podcast.
      The TRUTH About Business Coaching That Companies Don't Wants You to Know!
      Marketing isn’t just about spending money; it’s about strategy, creativity, and knowing what actually works. That’s exactly what Brian and Kim Walker unpack in this conversation with Doug DeLuca, owner of Boca AutoFix, who built a thriving auto repair shop without ever working as a technician before opening his doors.
      Doug’s IT background gave him an edge, helping him master SEO, content marketing, and social media, all while running his shop. He shares with Brian and Kim how he tracks data, refines his messaging, and attracts the right clients using unconventional but effective methods. From leveraging Facebook groups to pull in college students to secret-shopping a quick-lube competitor for blog content, Doug proves that marketing success comes from being proactive and intentional.
      This conversation tackles why not every shop needs Google Ads, how to structure diagnostic fees without scaring off clients, and the importance of community involvement. Doug’s hands-on, data-driven approach to marketing offers real insights for shop owners looking to take control of their marketing and maximize results.
      Brian, Kim, and Doug break it all down, giving shop owners a blueprint for smarter, more effective marketing.
      How To Get In Touch With The Guest
      Doug DeLucca’s Facebook account
      BOCA Auto Fix - (561) 826-8834
      ASTA
      They Ask You Answer
      They Ask You Answer Podcast Episode 093
      Which is the right fit for you? A quick lube or an independent auto repair shop?
      Introduction to the Podcast (00:00:01)  The podcast begins with a welcome message from the host, Brian Walker. Guest Introduction (00:00:10)  Brian introduces co-host Kim and guest Doug DeLuca, owner of Boca Auto Fix. Overview of Boca Auto Fix (00:00:51)  Doug shares details about his auto repair shop, including its location and age. Hiring an Apprentice (00:01:09)  Doug discusses the recent hiring of an apprentice and the journey leading to this decision. Challenges in Hiring (00:02:13)  The speakers reflect on the difficulties shop owners face in finding and hiring young talent. Marketing Journey Begins (00:03:02)  Discussion shifts to Doug's initial marketing efforts and his involvement in content creation. Background in Technology (00:04:07)  Doug explains his previous technology background and how it influenced his approach to marketing. Learning SEO and Marketing (00:04:45)  Doug describes his self-taught journey in SEO and digital marketing after opening his shop. Realizing Marketing Needs (00:06:14)  Doug reflects on his initial assumptions about marketing and the reality of attracting customers. Understanding SEO Basics (00:08:09)  Doug shares his insights on SEO and the learning process involved in mastering it. Frameworks in Marketing (00:10:25)  The conversation explores the use of frameworks in both auto repair and marketing strategies. Adopting "They Ask, You Answer" (00:11:23)  Doug discusses his experience with the "They Ask, You Answer" philosophy in content creation. Writing Blogs for Customer Engagement (00:12:21)  Doug explains how he uses customer inquiries to create relevant blog content for his shop. Experience at a Quick Lube (00:13:29)  Doug shares his firsthand experience at a quick lube to highlight differences in service quality. Experience Comparison (00:14:06) Doug shares his experience of visiting a competitor's shop to understand customer perception and service quality. Proactive Client Advocacy (00:14:57) The team discusses the importance of guiding potential clients to the right service provider based on their needs. Sponsorship and Marketing Tools (00:16:13) Brian introduces RepairPal, highlighting its benefits for attracting new customers and building trust. Customer Loyalty Apps (00:17:51) Brian discusses the advantages of using App Fueled to create customer loyalty programs for auto repair shops. Incognito Visits (00:18:20) Doug talks about visiting a competitor's shop incognito to gain insights without revealing their identity. Collaboration Over Competition (00:19:09) The speakers explore the idea of referring customers to other shops and building relationships in the industry. Challenging Competition Norms (00:20:20) Brian reflects on inviting competitors to the podcast, emphasizing collaboration over traditional competition. Marketing Involvement (00:22:42) Doug explains the ad hoc nature of their marketing efforts and the role of social media in their strategy. Community Involvement (00:27:41) Doug shares their family's volunteer work and how it integrates with their business's social media presence. Engaging the College Market (00:28:51) Doug discusses how 30% of his clients are college students and their marketing strategies. Collaborating with Local Professors (00:31:18) Doug shares his experience working with a marketing professor for student analysis of his business. Challenges of Seasonal Demand (00:32:24) Discussion on the impact of seasonal changes on business demand and local marketing efforts. Starting with Marketing (00:34:02) Doug advises new shop owners to listen to podcasts and conduct online research for marketing. SEO as a Long-Term Strategy (00:35:08) Doug explains the importance of SEO and its long-term benefits for business growth. Understanding Competition (00:36:44) Doug emphasizes the need to analyze competition and not assume marketing strategies will work universally. The Importance of Data (00:39:08) Doug highlights the role of data in assessing marketing effectiveness and making informed decisions. Nuances of Market Dynamics (00:41:14) Discussion on how geographical and seasonal factors affect marketing strategies in auto repair. Client Avatar and Marketing Alignment (00:42:13) Doug explains the significance of understanding the ideal customer for effective marketing strategies.  Overcoming Diagnostic Fee Challenges (00:43:09) Discussion on how Doug has adjusted his approach to diagnostic fees to improve customer conversion. The Importance of Evaluation Fees (00:43:40) Discussion on the role of evaluation fees and their impact on shop maturity. Improving Customer Communication (00:44:09)  Insights on enhancing customer explanations regarding services and processes. Coaching and Competitive Analysis (00:45:03)  How coaching helped refine service policies and improve customer relations. Content Creation and Marketing Strategy (00:46:32)  The significance of creating content for customer engagement and marketing. Duck Duck Jeep Initiative (00:47:05)  Fun marketing strategy involving ducks to engage with the local Jeep community. Value of Customer Feedback (00:48:46)  Importance of understanding customer inquiries and improving service based on feedback. Contact Information for Doug DeLuca (00:49:29)   Doug shares how listeners can reach him for further inquiries.
      The Weekly Blitz is brought to you by our friends over at Shop Marketing Pros. If you want to take your shop to the next level, you need great marketing. Shop Marketing Pros does top-tier marketing for top-tier shops. I’d like to give another shoutout to our sponsor, Shop Marketing Pros. They are the only marketing company I recommend, and they handle all of the marketing for my own shop as well. If you’re serious about growth, you need strategies that actually work: better websites, higher Google rankings, and ads that bring real customers through your doors. Visit ShopMarketingPros.com/chris to partner with a team that understands your business. Because every great shop deserves marketing that’s just as great. Check out their podcast here: https://autorepairmarketing.captivate.fm/ If you would like to join their private Facebook group go here: https://www.facebook.com/groups/autorepairmarketingmastermind
      In episode 205 of "The Weekly Blitz," host Chris Cotton delves into the themes of personal growth, overcoming guilt, and the pursuit of one's goals. Throughout the episode, Chris opens up about his own experiences, sharing the challenges and triumphs he faced while juggling multiple responsibilities. As a shop owner, Chris had to manage the day-to-day operations of his business, ensuring everything ran smoothly and efficiently. At the same time, he made the courageous decision to return to college, determined to complete his degree and fulfill a long-held aspiration.
      Chris discusses the delicate balance he had to maintain between his professional duties and academic commitments. He candidly talks about the guilt he initially felt for dedicating time to his studies, fearing it might detract from his business or family obligations. However, through this journey, Chris learned the critical importance of self-care and the necessity of prioritizing one's own dreams and aspirations. He encourages listeners to pursue their goals with determination and to not let guilt stand in the way of their personal development.
      Reflecting on his journey, Chris highlights the profound sense of fulfillment that comes from achieving personal goals. He notes how this accomplishment not only boosts self-esteem but also has a positive ripple effect on overall well-being, enhancing both personal and professional life. By sharing his story, Chris aims to inspire others to take bold steps towards their own dreams, reassuring them that it is possible to balance responsibilities while pursuing personal growth.
      The episode wraps up with a sponsorship mention for Shop Marketing Pros, a company that specializes in providing marketing solutions tailored specifically for auto repair shops. This partnership underscores the episode's focus on professional development and growth within the auto repair industry.
      Introduction to the Episode (00:00:00)
      Chris Cotton introduces the podcast and its purpose, highlighting its focus on auto repair business insights.
      Sponsorship Mention (00:00:59)
      Details about Shop Marketing Pros and their services for auto repair shops are discussed.
      Reflection on Vision 2025 (00:01:03)
      Chris shares his experience at the Vision 2025 event, noting the busy atmosphere among shop owners.
      The Importance of Self-Care (00:02:00)
      Discussion on the necessity of taking time for oneself as a shop owner without feeling guilty.
      Overcoming Guilt (00:03:04)
      Chris addresses the guilt shop owners often feel and the importance of prioritizing personal well-being.
      Personal Journey to Education (00:05:02)
      Chris reflects on his decision to return to college after many years, motivated by personal goals.
      Completion of Degrees (00:06:03)
      He shares the timeline of his and his daughter's graduation, emphasizing the significance of finishing what you start.
      Lessons in Persistence (00:08:26)
      Chris discusses the importance of completing tasks and setting an example for his daughter.
      Final Thoughts and Call to Action (00:10:30)
      Encouragement to pursue personal goals and a reminder of the podcast's sponsor, Shop Marketing Pros.
      chris autofixsos.com
      940-400-1008
      YouTube: https://bit.ly/3ClX0ae
      Email Chris: [email protected]
