Code Talkers
During World War II the US used a secret type of language to send and receive messages, so the enemy couldn't find out what they were talking about. They enlisted the help of Navajo and Comanche Native Americans as radio operators. These guys used a combination of their language and relative terms as a way to disguise the real message over unsecured radio waves during World War II.
Most of the coding was done by using a native word for each letter of the message. Such as, if you were going to say the word "ARMY" they would pick one of the native words that represented a word in English with the first letter "A" and the same for each letter after that. In other words the letter "B" would be sent over the radio waves as, "Toish-Jeh" which means, "barrel" in English.
So the word "ARMY" would have been transmitted something like this:
"Wol-la-chee" (Ant) – "Gah" (rabbit) – "Tsin-tliti" (Match) – "Tsah-as-zih" (Yucca) thus the word Army would have been spelled out and easily translated at the other end. A lot of times an entire phrase could be stated with one word, or a word that was often used had a selected native word that was used as a substitute. Then on other occasions an English word was thrown in just to confuse the whole thing even more. It was quite ingenious… and believe or not… the code was never --- ever --- broken. To quote General Howard Connor (while at Iwo Jima), "Were it not for the Navajos, the Marines would have never taken Iwo Jima."
Trying to sound out those four Native American words (correctly) and translate it into the actual word was easy for these guys. They understood it, it's their language and they could send/translate and relay an answer faster than any machine available back in the day. They truly were code talkers.
So you might ask where am I going with all of this? Well, think about it… doesn't this sound something like the codes we have with today's cars? It does to me.
I read a code, translate it into working data, and solve a problem, all with a language that isn't understood by everyone out there. I guess you could call me a modern day code talker.
The big difference is you've got people with hand held scanners they bought at a local store or from the internet, and have the ability to "read" a code. Or some of them have been to a repair shop that has bought a scanner and read the codes for them. But, they can't break the code. They can't determine what to do with the information they have in front of them.
Think about it… it's World War II, and you've just copied down a message from your secret hiding spot on the side of the hill. You are about to relay the message to your superior officers. But, you still haven't a clue what that gibberish means. It's like reading a code on a car these days, and not having a clue what all that information means. That's where a qualified automotive technician … (aka code talker) is needed.
I have lost count of how many times a car has come into my shop with a customer standing at the counter. They have already been somewhere else, and the other shop has given them an invoice with the codes and the definition written down on it, and… more than likely a big "goose egg" in the charge column of the invoice. And,… they still haven't had their problem resolved.
"Oh I see they didn't charge you to read the codes… how nice of them (a little sarcastically I might add). So, you need me to find out what it all means right?" I'll ask.
"Yes, but I won't need it diagnosed; that's already done," the customer will tell me.
Of course it's already diagnosed… and you know what is going to happen next. I'm going to tell them there is a charge to trace out the actual problem and determine the reason for the fault code. Any tests that are needed or extra equipment needed to diagnose the problem is all incorporated into the diagnostic fee, which of course ends up with a customer just about to grab all their paper work and head out the door. Because … oh you know what's coming next… "It shouldn't cost anything to find out what's wrong with my car, because I already had that done."
This is when I break into my "code talker" story and inform the customer of what the process takes to actually find out what that particular code means.
"There's everything from a compression check to TSB's that need to be considered when it comes to diagnosing a problem," I'll tell them.
Let's face it, an oscilloscope ain't cheap, and as far as I know they aren't giving away these scanners, not to mention the hand tools, meters, and specialty equipment you'll need to perform some of these tests.
I realize that the code information to them sounds more like "Comanche" or "Navajo" lingo than it does plain English… but then… I'm a modern day code talker… I can read it, I can interpret it, and I can translate it into English. That's what I'm here for.
The next thing to do is make the customer aware of the level of sophistication that is needed to decipher these coded messages from the car. (It still amazes me that there are still a lot of people out there who assume replacing a part will always solve the problem, and that intensive research isn't necessary.)
I don't know about you, but there are times when I have a car in the shop that looks like it is on life support with the amount of gadgets I've got hanging out of the hood or from under the dash, and it all started off with a simple code. (This is one of those times a cell phone or a camera comes in handy and sending a shot of the owner's car to them so they can see what you've had to do to locate the cause of that simple code number.)
I'm a modern day mechanic… I'm no grease monkey, nor am I the guy with a scanner who'll read your codes and give you the definition. I'm the guy who will read the code, define it, and translate it into a solution. The cars of today are not the car of yesterday… nor are they the cars of the future. I've got to take care of what is here now, and that requires some understanding of the fundamentals of todays' cars. But in order to find out what that little service light means on your dash…keep in mind… you don't need a code reader… you need a code talker.
Working on new stories all the time. Adding a little survey to this story... Which magazines do you see my articles in? Leave a comment ... love to hear from ya. Gonzo
Not even realizing it but when I was in the Marine Corps my primary MOS (Military Occupation Status) was a 2531/2542 "Field Radio Operator/Teletype Operator" I guess that's why I know how the code was used, because it was taught in some of the classes. It wasn't my intention to write about US Marine radio operators... I was going for the "code readers" we run across in our daily business and how I generally deal with them. But, don't worry none of the info I provided is anything to be worried about... it's all been declassified... We're not leaking national secrets here.. LOL
Glad ya liked the story... Gonzo
thanks Joe, as always you see the inner meaning of the story as I write them down. And yes the BP meds better be close by. LOL
This is one of those articles that I think would be a perfect one to have on a bullentin board or on the wall of the waiting room in every shop.
I'm betting this article is picked up really fast and goes into print before a lot of other really good ones do. This one just hits a nerve for every decent shop out there that has to deal with the cutthroat logics of the free "diagnostics" when in fact.... their idea of diagnostics is simple code reading. But that doesn't make you a code talker.... thanx again your insight is spot on... U Da Best Joe!
Well Gonzo, you did again. My blood pressure is up, thanks...
First, let me tell you, the analogy you make to the code-talkers of WWII is brilliant. My issue here is how little most of the public thinks of us, with respect to what it takes to test and diagnose and the modern automobile. I don't know how it started, but pulling codes is not a diagnosis and we need to be careful of the perception the public has on check engine lights and other hi-tech testing.
I have an AutoZone opening up around the corner from me soon, which is in walking distance of Advanced. Both stores promote free check engine light code reading. This only serves to diminish the complexity of that code and what it takes to understand the code, the equipment and the information data base. To be truthful, I can teach a monkey how to pull a code.
Repair shops have enough trouble getting the money they deserve, let's not jeapordize perhaps our future and reduce the check engine light to a commodity.
Great article, sorry for being so passionate....now let's see, where's my BP medication....
I'd like to say also the industry is lucky to have someone like you Joe... ASO is something you should be really proud of. I'm very glad to have made that phone call to you so many years ago... I'll bet ya never thought (at the time) that I wasn't kidding when I told you I had a few stories to tell... LOL
Don't worry I've got more stories and more articles to go.. I'm no rocket scientist... I'm no CEO ... I may not be as strong as a bull... ... ... but I did stay at a Holiday Inn once... I guess that means I'm qualified... ROFL... :) :) :rolleyes::DB):lol::P
I tip my hat to you, keep these article coming...our industry to lucky to have someone like you to bring up these sensitive issues in a way that is both informative and fun.
And, I do hope this strikes a nerve in the hearts of every shop out there. To be a shop owner and tech todays requires the strength of a bull, the intellect of a rocket scientist and the management skills of a top CEO, it aint easy...
Very nicely done Gonzo. I too love when the local "Chepo" parts stores that read codes and send them on thier way knowing what the whole problem is. Makes our lives so much easyer when they provide was with thier findings doesn't it. LOL U.S. Marine huh, I knew there was something I liked about you. Semper Fi brother, myself also.
Thanks Gary... semper fi... you'll find a lot of stories related to my GI days. Makes some great stories.
The radio systems they used in WWII were still on the training schedule when I was in the service (late 70's). Cryptographic radios pretty much put the code talkers out of business, the next thing is... what technilogical advancement puts the "code reader" of today out of business.
      Todays Show Post -  Our notes today will be in a different format, written by our host.
      Welcome to another episode of Speak Up - Effective communication.
      Your place for focusing on elevating our communication skills in the auto repair industry - I’m your host Craig O’Neill….
      I want you to ask yourself a question today - each time you receive a notification on one of your devices:
      Do I need this?
      Do I need to do something about this RIGHT NOW?
      This has been my question for any number of the alerts that pop onto my screens on a daily basis. - - As I’ve been at war with distractions in my life.  Loyal listeners have become familiar with my growing concern on the topic and I feel that I’ve begun to find some more balance slowly as of late and will share whats working for me.
      Of note - I’ve been reading a book titled, “Stolen Focus - Why you can’t pay attention and how to think deeply again” by Johann Hari.
      This read was a referral from Carm Capriotto - and it’s worth your attention.
      In our episode today, I have some thoughts on the topic of notifications - and hope to get you thinking differently on what YOU are allowing devices to compromise YOUR focus!
      Our Word of the Day:
      Frenetic: fre·net·ic
      adjective
      fast and energetic in a rather wild and uncontrolled way.
      Listen to this excerpt from the book, Stolen Focus - the author, Johann Hari, writes about a conversation with a friend who was getting notifications for things he didn’t want… and I’ll quote:
      “... All this frenetic digital interruption is “pulling our attention away from our thoughts,” and I think we’re almost in this constant stimulus-driven, stimulus bound environment, moving from one distraction to the next.”  If you don’t remove yourself from that, it will "suppress whatever train of thought you had.”
      That is a quote from Stolen Focus - Why you can’t pay attention and how to think deeply again.”
      The consequences of distractions are real - not just from tasks - but from our creative thoughts and even healthy mindwandering.
      Hari mentions in his book that “a distraction such as looking at an image from a friend pulls the average person away for up to 20 mins!  Not just one!
      And if you look around, you’ll recognize that the distractions are EVERYwhere - and we now have this habitual tendency to scan for them, in our own pockets, and on our own wrists!
      Look around you now - how many people do you see distracted by devices?
      Before you blame yourself or feel bad about this - let me state - our technological world has been engineered this way in a deliberate attempt to get more engagement from us.
      I will say - while I, like all modern humans, struggle with distractions, I have come to develop a few VERY simple and reasonable disciplines regarding notifications.
      I feel sometimes a little old-fashioned on this… but as I discussed recently in episode 35 with Darren Mclea, I feel like I came of age with technology enough to appreciate a slower pace of information than what has been engineered around us now.
      Here we go.  My thoughts for LESS distractions - and being MORE present (be it with your own thoughts - or for the people you are with)
      1.)  Silence your device - I don’t care what tech eco-system you favor - noisy notifications are not just a distraction for you - they are distracting for others.
      2.)  Don’t keep your devices in your pocket at home or work.
      3.)  Disable notifications from all non-essential applications - (or uninstall all non essential applications)
      4.)  No social media notifications.  This doesn’t mean no social media (but more on that another time).  You can check it as you want when you want.
      5.)  Silence that group chat thread…   you know the one.  Texting and group texting… really does function like social media.  Check at intervals.
      6.)   Smart Watches.  Don’t.  This is my opinion but it’s a strong one.  I think one of three things when I see you look at a smart watch while in conversation: 1.)  You have no time for this.  2.)  You have something more important to do.  Or 3.)  This interaction is causing a blood pressure spike.
      7.)  Organize your emails - filter or unsubscribe from ALL non essential emails.
      8.)  Email Away Messages are OK!  (There are conflicting schools of thought on this.)
      9.)  Set Expectations for availability with colleagues and loved ones.
      10.)  Replace the activity with something else - just turning off things on one device will often lead elsewhere.
      Why Used Car Parts Can Be Risk
      Running low on cash? Before panic sets in, it’s time to get strategic. In this episode of Business by the Numbers, Hunt explores practical steps to manage cash flow challenges, cut expenses wisely, and secure financing without sinking your business. Learn what options are available and how to make informed decisions to keep your shop running smoothly.
      Understand the root causes of cash flow issues to avoid repeating mistakes. Learn why preserving cash strategically is more effective than slashing every expense. Discover how to leverage credit lines, loans, and alternative financing options safely. Avoid common pitfalls, like cutting critical expenses, that can worsen financial struggles. Develop a plan to stabilize and grow your cash reserves for long-term success.
      Episode 197 - Used Parts & Bad Practices In Auto Repair With Jeff Compton & Keith Perkins
      Why Your Auto Repair Shop Needs Strong Leadership During A Transition
