Where's Waldo?
OK, I really do fix cars for a living. I take a car with a problem, locate the problem, and make the appropriate repair. Sometimes I haven't a clue where to look when I start, but with a few proper tools, a little ingenuity, and a whole lot of experience I'll find the problem.
It's like finding Waldo, yea that little nerdy guy in red and white. The one that hides in plain sight sometimes, and even as careful as you can be, you'll usually have to look closely to find him. Except my "Waldo" doesn't wear a red and white cap to give himself away. My Waldo is usually something to do with a component or part that has failed, or has decided to be difficult. I sometimes think that these weird repair jobs that end up at my shop are like an elaborate game of "who can find Waldo first".
I'm not always the first guy to try and find Waldo. A lot of times a customer will take their car to a relative or next door neighbor, and when that doesn't work they'll find the cheap shop or the closest garage in their area. Even more often I'll hear a customer tell me they always go to a certain shop for all their repairs, so they think nothing of going to a specialist for any repairs. But, when that doesn't work it's time to ask for a recommendation for a shop that can make the repairs. Now this isn't true of everyone, a lot of people have a family mechanic they have used for years, while others believe the dealership is the only place to go for repairs. Whichever or whatever way works for each and everyone is just fine with me. One way or another somebody has to find Waldo.
When it comes to cars, Waldo can be pretty crafty. He can be hiding in thousands of places. He can be under the hood, behind the dash, in the trunk, or under the seat. He can be well concealed or under layers of components, carpet, plastic, or engine parts. With today's cars he can even be inside a computer lurking about as a corrupted bit of information. I never know where he'll show up, but I'll do my best to find him. The other day I was on a Waldo hunt for a wacked out gas gauge. The fuel gauge was stuck on empty on this 03 Ford Van. It came from another shop after they had given up on it. The shop had already tried a new sending unit in the tank, but it only lasted a day or two before the gauge quit again.
So where is that little beanie cap wearing weirdo hiding this time? I think I'll start with a little behind the steering wheel work first. After doing the self-test on the dash it was clear the gauge was not responding, so I decided to break out the gauge simulator and hook it up to the fuel gauge. Even with the tester adjusted to 160 ohms (full tank reading) it never budged off of empty. Gotcha Waldo! You're in the instrument cluster… ah HA! Got ya this time for sure ya skinny little twerp!
I got the new cluster approved and installed it the next day. Hooked up to the scanner checked that all the programming needed was done, typical stuff… mileage, tire size, etc… not a big deal (with the right scanner, an IDS in this case or the dealer parts department can set most of it up for you when you order it… Actual programming needs varies from year to year, so be careful to follow all manufacturer's directions). I was so convinced that I had this one I didn't think I needed to recheck my work. I was in for a surprise when the gas gauge didn't move right away. I've seen this before; it can take a minute or two or up to even 20 minutes if the key was on while filling up the tank. I didn't recall turning the key on when I was installing the new cluster, but by the time I had the van off the lift and backed out of the shop the gauge was working. Done, problem solved… Waldo you're out-a-here!
Boy was I wrong. Seems old Waldo had to come back just a few days later. The gauge is back on empty again just as it did with the first shop. Now what is he doing… that Waldo he's a crafty kind of little nerd… is he messing with me? I'm about to go "mechanic" on his little butt.
Back to the gauge tester again, this time the gauge reacted with every movement and changed with every setting I could put it thru on the tester. I knew the empty reading on this tank is around 15 ohms and a full tank is 160, so I should have a reading somewhere in between those reading from the tank sender. It was 16 ohms… oh come on… is this tank empty?
I gave the tank a couple of knocks with my knuckle "rap, rap, rap" and muttered to myself very sheepishly, "You in there Waldo?"
I got an approval to drop the tank down to check it further. I could tell the other shop changed the tank sending unit. They had butt connected the lead together (gee, ya could have just disconnected it), but I did notice something rather strange about the sending unit. The float was bent around the fuel pump and an edge of the bail was trapped against the actual fuel pump bracket. Waldo is up to something here, and it's not the sender.
I grabbed a flashlight and looked down in the tank. There inside the tank is the tray that the fuel pump rests in. It's mainly there as a way to control the sloshing effect of the fuel and to help give the gauge a steady reading. The only thing was… the tray wasn't staying in place. It had broken free from the bottom of the tank and was sliding back and forth as the van drove down the road.
"Waldo… you've been a very naughty little fellow," I said to myself.
The only thing that made sense about the dash being bad was somebody must have tried to send voltage back up the sending wires to the dash, and it probably knocked the gauge out. It wouldn't have been hard to do with the gauge and fuel pump leads all in the same connector. Somebody could have easily (accidently I hope) crossed the wrong leads, which created another "Waldo". While the original Waldo remained in hiding inside the gas tank the whole time.
Now I just have to tell the customer where I found him at this time. Great, just great…. Two Waldo's in two places in one car. I think I'll let Waldo explain this to the owner, "Waldo … Waldo… where's Waldo?" Typical… I've got to go find him again.
Keep those comments coming, makes my day....that's for sure! Got an idea for a story, email me [email protected] Always looking for your input.
Don't forget... the more you go on line and read my articles the more the advertisers are watching too. Stop by any babcox magazine website, leave a comment if you can. www.brakeandfrontend.com, www.importcar.com, www.underhoodservice.com, www.counterman.com, www.enginebuilder.com, www.diagnosticnews.com.... and several others. If you don't see my column at your favorite magazine... SEND THEM AN EMAIL... and TELL THEM. I'd definetly appreciate it.
I lost count how many times I fix one thing only to find something else. Take a low fuel pressure problem that ends up with melted conveters that ends up with burnt exhaust valves... and the whole time you're trying to save the customer a few bucks. Sometimes they understand...sometimes they don't.
I welcome the challenge to anybody who thinks they can answer all the problems the first time around and still can keep the customer happy... yea, right, good luck on that one. Like I tell my customers sometimes... "If it was a horse you would have taking it out back and shot the poor thing before you asked it to go to town pulling the wagon one more time." But with cars... a lot of people think it can't be that bad... it was fine yesterday.
Well, there's that Waldo again. sneaky little bastard! LOL
Thanx for your comments Joe. Always appreciate it
We all have too many Waldo stories. The most difficult is explaining what happened to the customer, which is never easy and maybe nearly impossible for the average consumer to comprehend. Sometimes we fix, “A” problem, but not “THE” problem. But, how do explain this to the customer?
It’s amazing all the variables we deal with on a regular basis.
      Brian and Parker dive into how strategic marketing investment can drive real growth for auto repair shops. Parker shares how increasing his marketing spend transformed his business, leading to record-breaking profits and industry recognition. They discuss why many shop owners hesitate to spend more on marketing and how cutting back can actually slow growth.
      They break down the balance between brand-building and direct response marketing, highlighting how both contribute to long-term success. Parker shares insights from industry peer groups and how analyzing successful shops’ financials helped him refine his own strategy. They also explore how even small adjustments in marketing spend can make a big impact.
      They explain what it takes to turn marketing into a growth engine, from increasing car count to boosting profitability. With real-world insights and proven strategies, they make the case for why now is the time for shop owners to commit to smarter marketing investments.
      Declined repairs don’t have to be lost revenue. AppFueled’s call center schedules follow-up calls and equips your team with everything they need to close the deal. Get started now at appfueled.com
      VISION Hi-Tech Training & Expo
      Introduction to the Episode (00:00:01) Brian Walker introduces the podcast and guest, Hallie Wassinger, discussing the importance of Google Local Services Ads. Overview of Google Local Services Ads (00:02:53)  Hallie explains the recent availability of Google Local Services Ads for auto repair shops across the U.S. Historical Context of Local Services Ads (00:03:25)  Discussion on the past availability of Google Guaranteed Ads and their expansion to auto repair shops. Current Availability and Limitations (00:04:38)  Hallie details the current state of Local Services Ads for tire shops and their limited availability. Cost Structure of Local Services Ads (00:05:34)  Introduction to the pay-per-lead model, highlighting its differences from traditional Google Ads. Service Categories for Auto Repair (00:06:45) Hallie outlines the specific services auto repair shops can advertise under Local Services Ads. Lead Generation Process (00:07:44)  Explanation of how leads are generated through phone calls or messages via the Local Services Ads dashboard. Ongoing Maintenance of Ads (00:08:31)  Discussion on the necessity of monitoring and rating leads to optimize the ad performance. Success Stories from Beta Testing (00:10:55)  Brian shares a success story from Chris Cotton, highlighting low lead costs achieved through Local Services Ads. Lead Cost Insights (00:11:39)  Hallie provides average lead cost data, emphasizing the effectiveness of the ads for auto repair shops. Visibility of Local Services Ads (00:12:18)  Brian describes how Local Services Ads appear prominently in search results, enhancing visibility. Google Screened vs. Google Guaranteed (00:13:02)  Hallie explains the differences between Google Screened and Google Guaranteed, focusing on their application processes. RepairPal Sponsorship Message (00:14:27)  Brian thanks RepairPal for sponsoring the episode and discusses the benefits of being in their certified network. App Fueled Sponsorship Message (00:15:32)  Brian introduces App Fueled, promoting their customer loyalty app for auto repair shops. Verification Process for Shops (00:16:33)  Hallie outlines the verification process for shops to join Google Local Services Ads, including necessary checks. Verification Steps for LSA (00:16:50)  Overview of the verification process for auto repair shops applying for Google Local Services Ads. Challenges with Specialty Shops (00:19:14)  Discussion on difficulties specialty shops face with Google Local Services Ads targeting. Specialization in Google Ads (00:20:03)  Insights on why specialized shops may benefit more from traditional Google Ads. Opportunities with LSA (00:22:05)  Exploration of the current opportunities available for shops using Google Local Services Ads. Cost Benefits of LSA (00:23:13)  Comparison of lead costs between Google Local Services Ads and traditional Google Ads. Importance of Google Business Profile (00:24:29)  Discussion on how optimizing Google Business Profiles impacts LSA ad performance. Role of Reviews in SEO (00:27:40)  Emphasis on the significance of keywords in customer reviews for improving visibility. Optimizing Photos for LSA (00:29:42)  Best practices for managing and updating photos in Google Local Services Ads. Pricing for LSA Management (00:31:01)  Details on the costs associated with managing Google Local Services Ads for shops. Introduction to LSA (00:33:47)  Discussion on the performance of Google Local Services Ads and how to get started. Discovery Call Process (00:34:15)  Details on scheduling a discovery call and assessing local competition for LSA. Final Thoughts on LSA (00:34:38)  Emphasis on the importance of early adoption of LSA for auto repair shops. Self-Management of LSA (00:34:40)  Advice on running LSA independently, highlighting the required time and dedication. Closing Remarks (00:35:29)  Thanking listeners and sponsors, and encouraging engagement with the podcast.
      Marketing isn’t just about spending money; it’s about strategy, creativity, and knowing what actually works. That’s exactly what Brian and Kim Walker unpack in this conversation with Doug DeLuca, owner of Boca AutoFix, who built a thriving auto repair shop without ever working as a technician before opening his doors.
      Doug’s IT background gave him an edge, helping him master SEO, content marketing, and social media, all while running his shop. He shares with Brian and Kim how he tracks data, refines his messaging, and attracts the right clients using unconventional but effective methods. From leveraging Facebook groups to pull in college students to secret-shopping a quick-lube competitor for blog content, Doug proves that marketing success comes from being proactive and intentional.
      This conversation tackles why not every shop needs Google Ads, how to structure diagnostic fees without scaring off clients, and the importance of community involvement. Doug’s hands-on, data-driven approach to marketing offers real insights for shop owners looking to take control of their marketing and maximize results.
      Brian, Kim, and Doug break it all down, giving shop owners a blueprint for smarter, more effective marketing.
      How To Get In Touch With The Guest
      Doug DeLucca’s Facebook account
      BOCA Auto Fix - (561) 826-8834
      ASTA
      They Ask You Answer
      They Ask You Answer Podcast Episode 093
      Which is the right fit for you? A quick lube or an independent auto repair shop?
      Introduction to the Podcast (00:00:01)  The podcast begins with a welcome message from the host, Brian Walker. Guest Introduction (00:00:10)  Brian introduces co-host Kim and guest Doug DeLuca, owner of Boca Auto Fix. Overview of Boca Auto Fix (00:00:51)  Doug shares details about his auto repair shop, including its location and age. Hiring an Apprentice (00:01:09)  Doug discusses the recent hiring of an apprentice and the journey leading to this decision. Challenges in Hiring (00:02:13)  The speakers reflect on the difficulties shop owners face in finding and hiring young talent. Marketing Journey Begins (00:03:02)  Discussion shifts to Doug's initial marketing efforts and his involvement in content creation. Background in Technology (00:04:07)  Doug explains his previous technology background and how it influenced his approach to marketing. Learning SEO and Marketing (00:04:45)  Doug describes his self-taught journey in SEO and digital marketing after opening his shop. Realizing Marketing Needs (00:06:14)  Doug reflects on his initial assumptions about marketing and the reality of attracting customers. Understanding SEO Basics (00:08:09)  Doug shares his insights on SEO and the learning process involved in mastering it. Frameworks in Marketing (00:10:25)  The conversation explores the use of frameworks in both auto repair and marketing strategies. Adopting "They Ask, You Answer" (00:11:23)  Doug discusses his experience with the "They Ask, You Answer" philosophy in content creation. Writing Blogs for Customer Engagement (00:12:21)  Doug explains how he uses customer inquiries to create relevant blog content for his shop. Experience at a Quick Lube (00:13:29)  Doug shares his firsthand experience at a quick lube to highlight differences in service quality. Experience Comparison (00:14:06) Doug shares his experience of visiting a competitor's shop to understand customer perception and service quality. Proactive Client Advocacy (00:14:57) The team discusses the importance of guiding potential clients to the right service provider based on their needs. Sponsorship and Marketing Tools (00:16:13) Brian introduces RepairPal, highlighting its benefits for attracting new customers and building trust. Customer Loyalty Apps (00:17:51) Brian discusses the advantages of using App Fueled to create customer loyalty programs for auto repair shops. Incognito Visits (00:18:20) Doug talks about visiting a competitor's shop incognito to gain insights without revealing their identity. Collaboration Over Competition (00:19:09) The speakers explore the idea of referring customers to other shops and building relationships in the industry. Challenging Competition Norms (00:20:20) Brian reflects on inviting competitors to the podcast, emphasizing collaboration over traditional competition. Marketing Involvement (00:22:42) Doug explains the ad hoc nature of their marketing efforts and the role of social media in their strategy. Community Involvement (00:27:41) Doug shares their family's volunteer work and how it integrates with their business's social media presence. Engaging the College Market (00:28:51) Doug discusses how 30% of his clients are college students and their marketing strategies. Collaborating with Local Professors (00:31:18) Doug shares his experience working with a marketing professor for student analysis of his business. Challenges of Seasonal Demand (00:32:24) Discussion on the impact of seasonal changes on business demand and local marketing efforts. Starting with Marketing (00:34:02) Doug advises new shop owners to listen to podcasts and conduct online research for marketing. SEO as a Long-Term Strategy (00:35:08) Doug explains the importance of SEO and its long-term benefits for business growth. Understanding Competition (00:36:44) Doug emphasizes the need to analyze competition and not assume marketing strategies will work universally. The Importance of Data (00:39:08) Doug highlights the role of data in assessing marketing effectiveness and making informed decisions. Nuances of Market Dynamics (00:41:14) Discussion on how geographical and seasonal factors affect marketing strategies in auto repair. Client Avatar and Marketing Alignment (00:42:13) Doug explains the significance of understanding the ideal customer for effective marketing strategies.  Overcoming Diagnostic Fee Challenges (00:43:09) Discussion on how Doug has adjusted his approach to diagnostic fees to improve customer conversion. The Importance of Evaluation Fees (00:43:40) Discussion on the role of evaluation fees and their impact on shop maturity. Improving Customer Communication (00:44:09)  Insights on enhancing customer explanations regarding services and processes. Coaching and Competitive Analysis (00:45:03)  How coaching helped refine service policies and improve customer relations. Content Creation and Marketing Strategy (00:46:32)  The significance of creating content for customer engagement and marketing. Duck Duck Jeep Initiative (00:47:05)  Fun marketing strategy involving ducks to engage with the local Jeep community. Value of Customer Feedback (00:48:46)  Importance of understanding customer inquiries and improving service based on feedback. Contact Information for Doug DeLuca (00:49:29)   Doug shares how listeners can reach him for further inquiries.
