We center the wheels and install the nuts by hand and then torque the nuts by hand to oem spec with a torque wrench. We repair many stripped lug studs/nuts that were run up with torque sticks.That creates a different problem in which people can't remove the wheels when they need to for a flat or service. Many european models use lug bolts that screw into threaded holes on the hub's that are expensive to replace when the threaded holes are stripped out. I see that on most tire shops invoices it is noted that the serviced vehicle's wheels be retorqued in 50 miles or no warranty whatsoever.
Happy Daylight Savings time to all- I feel an hour younger. B)
Edited by FROGFINDER
Its not if you have had a tire fall off, its when. I won't say anything other than I have had it happen. Fortunately, no one was hurt and my insurance took care of the repairs. I really think it has to do with how well you take care of the "mistake" All the best processes in the world, can't prevent all accidents. I sent a customer recently to one of the largest tire chains in our area (yes, I didn't have a tire machine so I had no choice). The customer had a tire fall off, causing damage to the car. Fortunately, the customer was turning into a parking spot so it didn't hurt anyone. Even though all the "processes" had been followed it still happened. The manager at this tire store bent over backward and took care of everything. This customer was so impressed, they personally told me so.
I have never had a wheel fall off, but other mistakes occur due to stress, pressure, productivity, and just trying to get things done in general. I think sometimes as owners, managers, mechanics etc... we need to just take a step back, slow down, and recheck our work before it leaves the lot. There is a lot going on in an auto garage, and the pressure from owners, productivity goals, and customers can cause us to over look the most simple things.
The fast paced society we live in today contributes to these errors, we just have to learn how to minimize them while staying productive and safe at the same time.
Joe, I do like your torque method with a coworker in sight. I may consider doing this in my shop when I hire in help.
Edited by Mario
Asking that wheels be retorqued and then watching it being done helps alot. B)
We had an ambulance wheel fall of in our parking lot when it was being brought it. thankfully it had just had brand new tires put on by someone else. That was neat
We use torque sticks then- hand torque .
We have a stamp that informs the client to come back in 200 miles for retorque and have them intial about 90 % come back.
We still have clients complain to tight when they try to remove the tires , but with the o/e equipped or handiman tools it is hard on some.
hope this helps
I have only had one wheel fall off. It was this year on a Volvo XC70. Brilliant me, I was doing brake work and putting her summer tires/rims on. Well one front lug bolt was missing so I decided to be nice and replace it, no charge. So I ordered up another. The bolt had been missing so long the threads were badly rusted and wouldn't take the bolt with out force so I "dressed all the threads in that hub with a rethreading tap, not a thread cutting tap. I ALWAYS install the wheel nuts/bolts with a torque stick and then hand torque them to the manufacturer's recommendation in AllData. She talked to me about a week later. She had driven it about 50 miles before the tire came off. Luckily she was still on a slow back country road. She said her neighbor who was kind of a car guy snagged a lug bolt from each of the other wheels and put the tire back on and TIGHTENED, she emphasized very tight, the wheel bolts. She drove back home and the next day started back to town, a total of about 4 miles and the wheel came loose again. So she stopped, tightened the bolts herself and drove back home to get her truck. So I towed the Volvo in, replaced the wheel bearing/hub assembly, replaced all the missing wheel bolts and the ones that looked damaged and she's been driving it for four months now with no issues. Just another reason I hate eurotrash. I don't really blame the car, but the problem was on a euro car after all.
I review all of my work orders with my customers before I have them sign and I put a disclaimer on all work orders where the tires were off,
"Improper, uneven or excessive wheel nut (or lug nut) torque can contribute to brake rotor distortion and eventually brake pulsation. Care must always be taken to properly and evenly tighten wheel nuts when rotating tires or when a tire is removed for any reason.
Wheel nut torque MUST be rechecked after approximately 50 miles."
I know 50 miles is really soon, but when the average customer comes back, when the remember it, which is typically 100-200 miles later I don't see a problem.
We implemented a system where EVERY wheel is hand torqued, we modified our repair orders to show a line item at the bottom to show wheel torque and
the tech writes down the value he torqued the wheel to. At the end of the day I scan each and every repair order so I have a copy of this information. Comes
in handy sometimes. I had an old guy last month tell me he was doing his own brake job at home and couldn't get the wheels off. He accused us of
tightening his wheels too tight when we installed tires on his car the previous month. I pulled up the scan that showed what the tech torqued them to.
Come to find out he was using a tiny 1/2 ratchet.
In my 45 years of dealing with Gomer And Goober or the very best mechanics that I knew NEVER leave loose lug nuts. Then the phone call and the unexplained wheel fastener failure. I have seem more failures with the Euro cars, customer universal mount wheels, and vehicles parked outside in apartments or townhomes. Thus far no injuries or major property damage thank God.
A wheel fall off...since I've been in business...ah, no...BUT back when I was young and dumb (got thru the young part) I was changing the wheels on a Triumph for a used car lot I was working for and had to take it down to get it aligned next. I left the lot turned onto a busy street and in the middle of the intersection the right front took off down the street leaving me blocking traffic. I managed to get it to the corner and called the boss. He was more concerned about the car, me...I was scared shtttless. LOL
These days, it's torque sticks and a torque wrench. Safe instead of sorry...besides, getting stuck in an interescetion isn't high on my list of things I want to do again.
We hand torque all wheels, generally the cars we service have center caps so that's a good indicator that they still need to be torqued after its off the lift, another problem I have seen is people torquing them while the car only is park which allows movement that can create an under torque condition, I instruct all techs to leave the lift slightly raised so that there is no movement of the car.
I like the chalk idea, I may try that. I do not under the torque stick usage if your hand torquing, We run them up lightly, then hand torque.
      In the 200th episode of "The Weekly Blitz," Coach Chris Cotton marks a significant milestone for the podcast by taking a moment to reflect on the journey over the past year. He shares personal anecdotes that resonate with the audience, including a heartfelt update on Kimberly, who made the selfless decision to donate a kidney to her brother, highlighting the profound impact of family and generosity.
      Chris delves into key topics that are crucial for auto repair shop owners, offering insights and advice that are both practical and forward-thinking. One of the main discussions revolves around the concept of adopting a four-day workweek. He explores the potential benefits this can bring, such as improved work-life balance for employees, increased productivity, and enhanced job satisfaction, while also addressing the challenges and considerations that come with implementing such a change.
      Another focal point of the episode is the distinction between commitment and mere interest. Chris emphasizes that true success in business requires a deep commitment, rather than just a passing interest. He encourages shop owners to fully dedicate themselves to their goals and to cultivate a mindset that prioritizes long-term success over short-term gains.
      The benefits of business coaching are also highlighted, with Chris advocating for the value of having a mentor or coach to guide business owners through the complexities of running an auto repair shop. He shares how coaching can provide clarity, accountability, and strategic direction, ultimately leading to more effective decision-making and business growth.
      Throughout the episode, Chris underscores the importance of professionalism within the industry. He stresses that maintaining high standards of professionalism not only enhances the reputation of individual shops but also elevates the industry as a whole.
      In addition, he encourages listeners to take advantage of the marketing resources offered by the podcast's sponsor, Shop Marketing Pros. He explains how utilizing these resources can help shop owners effectively reach their target audience, build their brand, and drive business success.
      Overall, the episode serves as both a retrospective on the past year's achievements and a motivational message aimed at inspiring business improvement. Chris Cotton's insights and stories provide valuable lessons and encouragement for auto repair shop owners looking to elevate their businesses to new heights.
      Introduction to the Podcast (00:00:11)
      Overview of the podcast's purpose and the value it offers to auto repair businesses. Celebrating Episode 200 (00:01:08) Kimberly's Kidney Donation (00:02:06) Highlighting Episode 164 - Unlocking Greatness (00:04:21) Highlighting Episode 170 - Four Day Workweek (00:05:24) Preparing for 2025 (00:07:42) Highlighting Episode 172 - Commitment vs. Interest (00:08:46) Highlighting Episode 175 - The Pumpkin Patch (00:09:58) Highlighting Episode 180 - Profit First (00:11:11) Highlighting Episode 185 - Mom and Pop Shops (00:12:00) Highlighting Episode 186 - Coached vs. Uncoached (00:12:46) Highlighting Episode 187 - Project Alpha (00:13:05) Highlighting Episode 189 - Impact of Politics (00:13:55) Highlighting Episode 192 - Self-Obstruction (00:14:20) Highlighting Episode 193 - Being the Best Shop (00:14:46) Highlighting Episode 197 - Chris's Favorite Things (00:15:30) Looking Ahead to Episodes 201 and 202 (00:15:50)
    • By marxautocenter
      Thanks to our Partners, NAPA TRACS, and Today's Class Discover how to harness AI tools effectively in business with two experts from Optimize Digital Marketing. They share practical tips on using AI to streamline operations, generate creative marketing ideas, optimize SEO, and improve customer interactions—all while maintaining a personal touch. Learn how to balance AI’s efficiency with human creativity and judgment, avoid pitfalls like bias and plagiarism, and make AI work for you without losing authenticity. Doug Robison, Director of Sales and Partnership, Optimize Digital Marketing  Jordan Greene, Director of Product and Partner, Optimize Digital Marketing  Show Notes Watch Full Video Episode Discussion on AI (00:00:00) "Add You to It" Concept (00:02:13) Cautions with AI Use (00:03:56) AI in Customer Interactions (00:05:08) Risks of AI Responses (00:06:18) Personalization in AI Responses (00:07:29) AI's Evolution (00:08:26) AI's Historical Context (00:09:23) Logistical Challenges of AI (00:12:09) AI in Automotive Industry (00:13:11) AI's Role in Marketing (00:14:01) Best Practices for Using AI (00:15:51) Emotional Tone in AI Prompts (00:16:49) Adapting AI for Different Roles (00:17:16) Gemini AI and Source Validation (00:19:59) Caution with AI Outputs (00:21:08) AI's Role in Enhancing Efficiency (00:22:05) Plagiarism Concerns in AI Usage (00:23:00) SEO and AI Integration (00:26:07) Human Oversight in AI Use (00:29:09) Veterinary Analogy in Customer Relations (00:34:29) The Importance of Charging Appropriately (00:34:52) AI as a Virtual Assistant (00:36:10) Utilizing AI for Problem-Solving (00:37:25) AI in Education (00:37:51) Enhancing Communication with AI (00:39:07) Efficiency Through AI (00:39:38)
      Thanks to our Partner, NAPA TRACS NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Thanks to our Partner, Today's Class Optimize training with Today's Class: In just 5 minutes daily, boost knowledge retention and improve team performance. Find Today's Class on the web at https://www.todaysclass.com/ Connect with the Podcast: -The Aftermarket Radio Network: https://aftermarketradionetwork.com -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on X: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/
      In our episode this week - roles are reversed!
      Our host Craig O’Neill allows himself to be interviewed by a friend of the show - Evan Wisner.
      This is one of those conversations you can turn on - laugh, and learn with.
      The reason for this role reversal? Evan had suggested it would be good for our listeners to get a chance to hear more about the journey which led Craig to develop a passion for focusing on communication and dive into what Craig sees as his goals with the podcast.
      Evan asked many questions which drew out meaningful discussion on topics including:
      Craig’s Early experiences in the industry What it’s like to grow up within the industry and it’s stigmas The effect a good ‘ambassador’ can have on others perspective of the industry Formative feedback that promoted early interest in communication skills Perspective on technology in communication pros/cons Craig’s mentors and the most important advice he’s received Early obstacles to improving communication and mindset Developing the ability to choose not to take offense to things Toastmasters then vs now. The joy of observing others improve their skills A reminder that it’s about progress, not perfection.
      Loyal listeners will find plenty of inspiration in this episode and emerge feeling great about the talent in our industry, and the value of friendships and relationships developed around mutual purpose. Those who have become familiar with Evan will appreciate the back and forth conversation that flows through many very thoughtful questions.
      The Word of the Day:
      Heedful
      - adj -
      Aware of and attentive to.
      The Institute at WeAreTheInstitute.com. "Stop stressing over your business, you deserve a good night's sleep. The Institute’s coaching helps you achieve success and financial peace.
      Email Craig O'Neill: [email protected] Watch Full Video Episode
