What do you do to protect your machine? Will stop leak ruin your recovery machine? How to protect it?OTC has a filter I bought it but not sure where to install or if it is recomended.I have a CPS Mach 7 I'm not sure if recover is only from the low side? The machine recovers so slow now I hate to slow it down more........And what if you use a refridgerent identifer to see whats in a customers car and it fails the test .What do you do then? will stop leak or air make it fail ?
  • 2 years later...
I'm going to resurrect this post, as I have been wondering the same thing.
Our equipment supplier has a ton of stories about stop-leak ruining recovery equipment. Are you guys running any pre-filters on your high/low lines, or how are you testing for stop-leak prior to evac'ing systems?
When I worked at the dealer, we never checked... But the type of cars that come into aftermarket/independent shops are probably more likely to have leak sealant vs. those that go to the dealer...
That being said, I said a little prayer right after I bought my AC machine, praying that I wouldn't get any cars in my shop with a sealant... That's how I protect mine :D
They have some kits out there that just screw on the the service port and create a real tiny leak. If the leak stops, then you know it has sealant... Pretty simple system, I can find the website again with a video if ya need
Wow. That's a great idea. Yes, please shoot me the video when you have a minute.
Excellent video. However, he did not answer the million dollar question: What do you do when leakseal is detected? It's certainly not recoverable. Vent it to the atmosphere? Put a filter on the recovery machine (do these even work)? Tell the customer tough luck?
We have used the Neutronic's system for a little over two years now. Have caught more then a half dozen with the sealent in the vehicle system before we hook up. I will not let our guys hook up without testing and if they find any trace they are instructed to not hook up any other A/C equipment,
I would recommend purchasing the tester and using it.
Spence
Thanks, Jeff. Good to know, I'm going to ask the rep about an all-in-one unit.
Spence, how do you service A/C systems where you do find sealants, though?
Wes lets think about it for a minute or two here. Just who do you think would put this sealant crap in?
Haha, they're across the counter from you. The fix-o-can from AutoZone didn't work, so now they're at the shop.
Seems you may have a handle on this... So now the question isssssss... Do you want this kind of person as a customer?
Another part of your comment is more then likely true as well. You say it didn't work, Explain what you mean by it?
Is this a trick questions, because I'm not very good at riddles. The fix-o-can didn't work ... i.e. the leak stop didn't stop the leak / fixed it too late / wasn't the issue in the first place / etc.
Don't mean for it to be a trick question. It was meant to make you think. By answering it you will have come to the conclusion made by your own answers instead of me just saying this is the way it is done. Hell you might not like the way I say it is done and who am I to say something should be done that way in the first place. So if I comment and we discuss it I might turn the light bulb on in your head to a thought of how you want to handle it.
Now to get back to my question. If the leak is not fixed the car probably is low on refrigerant and not cooling as the consumer wants on the hot day they are across your (or my) counter. If it is a leak that is causing it not to work then it will be empty soon and you won't have to recycle it into your machine. There was an "IF" at the beginning of that comment. What does the sealant do? When it works on clogging leaks it will also start clogging up EVAPORATORS and CONDENSERS. If you do not understand A/C systems and are only a shop owner and not a tech then ask your tech what happens if a either or both of these clog up! The system will NOT function properly! Keep that thought for the next paragraph.
I ask you now the same question I did in reply #13. Do you want this person for a customer? Is this a trick question... Well here's some thought.
1. If they are of the cheap kind of customer they are going to eat your lunch if you handle this wrong!
2. If they bought the car this way from a used car lot of private sale you have a chance of making them a customer if you handle it right.
I'll let you dwell on that for a bit... B)
Edited by Spence
Hmmmmm, I've never thought about this type of situation... Can't help but feel you have gone through this before. GRRRRRR, sounds like I need to loosen my grip on my wallet and buy a freaking leak sealant detector kit
Edited by mmotley
Holy cow! All I can say is price shop that neutronics kit!!!! Ebay has quite a few for MUCH cheaper than their website.
Hmmmmm, I've never thought about this type of situation... Can't help but feel you have gone through this before. GRRRRRR, sounds like I need to loosen my grip on my wallet and buy a freaking leak detector kit
Cool so I got you to think. :) So if you have a "CHEAP" consumer... And they installed this crap... For the sake of conversation the leak is a hose... So you drain the half charge left in this system into your equipment, You replace the hose. You did a proper repair and recharge the system with the proper amount of refrigerant but being as the evaperator and/or the condensor is not functioning correctly due to being clogged... This system doesn't cool properly...
Now just who do you think this CHEAP CONSUMER is going to blame for what they feel was a poor service because they now paid for it... Just who do you think they now want fixed for ahhhhhhh... FREE? Oh but you now are back pedaling trying to say they need more parts to fix this vehicle and you want more money...
I said if this is not handled properly they will EAT YOUR LUNCH... Oh yeah and I'm sure they are talking good about you to everyone they know...
How we doing now? B)
Edited by Spence
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Dan Clark explores how emotion surpasses reason in driving action, particularly in sales, emphasizing the power of storytelling to activate specific brain chemicals. He shares personal experiences, including his recovery from paralysis, to illustrate the impact of belief and a strong "why." The conversation delves into societal stigmas around emotional expression, especially for men, and the importance of genuine connection. Clark further explains how leveraging brain chemistry through storytelling enhances influence and strengthens customer relationships. He concludes by stressing that businesses should prioritize deep human connections over mere transactions. Dan Clark, Hall of Fame Keynote Speaker, New York Times Best-Selling Author of 37 Books, Expert in Next-Level Leadership for Teams, Sales, and Life. https://danclark.com/ Show Notes Watch Full Video Episode The Institute of Automotive Business Excellence: https://www.wearetheinstitute.com/ Introduction of Dan Clark (00:00:00) The Importance of Emotion in Memory (00:02:47) Emotion vs. Knowledge in Sales (00:04:17) Statistics on Sales Persistence (00:04:47) The Role of Storytelling in Sales (00:05:13) Social Stigma Around Emotion (00:05:23) Mental Health and Emotional Prosperity (00:06:01) Creating Discomfort for Growth (00:07:05) Asking for Help in Mental Health (00:07:49) The Role of Feelings in Leadership and Sales (00:08:07) The Zone and Brain Chemicals (00:09:11) Emotional Connection in Sports (00:10:06) Impact of Storytelling on Audience (00:12:07) Overcoming Struggles and Emotional Growth (00:16:29) Authenticity and Emotional Expression (00:17:54) The Importance of Belief (00:18:30) Energy and Attraction (00:19:26) Authenticity in Connection (00:19:54) Personal Injury Story (00:20:31) Rock Foundation vs. Rock Bottom (00:21:21) Core Values in Business (00:22:22) The Power of Belief (00:23:08) Asking the Right Questions (00:23:51) Connecting Head and Heart (00:24:36) Physiological Responses to Fear (00:24:49) Storytelling in Sales (00:27:32) Self-Awareness in Customer Service (00:28:29) Identifying with Roles (00:30:22) Heart-to-Heart Connection (00:30:44) Story of Empathy (00:31:07)
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Get ready to grow your business with the Automotive Management Network: Find on the Web at http://AftermarketManagementNetwork.com for information that can help you move your business ahead and for the free and informative http://LaborRateTracker.com Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/
      Introduction to the Podcast (00:00:01)  The podcast begins with a welcome message from the host, Brian Walker. Guest Introduction (00:00:10)  Brian introduces co-host Kim and guest Doug DeLuca, owner of Boca Auto Fix. Overview of Boca Auto Fix (00:00:51)  Doug shares details about his auto repair shop, including its location and age. Hiring an Apprentice (00:01:09)  Doug discusses the recent hiring of an apprentice and the journey leading to this decision. Challenges in Hiring (00:02:13)  The speakers reflect on the difficulties shop owners face in finding and hiring young talent. Marketing Journey Begins (00:03:02)  Discussion shifts to Doug's initial marketing efforts and his involvement in content creation. Background in Technology (00:04:07)  Doug explains his previous technology background and how it influenced his approach to marketing. Learning SEO and Marketing (00:04:45)  Doug describes his self-taught journey in SEO and digital marketing after opening his shop. Realizing Marketing Needs (00:06:14)  Doug reflects on his initial assumptions about marketing and the reality of attracting customers. Understanding SEO Basics (00:08:09)  Doug shares his insights on SEO and the learning process involved in mastering it. Frameworks in Marketing (00:10:25)  The conversation explores the use of frameworks in both auto repair and marketing strategies. Adopting "They Ask, You Answer" (00:11:23)  Doug discusses his experience with the "They Ask, You Answer" philosophy in content creation. Writing Blogs for Customer Engagement (00:12:21)  Doug explains how he uses customer inquiries to create relevant blog content for his shop. Experience at a Quick Lube (00:13:29)  Doug shares his firsthand experience at a quick lube to highlight differences in service quality. Experience Comparison (00:14:06) Doug shares his experience of visiting a competitor's shop to understand customer perception and service quality. Proactive Client Advocacy (00:14:57) The team discusses the importance of guiding potential clients to the right service provider based on their needs. Sponsorship and Marketing Tools (00:16:13) Brian introduces RepairPal, highlighting its benefits for attracting new customers and building trust. Customer Loyalty Apps (00:17:51) Brian discusses the advantages of using App Fueled to create customer loyalty programs for auto repair shops. Incognito Visits (00:18:20) Doug talks about visiting a competitor's shop incognito to gain insights without revealing their identity. Collaboration Over Competition (00:19:09) The speakers explore the idea of referring customers to other shops and building relationships in the industry. Challenging Competition Norms (00:20:20) Brian reflects on inviting competitors to the podcast, emphasizing collaboration over traditional competition. Marketing Involvement (00:22:42) Doug explains the ad hoc nature of their marketing efforts and the role of social media in their strategy. Community Involvement (00:27:41) Doug shares their family's volunteer work and how it integrates with their business's social media presence. Engaging the College Market (00:28:51) Doug discusses how 30% of his clients are college students and their marketing strategies. Collaborating with Local Professors (00:31:18) Doug shares his experience working with a marketing professor for student analysis of his business. Challenges of Seasonal Demand (00:32:24) Discussion on the impact of seasonal changes on business demand and local marketing efforts. Starting with Marketing (00:34:02) Doug advises new shop owners to listen to podcasts and conduct online research for marketing. SEO as a Long-Term Strategy (00:35:08) Doug explains the importance of SEO and its long-term benefits for business growth. Understanding Competition (00:36:44) Doug emphasizes the need to analyze competition and not assume marketing strategies will work universally. The Importance of Data (00:39:08) Doug highlights the role of data in assessing marketing effectiveness and making informed decisions. Nuances of Market Dynamics (00:41:14) Discussion on how geographical and seasonal factors affect marketing strategies in auto repair. Client Avatar and Marketing Alignment (00:42:13) Doug explains the significance of understanding the ideal customer for effective marketing strategies.  Overcoming Diagnostic Fee Challenges (00:43:09) Discussion on how Doug has adjusted his approach to diagnostic fees to improve customer conversion. The Importance of Evaluation Fees (00:43:40) Discussion on the role of evaluation fees and their impact on shop maturity. Improving Customer Communication (00:44:09)  Insights on enhancing customer explanations regarding services and processes. Coaching and Competitive Analysis (00:45:03)  How coaching helped refine service policies and improve customer relations. Content Creation and Marketing Strategy (00:46:32)  The significance of creating content for customer engagement and marketing. Duck Duck Jeep Initiative (00:47:05)  Fun marketing strategy involving ducks to engage with the local Jeep community. Value of Customer Feedback (00:48:46)  Importance of understanding customer inquiries and improving service based on feedback. Contact Information for Doug DeLuca (00:49:29)   Doug shares how listeners can reach him for further inquiries.
      Overcoming Guilt (00:03:04)
      chris autofixsos.com
