Some Fatherly Advice Gonzo 2010
Before my father passed away we spent several years under the hood of cars working together at my shop. He was an old school repair guy. Always looking out for the customer, and wanting to do that little bit extra for them. You know, adjust that crooked license plate, grease the door hinges before they pulled away from the shop, that kind of thing.
I usually did the diagnostic work, and he would stick with the mechanical repairs. But most of the time his favorite thing to do was to entertain the customer while I figured out the problem. The one thing that would give him fits was the way a customer would react after I diagnosed the problem, especially if I diagnosed it quickly. A quick diagnostic might be fine for some people, but others it was more of a matter of pride that their "regular" mechanic hadn't found it so quickly, or that the customer themselves didn't find it so easily. It didn't set well with them. I got the impression that a quick diagnosis led to some sort of mistrust with my abilities, or that I didn't thoroughly examine the problem to their satisfaction. A lot of times it had more to do with the previous technician taking so much time and not coming up with an answer, so they think it can't be that simple.
Dad had his own answer for it. He was going to get one of those aluminum foil fire suits, a couple of tall curtains on moveable stands, a disco ball, and some strobe lights. His idea was to pull the car into this "special" diagnostic area turn on the strobe lights and hang the disco ball over the car. Stick the suit on and make some comment like, "I'm going in…" and then let the light show begin. After a few minutes, come out from behind the curtain wall, whip off the aluminum fire suit hood and say something like, "Whoo that was a tough one." Maybe then, these types of people would be more likely to believe the results of a quick diagnosis.
We never tried it, but I think about doing it from time to time. With the advent of the scanners to read and show detailed parameters diagnosing has taken on a whole new approach. A lot of problems are a matter of following the diagnostic tree correctly to get to the source of the problem. (Codes don't fix cars… codes are the starting point) Sometimes it's a quick trip on the diagnostic ladder, and other times it's quite lengthy. It really depends on the problem, of course.
Trying to be quick and on the right track with every diagnosis is what makes the money in the shop. Stalling the results just for the sake of making it look like it was an extensive search to find the problem doesn't make a lot of sense to me. Then on the other hand, I sometimes believe this is one of the many reasons why a doctor has you wait so long for his 10 minutes of time. Even though he may have walked into the exam room, looked at the chart, took some quick looks at you, and back out of the exam room in less than 10 minutes, I'll guarantee his bill isn't going to show a 10 minute charge on it. But, in my business, time is money… and most customers are watching the clock.
Back in the days when my father and I worked together, he came across an old Bosch injector tester for the early K and L injection systems. The old tester was done for. Not only was it dated, it had several missing connectors and the information booklet didn't come with it. I took it apart and rewired it as a large volt meter, with a lighted buzzer attached to a separate set of wires. We then rigged up a swinging arm mounted to the wall out of PVC pipe. The pipe contained the wires to the tester that we mounted on the wall. It was more for decoration than usable, but it was kinda cool in its own funky way.
Anytime we got one of those "lookylews" (one of my dad's favorite words), you know the type, the kind that has to hover over the hood while you're working on it. Dad would motion to me to wire up the buzzer to the battery, and use it as a way to find the draw or short in the car. His job was to entertain, while I looked for the problem. Most of the time, I'd study the wiring diagrams, determine the most likely spot for the problem, and find the solution. As I would get close to the problem I would intentionally ground out the buzzer on the wall, and it would make a horrible noise. Dad would make a comment to the customer as to what was going on. His old school charm was what made the difference. At times this whole thing would get quite humorous. I'd be lying under the dash zapping the buzzer and good old dad would be working his magic with his broad smile, and his quirky sense of humor.
These days the electronic scanners have somewhat evened the playing field. To some degree the abilities of a good tech are now wrapped up in a good quality diagnostic machine. But it still takes a good tech to understand it, and evaluate the information he/she sees on the screen.
I still try to diagnose things as fast and accurately as I can. I don't have the old buzzer, or my dad's inventive conversations with the customers to help me with the diagnostics. It's a memory I'll never forget. But, I'll always keep in mind some of those lessons from my father… "Take your time son, you're good… but they (the customer) don't know how good you are… so you'll have to prove it to them each and every time."
Old school wisdom is still important, and fatherly advice is some of the best.
Thanx for taking time to read my stories. These stories are here for your enjoyment and before final editing. As a shop owner, an author, and a syndicated columnist I spend an equal amount of time writing as well as turning wrenches. So each week I try to introduce one new story for everyone to read. Your comments are extremely valuable to me to find out what you think of the stories.
Leave a comment and visit my webiste www.gonzostoolbox.om for more auto info.
Thanx again, Gonzo
Edited by Gonzo
Joe, you are always welcomed with your comments. I see I accomplished what I set out to do in this story. Have guys like you and me read this, and walk away with a better outlook on what we do. A little self gratification is what I call this article. Like ya said, it's a roller coaster of emotions. It makes ya think of the past and the future at the same time. I can't think of a better way to express it than the way I wrote this article. I'm sure one of my editors is going to pick this one up and print it in one of my columns. I think it's a story that needs to be told to everyone out there in the business.
Thanx again Joe, as always... I'm very appreciative of ASO, it's my pleasure to share my thoughts and stories with everyone. All the best... Gonzo
Wow, is it me or are there multiple messages all wrapped up in one story? My emotions were on a roller coaster ride as my mind shifted from the customer, the new technology, how we did things in the past and even brought back memories of my own father.
Here's personal note: Thanks! Thank you for explaining in one article why people like us choose this business and why we are the best of the best!
I was having a tough time today thinking about an article for the next ASO newsletter….well thanks to you I know what to write about.
It's timeless... I don't think it will ever change in this business. All the tomorrows start with doing a good job today. you can quote me on that one... LOL
I love the quote at the end. Very important message to remember.
      Introduction to the Episode (00:00:01) Brian Walker introduces the podcast and guest, Hallie Wassinger, discussing the importance of Google Local Services Ads. Overview of Google Local Services Ads (00:02:53)  Hallie explains the recent availability of Google Local Services Ads for auto repair shops across the U.S. Historical Context of Local Services Ads (00:03:25)  Discussion on the past availability of Google Guaranteed Ads and their expansion to auto repair shops. Current Availability and Limitations (00:04:38)  Hallie details the current state of Local Services Ads for tire shops and their limited availability. Cost Structure of Local Services Ads (00:05:34)  Introduction to the pay-per-lead model, highlighting its differences from traditional Google Ads. Service Categories for Auto Repair (00:06:45) Hallie outlines the specific services auto repair shops can advertise under Local Services Ads. Lead Generation Process (00:07:44)  Explanation of how leads are generated through phone calls or messages via the Local Services Ads dashboard. Ongoing Maintenance of Ads (00:08:31)  Discussion on the necessity of monitoring and rating leads to optimize the ad performance. Success Stories from Beta Testing (00:10:55)  Brian shares a success story from Chris Cotton, highlighting low lead costs achieved through Local Services Ads. Lead Cost Insights (00:11:39)  Hallie provides average lead cost data, emphasizing the effectiveness of the ads for auto repair shops. Visibility of Local Services Ads (00:12:18)  Brian describes how Local Services Ads appear prominently in search results, enhancing visibility. Google Screened vs. Google Guaranteed (00:13:02)  Hallie explains the differences between Google Screened and Google Guaranteed, focusing on their application processes. RepairPal Sponsorship Message (00:14:27)  Brian thanks RepairPal for sponsoring the episode and discusses the benefits of being in their certified network. App Fueled Sponsorship Message (00:15:32)  Brian introduces App Fueled, promoting their customer loyalty app for auto repair shops. Verification Process for Shops (00:16:33)  Hallie outlines the verification process for shops to join Google Local Services Ads, including necessary checks. Verification Steps for LSA (00:16:50)  Overview of the verification process for auto repair shops applying for Google Local Services Ads. Challenges with Specialty Shops (00:19:14)  Discussion on difficulties specialty shops face with Google Local Services Ads targeting. Specialization in Google Ads (00:20:03)  Insights on why specialized shops may benefit more from traditional Google Ads. Opportunities with LSA (00:22:05)  Exploration of the current opportunities available for shops using Google Local Services Ads. Cost Benefits of LSA (00:23:13)  Comparison of lead costs between Google Local Services Ads and traditional Google Ads. Importance of Google Business Profile (00:24:29)  Discussion on how optimizing Google Business Profiles impacts LSA ad performance. Role of Reviews in SEO (00:27:40)  Emphasis on the significance of keywords in customer reviews for improving visibility. Optimizing Photos for LSA (00:29:42)  Best practices for managing and updating photos in Google Local Services Ads. Pricing for LSA Management (00:31:01)  Details on the costs associated with managing Google Local Services Ads for shops. Introduction to LSA (00:33:47)  Discussion on the performance of Google Local Services Ads and how to get started. Discovery Call Process (00:34:15)  Details on scheduling a discovery call and assessing local competition for LSA. Final Thoughts on LSA (00:34:38)  Emphasis on the importance of early adoption of LSA for auto repair shops. Self-Management of LSA (00:34:40)  Advice on running LSA independently, highlighting the required time and dedication. Closing Remarks (00:35:29)  Thanking listeners and sponsors, and encouraging engagement with the podcast.
