HOOPTY Gonzo Jan. 2010
A decrepit 94 Impala SS with a 5.7 liter engine was towed in. When this thing was new, it was a real power house. But, this poor thing had a pretty rough life. Terry, (My buddy the tow driver) was standing in the lobby with this grin on his face. I could tell he was about to give me one of his patented tall tales about this car.
"Gonz, you're going to like this one, nice car, a crème puff, oh, and the paint, awesome, just awesome... You'll have to put your gloves on before you start on this cherry ride. Wait till ya see this one," he tells me, while trying to keep a straight face.
"Really, how come I don't believe you," I said.
By now he couldn't stop from laughing, and then he tells me that on the way over the trunk lid pops open. He stopped to close it only to find out that the entire latch area was completely rotted away. The car was completely painted with flat black paint from a spray can. No door panels, broken trim inside and out, cracked glass, and a pillow in the driver seat to keep you from falling thru the seat. The car had a slight lean to one side as if a spring was broken or the shock towers were rusted thru. The outside mirrors are dangling off the doors, the wheels don't match, and there's a steady drip of oil from under the car. It's a real POS. (Your definition is sufficient; I don't need to explain that one I'm sure.)
It started, so I drove it into a service bay. The thing smelled awful and I'm not talking just the exhaust. All I was told was that it would die while driving and you would have to wait quite some time before it would start again. The service light was on, along with almost all the other warning lights. But as it was, I was only concerned with the service light and see if that led to any results.
Several codes were stored; I wrote them all down and then cleared the memory and restarted the car. 2 codes did return right away. One was for the secondary air system, that one was easy, the relay was missing. The other code (code 36) had to do with the distributor (High resolution circuit). I ran the test procedure to see where it led. One of tests required that the connector at the distributor needed to be disconnected to verify connection quality. The connector…. A … what connector? Someone had stabbed the 4 wires into the distributor housing and then used silicone to keep them in place. The entire distributor area was covered in oil. In fact, the oil was dripping out of a crack in the distributor cap. (How the H?LL did this thing even start?)
There's no sense in going any further, I priced out the obvious parts and called the customer. To say they were shocked would be an understatement. This distributor isn't cheap by a long shot on these 5.7's. But, what surprised me even more was what the owner told me.
He said, "The parts were new."
New? You've got to be kidding me. I needed to find out what this bailing wire commandos version of new was. There wasn't one new part on this heap. The crack in the distributor cap was large enough to actually be seen without getting that close to it. And, that's even with the distributor buried behind the waterpump and the harmonic balancer. You could see it plain as day.
"Where did you get them?"
"Salvage yard across town," he said.
"Then there not new, they're just new to the car," I told this POS captain.
"Well, they looked new when I took them off the wrecked car," he tells me.
Off a wrecked car, of course a wrecked car… right….I'll bet it's probably one that got smacked by a train right in the radiator too. It's not so much that this POS pilot used salvage yard parts, that's not what I'm concerned with. It's the amateurish way he installed the distributor wires and the fact that he wasn't concerned about this huge crack. But, as it always seems the case… money, or the lack of, is the real issue here. Now why is it, when you get a job in like this the very first thing that happens is the wallet starts to dictate the repair.
He wanted to know if he could get more parts from the salvage yard and if I would put them in. I don't like doing that, but to help the guy out I said I would work with him, a bit. But the big deal was that connector; he had to find a replacement. As far as he knew there wasn't another one at the salvage yard with a decent connector.
After talking to the dealership about the parts, they told me there was a replacement harness still available, however, it was revised from the original and most likely the connector would not match the older style distributor. So, it's not looking good for this guy.
When I told him what the labor costs would be just to replace the distributor and the rewire the connector, he had a big problem with that, he couldn't afford any of it. Then the wallet started talking again, now he wanted me to change only the distributor connector since the other parts were new. There's that word again… new… Yea, right it's new…. Let's leave the dripping oil filled distributor assembly bleeding all over the place. I'm sure that's exactly how it was designed to work. Must be one of those "total loss" oil systems from years gone by that I read about in the history books.
I think it's time this guy finds a new car. I'm sure if he drove, pushed, or pulled this heap of junk to the salvage yard the car would automatically find its own parking spot somewhere next to the rest of the worn out scrap wagons waiting for their final demise. It's just too far gone for any professional shop to tackle on this guy's income. Not that it couldn't be repaired and brought back to refurbished shape, just not on this guy's salary.
Sorry dude, I'm real sorry, but I can't work these kinds of miracles on a budget. The sad truth of it is, there are a lot of cars out there that are in just as bad of shape. Look around the next time you drive home you might even spot one of these "hoopties" driving down the road.
I feel pretty bad that even though I know how to fix it, I just can't fix it without spending a fortune on it, and maintain some professionalism to the finished product. I took some time to talk him, gave the young lad some fatherly advice on how to pick out a decent car and not get so wrapped up in his emotional attachment to this aging wanna-be hot rod. (He called it a hot rod… not me.)
I hope he takes my advice, and I hope he finds a decent cheap car that won't eat his pocketbook up in repairs. Because this car is done, put a fork in it… call the scrap yard and tell them, "Gotta another one for the crusher!"
Thanx for reading these stories, they are here for your enjoyment before publication. The final version that is published might be slightly different, and that's how you can help. Your comments make it easier for me to edit and send a finished story.
Thanx, Gonzo
Edited by Gonzo
Thanks Joe, always like to hear from ya, I believe the sad part of this story is the poor car.... it was a totaly bomb... LOL
and the guy didn't have a dime. In fact he called several days in a row to find out the cost of diagnostics before towing it in.
There's no doubt that any professional shop that would have done "anything" to this car .... it would come back and haunt you.
This was the type of person who can't see how bad it really is, he only invisions it as it once was.
I was more afraid of this guy coming back the next day or next week with another "no-start" condition unrelated to the last repair... and with an attitude.
Sorry, gettting to old for that. This POS needed to rest in pieces...it kinda, sorta was already doing that... because everywhere it went something fell off.
Great story...more sad than funny. Even after more than 35 years in this business, people still baffle me. I do agree that it's about money...but not everyone is having it tough financially. I think, too many people DO NOT WANT to spend the money. As usual, I enjoyed reading you article. Thanks!
Oh man, what a riot... I thought I was the only one that did that.... I don't call it "married" to them I call it "given birth to a step child" LOL
The way I look at it... you've taken responsiblity for the car, but you didn't create the problem.... LOL
That's so so SO true .... Now that put a big smile on my mug... thanks for sharing guys... Sounds like I've got another story idea ...
Agree...I have gotten "married" to a few cars too in my career, it's no fun. I hate to profile a customer and/or the car they drive, but sometimes the end result does not justify the time, effort or money.
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Recorded at the 2025 Institute Summit, workplace culture expert Dr. Jessica Kriegel discusses her data-driven framework for boosting business performance through clarity, alignment, and accountability, anchored by her "Results Pyramid," which highlights how beliefs and experiences shape outcomes.
      The discussion unpacks what truly defines organizational culture, the power of storytelling to inspire change, and challenges common generational stereotypes in the workplace, advocating instead for a focus on individual motivations and behaviors. Dr. Jessica Kriegel, Chief Strategy Officer of Workforce and Labor for Culture Partners Dr. Jessica Kriegel is driven by data and defined by results.  She transforms corporate culture for success.  As seen on CNBC, MSNBC, CNN, NBC, FOX Business, New York Times, Wall Street Journal, Forbes, and more,  Jessica is a household name for all workplace, labor, leadership, women in the workplace, and job markets. Her renowned “Culture Equation” was acquired by Culture Partners in 2021, where she is currently Chief Strategy Officer of Workforce and Labor. https://www.jessicakriegel.com/ Show Notes Watch Full Video Episode The Institute of Automotive Business Excellence: https://www.wearetheinstitute.com/ Overview of Dr. Jessica Kriegel (00:00:00) Three-Step Change Equation (00:02:47) Accountability in Business (00:03:31) Results Pyramid Explanation (00:04:11) Beliefs and Experiences (00:05:09) Defining Workplace Culture (00:06:50) Hospital Story for Illustration (00:12:02) Transformative Change Through Storytelling (00:14:09) Culture of Caring (00:15:09) Storytelling in Meetings (00:15:58) Generational Dynamics (00:17:51) Technology Adoption Across Generations (00:20:37) Connecting with Dr. Kriegel (00:22:23)
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Get ready to grow your business with the Automotive Management Network: Find on the Web at http://AftermarketManagementNetwork.com for information that can help you move your business ahead and for the free and informative http://LaborRateTracker.com Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/         Click to go to the Podcast on Remarkable Results Radio
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Margaret Palango, CEO of Autoshop Solutions, shares her unexpected diagnosis of acute myeloid leukemia (AML) in May 2023. In this powerful episode, she shares the emotional and physical hurdles she faced, the intensity of her treatment, and how she stayed grounded through it all with a positive mindset. Margaret highlights the critical role of a strong support system and how her team, resilience, and leadership helped her navigate one of life’s toughest battles. Her story is a moving testament to the strength of the human spirit. Don’t miss this inspiring conversation filled with motivation, hope, and meaningful life lessons. Margaret Palango, CEO Autoshop Solutions. Margaret's previous episodes HERE Show Notes Watch Full Video Episode Introduction and Celebration (00:00:00) Margaret's Introduction (00:02:18) Understanding AML (00:02:30) The Importance of Positivity (00:06:18) Treatment Navigation (00:07:32) Listening to Your Body (00:08:18) Advocating for Health (00:09:50) Teamwork with Medical Staff (00:12:35) Managing Side Effects (00:18:25) Bone Marrow Transplant Journey (00:19:56) Importance of Remission (00:20:50) Mental Strength During Treatment (00:24:00) Support and Positivity (00:28:34) Team Dynamics and Leadership (00:30:08) Planning for the Unexpected (00:36:20) Lessons in Trust and Growth (00:37:00) Support from the Team (00:40:12)
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Dan Clark explores how emotion surpasses reason in driving action, particularly in sales, emphasizing the power of storytelling to activate specific brain chemicals. He shares personal experiences, including his recovery from paralysis, to illustrate the impact of belief and a strong "why." The conversation delves into societal stigmas around emotional expression, especially for men, and the importance of genuine connection. Clark further explains how leveraging brain chemistry through storytelling enhances influence and strengthens customer relationships. He concludes by stressing that businesses should prioritize deep human connections over mere transactions. Dan Clark, Hall of Fame Keynote Speaker, New York Times Best-Selling Author of 37 Books, Expert in Next-Level Leadership for Teams, Sales, and Life. https://danclark.com/ Show Notes Watch Full Video Episode The Institute of Automotive Business Excellence: https://www.wearetheinstitute.com/ Introduction of Dan Clark (00:00:00) The Importance of Emotion in Memory (00:02:47) Emotion vs. Knowledge in Sales (00:04:17) Statistics on Sales Persistence (00:04:47) The Role of Storytelling in Sales (00:05:13) Social Stigma Around Emotion (00:05:23) Mental Health and Emotional Prosperity (00:06:01) Creating Discomfort for Growth (00:07:05) Asking for Help in Mental Health (00:07:49) The Role of Feelings in Leadership and Sales (00:08:07) The Zone and Brain Chemicals (00:09:11) Emotional Connection in Sports (00:10:06) Impact of Storytelling on Audience (00:12:07) Overcoming Struggles and Emotional Growth (00:16:29) Authenticity and Emotional Expression (00:17:54) The Importance of Belief (00:18:30) Energy and Attraction (00:19:26) Authenticity in Connection (00:19:54) Personal Injury Story (00:20:31) Rock Foundation vs. Rock Bottom (00:21:21) Core Values in Business (00:22:22) The Power of Belief (00:23:08) Asking the Right Questions (00:23:51) Connecting Head and Heart (00:24:36) Physiological Responses to Fear (00:24:49) Storytelling in Sales (00:27:32) Self-Awareness in Customer Service (00:28:29) Identifying with Roles (00:30:22) Heart-to-Heart Connection (00:30:44) Story of Empathy (00:31:07)
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Parker Branch of Branch Automotive joins the conversation to discuss shop culture, leadership, storytelling, and business growth in the diesel specialty repair industry. Learn about the importance of employee buy-in, boosting productivity, and ways to build customer trust through thoughtful use of technology. Parker shares his journey from technician to business coach, offering personal experiences and proven strategies for success. Parker Branch, Branch Automotive, Littleton, CO. Show Notes Watch Full Video Episode TST Big Event, March 29th, 2025: https://www.tstseminars.org/ The Institute of Automotive Business Excellence: https://www.wearetheinstitute.com/ Introduction to the Summit (00:00:00) Keynote Insights (00:02:07) Importance of Storytelling (00:04:08) Parker's Background (00:04:52) Business Growth (00:05:12) Culture in Business (00:06:02) Self-Assessment in Leadership (00:08:27) Team Accountability (00:09:27) Lean Practices (00:10:26) Building Trust with Customers (00:11:27) AI in Automotive Communication (00:13:33) Motivation and Resources (00:17:26) Attracting and Retaining Talent (00:18:14) Growth vs. Loss (00:18:40) Creating a Positive Culture (00:19:34) Dealing with Toxic Employees (00:20:19) Accountability After Conferences (00:22:22) Cultural Engagement Strategies (00:23:41) Networking and Collaboration (00:24:23) Productivity Challenges (00:28:00) Quarterly Performance Evaluations (00:28:31) Inspiring Change vs. Forcing Change (00:30:20) Seasons of Business (00:31:16) Creating Momentum in Business (00:33:14) Commitment to Success (00:34:21)
