Rocky Mountain Oysters Gonzo Jan 2010
At my shop I tend to do more electrical repairs than anything else. It's what I'm known for, and sometimes I get my share of odd ball electrical problems. Sometimes it's a factory defect where a harness has rubbed into a bracket behind the dash and shorted things out.
But, a lot of the time it's some add-on that causes the problems. Usually some sort of flashy-testosterone filled bling that the owner is using to show off his macho self to all who pass by. Seldom do I see these "manly" things on a girl's car… it's mostly the guy's… sorry dudes… it's true. You guys can't leave them alone. Ya gotta show your manhood somewhere on that Detroit steel.
I had this cowboy's truck in the shop; it's a late 80's Chevy pickup, jacked up to the sky and loud. His only problem for the day was that his parking lights would blow a fuse. My usual first question is, "When did ya put in the stereo?"
Over the years I would say it's probably the no#1 problem I find in the park light systems on these GM cars and trucks of that era. It never fails; some goof ball is going to use the gray wire as the radio ground. I can usually tell these types of guys because they'll "always" tell me how they used an ohm meter to check the wiring.
Ah, dude, it will show continuity to ground because the gray wire is the dash lights and you'll pick up a ground signal thru a bulb filament back to another dash bulb. However when you turn the park lights on (which they won't check till the next time they drive at night) the fuse to the park lights will blow.
But in this case this hombre was safe… it wasn't the radio. Now I have to look elsewhere. One of my many "tricks" to test a short circuit on these older trucks is with 2 fuses. First stick one in the fuse box and turn on the park lights. (It came in blown, and I doubt you're going to make it any worse) … Keep your eye on the fuse, did it blow quickly? … Or did it take a bit? When I say a bit… I don't mean like… a second….I mean not immediately, let's just call it a quick blink. If the fuse takes a bit to blow that tells me the short is farther away from the fuse box than closer. (Learning the difference may take some practice.)
In this case this saddle sore owner's problem was not immediate, but an ever slight delay. I'm going to look around the outside of the vehicle and see if it reveals any clues. It could be in the back or the front of this herd chasing cattleman's Cadillac. I climbed out of the cab and headed to the south end of this northbound rig to check for any trailer wiring. It's my 2nd usual place to look for faulty wiring on this type of truck. Any time you get the handy-dandy farmhand with his fence pliers working his magic on the horse trailer wiring, you're going to have problems.
Well, how about that… it was professionally done… and in fact the wiring looked great! But there was this other foreign object dangling on the receiver hitch. Oh man … is this necessary? Bull testicles? There's a pair of fake plastic bovine manhood rocking back and forth with every sway of this pasture cavorting vehicle. Now, I don't know who this cowboy is trying to impress… 'cause if I was a cow… I'd think there something wrong with this bull. And, if I was some gal in a car behind this boot wearin', skoal chewin', cattle jockey… I don't think I'd be impressed… at all.
But then something else caught my eye… and it wasn't the swinging genitals. There's a small wire connected to them, and the wire is connected to the brown wire of the trailer connector… which, is the park light wiring. OMG… no way…these rocky mountain oysters light up and glow with the evening sky. I don't remember animal husbandry being a part of my job requirements. And I don't think glow in the dark dangling beef ta-tas was covered in any of my training classes.
You mean to tell me, if I disconnect the wire from this cowboy's dangling plastic bull parts the park lights might work? This is nuts! I can't believe this … … this is definitely not going well today. Well, I've gotta try, it could be the end of my search of why the park lights are blowing the fuse … here goes… … with one hand, I grabbed this pasture-prowlers-artificial-cattle-creators and held on with an almighty firm grip. With the other hand, I took steady aim with my trusty cutters--- "Snip" ---the deed is done.
Back to the fuse box and change the fuse, and then flip on the park lights. Well what do ya know, we have lights! Tell all the Angus and Holsteins on the farm – the park lights are working perfectly! ! Whoo Hoo!
I'll have to admit, it's the first time I have ever had to castrate a truck to get the park lights to work… Well, there's a first time for everything… might as well start up a new career… You'll find me on one of those late night infomercials and in the business yellow pages under;--- "Bull Castrator/Mechanic"--- .
these stories are posted before publication and final editing. Comments make a difference in which will be published. Most of these stories will be in my next book and your comments help me decide which ones to use.
Visit my website for more stories and car related info. www.gonzostoolbox.com
Edited by Gonzo
Thanx Joe, I enjoy doing the stories... and some are better than others. As I've said before, it's not so much the story but the telling of them. We all have these experiences and in some small way I hope I bring some laughter to our otherwise hetic days.
They'll be more laughs, and more stories...
thanx again... Gonzo
BTW... the reason their called Oysters.... is because they don't taste like Chicken... more like Oysters...
You are truly blessed in many ways, to have the opportunity and the ability to write in such a way that you brings joy and humor to all of us. Again, great story. I would say one of your best...BUT they are all great!
      Timestamps:
      (00:00) – Intro
      Quotes
      Tools & Resources Mentioned:
      Final Thoughts:
      Introduction to the Podcast (00:00:01)  The podcast begins with a welcome message from the host, Brian Walker. Guest Introduction (00:00:10)  Brian introduces co-host Kim and guest Doug DeLuca, owner of Boca Auto Fix. Overview of Boca Auto Fix (00:00:51)  Doug shares details about his auto repair shop, including its location and age. Hiring an Apprentice (00:01:09)  Doug discusses the recent hiring of an apprentice and the journey leading to this decision. Challenges in Hiring (00:02:13)  The speakers reflect on the difficulties shop owners face in finding and hiring young talent. Marketing Journey Begins (00:03:02)  Discussion shifts to Doug's initial marketing efforts and his involvement in content creation. Background in Technology (00:04:07)  Doug explains his previous technology background and how it influenced his approach to marketing. Learning SEO and Marketing (00:04:45)  Doug describes his self-taught journey in SEO and digital marketing after opening his shop. Realizing Marketing Needs (00:06:14)  Doug reflects on his initial assumptions about marketing and the reality of attracting customers. Understanding SEO Basics (00:08:09)  Doug shares his insights on SEO and the learning process involved in mastering it. Frameworks in Marketing (00:10:25)  The conversation explores the use of frameworks in both auto repair and marketing strategies. Adopting "They Ask, You Answer" (00:11:23)  Doug discusses his experience with the "They Ask, You Answer" philosophy in content creation. Writing Blogs for Customer Engagement (00:12:21)  Doug explains how he uses customer inquiries to create relevant blog content for his shop. Experience at a Quick Lube (00:13:29)  Doug shares his firsthand experience at a quick lube to highlight differences in service quality. Experience Comparison (00:14:06) Doug shares his experience of visiting a competitor's shop to understand customer perception and service quality. Proactive Client Advocacy (00:14:57) The team discusses the importance of guiding potential clients to the right service provider based on their needs. Sponsorship and Marketing Tools (00:16:13) Brian introduces RepairPal, highlighting its benefits for attracting new customers and building trust. Customer Loyalty Apps (00:17:51) Brian discusses the advantages of using App Fueled to create customer loyalty programs for auto repair shops. Incognito Visits (00:18:20) Doug talks about visiting a competitor's shop incognito to gain insights without revealing their identity. Collaboration Over Competition (00:19:09) The speakers explore the idea of referring customers to other shops and building relationships in the industry. Challenging Competition Norms (00:20:20) Brian reflects on inviting competitors to the podcast, emphasizing collaboration over traditional competition. Marketing Involvement (00:22:42) Doug explains the ad hoc nature of their marketing efforts and the role of social media in their strategy. Community Involvement (00:27:41) Doug shares their family's volunteer work and how it integrates with their business's social media presence. Engaging the College Market (00:28:51) Doug discusses how 30% of his clients are college students and their marketing strategies. Collaborating with Local Professors (00:31:18) Doug shares his experience working with a marketing professor for student analysis of his business. Challenges of Seasonal Demand (00:32:24) Discussion on the impact of seasonal changes on business demand and local marketing efforts. Starting with Marketing (00:34:02) Doug advises new shop owners to listen to podcasts and conduct online research for marketing. SEO as a Long-Term Strategy (00:35:08) Doug explains the importance of SEO and its long-term benefits for business growth. Understanding Competition (00:36:44) Doug emphasizes the need to analyze competition and not assume marketing strategies will work universally. The Importance of Data (00:39:08) Doug highlights the role of data in assessing marketing effectiveness and making informed decisions. Nuances of Market Dynamics (00:41:14) Discussion on how geographical and seasonal factors affect marketing strategies in auto repair. Client Avatar and Marketing Alignment (00:42:13) Doug explains the significance of understanding the ideal customer for effective marketing strategies.  Overcoming Diagnostic Fee Challenges (00:43:09) Discussion on how Doug has adjusted his approach to diagnostic fees to improve customer conversion. The Importance of Evaluation Fees (00:43:40) Discussion on the role of evaluation fees and their impact on shop maturity. Improving Customer Communication (00:44:09)  Insights on enhancing customer explanations regarding services and processes. Coaching and Competitive Analysis (00:45:03)  How coaching helped refine service policies and improve customer relations. Content Creation and Marketing Strategy (00:46:32)  The significance of creating content for customer engagement and marketing. Duck Duck Jeep Initiative (00:47:05)  Fun marketing strategy involving ducks to engage with the local Jeep community. Value of Customer Feedback (00:48:46)  Importance of understanding customer inquiries and improving service based on feedback. Contact Information for Doug DeLuca (00:49:29)   Doug shares how listeners can reach him for further inquiries.
