What we need to do is effectively educate the consumer that even though the $18.95 (yeah some shops in my area screw the public with this price point) oil change is a thing of the past. By using a far superior oil, their frequency, and therefore the effective cost over the life of the vehicle is similar or lower because they will have to change their oil less frequently. What we need really is to stop focusing on price and emphasize the higher quality.
But don't think that GM didn't have profits in mind when they developed this standard.
Mobil 1 5w-30 meets the spec. This is really nothing new, European manufacturers have been doing this for better than a decade. With extended service intervals upwards of 15k miles synthetics are required. People need to realize that an oil change is not an oil change, there is regular maintenance at regular intervals and every 7,500, 10k or 15k, whatever (per manufacturer spec) is going to cost a hundred bucks or so. Service shops need to stop pitching 3k mile oil changes because its not only incorrect, its a waste of time, money and will theoretically wear engines out faster by over maintaining them.
I agree with everything except the bold portion. Some manufactures recomend 3k lof and maintenance so a blanket answer doest work.
the only thing I can think of is if it wasnt allowing the rings to properly seat on a new engine? Otherwise Im at a loss.
Most modern engines come with a steel nitrided coated ring set on the top ring, a moly coated second ring and a low tension oil control ring in stainless.
There is no wear problem or break in issue with any modern rings, not only that but most engine assembly lines test spin new engines at end of line and the ring seating is checked and done there.
You can't over maintain a engine, what you can do is underdrive a engine and if the oil does not reach the proper tempature the detergents will not effectively clean the engine and moisture will not evaoporate out of the engine and you will get sludge. also carbon will accumulate in the rings and cuase oil burning and consumption.
the worst thing in the world or a engine is to constantly operate it below the designed operating tempature. It takes a good 15-20 minutes of run time at full tempature for the detergent carbon etc to burn off.
If you have customers who only short trip their vehicles it should be your job to alert them to the damage they are doing and that you need a more aggresive service schedule for things like the mity vac decarbon system, gm top end cleaner etc.
As most of you know I entered this business not as a technician but as a businessman. How does over maintaining an engine theoretically wear out engines faster????
Initial start of an engine after an oil change causes a period of low oil pressure that wears an engine. Most people don't pre-fill oil filters and on many cars you can't do it anyway due to mounting locations/positions. This period of time where the oil filter is being primed wears the engine more than normal as there is little to no oil pressure. Listen for it when you do your oil changes, you'll notice those few seconds of the cams running dry before it quiets down. So over-maintaining an engine is actually worse than correct maintenance. Notice that car and filter manufacturers have been moving to smaller filters in part to reduce this problem.
On Brianp's comment, I agree you are correct if the manufacturer states an interval that short. It is rare now a days though.
ehh with today aluminum bearings I wouldn;t worry to much about dry starts. Plus the journals are well oiled during a oil change.
      Oil analysis expert Lake Speed Jr., "The Motor Oil Geek," explains the critical role of oil analysis in diagnosing engine health and performance. Lake Speed Jr. is the son of race car driver Lake Speed Sr.
      Lake Speed Jr.
      https://www.speediagnostix.com www.youtube.com/@themotoroilgeek
      Discussion on Friction and Lubrication (00:00:45) Oil Analysis Services (00:02:12) Importance of Trend Analysis (00:03:13) Interpreting Oil Analysis Data (00:05:29) Evidence-Based Diagnosis (00:06:34) Identifying Head Gasket Leaks (00:07:22) Comparing Testing Methods (00:09:10) Experience in Oil Analysis (00:11:47) Early Detection of Engine Issues (00:12:43) Fuel Dilution Problems (00:13:18) Diesel Engine Challenges (00:17:11) Diagnostic Value of Oil Samples (00:18:55) Ecosystem of Vehicle Data (00:19:57) Value to Vehicle Owners (00:21:19) Misunderstandings About Motor Oil (00:22:45) Data-Driven Decisions (00:25:01) Importance of Filtration (00:26:24) Foam and Lubrication Properties (00:30:18) The Impact of Innovation (00:32:08) Rules Evolving from Success (00:32:30) Promoting Oil Analysis (00:32:46)
      Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/No Show Notes!!!
      Thanks to our Partners, Shop Boss, and 360 Payments Donny Seyfer from NASTF highlights the increasing complexity of vehicle systems, security concerns like vehicle theft, and broader issues such as employment and the right to repair. Donny Seyfer, NASTF, Listen to Donny’s previous episodes HERE. Show Notes: Watch Full Video Episode Importance of Embracing Complexity (00:00:26) Vehicle Theft and Security (00:01:01) Challenges in the Industry (00:01:35) Right to Repair Evolution (00:01:53) Preparation for Vehicle Repairs (00:03:15) Embracing Complexity for Professional Growth (00:04:21)
      Thanks to our Partners, Shop Boss and 360 Payments Shop Boss – Shop Management Software built by shop owners for shop owners. It works the way you need it to, right out of the box. Find on the web at https://shopboss.net Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -The Aftermarket Radio Network: https://aftermarketradionetwork.com -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size.             Click to go to the Podcast on Remarkable Results Radio
    • By Hands On
      My techs prefer clean up pads over kitty litter. Those of you that use pads, which ones, how much, where do you get them etc? Thanks.
    • By Transmission Repair
