What we need to do is effectively educate the consumer that even though the $18.95 (yeah some shops in my area screw the public with this price point) oil change is a thing of the past. By using a far superior oil, their frequency, and therefore the effective cost over the life of the vehicle is similar or lower because they will have to change their oil less frequently. What we need really is to stop focusing on price and emphasize the higher quality.
But don't think that GM didn't have profits in mind when they developed this standard.
Mobil 1 5w-30 meets the spec. This is really nothing new, European manufacturers have been doing this for better than a decade. With extended service intervals upwards of 15k miles synthetics are required. People need to realize that an oil change is not an oil change, there is regular maintenance at regular intervals and every 7,500, 10k or 15k, whatever (per manufacturer spec) is going to cost a hundred bucks or so. Service shops need to stop pitching 3k mile oil changes because its not only incorrect, its a waste of time, money and will theoretically wear engines out faster by over maintaining them.
I agree with everything except the bold portion. Some manufactures recomend 3k lof and maintenance so a blanket answer doest work.
the only thing I can think of is if it wasnt allowing the rings to properly seat on a new engine? Otherwise Im at a loss.
Most modern engines come with a steel nitrided coated ring set on the top ring, a moly coated second ring and a low tension oil control ring in stainless.
There is no wear problem or break in issue with any modern rings, not only that but most engine assembly lines test spin new engines at end of line and the ring seating is checked and done there.
You can't over maintain a engine, what you can do is underdrive a engine and if the oil does not reach the proper tempature the detergents will not effectively clean the engine and moisture will not evaoporate out of the engine and you will get sludge. also carbon will accumulate in the rings and cuase oil burning and consumption.
the worst thing in the world or a engine is to constantly operate it below the designed operating tempature. It takes a good 15-20 minutes of run time at full tempature for the detergent carbon etc to burn off.
If you have customers who only short trip their vehicles it should be your job to alert them to the damage they are doing and that you need a more aggresive service schedule for things like the mity vac decarbon system, gm top end cleaner etc.
As most of you know I entered this business not as a technician but as a businessman. How does over maintaining an engine theoretically wear out engines faster????
Initial start of an engine after an oil change causes a period of low oil pressure that wears an engine. Most people don't pre-fill oil filters and on many cars you can't do it anyway due to mounting locations/positions. This period of time where the oil filter is being primed wears the engine more than normal as there is little to no oil pressure. Listen for it when you do your oil changes, you'll notice those few seconds of the cams running dry before it quiets down. So over-maintaining an engine is actually worse than correct maintenance. Notice that car and filter manufacturers have been moving to smaller filters in part to reduce this problem.
On Brianp's comment, I agree you are correct if the manufacturer states an interval that short. It is rare now a days though.
ehh with today aluminum bearings I wouldn;t worry to much about dry starts. Plus the journals are well oiled during a oil change.
    • By marxautocenter
      Fixing a $20K Engine Mistake
      Thanks to our Partners, NAPA TRACS, and Today's Class This episode covers the practical benefits of digital vehicle inspections (DVIs) for shop owners. Learn how DVIs can boost Average Repair Orders (ARO) and improve customer communication. Industry professionals share real-world insights on overcoming cultural resistance, the role of leadership, and strategies for successful implementation. Plus, explore how AI enhances inspection reports and processes. Whether you're new to DVIs or looking to optimize, this episode is packed with actionable tips to help your shop thrive. Ben Dexter, National Training Manager, NAPA TRACS Chris Cloutier, Golden Rule Auto Care and CEO of Autoflow. Charlie Pixley, Charlie's Car Car, Clearwater, FL Show Notes Watch Full Video Episode Introduction to Digital Vehicle Inspections (00:00:00) Challenges of Implementing DVI (00:03:03) Leadership and Accountability (00:04:07) Charlie's Experience with DVI (00:05:02) DVI Evolution and Adoption (00:06:25) Ben's Insights on Change (00:07:56) The Importance of KPIs (00:09:41) Battling Priorities in Shops (00:13:01) Improving DVI Processes (00:16:40) Customer Perspective on DVI (00:18:53) Challenges in DVI Implementation (00:19:45) Consumer Engagement with DVI (00:20:26) AI and Technology in DVI (00:21:18) Importance of Customer Complaints in DVI (00:22:36) Professionalism in DVI Communication (00:23:40) Learning from Industry Peers (00:25:21) Benefits of DVI for Sales Growth (00:26:38) Leadership Role in DVI Implementation (00:30:49) 300% Rule in DVI (00:33:03) Creating Habits for Change (00:35:44) Leadership and Accountability (00:36:36) Key Performance Indicators (00:41:21) Start Simple and Improve (00:42:07) Constant Correction and Praise (00:43:55)
      Thanks to our Partner, NAPA TRACS NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Thanks to our Partner, Today's Class Optimize training with Today's Class: In just 5 minutes daily, boost knowledge retention and improve team performance. Find Today's Class on the web at https://www.todaysclass.com/ Connect with the Podcast: -The Aftermarket Radio Network: https://aftermarketradionetwork.com -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on X: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/
    • By Zenoo
      Hi my name is Zenas and I am 26 years old from Alberta, Canada. I started my own automotive repair shop in December 2023. After running it for 1 year I made a little bit of profit. I needed some advice on how I could increase it. Its a 3 bay shop with two 2 post hoists and one 4 post hoist with alignment. I am the only mechanic in the shop as I can't afford to hire anyone at this point. I am charging about $120 per hour for the labor and very minimal mark up on parts. The shop had no customer base when I got it so it took me sometime to build returning customers. If I try to increase the prices on parts the customers run away. Seems like they are calling around the city and going to the cheapest person. My monthly over head cost is about $7000. Whatever I make in a month goes back into next month's rent. Any advices on how to manage this properly from other shop owners?
