Shift Happens
Jo was a new customer referred by an old-time regular. Her little KIA had a transmission problem that seemed to be getting the best of the transmission shop. The story goes that the SUV was constantly in limp mode, and would never shift properly… ever. As it always seems to be the case when a simple problem can't be solved simply, somebody started the diagnostics off in the wrong direction. Little did I know this was a simple problem…. But, as I see it, each and every type of diagnostic work that you do requires a certain step by step procedure that you must follow. Miss a step, or completely overlook a step, usually means you're going to miss that simple problem all together. This was no exception.
From what information I could gather the person who diagnosed it at the transmission shop wasn't the same person who installed it. So after the tech put the last bolt in the transmission, he set the car out front, and told the front office, "Got the transmission in that KIA." The front office considered it done, and the call went out for Jo to pick it up. She didn't make it around the block before she was back at the front counter in a "not-so" pleasant mood. You can just imagine the situation at the counter… not pleasant I'm sure. After some deliberation, and very little diagnostics the transmission shop came up with the conclusion that it must be a bad transmission. Luckily, Jo's ride that had brought her there was still in the parking lot, so she left the KIA for them to re-do the whole job again.
A week later, it was supposedly done. This time a different tech had installed the second transmission. Unfortunately, he made the same mistake as the first tech. When Jo came to pick up her car the shop owner took her for a ride to be sure that the repairs were made to her satisfaction. It was a short drive… This time, the owner said he was going to pay for the transmission, and would even purchase one from the dealership just to be sure it wasn't their mistake in rebuilding it. But even the dealer transmission failed to shift properly. The tranny shop was at a loss, they decided to make a few calls for some help, and that's when my phone rang.
Now, I'm not one to diagnose anything over the phone. I just don't think it's a smart way of taking care of such problems, because you never quite know what you're getting into. But the tranny shop owner sounded desperate, and now the repair costs were coming out of his pocket. From his frantic explanations of no codes, no shift, and no idea of the problem, he kind of put me on the spot … so … I suggested a computer. Heck, why not… ya' changed the tranny 3 times for Pete's sake, obviously that ain't' it. I probably shouldn't have done that, but I think he wanted to try and save as much money as possible without resorting to taking it to another shop.
Well, a new TCM didn't work either…. Now, the car is finally coming my way. Jo was a little unsure whether or not there was anyone out there who could find the problem, but her friend told her that it couldn't hurt to let me see what I could do for her. I'll give it a try.
When the car showed up at the shop I took it around the block once to verify the condition, and then put it up on the lift. While it was on the lift I decided to drop it into gear and check it against the scanner. To my surprise, it shifted perfectly. I'm not kidding… absolutely perfect. I dropped it back on the ground, and went for a ride again. I didn't even make it around the first corner… stuck in limp mode just as it was before, this dang thing can't pull itself out of a pot hole.
Back up on the lift, and wouldn't ya know it, shifts perfectly… AGAIN! What's the deal here? I did it several times, just so I could be sure of the results I was getting. After a few trips I checked the wiring to the transmission while it was on the ground. Oh, oh, the main ground to the TCM wasn't there. How in the world was it there when it was in the air? AH HA! It's moving the wire! Yes, it was moving the wire alright, and a few more than just the TCM ground lead. The locator page showed the TCM ground wire was bundled with several other ground leads that were all attached to the main chassis ground… which wasn't attached to a thing, but was dangling by the battery box.
Turns out the whole problem started when she had her battery changed at a department store repair shop, and they didn't have the right size to fit the car. They disconnected the chassis ground wire, so the taller battery would fit.
When I told Jo what I found, the two of us pieced together the how and why it happened. Her only comment was, "Well, shift happens".
All said and done with, the transmission shop paid for the entire repair, and gave her back what she spent with them. Everyone involved was glad to have the problem solved, and the car back on the road as good as new. I like this gal, she's become a regular at the shop these days. What a card! Always has some sarcastic comment for me, but at the same time a very understanding nature and takes life in stride. I'd love to have a couple of dozen customers just like her.
As she always tells me… "If you can't live on the bright side of life… start polishing the dull one."
Edited by Gonzo
Your probably right about the tranny shop... I don't know... I really don't know. After looking back on it... I really think it was one of those jobs that the diagnostics just got off on the wrong foot and no matter what they did ... they just couldn't get it back on track. The tranny shop is usually pretty good... However, after this job I never got another job from them. I credit that to either being more careful with their diagnostics or to save embarrasment... they found somebody else to check their stuff out... go figure...
Sometimes, being good, ain't so good... at least that's my thoughts on this one.
You know these stories, as my wife tells me... Are for everyone to read that's in the business... her way of putting it... is that there is more to fixing cars than turning some wrenches or pushing some buttons on a scanner... and my stories try to bring out the other side of the business...
glad ya like the stories... so far almost everything I send out gets picked up by one of the magazines... I've hardly had to rewrite or reject a story proofing them here really makes a difference.
You know, there's one thing in this business... you hardly ever "really" get a thank you, oh we do on occasions... but for the most part... it's not like each and everyone calls you back and tells you how good their car is working..(screw one up and watch how soon they show up). I just hope my stories let everyone know... we all do care.. and we all do apperciate it. And most of those customers really do too. because... "shift happens"
Thanx again for your comments Joe.... always appreciate them...
      Introduction to the Podcast (00:00:01)  The podcast begins with a welcome message from the host, Brian Walker. Guest Introduction (00:00:10)  Brian introduces co-host Kim and guest Doug DeLuca, owner of Boca Auto Fix. Overview of Boca Auto Fix (00:00:51)  Doug shares details about his auto repair shop, including its location and age. Hiring an Apprentice (00:01:09)  Doug discusses the recent hiring of an apprentice and the journey leading to this decision. Challenges in Hiring (00:02:13)  The speakers reflect on the difficulties shop owners face in finding and hiring young talent. Marketing Journey Begins (00:03:02)  Discussion shifts to Doug's initial marketing efforts and his involvement in content creation. Background in Technology (00:04:07)  Doug explains his previous technology background and how it influenced his approach to marketing. Learning SEO and Marketing (00:04:45)  Doug describes his self-taught journey in SEO and digital marketing after opening his shop. Realizing Marketing Needs (00:06:14)  Doug reflects on his initial assumptions about marketing and the reality of attracting customers. Understanding SEO Basics (00:08:09)  Doug shares his insights on SEO and the learning process involved in mastering it. Frameworks in Marketing (00:10:25)  The conversation explores the use of frameworks in both auto repair and marketing strategies. Adopting "They Ask, You Answer" (00:11:23)  Doug discusses his experience with the "They Ask, You Answer" philosophy in content creation. Writing Blogs for Customer Engagement (00:12:21)  Doug explains how he uses customer inquiries to create relevant blog content for his shop. Experience at a Quick Lube (00:13:29)  Doug shares his firsthand experience at a quick lube to highlight differences in service quality. Experience Comparison (00:14:06) Doug shares his experience of visiting a competitor's shop to understand customer perception and service quality. Proactive Client Advocacy (00:14:57) The team discusses the importance of guiding potential clients to the right service provider based on their needs. Sponsorship and Marketing Tools (00:16:13) Brian introduces RepairPal, highlighting its benefits for attracting new customers and building trust. Customer Loyalty Apps (00:17:51) Brian discusses the advantages of using App Fueled to create customer loyalty programs for auto repair shops. Incognito Visits (00:18:20) Doug talks about visiting a competitor's shop incognito to gain insights without revealing their identity. Collaboration Over Competition (00:19:09) The speakers explore the idea of referring customers to other shops and building relationships in the industry. Challenging Competition Norms (00:20:20) Brian reflects on inviting competitors to the podcast, emphasizing collaboration over traditional competition. Marketing Involvement (00:22:42) Doug explains the ad hoc nature of their marketing efforts and the role of social media in their strategy. Community Involvement (00:27:41) Doug shares their family's volunteer work and how it integrates with their business's social media presence. Engaging the College Market (00:28:51) Doug discusses how 30% of his clients are college students and their marketing strategies. Collaborating with Local Professors (00:31:18) Doug shares his experience working with a marketing professor for student analysis of his business. Challenges of Seasonal Demand (00:32:24) Discussion on the impact of seasonal changes on business demand and local marketing efforts. Starting with Marketing (00:34:02) Doug advises new shop owners to listen to podcasts and conduct online research for marketing. SEO as a Long-Term Strategy (00:35:08) Doug explains the importance of SEO and its long-term benefits for business growth. Understanding Competition (00:36:44) Doug emphasizes the need to analyze competition and not assume marketing strategies will work universally. The Importance of Data (00:39:08) Doug highlights the role of data in assessing marketing effectiveness and making informed decisions. Nuances of Market Dynamics (00:41:14) Discussion on how geographical and seasonal factors affect marketing strategies in auto repair. Client Avatar and Marketing Alignment (00:42:13) Doug explains the significance of understanding the ideal customer for effective marketing strategies.  Overcoming Diagnostic Fee Challenges (00:43:09) Discussion on how Doug has adjusted his approach to diagnostic fees to improve customer conversion. The Importance of Evaluation Fees (00:43:40) Discussion on the role of evaluation fees and their impact on shop maturity. Improving Customer Communication (00:44:09)  Insights on enhancing customer explanations regarding services and processes. Coaching and Competitive Analysis (00:45:03)  How coaching helped refine service policies and improve customer relations. Content Creation and Marketing Strategy (00:46:32)  The significance of creating content for customer engagement and marketing. Duck Duck Jeep Initiative (00:47:05)  Fun marketing strategy involving ducks to engage with the local Jeep community. Value of Customer Feedback (00:48:46)  Importance of understanding customer inquiries and improving service based on feedback. Contact Information for Doug DeLuca (00:49:29)   Doug shares how listeners can reach him for further inquiries.
