Our state, NY, isn't considering the ban, it has enacted the ban. We will be unable to sell or install lead wheel weights as of April 1,2011. I am seriously looking at the 3M stick on roll wheel weights. That way I only have 2 numbers to stock and I have any weight I need at my fingertips. I'm curious to know if anyone else is using the 3M system. It is expensive from the start, but I think it would be cheeper than stocking all of the weights in different clips.
Another wonderful example of the government sticking its head in where it doesn't belong. Hey, lets outlaw a needed product with no good known replacement on the market. What a bunch of idiots.
Here's the NY law:
Section 1. The environmental conservation law is amended by adding a
2 new section 37-0113 to read as follows:
3 S 37-0113. LEAD WHEEL WEIGHT; PROHIBITED.
4 1. ON AND AFTER APRIL FIRST, TWO THOUSAND ELEVEN ANY PERSON REPLACING
5 OR BALANCING A TIRE ON A MOTOR VEHICLE REQUIRED TO BE REGISTERED UNDER
6 ARTICLE FOURTEEN OF TITLE FOUR OF THE VEHICLE AND TRAFFIC LAW, SHALL NOT
7 USE A WHEEL WEIGHT OR OTHER PRODUCT FOR BALANCING MOTOR VEHICLE WHEELS
8 IF THE WEIGHT OR OTHER BALANCING PRODUCT CONTAINS MORE THAN 0.1 PERCENT
9 LEAD BY WEIGHT.
10 2. ON AND AFTER APRIL FIRST, TWO THOUSAND ELEVEN, A PERSON SHALL NOT
11 SELL OR OFFER TO SELL OR DISTRIBUTE WEIGHTS OR OTHER PRODUCTS FOR
12 BALANCING MOTOR VEHICLE WHEELS IF THE WEIGHT OR OTHER BALANCING PRODUCT
13 CONTAINS MORE THAN 0.1 PERCENT LEAD BY WEIGHT.
14 3. ON AND AFTER APRIL FIRST, TWO THOUSAND TWELVE, A PERSON MAY NOT
15 SELL A NEW MOTOR VEHICLE THAT IS EQUIPPED WITH A WEIGHT OR OTHER PRODUCT
16 FOR BALANCING MOTOR VEHICLE WHEELS IF THE WEIGHT OR OTHER BALANCING
17 PRODUCT CONTAINS MORE THAN 0.1 PERCENT LEAD BY WEIGHT.
EXPLANATION--Matter in ITALICS (underscored) is new; matter in brackets
[ ] is old law to be omitted.
LBD14006-04-0
A. 8687--B 2
1 4. FOR PURPOSES OF THIS SECTION, THE FOLLOWING TERMS SHALL HAVE THE
2 FOLLOWING MEANINGS:
3 A. "NEW MOTOR VEHICLE" MEANS A MOTOR VEHICLE THAT IS REQUIRED TO BE
4 REGISTERED UNDER ARTICLE FOURTEEN OF TITLE FOUR OF THE VEHICLE AND TRAF-
5 FIC LAW THAT HAS NOT BEEN PREVIOUSLY SOLD TO ANY PERSON EXCEPT A
6 DISTRIBUTOR, WHOLESALER OR MOTOR VEHICLE DEALER FOR RESALE.
7 B. "PERSON" MEANS ANY INDIVIDUAL, FIRM, ASSOCIATION, PARTNERSHIP,
8 CORPORATION, ORGANIZATION, OR JOINT VENTURE.
9 S 2. This act shall take effect immediately.
I don't have a problem usin steel weights, or whatever they want. It's just a pain to switch. Bada has a full ine of clip-on weights as well as stick on. I have a problem with the statistics they are using. I, personally have never lost a wheel weight on any of my vehicles. I put over 40,000 miles a year on my 2 vehicles as well as friends and family and customers. We have all never lost a wheel weight. I'm not sure why they think we lose millions of pounds of weights every year and automatically that equates to millions of pounds of lead in our ecosystem. As far as I know, lead doesn't melt in rainwater. Like I said, I will use steel, no problem, as long as I can balance the wheel.
We have not made the switch yet, but I have been researching it for about a month. We are in Missouri which does not have the law, but it will be coming in the near future. From what I have read it is best to make the switch on our time, rather than waiting until we have to do it. That way we don't get stuck with a shelf full of lead inventory. I know some of the nationwide distributors will buy your lead back if they have another state they can unload them on. Bada steel clip on weights is probably the way we will go. The 3M is awful expensive per ounce compared to the clip weights. That brings the next question, how much do you up the cost of wheel balance to offset the added expense. I figure it needs to be atleast 30%, but then do you price yourself out of the market because the competition hasn't switched? I guess that's when you push the "green" aspect of it.
I agree, the 3M is expensive per ounce, but then it is only 2 part numbers to stock. I don't sell a large quantity of tires or balancing. Heck, you might even ask me why I do it. I am considering the 3M system (or Bada, they have a similar roll weight system) simply because I won't have hundreds of dollars tied up in clip-on weights I won't use. Also, in a small shop the space is at a premium. Anyone have any further insight? Anyone using steel or zinc weights yet?
Here's the NY law:
9 LEAD BY WEIGHT.
LBD14006-04-0
A. 8687--B 2
I think it is more a matter of where do the old used weights get disposed of after they are removed from the wheel, im sure there are shops that just throw them in the trash - which means they end up in a landfill somewhere. ??
Having shops in NH and MA we have tried different weights to see what is going to work. 3M's wheel weighs are great, on new rims. They fall off on old rims and lets face it in the weather we have here, its a rare feat for a rim to be dry and free of debris. Currently we are using "steel" coated stick on weights. Very flexible and very sticky. Steel clip on weights I have been using for over a year and other than them being bigger Price wise is pretty close.
I recycle mine and get money for it. Why would you throw the weights out when someone will pay you for them :)
Same here, I push recycling pretty hard. We recover almost everything and recycle it. Wire scraps, unusable wheel weights, bolts, rotors and other scrap metal. Every few weeks I make a trip to the recycling center and make a few hundred extra bucks with whatever bin is full at the time. Well worth it.
I'm going to watch this thread, I'm also interested in what works best. I looked into this a year ago to try to be in front of the trend and pitch the "green" angle but no local suppliers carried anything but lead stuff. I don't want to deal with the lead anyway. Sick of even yelling at techs who handle the weights without gloves on.
We sell a ton of tires and use a whole lot of wheel weights. I'm in Louisiana and, by reputation, I'm sure we will be one of the last to adopt the ban. I have priced the alternatives and I have not found anything on the market that is as cheap as lead. We will price accordingly and pass the cost on when the time comes.
I got a free demo of the 3M system a while back. I think it is excellent but more than double the price per ounce of lead stick-on weights, which are already more expensive than clip-ons. We are being forced to use more and more stick-on weights due to modern wheel design which is driving up costs.
We try to offset this cost by only making 2 bulk purchases a year for our wheel weights. I have found that there is quite a bit of flexibility in pricing when dealing with the major tire supply companies (Myers, McGee, American Tire Distributors). We have each supplier submit bids and pick the lowest. We are able to get a 35-40% price reduction off their list prices using this method. I would assume you could do the same in the future with alternative weight options to drive costs down.
    • By marxautocenter
      Managing your cash flow can feel overwhelming, but the Profit First system offers a fresh approach to organizing your finances. In this episode of Business by the Numbers, Hunt Demarest, CPA, dives into the pros, cons, and practical applications of Profit First for auto repair shops. Whether you’re new to the system or looking to refine your cash management strategy, this episode is packed with actionable insights.
      What is Profit First? Learn the basic framework of allocating revenue into multiple bank accounts to better manage cash flow. Benefits of Profit First: Understand how it can help you get a clear picture of your cash flow and improve financial decision-making. Challenges to Watch For: Discover why overcomplicating allocations or starting with too many accounts can hinder success. Practical Implementation: Hunt shares a simple three-account system tailored to auto repair --shops for effective cash management. Expert Tips: Adapt the system to your business size and goals, and avoid common pitfalls that lead to failure.
      Podcasting isn’t about having all the answers—it’s about sharing the journey. In this episode, we tackle the hard truth: Podcast hosts don’t have it all figured out. From the insecurities of giving advice to the challenges of staying authentic, we explore what it really means to put yourself out there as a host.
      You’ll discover how to sift through advice, find what works for you, and embrace the imperfect process of learning and leading. If you’ve ever felt like you don’t have it all together, this episode will remind you—you’re not alone.
      Listen in for an honest discussion about navigating the auto repair industry, embracing authenticity, and growing through the challenges of imperfection!
      RepairPal.com/shops
      https://shopmarketingpros.com/ep-118-doing-video-every-day-for-a-month/ - Episode 118 VEDA
      https://agencyanalytics.com/blog/how-profit-first-helped-this-agency-scale - Profit First Was the Key to Our Agency’s Financial Transformation
      https://shopmarketingpros.com/ep-125-its-ok-to-dream-big-stop-playing-small/ - It’s OK to Dream Big (Stop Playing Small)
      Introduction to the Episode (00:00:01)  Brian introduces the podcast and sets the theme about podcast hosts not having all the answers. Inspiration from Mike Allen's Post (00:00:10)  Discussion on how Mike Allen's humorous post sparked Brian's reflections on podcasting and advice-giving. Brian's Insecurities as a Host (00:01:15)  Brian shares his personal insecurities regarding his role as a podcast host and influencer. Critique of Influencers (00:02:26)  Brian expresses frustration with influencers who claim to have life figured out, relating it to his experiences. Sharing Personal Experiences (00:03:33)  Emphasis on the importance of sharing personal learning experiences rather than presenting oneself as an expert. Struggles with Advice-Giving (00:04:36)  Brian discusses his ongoing struggles with the advice he shares in his podcasts and posts. Imposter Syndrome (00:05:37)  Brian reflects on feelings of imposter syndrome when sharing advice on managing expenses and business practices. Going Against Popular Opinion (00:06:46)  Brian talks about the challenges of discussing unpopular business opinions and the reactions he receives. Sponsor Promotion: RepairPal (00:08:54)  Brian promotes RepairPal and its benefits for auto repair shops seeking new customers. Sponsor Promotion: App Fueled (00:09:55)  Introduction of App Fueled and its services for building customer loyalty apps for auto repair businesses. Rewarding Success Stories (00:10:59)  Brian shares the rewarding experience of hearing success stories from listeners implementing his advice. Discernment in Advice-Giving (00:12:03)  Brian advises listeners to discern the credibility of advice from various influencers and podcasters. Conclusion and Reflection (00:13:10)  Brian wraps up the discussion, emphasizing the importance of honesty in sharing experiences and insights.
