What are the Different Types of Auto Paint?
Auto paint has changed dramatically since the late 1800s, and today’s market offers no less than four different types to choose from. Let’s take a quick look at the different kinds of auto paint and the advantages and disadvantages of each.
The four basic types of paint available today are: acrylic lacquer, acrylic enamel, acrylic urethane and water-based. We’ll drop “acrylic” and simply refer to them as lacquers, enamels, urethanes and water-based.
Lacquer-based auto paint was popular between the mid 1920s and 1960s, and is still available today, though it has become illegal in certain areas. Lacquer paint is cheap and goes on easy for the inexperienced painter, plus it provides a nice high gloss. However, it also chips easily being a relatively “soft” paint, and it doesn’t stand up well to UV and chemicals, making it a short-lived paint job. Lacquer auto paint is available in aerosol spray cans and for use with spray guns, but is not generally recommended.
Enamel paints dry to a hard shell making them tougher than lacquer paints. Professional shops bake on enamel paint in heated bays or "ovens," but enamels are also available in aerosol cans and for use with spray guns. Enamels, while tougher than lacquer, do not lay down as easily as lacquer paint, making them trickier for the Do-It-Yourselfer (DIYer) to apply. This translates to more finishing work. Some enamel colors require a clear topcoat, known as a two-stage system, while others can be used alone, referred to as a single-stage system.
Urethane paints are newer than enamels, are more expensive and more trouble, but they lay down easily like lacquer while having the toughness of enamels. This auto paint requires three products: the color, a reducer to thin the color to the right viscosity for the spray gun, and a catalyst used to accelerate drying time. Once the paint is mixed, it must be used quickly and unused paint must be discarded. Urethane auto paint is highly toxic, and though a facemask is standard for all paint jobs, gloves, coveralls, and a respirator are mandatory for working with urethane auto paint.
Like enamels, urethanes can be used alone or in multi-stage paint systems that utilize a final protective clearcoat. A two-stage urethane paint system is the most recommended system as it provides easy-on paint, minimum finish work, and optimum results: a paint job that, with a little care, can look brand new year after year. Urethane clearcoat is also purchased as three products: clear, reducer and catalyst to be used with a spray gun, though there is form of urethane clearcoat available in an aerosol can.
The newest auto paint technology has brought us non-toxic water-based paints. These paints are the most versatile of all, able to be applied to metal, primer, or to an existing paint job. Water-based auto paint is especially popular for use in adding graphics to a vehicle or motorcycle, but can also be used to paint the entire vehicle. Being non-toxic this choice is perfect for the DIYer to use in the home garage, however it does require a topcoat of clear urethane to protect the paint.
Water-based paint is no doubt the future of the auto paint industry, however the line of colors is still expanding. If looking to add graphics or change your vehicle’s color, water-based auto paint is an option. If looking to re-paint a panel with a need to match factory paint, you might have to wait for the introduction of pre-mixed factory colors, or let a professional shop do the job for you.
Source: http://www.wisegeek.com/what-are-the-different-types-of-auto-paint.htm
      Brian and Parker dive into how strategic marketing investment can drive real growth for auto repair shops. Parker shares how increasing his marketing spend transformed his business, leading to record-breaking profits and industry recognition. They discuss why many shop owners hesitate to spend more on marketing and how cutting back can actually slow growth.
      They break down the balance between brand-building and direct response marketing, highlighting how both contribute to long-term success. Parker shares insights from industry peer groups and how analyzing successful shops’ financials helped him refine his own strategy. They also explore how even small adjustments in marketing spend can make a big impact.
      They explain what it takes to turn marketing into a growth engine, from increasing car count to boosting profitability. With real-world insights and proven strategies, they make the case for why now is the time for shop owners to commit to smarter marketing investments.
      Declined repairs don’t have to be lost revenue. AppFueled’s call center schedules follow-up calls and equips your team with everything they need to close the deal. Get started now at appfueled.com
      VISION Hi-Tech Training & Expo
      Introduction to the Episode (00:00:01) Brian Walker introduces the podcast and guest, Hallie Wassinger, discussing the importance of Google Local Services Ads. Overview of Google Local Services Ads (00:02:53)  Hallie explains the recent availability of Google Local Services Ads for auto repair shops across the U.S. Historical Context of Local Services Ads (00:03:25)  Discussion on the past availability of Google Guaranteed Ads and their expansion to auto repair shops. Current Availability and Limitations (00:04:38)  Hallie details the current state of Local Services Ads for tire shops and their limited availability. Cost Structure of Local Services Ads (00:05:34)  Introduction to the pay-per-lead model, highlighting its differences from traditional Google Ads. Service Categories for Auto Repair (00:06:45) Hallie outlines the specific services auto repair shops can advertise under Local Services Ads. Lead Generation Process (00:07:44)  Explanation of how leads are generated through phone calls or messages via the Local Services Ads dashboard. Ongoing Maintenance of Ads (00:08:31)  Discussion on the necessity of monitoring and rating leads to optimize the ad performance. Success Stories from Beta Testing (00:10:55)  Brian shares a success story from Chris Cotton, highlighting low lead costs achieved through Local Services Ads. Lead Cost Insights (00:11:39)  Hallie provides average lead cost data, emphasizing the effectiveness of the ads for auto repair shops. Visibility of Local Services Ads (00:12:18)  Brian describes how Local Services Ads appear prominently in search results, enhancing visibility. Google Screened vs. Google Guaranteed (00:13:02)  Hallie explains the differences between Google Screened and Google Guaranteed, focusing on their application processes. RepairPal Sponsorship Message (00:14:27)  Brian thanks RepairPal for sponsoring the episode and discusses the benefits of being in their certified network. App Fueled Sponsorship Message (00:15:32)  Brian introduces App Fueled, promoting their customer loyalty app for auto repair shops. Verification Process for Shops (00:16:33)  Hallie outlines the verification process for shops to join Google Local Services Ads, including necessary checks. Verification Steps for LSA (00:16:50)  Overview of the verification process for auto repair shops applying for Google Local Services Ads. Challenges with Specialty Shops (00:19:14)  Discussion on difficulties specialty shops face with Google Local Services Ads targeting. Specialization in Google Ads (00:20:03)  Insights on why specialized shops may benefit more from traditional Google Ads. Opportunities with LSA (00:22:05)  Exploration of the current opportunities available for shops using Google Local Services Ads. Cost Benefits of LSA (00:23:13)  Comparison of lead costs between Google Local Services Ads and traditional Google Ads. Importance of Google Business Profile (00:24:29)  Discussion on how optimizing Google Business Profiles impacts LSA ad performance. Role of Reviews in SEO (00:27:40)  Emphasis on the significance of keywords in customer reviews for improving visibility. Optimizing Photos for LSA (00:29:42)  Best practices for managing and updating photos in Google Local Services Ads. Pricing for LSA Management (00:31:01)  Details on the costs associated with managing Google Local Services Ads for shops. Introduction to LSA (00:33:47)  Discussion on the performance of Google Local Services Ads and how to get started. Discovery Call Process (00:34:15)  Details on scheduling a discovery call and assessing local competition for LSA. Final Thoughts on LSA (00:34:38)  Emphasis on the importance of early adoption of LSA for auto repair shops. Self-Management of LSA (00:34:40)  Advice on running LSA independently, highlighting the required time and dedication. Closing Remarks (00:35:29)  Thanking listeners and sponsors, and encouraging engagement with the podcast.
      Marketing isn’t just about spending money; it’s about strategy, creativity, and knowing what actually works. That’s exactly what Brian and Kim Walker unpack in this conversation with Doug DeLuca, owner of Boca AutoFix, who built a thriving auto repair shop without ever working as a technician before opening his doors.
      Doug’s IT background gave him an edge, helping him master SEO, content marketing, and social media, all while running his shop. He shares with Brian and Kim how he tracks data, refines his messaging, and attracts the right clients using unconventional but effective methods. From leveraging Facebook groups to pull in college students to secret-shopping a quick-lube competitor for blog content, Doug proves that marketing success comes from being proactive and intentional.
      This conversation tackles why not every shop needs Google Ads, how to structure diagnostic fees without scaring off clients, and the importance of community involvement. Doug’s hands-on, data-driven approach to marketing offers real insights for shop owners looking to take control of their marketing and maximize results.
      Brian, Kim, and Doug break it all down, giving shop owners a blueprint for smarter, more effective marketing.
      How To Get In Touch With The Guest
      Doug DeLucca’s Facebook account
      BOCA Auto Fix - (561) 826-8834
      ASTA
      They Ask You Answer
      They Ask You Answer Podcast Episode 093
      Which is the right fit for you? A quick lube or an independent auto repair shop?
      Introduction to the Podcast (00:00:01)  The podcast begins with a welcome message from the host, Brian Walker. Guest Introduction (00:00:10)  Brian introduces co-host Kim and guest Doug DeLuca, owner of Boca Auto Fix. Overview of Boca Auto Fix (00:00:51)  Doug shares details about his auto repair shop, including its location and age. Hiring an Apprentice (00:01:09)  Doug discusses the recent hiring of an apprentice and the journey leading to this decision. Challenges in Hiring (00:02:13)  The speakers reflect on the difficulties shop owners face in finding and hiring young talent. Marketing Journey Begins (00:03:02)  Discussion shifts to Doug's initial marketing efforts and his involvement in content creation. Background in Technology (00:04:07)  Doug explains his previous technology background and how it influenced his approach to marketing. Learning SEO and Marketing (00:04:45)  Doug describes his self-taught journey in SEO and digital marketing after opening his shop. Realizing Marketing Needs (00:06:14)  Doug reflects on his initial assumptions about marketing and the reality of attracting customers. Understanding SEO Basics (00:08:09)  Doug shares his insights on SEO and the learning process involved in mastering it. Frameworks in Marketing (00:10:25)  The conversation explores the use of frameworks in both auto repair and marketing strategies. Adopting "They Ask, You Answer" (00:11:23)  Doug discusses his experience with the "They Ask, You Answer" philosophy in content creation. Writing Blogs for Customer Engagement (00:12:21)  Doug explains how he uses customer inquiries to create relevant blog content for his shop. Experience at a Quick Lube (00:13:29)  Doug shares his firsthand experience at a quick lube to highlight differences in service quality. Experience Comparison (00:14:06) Doug shares his experience of visiting a competitor's shop to understand customer perception and service quality. Proactive Client Advocacy (00:14:57) The team discusses the importance of guiding potential clients to the right service provider based on their needs. Sponsorship and Marketing Tools (00:16:13) Brian introduces RepairPal, highlighting its benefits for attracting new customers and building trust. Customer Loyalty Apps (00:17:51) Brian discusses the advantages of using App Fueled to create customer loyalty programs for auto repair shops. Incognito Visits (00:18:20) Doug talks about visiting a competitor's shop incognito to gain insights without revealing their identity. Collaboration Over Competition (00:19:09) The speakers explore the idea of referring customers to other shops and building relationships in the industry. Challenging Competition Norms (00:20:20) Brian reflects on inviting competitors to the podcast, emphasizing collaboration over traditional competition. Marketing Involvement (00:22:42) Doug explains the ad hoc nature of their marketing efforts and the role of social media in their strategy. Community Involvement (00:27:41) Doug shares their family's volunteer work and how it integrates with their business's social media presence. Engaging the College Market (00:28:51) Doug discusses how 30% of his clients are college students and their marketing strategies. Collaborating with Local Professors (00:31:18) Doug shares his experience working with a marketing professor for student analysis of his business. Challenges of Seasonal Demand (00:32:24) Discussion on the impact of seasonal changes on business demand and local marketing efforts. Starting with Marketing (00:34:02) Doug advises new shop owners to listen to podcasts and conduct online research for marketing. SEO as a Long-Term Strategy (00:35:08) Doug explains the importance of SEO and its long-term benefits for business growth. Understanding Competition (00:36:44) Doug emphasizes the need to analyze competition and not assume marketing strategies will work universally. The Importance of Data (00:39:08) Doug highlights the role of data in assessing marketing effectiveness and making informed decisions. Nuances of Market Dynamics (00:41:14) Discussion on how geographical and seasonal factors affect marketing strategies in auto repair. Client Avatar and Marketing Alignment (00:42:13) Doug explains the significance of understanding the ideal customer for effective marketing strategies.  Overcoming Diagnostic Fee Challenges (00:43:09) Discussion on how Doug has adjusted his approach to diagnostic fees to improve customer conversion. The Importance of Evaluation Fees (00:43:40) Discussion on the role of evaluation fees and their impact on shop maturity. Improving Customer Communication (00:44:09)  Insights on enhancing customer explanations regarding services and processes. Coaching and Competitive Analysis (00:45:03)  How coaching helped refine service policies and improve customer relations. Content Creation and Marketing Strategy (00:46:32)  The significance of creating content for customer engagement and marketing. Duck Duck Jeep Initiative (00:47:05)  Fun marketing strategy involving ducks to engage with the local Jeep community. Value of Customer Feedback (00:48:46)  Importance of understanding customer inquiries and improving service based on feedback. Contact Information for Doug DeLuca (00:49:29)   Doug shares how listeners can reach him for further inquiries.
      Episode 208 - Training Hurdles & Reputation Challenges in Auto Repair With Tim Iezzi & Ira Waldman
