Is Change always a Good thing
A body shop dropped off a 2005 Nissan Titan XE for a trailer light problem. It was hit in the rear and had folded the bumper under the body. This particular body shop I have known for years, and they pride themselves on doing a top notch repair on every vehicle that they are associated with. This truck was being a problem though. All the systems were working except for the trailer turn signal lights. To be thorough, they went back thru each and every part that they had replaced or disturbed. Nothing, not a thing… 2 days of checking it out led to a dead end.
That’s where I came into the picture. As always, the first thing I want to see is the wiring diagram. You know, I’ve always said change is a good thing… this time, I should rephrase that to… it’s a good thing that “things change”… and I hope this does real soon, because, this was about the stupidest thing I’ve ever seen. It’s not the first time I have ran across trailer lights going thru computer systems but it’s the first time I ran across only the trailer turn signals running thru the BCM (body control module) not the trailer park lights, not trailer brakes… nope, just the turn signals. Right there on the print… plain as day… R-trailer turn and L-trailer turn… oh please… what were you dudes thinking? (Referring to the engineers)…What was the reasoning behind this?
I checked the rear wiring and all the circuits involved along the underside of the truck… all of which were in impeccable condition. I couldn’t help but stare at that BCM on the wiring diagram… I said to myself, “You mean to tell me I’m going to have to change an expensive BCM just for trailer lights… come on… guys?” (Engineers)
The BCM is attached to brackets just above the gas pedal. Once I managed to get into position to see the BCM, I moved the wire harness out of the way to get a better look at it. All of which looked great. Another glance at the print showed that pin 51 and 52 were the trailer turn signal wires, one yellow/black and the other green/black. Using a test light I checked the leads output signal directly at the BCM connector… I was so glad to see the test light flashing with the turn signals… what a relief… at least it’s not the BCM… it’s wiring in between the BCM and the rear connector. Another long stare at the print with my head under the dash, all wedged in between the driver’s seat and my feet dangling out the door, one hand holding the wiring harness out of the way… flash light by my right ear, the test light and the wiring diagram all getting cramped in what little space that’s provided… but I still couldn’t see the problem. Since I already checked the wiring running into the truck and the signal was coming out of the BCM I had to be close… real close. I was starting to understand why the body shop spent two days looking for the problem and couldn’t find it.
I knew what I had to do… start hand tracing the two leads again from start to finish… one-more-time. At this point anything would be better than spending another minute “sardined” in this truck. As I moved my arm out of the way and was about to slide out from under the dash I noticed right where I had my hand holding the harness out of the way were two small in line fuse holders… almost opaque in color right on the green/black and the yellow/black wires leading away from the BCM. AHA! THERE IT IS! Two in line 10 amp fuses to the trailer lights… Wowser!!! Fixed, done, works perfectly … the prints did not show any fuses in the circuits… it only showed the wiring leading from end to end. Unbelievable, no wonder the body shop couldn’t find the problem… I even missed it till I move my hand out of the way and knew the correct wire colors. It’s not the sort of thing I’d expect to find … factory fuse holders in-line with the BCM… but there they were, you can be guaranteed that I made a note about this one. I won’t forget next time.
It doesn’t help that the prints were wrong, and it doesn’t help that the manufacturer ran the trailer turn signals leads thru the BCM… so I guess I can officially change my status from “change is a good thing” to “good thing it changes” now do me a favor there engineers… Change it!
Crazy, I think it's nuts....! ! If it isn't the customer not wanting to pay for a tough repair, it's the engineering, or the company that prints the schematics. There are so many different pitfalls everywhere you turn.... it's a wonder I don't keep safety lines attached to the roof beams to keep me from falling over everytime I get into one of these situations.
Oh, I charge them, I give them the option before I start and if they say YES, I'm going to go for it.... .... .... yea I know, I'm still going to get an argument... "Why does it cost so much." It never ends....
I'd like to back charge the engineer
  On 10/16/2010 at 11:32 AM, xrac said:
Doesn't stuff like that just drive you crazy. That poor design caused the body shop and you to take all of that time to find what I call a "Mickey Mouse" problem. Who winds up paying for all of those hours? It is hard to convince a customer that it took four hours or $200 or whatever it was to find a blown fuse. We recently had a car that drove us mad with a very intermitten running problem. When the issue was finally solved it was with the battery.
      Doug@bocaautofix.com
      Introduction to the Podcast (00:00:01)  The podcast begins with a welcome message from the host, Brian Walker. Guest Introduction (00:00:10)  Brian introduces co-host Kim and guest Doug DeLuca, owner of Boca Auto Fix. Overview of Boca Auto Fix (00:00:51)  Doug shares details about his auto repair shop, including its location and age. Hiring an Apprentice (00:01:09)  Doug discusses the recent hiring of an apprentice and the journey leading to this decision. Challenges in Hiring (00:02:13)  The speakers reflect on the difficulties shop owners face in finding and hiring young talent. Marketing Journey Begins (00:03:02)  Discussion shifts to Doug's initial marketing efforts and his involvement in content creation. Background in Technology (00:04:07)  Doug explains his previous technology background and how it influenced his approach to marketing. Learning SEO and Marketing (00:04:45)  Doug describes his self-taught journey in SEO and digital marketing after opening his shop. Realizing Marketing Needs (00:06:14)  Doug reflects on his initial assumptions about marketing and the reality of attracting customers. Understanding SEO Basics (00:08:09)  Doug shares his insights on SEO and the learning process involved in mastering it. Frameworks in Marketing (00:10:25)  The conversation explores the use of frameworks in both auto repair and marketing strategies. Adopting "They Ask, You Answer" (00:11:23)  Doug discusses his experience with the "They Ask, You Answer" philosophy in content creation. Writing Blogs for Customer Engagement (00:12:21)  Doug explains how he uses customer inquiries to create relevant blog content for his shop. Experience at a Quick Lube (00:13:29)  Doug shares his firsthand experience at a quick lube to highlight differences in service quality. Experience Comparison (00:14:06) Doug shares his experience of visiting a competitor's shop to understand customer perception and service quality. Proactive Client Advocacy (00:14:57) The team discusses the importance of guiding potential clients to the right service provider based on their needs. Sponsorship and Marketing Tools (00:16:13) Brian introduces RepairPal, highlighting its benefits for attracting new customers and building trust. Customer Loyalty Apps (00:17:51) Brian discusses the advantages of using App Fueled to create customer loyalty programs for auto repair shops. Incognito Visits (00:18:20) Doug talks about visiting a competitor's shop incognito to gain insights without revealing their identity. Collaboration Over Competition (00:19:09) The speakers explore the idea of referring customers to other shops and building relationships in the industry. Challenging Competition Norms (00:20:20) Brian reflects on inviting competitors to the podcast, emphasizing collaboration over traditional competition. Marketing Involvement (00:22:42) Doug explains the ad hoc nature of their marketing efforts and the role of social media in their strategy. Community Involvement (00:27:41) Doug shares their family's volunteer work and how it integrates with their business's social media presence. Engaging the College Market (00:28:51) Doug discusses how 30% of his clients are college students and their marketing strategies. Collaborating with Local Professors (00:31:18) Doug shares his experience working with a marketing professor for student analysis of his business. Challenges of Seasonal Demand (00:32:24) Discussion on the impact of seasonal changes on business demand and local marketing efforts. Starting with Marketing (00:34:02) Doug advises new shop owners to listen to podcasts and conduct online research for marketing. SEO as a Long-Term Strategy (00:35:08) Doug explains the importance of SEO and its long-term benefits for business growth. Understanding Competition (00:36:44) Doug emphasizes the need to analyze competition and not assume marketing strategies will work universally. The Importance of Data (00:39:08) Doug highlights the role of data in assessing marketing effectiveness and making informed decisions. Nuances of Market Dynamics (00:41:14) Discussion on how geographical and seasonal factors affect marketing strategies in auto repair. Client Avatar and Marketing Alignment (00:42:13) Doug explains the significance of understanding the ideal customer for effective marketing strategies.  Overcoming Diagnostic Fee Challenges (00:43:09) Discussion on how Doug has adjusted his approach to diagnostic fees to improve customer conversion. The Importance of Evaluation Fees (00:43:40) Discussion on the role of evaluation fees and their impact on shop maturity. Improving Customer Communication (00:44:09)  Insights on enhancing customer explanations regarding services and processes. Coaching and Competitive Analysis (00:45:03)  How coaching helped refine service policies and improve customer relations. Content Creation and Marketing Strategy (00:46:32)  The significance of creating content for customer engagement and marketing. Duck Duck Jeep Initiative (00:47:05)  Fun marketing strategy involving ducks to engage with the local Jeep community. Value of Customer Feedback (00:48:46)  Importance of understanding customer inquiries and improving service based on feedback. Contact Information for Doug DeLuca (00:49:29)   Doug shares how listeners can reach him for further inquiries.
