Drivin’- Drinkin’ and Grandpa
One of many slow days at the shop I had a small job come in from one of the local tire shops. This rather young girl brought the car to me from the tire shops just a few blocks away. She told me she was the owner and that the tire shop was rude and wouldn’t help her. I told her I’ve never knew them to be that way, but I occasional get like that depending on the reaction at the front desk. (Trying to lighten up the tension at the counter). She wasn’t much for my kind of humor, so I called the tire shop to find out what the deal was.
Her problem was that it would occasionally not start, nothing new, just another typical job. The tire shop didn’t want to get involved with this because it had a breath analyzer attached to the starting system. For anyone out there that hasn’t a clue what this is…, I’ll explain… drinking and driving should NEVER EVER mix, get caught, you’re probably going to have to blow into this ridicules thing to start your car. My opinion, if you get behind the wheel in a condition that would require having to blowing into a plastic tube to start your car, you are without a doubt the most STUPID, inconsiderate person of all times.
Don’t drink and drive!
Personally, I would rather see the driver’s license revoked and give ya a bus ticket instead. (Mandatory taxi/bus or signed sealed delivered notice that has to be approved by the court system from another driver any time you get into a car. Make ya prove you’re not the person behind the wheel.)
Beyond that, I need to find out why this car won’t start. First thing I did was disconnect the breath machine to verify if the problem was “factory” or the analyzer. Once the unit is disconnected from the car I have to call the 800 number on the device to let them know that it is an authorized disconnect and not the driver trying to bypass the system. It’s quite an ordeal to go thru… not the physical disconnect of the unit… that’s easy…but, the information you have to know to prove that you are actually a repair shop when it comes to properly disconnecting the unit. With that over with, I can get back to diagnosing the problem at hand. It turned out to be a bad starter motor. I called the parts warehouse and got prices on a replacement starter for the owner. Later that day the owner called back and said they had just put a starter on so I must be mistaken. …..yea, they did, but it was one of those “discount” brands…..the type that offer a life time warranty…..life time warranty, right a lifetime of changing it. (Note: cheap parts = cheap results)
Instead of getting a name brand part they wanted to replace the starter with another “cheap” brand. Ah yes, the cheapo repair part syndrome, repairing your car with your wallet not with wrenches...
She came for the old starter and sometime later showed up with the replacement starter. I informed the owner that since you have decided on the quality of the part but the quality of my diagnostics hasn’t changed, however if it fails to start for any reason beyond the bolts falling out of the starter do to the fact that I forgot to tighten them up… it’s an all new diagnostic charge to rework the test… which I have no doubt it will end up back to this cheap starter. It’s your choice, just warning you that I can’t trust these cheap parts to perform like good quality parts… “You get what you pay for,” I told her.
It went in one ear and out the other. She answer me, “Ok, can ya have it done today?” Whatever, fine, I’ll put it on…. To my surprise……it worked. The next thing was to rewire the breath machine back into the system. No problems there, everything is in working order.
Enough said about the repair….the next thing was….. Close out the ticket in the front office. That’s when old Grandpa showed up with one hell of a chip on his shoulder. (I think old Grandpa threw back a few before he showed up too.)
“You’re charges are higher than the tire shop,” he said angrily, “I don’t think I should have to pay that much for it if the other shop could have done it for less.”
I informed him that my prices were discussed before the job was even done and the price was OK’d before we even started. Besides, the tire shop may have a lower labor cost but, they also said they didn’t have the necessary skills to actually make the proper diagnosis and or the repair.
He rambled on about how he had fixed cars when he was younger and knew a lot about them He would have fixed it himself if he knew what was wrong with it. Aha! The old “if I knew what was wrong with it” scheme. Now we are on to something. So it’s not so much…what I did or how I did it…. It was “knowing” how and what I did .
Seems I’m not doing my job right, maybe I should just start guessing at the repairs…. Maybe then I could lower the cost of the repairs then I could be like the tire shop…. Or maybe I should just throw a dart at a bulletin board full of pictures of parts and where ever it hits that’s the part I change… or better yet, I’ll send it to someone else who knows how fix it. Oh, wait a minute ….that’s how I ended up with it. Oh that’s right…..I’m the guy who is supposed to be the guy that supposed to fix it for the guy. Guess that’s why I get paid the big bucks.
Sorry Grandpa, maybe I’m doing you a big favor… you spend a few bucks with me, that way you’ll be a few bucks shy of that next 6 pack. That might keep you or your tube blowin’ granddaughter from getting behind the wheel drunk and I might actually be preventing a future fatal accident. So do me a favor…. Save some of that hot air for the breath machine Mr., you’ll need it to start the car….
I thought about getting involved with the installation of these things, even had a rep call me about them. After this little episode I turned it down. It was a wake up call to the type of attitudes and the type of people I am probably going to run into while installing them. And your story is no different. Just goes to show that people are people, no matter what part of the country your in.
Thanx Frank... always can count on ya... Gonzo
Gonzo we installed interlock devices for "National Interlock" for about 6 months. We decided that for our shop with our increasing car counts that it was a losing proposition. However, we did meet some interesting characters including one of the interlocks customer's girlfriends who was either a stark raving maniac or high as a kite. We declined to ever work on that one again.
Joe, I don't know if we were born under the same star or what.... but you REALLY understand the whole thought process behind my writing. It's like the old Dragnet opening comment "the names have been changed to protect the innocent, the stories are true" and it doesn't matter what part of the world you come from it's all the same type of people... clan or whatever ya wanna call it. I always try to write the stories so that everyone across the country can relate to them... and...if they haven't experienced this scenario yet... you will, and hopefully my stories will help prepare that next shop for what is coming next. I honestly believe my stories can help shop owners and techs prepare and be aware of the reality of working with the public.
Like you said... I want to do the job with honesty and integrity... pay me for my time, let us all part ways and go on with our own individual lives. I absolutely HATE people who try to get over on insurance companies or repair shops for things that are not true. Needless to say when I get some slacker in my lobby that thinks they can push their wieght around with that --- "because I'm the customer" type attitude... I've got news for ya buddy... this ain't Walmart, there ain't no upper managment that will take a different look at this problem.... I am the head Honcho here... You deal with me with an attitude... you're going to get one right back...
I'll do my job honestly.... I'll treat you fare... I expect the same in return.
Gonzo, there has to be "clan" of people out there that must share the same genetic makeup. No matter where you go, these people find us. Change the names, the town, and the shop....same clan of people!
What I do like is how you handled the situation. I tip my hat to you. You do not waver, you stand your ground. You are a through-back from a time when people performed a quality job just because it was the right thing to do. Too many businesses today are caught up with the bottom line. Well the bottom line, for me, is doing the right job with honesty and integrity. I am sure you agree.
I consider it an honor to be associated with ASO... and I'm even more honored to know that guys like you...understand this side of the counter and know what it takes to run a shop... AND ... understand what it takes to deal with these type of customers. We can't avoid them, but hopefully thru my stories we can help each other deal with them... and ... let other shop owners that haven't experienced it... know how we all feel.
Thanx again guys... I'll keep writing... you keep readin' thanx again
Right on!!!!! That is exactly the way I feel. When people tell me they are going to call Car-X corporate I tell them that all Car-X corporate will do is call me and tell me about the complaint but this is the place that ALL the decisions for this business are made. If I don't do it it don't get done. If they tell me they are going to call the Better Business Bureau I offer to give them the BBB's phone number. If they tell me they are going to talk to their attorney I have to refrain from laughing. I am a nice guy who will bend over backwards to take care of my customers but when people get me mad they won't get ANYTHING out of me.
We were an Interlock dealer for awhile too. Too many problems with clients that didn't show up for their scheduled appt and particular problems with a couple of clients. One was very aggressive with the mechanics and office and one who blamed us for scratches on his vehicle that was a wreck already. We quit after 4 months. Too little money for too much effort with the not only the mechanical part but the clients as well.
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Recorded at the 45th annual Mobile Air Climate Systems Conference (MACS 2025) in Orlando, Florida, Rob Bollinger shares the unique story of his third-generation family business, emphasizing their commitment to personal service and the legacy of his grandfather, who invented the overflow bottle system. The discussion also touches upon industry trends, the challenges of price competition, the evolution of AC systems with electric vehicles, and Bollinger's future plans for the business. Rob Bollinger, ABC Radiator, Baltimore, MD. https://www.facebook.com/abcradiator401 Show Notes Watch Full Video Episode MACS Training Event & Trade Show: https://macsmobileairclimate.org/ National Automotive Service Task Force (NASTF): https://wp.nastf.org/ Koura: https://www.kouraglobal.com/ Honeywell: https://www.honeywell.com/us/en Introduction to MAC Conference (00:00:00) Guest Introduction: Rob Bollinger (00:02:17) Rob's Family Business Legacy (00:02:52) Personal Touch in Deliveries (00:03:52) Customer Engagement During Deliveries (00:04:30) Rob's Background in the Business (00:06:08) Regrets About Family Business (00:06:22) Coolant Reservoir Bottle Invention (00:07:40) Patenting the Invention (00:08:25) Legacy of the Invention (00:09:48) Cash vs. Cashless Transactions (00:10:05) Honesty in Business (00:15:46) Future of Specialty Shops (00:16:20) Customer Outreach (00:16:30) Changes in Radiator Industry (00:16:54) Hiring Challenges (00:18:11) Golfing and Business Balance (00:18:39) AC Industry Challenges (00:20:10) Leak Detection Methods (00:20:57) Future Plans (00:21:50) Real Estate and Business Stability (00:22:28) Family Support (00:23:33) Training and Industry Updates (00:24:26) Vendor Interaction at Conferences (00:25:08) AI Repair Discussion (00:25:55) Reflection on the Conversation (00:26:09)
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Get ready to grow your business with the Automotive Management Network: Find on the Web at http://AftermarketManagementNetwork.com for information that can help you move your business ahead and for the free and informative http://LaborRateTracker.com Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/         Click to go to the Podcast on Remarkable Results Radio
      Introduction to the Episode (00:00:01) Brian Walker introduces the podcast and guest, Hallie Wassinger, discussing the importance of Google Local Services Ads. Overview of Google Local Services Ads (00:02:53)  Hallie explains the recent availability of Google Local Services Ads for auto repair shops across the U.S. Historical Context of Local Services Ads (00:03:25)  Discussion on the past availability of Google Guaranteed Ads and their expansion to auto repair shops. Current Availability and Limitations (00:04:38)  Hallie details the current state of Local Services Ads for tire shops and their limited availability. Cost Structure of Local Services Ads (00:05:34)  Introduction to the pay-per-lead model, highlighting its differences from traditional Google Ads. Service Categories for Auto Repair (00:06:45) Hallie outlines the specific services auto repair shops can advertise under Local Services Ads. Lead Generation Process (00:07:44)  Explanation of how leads are generated through phone calls or messages via the Local Services Ads dashboard. Ongoing Maintenance of Ads (00:08:31)  Discussion on the necessity of monitoring and rating leads to optimize the ad performance. Success Stories from Beta Testing (00:10:55)  Brian shares a success story from Chris Cotton, highlighting low lead costs achieved through Local Services Ads. Lead Cost Insights (00:11:39)  Hallie provides average lead cost data, emphasizing the effectiveness of the ads for auto repair shops. Visibility of Local Services Ads (00:12:18)  Brian describes how Local Services Ads appear prominently in search results, enhancing visibility. Google Screened vs. Google Guaranteed (00:13:02)  Hallie explains the differences between Google Screened and Google Guaranteed, focusing on their application processes. RepairPal Sponsorship Message (00:14:27)  Brian thanks RepairPal for sponsoring the episode and discusses the benefits of being in their certified network. App Fueled Sponsorship Message (00:15:32)  Brian introduces App Fueled, promoting their customer loyalty app for auto repair shops. Verification Process for Shops (00:16:33)  Hallie outlines the verification process for shops to join Google Local Services Ads, including necessary checks. Verification Steps for LSA (00:16:50)  Overview of the verification process for auto repair shops applying for Google Local Services Ads. Challenges with Specialty Shops (00:19:14)  Discussion on difficulties specialty shops face with Google Local Services Ads targeting. Specialization in Google Ads (00:20:03)  Insights on why specialized shops may benefit more from traditional Google Ads. Opportunities with LSA (00:22:05)  Exploration of the current opportunities available for shops using Google Local Services Ads. Cost Benefits of LSA (00:23:13)  Comparison of lead costs between Google Local Services Ads and traditional Google Ads. Importance of Google Business Profile (00:24:29)  Discussion on how optimizing Google Business Profiles impacts LSA ad performance. Role of Reviews in SEO (00:27:40)  Emphasis on the significance of keywords in customer reviews for improving visibility. Optimizing Photos for LSA (00:29:42)  Best practices for managing and updating photos in Google Local Services Ads. Pricing for LSA Management (00:31:01)  Details on the costs associated with managing Google Local Services Ads for shops. Introduction to LSA (00:33:47)  Discussion on the performance of Google Local Services Ads and how to get started. Discovery Call Process (00:34:15)  Details on scheduling a discovery call and assessing local competition for LSA. Final Thoughts on LSA (00:34:38)  Emphasis on the importance of early adoption of LSA for auto repair shops. Self-Management of LSA (00:34:40)  Advice on running LSA independently, highlighting the required time and dedication. Closing Remarks (00:35:29)  Thanking listeners and sponsors, and encouraging engagement with the podcast.
      Introduction to the Podcast (00:00:01)  The podcast begins with a welcome message from the host, Brian Walker. Guest Introduction (00:00:10)  Brian introduces co-host Kim and guest Doug DeLuca, owner of Boca Auto Fix. Overview of Boca Auto Fix (00:00:51)  Doug shares details about his auto repair shop, including its location and age. Hiring an Apprentice (00:01:09)  Doug discusses the recent hiring of an apprentice and the journey leading to this decision. Challenges in Hiring (00:02:13)  The speakers reflect on the difficulties shop owners face in finding and hiring young talent. Marketing Journey Begins (00:03:02)  Discussion shifts to Doug's initial marketing efforts and his involvement in content creation. Background in Technology (00:04:07)  Doug explains his previous technology background and how it influenced his approach to marketing. Learning SEO and Marketing (00:04:45)  Doug describes his self-taught journey in SEO and digital marketing after opening his shop. Realizing Marketing Needs (00:06:14)  Doug reflects on his initial assumptions about marketing and the reality of attracting customers. Understanding SEO Basics (00:08:09)  Doug shares his insights on SEO and the learning process involved in mastering it. Frameworks in Marketing (00:10:25)  The conversation explores the use of frameworks in both auto repair and marketing strategies. Adopting "They Ask, You Answer" (00:11:23)  Doug discusses his experience with the "They Ask, You Answer" philosophy in content creation. Writing Blogs for Customer Engagement (00:12:21)  Doug explains how he uses customer inquiries to create relevant blog content for his shop. Experience at a Quick Lube (00:13:29)  Doug shares his firsthand experience at a quick lube to highlight differences in service quality. Experience Comparison (00:14:06) Doug shares his experience of visiting a competitor's shop to understand customer perception and service quality. Proactive Client Advocacy (00:14:57) The team discusses the importance of guiding potential clients to the right service provider based on their needs. Sponsorship and Marketing Tools (00:16:13) Brian introduces RepairPal, highlighting its benefits for attracting new customers and building trust. Customer Loyalty Apps (00:17:51) Brian discusses the advantages of using App Fueled to create customer loyalty programs for auto repair shops. Incognito Visits (00:18:20) Doug talks about visiting a competitor's shop incognito to gain insights without revealing their identity. Collaboration Over Competition (00:19:09) The speakers explore the idea of referring customers to other shops and building relationships in the industry. Challenging Competition Norms (00:20:20) Brian reflects on inviting competitors to the podcast, emphasizing collaboration over traditional competition. Marketing Involvement (00:22:42) Doug explains the ad hoc nature of their marketing efforts and the role of social media in their strategy. Community Involvement (00:27:41) Doug shares their family's volunteer work and how it integrates with their business's social media presence. Engaging the College Market (00:28:51) Doug discusses how 30% of his clients are college students and their marketing strategies. Collaborating with Local Professors (00:31:18) Doug shares his experience working with a marketing professor for student analysis of his business. Challenges of Seasonal Demand (00:32:24) Discussion on the impact of seasonal changes on business demand and local marketing efforts. Starting with Marketing (00:34:02) Doug advises new shop owners to listen to podcasts and conduct online research for marketing. SEO as a Long-Term Strategy (00:35:08) Doug explains the importance of SEO and its long-term benefits for business growth. Understanding Competition (00:36:44) Doug emphasizes the need to analyze competition and not assume marketing strategies will work universally. The Importance of Data (00:39:08) Doug highlights the role of data in assessing marketing effectiveness and making informed decisions. Nuances of Market Dynamics (00:41:14) Discussion on how geographical and seasonal factors affect marketing strategies in auto repair. Client Avatar and Marketing Alignment (00:42:13) Doug explains the significance of understanding the ideal customer for effective marketing strategies.  Overcoming Diagnostic Fee Challenges (00:43:09) Discussion on how Doug has adjusted his approach to diagnostic fees to improve customer conversion. The Importance of Evaluation Fees (00:43:40) Discussion on the role of evaluation fees and their impact on shop maturity. Improving Customer Communication (00:44:09)  Insights on enhancing customer explanations regarding services and processes. Coaching and Competitive Analysis (00:45:03)  How coaching helped refine service policies and improve customer relations. Content Creation and Marketing Strategy (00:46:32)  The significance of creating content for customer engagement and marketing. Duck Duck Jeep Initiative (00:47:05)  Fun marketing strategy involving ducks to engage with the local Jeep community. Value of Customer Feedback (00:48:46)  Importance of understanding customer inquiries and improving service based on feedback. Contact Information for Doug DeLuca (00:49:29)   Doug shares how listeners can reach him for further inquiries.
