Mr. Gorillalilla
With all the talk about the cars with push button starting systems and the runaway acceleration problems it made me think of all the ways everyone has been talking about as far as what is the best method to safely stop the vehicle in these instances.
Most everyone will agree that turning off the ignition is NOT the best solution, however, not everyone can agree on whether or not a driver in a panic situation will remember to put the car in neutral instead of reaching for the key or that they shouldn't turn the key back to the "steering" lock position. And for those vehicles with push to start that an operator would remember that you have to hold the "start" button down for several seconds before the car will shut off unless it's in park position.
So a lot of the conversations I'm involved in end up back at the steering lock mechanism, which, in a panic situation is the deadly "lose control" factor. Not to forget the fact that during this so called emergency situation you might be driving at close to 100 miles, which could be scary enough without having to worry about shutting the car off. The conversations I get involved in end up with the controversy over whether or not the "general public" will remember and follow the procedures each and every time they are in an emergency situation.
This made me think of a situation I had with a customer a few years ago. Let's call him "Mr. Gorillalilla"… nice guy and all, but he was a huge muscular dude and as strong as an ox. His mid 80's Jeep CJ was equipped with a key and lock setup that allowed you to turn the key off without it going all the way to steering lock position. There was a lever that had to be pushed down in order to rotate the key back to the off position and remove the key from the ignition lock.
Mr. Gorillalilla had brought his CJ in because he couldn't get the key out of the ignition lock. Examining the problem led to the linkage arms inside the steering column that had been bent and allowed the key and tumbler to rotate around the lock-out mechanism. No parts were really needed; I just had to take it apart and straighten the bent section of the mechanism and reinstall everything. He was relieved that the problem was nothing major and was soon off on his way.
The very next day he was back, but this time he wasn't a very happy rock crawler like he was the first time.
"It's doing the same thing," he angrily yelled back to me.
"Hmm, I wonder how that could be," I said, curious as to how it left in perfect working order but now it's back they way it was.
"Let me get it into the shop and check it out."
Once I had pulled the steering column back down to where I was the day before I noticed the same parts were bent in the same manner as they were when I first seen them. Now how can that be? Not knowing the whole story I went ahead and put everything back to working order again.
"Here ya go, I haven't a clue how in the world that happened sir, sorry about that," I said.
Mr. Gorillalilla thanked me for my time and proceeded to leave. Before he left the parking lot he tried it several times to make sure it was working. It wasn't long before he was back through the door screaming at me again.
"What do I have to do to get you guys to fix this right," he shouted at me.
I went out to the parking lot and looked at his problem again. This time he followed me out to his car. I was totally taken by surprise. Just a few minutes ago I personally saw the switch move just like it was suppose to and I tried it myself several times.
This time, I'm not moving the car. I went back into the shop and grabbed my tools. Right there in the parking lot I pulled it down as he watched me perform the operation on his steering column. I tried it several times myself before I let him try it. As soon as this big brute got behind the wheel I knew right there and then where the problem was. He wasn't using the lever to release the key… he somehow, someway was strong enough to rotate the key over the lever mechanism and that was what was causing all the problems.
The astonishing thing was he could not see that he was the cause of the problem and insisted that it was a defect in the column. After all the debating I told him that I could remove the "safety" and then he could turn the key off without using the lever anymore. That was fine with him. I tore into the column for a fourth time and removed the latching arm that was attached to the outside release lever.
Now I want to complain, but complaining about it doesn't do any good. This big brute had such strong hands he could pull the tumbler back across the stops. The whole thing could have been avoided if the vehicle operator was more aware of how to operate his vehicle correctly. It seems no matter how many times I run across a problem like this I'm the one that ends up putting the labor hours in even though the whole time the problem wasn't my workmanship but this Gorilla's brute strength.
My point about this whole affair?
This was a perfect example of a safety system that failed because the owner wouldn't follow the procedures, and this wasn't even a panic situation. I'm glad I'm not the engineer, because I don't know how I would solve these issues we are having with these latest designs and technologies (drive by wire). But, I will say this, when it comes to adding or changing the systems in the cars to alleviate problems from the driver's seat… I hope they try making the designs and procedures "Gorilla" proof.
Edited by Gonzo
Glad ya liked this one. It was a result of several conversations with vendors, customers, and other shop owners. As usual, every time a few of us get together the "dog stories" start coming out. Which reminded me of this big brute of a fella. Thought it tied the begining of the story to what I wanted to mention in the ending paragraph. Worked well I think.
Plenty more stories, plenty more subjects.
Thanx for the comments. Gonz
Great story. LOL I knew as soon as you mentioned he was a strong man what he was doing to the ignition. I hate to admit it but I have done this type of thing before. Having stronger than normal hands helps in some areas and can get you in trouble at other times.
You Gorilla You.... LOL now thats funny...
I don't get called for the heavy lifting for nothing. The problem is I forgot to listen to my Dad's advice growing up to use my brain instead of my brawn. Now I tend to have to use my brain because my brawn hurts. LOL
There's a story in my published book that you would get a kick out of. Talk about a big brute story... this guy was the king of big guys.
the story is called "Honk for Jesus" if you don't have a copy of my book...yet... ya need too... I'll post that story one of these days if you like. It's another good one. (You know after all these years I pretty much have a story about any subject... LOL)
I will have to look for it :) I got a copy of your book a few weeks ago but have been so busy I haven't had a chance to read much of it.
      Optimize Your Marketing & Stop ARO Drops NOW!
      Welcome to another episode of the Auto Repair Marketing Podcast! I'm your host, Brian Walker, and I’m excited to have my co-host, Kim, back with me after her recovery. Today, we’re diving into a topic that can change the game for your shop: Stop Playing Small.
      If you’re tired of feeling stuck or just getting by, this episode is for you. We'll be talking about the mindset shifts and practical steps needed to build a thriving, impactful business. It’s time to break free from the limits we place on ourselves and dream bigger.
      From overcoming the unique challenges of the auto repair industry to redefining what true success means, we’ll share real stories, honest advice, and strategies you can use to push your business to new heights. Plus, you’ll hear how the right mentors, clarity breaks, and a supportive community can make all the difference.
      Get ready to challenge yourself, take a fresh look at your goals, and start building a business that’s more than just getting by—it’s an empire.
      Let’s jump in and stop playing small together!
      Are you ready to convert clients to members? App fueled specializes in creating custom apps tailored specifically for auto repair businesses. Build client loyalty. Get started today with your own customer loyalty app. Visit https://appfueled.com/
      https://en.wikipedia.org/wiki/Start_with_Why  - Start with Why by Simon Sinek
      https://youtu.be/u4ZoJKF_VuA?si=8yihKPEDRkFErdeN
      https://shopmarketingpros.com/kim-and-brian-tell-their-story/  - Episode 2 : Kim and Brian Tell Their Story
      https://shopmarketingpros.com/walkers-hierarchy-of-marketing-needs/ - Walkers Hierachy of Marketing Needs (Blog)
      https://shopmarketingpros.com/ep-101-walkers-hierarchy-of-marketing-needs/ - Podcast Episode 101
      https://shopmarketingpros.com/ep-084-failing-forward-in-marketing/ - Failing Forward in Marketing - Episode 84
      Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion.
