Here's a problem everyone should be aware of. We replaced both axles on a 2005 Subaru Outback, 2.5. We replaced the axle because both outer axle joints boots were broken. After we put the axles in, the car had a bad vibration at idle and felt like bad engine mounts.
We found an Identifix bulletin about aftermarket axles causing this problem. A few phone calls to the part supplier later, we found out that these axles are new from China and they are machined wrong and somehow transmitting the engine vibrations thru the vehicle.
Many part companies carry these axles under different names, so be carefull!
That's almost funny Joe, a year ago or so I had the same situation... It was because the joints were to stiff... they wouldn't turn smoothly... made the car vibrate like crazy. Had to switch manufacturers...
I have had this problem in the past (several times with Hondas). They would vibrate bad under load. I have come to the conclusion not to ever used remaned axles unless I absolutely have to. I have had much better luck with new axles and I don't have to mess with the cores.
Joe, I noticed you replaced these because the boots were torn. Have you ever just replaced the boots? I do that at my shop and I think it has potentially saved me these headaches. I've heard for a long time that the best parts for a car are the ones they are born with, I think in this case that rings true? Of course, just changing the boots does require more labor and you have to make sure they are installed and greased properly, so maybe it's not the best idea? Just searching for ideas...
  • 4 years later...
old topic but we just had the same problem. Another shop removed the original torn axles and put in "new" ones on a Subaru. Gravy job turned bad, it picked up a bad vibration on acceleration. They balanced the tires and replaced the axles under warranty. Same problem. Sent it to us frustrated. We identifixed it and sent back the new "new" axles and traded them for new "reman" axles, problem solved. Customer normally would have been screwed $115 per side on the cores as the originals were gone but lucky for them we had some laying around in the junk pile.
We don't rebuild axles or replace boots anymore either, the reman axle with lifetime warranty is faster to install and cheaper in most cases.
      Navigating Business Success After Achievements #podcast #autorepairbusiness #automotivebusiness
      Shop Boss – Shop Management Software built by shop owners for shop owners. It works the way you need it to, right out of the box. Find on the web at https://shopboss.net Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/             Click to go to the Podcast on Remarkable Results Radio
      Coping with Business Stress After Opening a Shop
