I'm not so sure about the last quote. Didn't we hear that when obdii took over? No one will be able to afford the complex diagnostic equipment, etc... I actually think it is getting easier and less expensive to purchase diagnostic equipment that was before off limits to DIY'ers. This also leads to the "I know what is wrong, just replace the (insert part name here) for me, it'll just take a few minutes and shouldn't cost me more than $10. Here, I already bought the part.
Amen brother. I don't feel so alone now
While I agree that the people that throw parts at a problem just because the code reader "says to" can become good customers, there are also those that will throw one part at a problem and it will go away. Those people won't be in your shop anytime soon. I might say that it's closer to 50% of the time it's not a sensor causing the problem. The most common sensor code is probably related to O2 sensors and generally it's because the sensor has gotten slow or the heater is shot. I think it basically comes down to this: the gravy jobs won't be as plentiful, but the difficult to diagnose will be. Which goes back to the article about charging for diagnostic work. We need to be careful not to minimize the value of diagnostics as apposed to "code reading". The information needs to be put out there that the "computer" doesn't tell you what part to replace, it just tells you the values the computer is getting are outside of the expected parameters. That can be caused by a bad sensor, poor connections, bad wiring, etc... There needs to be a consumer advocate group (notice I didn't say shop owners group or industry group) that is not into bashing repair shops but will explain exactly what you are getting when you pay for diagnostics and what you get with a "free diagnostic check". That would push more people to our doors and away from the autozones of the world.
Since I was the guy that wrote the article about diagnostics... I guess I'll put another two cents into the conversation.
Yes, charge for diagnostics, No I don't think the "REAL" scanners are getting cheaper... just those (@#!&**@!) code readers. Which as everyone has mentioned... only give you a direction not an answer.
However, I'm finding more and more DIY'rs want to "self diagnose"... had one the other day... "All I want is a thermostat put in." I wanted to diagnose why it needed one... I was assuming it was overheating... but nope, nadda, I'm a stupid mechanic and I don't know anything more than to unscrew a couple of bolts. So I did, in the mean time the lady wanted an oil change... and of course "I brought my own parts" So the whole job was a wash... wasn't worth the time to do.
When I finished the thermostat, and put it up in the air for the oil change... I had to dodge the leaking radiator fluid..... I pulled the car around front, told the lady... we didn't diagnose this problem for you... I only did what you wanted me to do...
Which was fine with her... ... ... ... I never told her about the radiator, I had her sign off on the invoice about "not resposible" and left it at that...
If they are going to argue about having you diagnose it... and they are so damned sure that they know more than me... well, then, I'll play dumb mechanic... and your results... WILL VARY... the old saying never try to be your own lawyer should also include being your own mechanic.
I agree with you one hundred percent. I have customers try that all the time. When you explain the damages that can occur from an improperly diagnosed system they think you are just trying to make more money. Case in point: I had a Ford Escape in my shop with a blown egr valve. I told them that back pressure from a clogged cat caused the valve to blow and that there was an underlying problem that cause the cat to clog. I explained to them that if i replaced the cat and did not diagnose the issue that the cat will clog again and next time they may not have the luck of an 80 dollar part go out. It may be a connecting rod. Well the car came back a few days later. All that work had to be redone.
      This week on Business by the Numbers, Hunt Demarest, CPA with Paar Melis and Associates, breaks down the latest market news and legislative updates that directly impact auto repair shop owners. From the return of the BOI (Beneficial Ownership Information) report to evolving tax policy discussions and IRS processing delays, Hunt provides a no-nonsense analysis of what’s happening and how it could affect your business.
      In This Episode, You'll Learn:
      ✔️ The BOI Report is back—what it is, why it matters, and the March 21st deadline you can’t ignore.
      ✔️ Trump’s tax proposals—what’s being discussed, what’s likely to pass, and what it means for your shop and your customers.
      ✔️ IRS struggles & refund delays—why tax processing is slower than ever and what to expect if you’re waiting on an Employee Retention Tax Credit (ERTC) refund.
      ✔️ Interest rates & the economy—why rates aren’t moving much (yet), and what this means for your financial strategy in 2025.
      ✔️ The state of small businesses & consumer spending—how last year’s trends impact this year’s outlook, and why customer financial health affects your shop’s profitability.
      As a business owner, the fast pace of entrepreneurship can feel overwhelming, but when do you give yourself permission to slow down? In this episode, we delve into The Art of Slowing Down—what it means, why it’s important, and how to make it a reality in your daily life.
      From intentional daily practices to creating systems that allow you to step away, this episode shares actionable insights and personal experiences to inspire you to find balance. Whether you’re planning for the future or simply trying to catch your breath, this conversation will encourage you to rethink how you manage your time and energy.
      Hit play now to learn how slowing down could help you build a healthier, more sustainable approach to business and life!
      Thank you to our friends at RepairPal for providing you this episode. As shop owners we were part of RepairPal’s Certified network and you can learn more at RepairPal.com/shops.
      Introduction to the Episode (00:00:01)  The host introduces the podcast and the topic of slowing down in auto repair business ownership. Discussion of New Features (00:00:46)  The speakers mention the potential of live streaming their podcast on Facebook. The Importance of Slowing Down (00:01:59)  The co-host emphasizes that slowing down doesn't mean being lazy or complacent. Target Audience Clarification (00:02:16)  The host clarifies that the episode is not for new business owners who are still growing. Personal Experiences with Surgery (00:05:30)  Kim shares her experience of recovery after back surgery and the need for slowing down. Planning for Recovery (00:06:56)  Kim discusses the importance of planning and preparing for recovery from her surgery. Building Trust in the Team (00:09:59)  Kim reflects on how stepping back built confidence in her team and their abilities. Easing Back into Work (00:12:33)  Kim talks about her gradual return to work and the importance of giving herself grace. Avoiding Extreme Situations (00:13:25)  The host encourages listeners not to wait for extreme situations like surgery to slow down. The Importance of Slowing Down (00:14:32)  Kim discusses the brutal nature of automotive conference seasons and the need for downtime. Personal Time and Routine (00:15:25)  Kim shares her Friday routine, emphasizing quiet time, workouts, and relaxation. Work-Life Balance for Entrepreneurs (00:16:14)  Kim reflects on the stress of entrepreneurship and the importance of not working excessively every day. Freedom of Time and Finances (00:18:22)  Kim highlights the reasons for becoming a business owner, focusing on achieving freedom of time. Daily Slow Time (00:18:38)  Brian talks about integrating intentional slow time into daily routines, even during work trips. One Minute Pause Technique (00:19:28)  Brian introduces a one-minute pause app for quick moments of mindfulness during busy days. Creating Healthy Leadership (00:20:30)  Brian emphasizes the need for leaders to be emotionally and physically healthy for their teams. Encouragement to Slow Down (00:21:25)  Kim encourages listeners to consider slowing down and reflects on building a supportive team. Conclusion and Thanks (00:22:29)  Kim and Brian thank their sponsors and invite listeners to tune in next week.
      End-of-year chaos is here, and Hunt’s been busy diving into webinars, questions, and updates on some big topics like the BOI report, interest rates, and the infamous Employee Retention Tax Credit (ERTC). In this episode, Hunt breaks down what’s happening, what you need to know, and what you should (or shouldn’t) do before heading into 2024.
      Here’s What You’ll Learn in This Episode:
      BOI Report (Beneficial Ownership Information): This rule was meant to track down shady business practices, but now it’s tangled in legal challenges and paused—for now. Already filed? You’re good. Haven’t filed? You’ve got choices. Hunt explains the pros and cons of sitting tight or filing now. Interest Rates and the Economy: Rates are dropping, but what does that actually mean? Hunt explains why “good news is bad news” for the economy and what’s expected for borrowing costs, CDs, and savings rates in 2024. Key dates to watch for financial reports that could shake things up (spoiler alert: December 11th and 12th are big ones). ERTC: Still Alive, but Barely: The IRS is drowning in a mountain of unprocessed claims—think years of delays. What to do if you’re still waiting on your ERTC money and why you shouldn’t count your chickens (or your tax credit) just yet. Learn more about how to fill out the BOI Report here: https://youtu.be/5pP1b_IzbSY
      Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/
      Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/
      Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/
      The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/
      The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/
      Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/
