We use brake clean as well. You can use the non-chlorinated version. However, we have found a cleaner called Drive-up that is made to clean oil from concrete but a solution of it works great as a degreaser on engines. It is not a petroluem based product but must be some type of akaline. It does not have any obnoxius odor or fumes. Driveup is a good product.
http://www.driveupusa.com/store/dynamicIndex.asp
Cool thanks. I will ask around for this.
I use a crap load of brake cleaner because I am very particular about my stuff being clean when I am done with the repair. I know is probably not good for me and I know first hand that it burns like crap when you get it in the eyes :) I will have to see if I can get this stuff at my Oreillys which it shows sell it.
Not to scare you, but a good friend of mine is a machinist and used brake cleaner to clean parts for more than 20 years. He recently had a kidney transplant for a failed kidney.
The doctors attributed to brake cleaner!
That's still scary Joe....
If we could look through the microscope at almost anything these days, we would probably all be running for the wide open country. I used to spray a lot of Dupont Imron paint years ago and today I feel I'm suffering from the affects it had on my central nervous system. (It had Cyanide in the formula)
I just wanted to mention the we manufacturer a very special soap for cleaning brake parts, we needed something to go along with our OE Approved "5 Step" Brake Procedure ( www.StopBrakeNoise.com ).
You simply mix a couple of tablespoons of the powder in a gallon of water and your have a solution that is perfectly matched to the surface of a rotor or drum. By that I mean, the surfactants, anti corrosives and lack of oil, make it perfect for demagnetizing and cleaning of the pores. This is a critical if you want to eliminate potential problems when the rotor or drum heats up on the vehicle. When that happens, any remaining metal particles from the cut works their way out and into the pad surface and cause excessive noise. ( www.BrakeSoap.com )
Best part is the GWR Brake Soap is biodegradable and costs less than .05 cents to properly clean a vehicle's brake system. Be careful comparing this to a couple of cans of brake clean per vehicle, times the number of jobs per year, you'll have a heart attack. Even if you don't use our soap for other services, doing brakes is a large consumer of brake cleaner in today's shop. If you figure only a case or two a week of sprays, using Brake Soap can save you $500 to well over a $1,000 per year.
Hope this is of value...
Gary
1(800) 266-4497
www.GWRauto.com
Gary
1(800) 266-4497
www.GWRauto.com
I must chime in here. I have been using Garys soap along with his other products for about 5 years now. The brake rotor hone and rotor conditioning spray are two products my brake techs will not be without. I must admit that we use the soap to wash each newly machined rotor but have not tried it as a way to clean prior to starting service. Is that what you suggest Gary?
Hi Curt,
Thanks so much for posting your experience with our brake products, I really appreciate you taking the time to let the members of the group know we have viable solutions to service problems.
As to your question on using the Brake Soap during disassembly, I have used it for that work with good results. I would base the decision on whether or not the parts are caked with heavy, greasy contaminants. Our specially formulated soap is not intended to cut heavy grease but rather to go deep in to the pours of the cast iron rotors and drums, to demagnetize and pull out the loose metal parts. If the parts are really dirty (greasy) us a serious degrease type product before the cutting and honing process. As a note, if the rotor or drum is rusted and dry, I highly recommend using a simple sand blaster (table top or cabinet style, etc) to remove rust and clean surface to a shine. From there you can rinse in our brake soap liquid before going to the lathe. It is imperative you have a shiny surface in the hat areas (adapter mating surfaces), before setting up on the lathe, otherwise you will induce run-out and create an out of spec part.
If a shop is still using brake clean to prepare a rotor for assembly, they are behind the curve nearly 10 years. In tests done over 7 years ago at Aimco (largest mfg of brake rotors), it was determined a soap and water cleaning of rotors or drums removed 40% to 60% more of the loose metal introduced during the cutting process. The properly washed rotors, the ones cleaned with soap and water, retained less than 3% metal while the brake cleaned rotor retained 25% to 35%.
If metal particles are left in the rotor or drum surface, when they are heated during the braking cycle, the metal will work it way out and impregnate the pad surface. This will case excess heat to build during the stop but of more concern is the chance for noise.
Please call me and get some Brake Soap, you will never go back to expensive brake clean. Better, you will be providing your customer with the best brake job possible.
Gary
1(800) 266-4497
  • 6 months later...
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Margaret Palango, CEO of Autoshop Solutions, shares her unexpected diagnosis of acute myeloid leukemia (AML) in May 2023. In this powerful episode, she shares the emotional and physical hurdles she faced, the intensity of her treatment, and how she stayed grounded through it all with a positive mindset. Margaret highlights the critical role of a strong support system and how her team, resilience, and leadership helped her navigate one of life’s toughest battles. Her story is a moving testament to the strength of the human spirit. Don’t miss this inspiring conversation filled with motivation, hope, and meaningful life lessons. Margaret Palango, CEO Autoshop Solutions. Margaret's previous episodes HERE Show Notes Watch Full Video Episode Introduction and Celebration (00:00:00) Margaret's Introduction (00:02:18) Understanding AML (00:02:30) The Importance of Positivity (00:06:18) Treatment Navigation (00:07:32) Listening to Your Body (00:08:18) Advocating for Health (00:09:50) Teamwork with Medical Staff (00:12:35) Managing Side Effects (00:18:25) Bone Marrow Transplant Journey (00:19:56) Importance of Remission (00:20:50) Mental Strength During Treatment (00:24:00) Support and Positivity (00:28:34) Team Dynamics and Leadership (00:30:08) Planning for the Unexpected (00:36:20) Lessons in Trust and Growth (00:37:00) Support from the Team (00:40:12)
      Thanks to our Partners, NAPA Auto Care, NAPA TRACS and Automotive Management Network Learn more about NAPA Auto Care and the benefits of being part of the NAPA family by visiting https://www.napaonline.com/en/auto-care NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Get ready to grow your business with the Automotive Management Network: Find on the Web at http://AftermarketManagementNetwork.com for information that can help you move your business ahead and for the free and informative http://LaborRateTracker.com Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network: https://aftermarketradionetwork.com/ Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion. https://remarkableresults.biz/ Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. https://mattfanslow.captivate.fm/ Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. https://huntdemarest.captivate.fm/ The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. https://autorepairmarketing.captivate.fm/ The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. https://chriscotton.captivate.fm/ Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size. https://craigoneill.captivate.fm/         Click to go to the Podcast on Remarkable Results Radio
      Episode 205 - Preserving Lost Arts in a Changing Industry With Jeff Eddy
      A.P.A.C.
      Acknowledge
      Probe
      Answer
      Confirm
