I would like some feedback from those who have been using BG products. Which ones should I start out with? Which ones are you using the most of? I have a customer who is bringing their car in for 45K service and it says "install BG service kit".
We do coolant, trans, power steering, differentials and transfer case. We sell coolant & transmission more often than the other flushes because customers have been informed more about them in the past. Power steering is really a profitable item because of the time it takes, 10 minutes or less in most cases. But, it does take some training of your customer to make the sale. Generally we add on a flush whenever a system is drained. Our customer's generally won't question a price when you tell them about the added service you are providing. Example: water pump with a coolant flush $xxx.
I agree with you Joe. One thing we try to do is set ourself apart from our competition. BG helps in most cases because of the protection plan. Some shops only sell the product when asked to do a flush. Our sales are from a maintenance view...same as oil change. When we incorporate them into a repair job that is what helps distinguish me from the guy next door. The quality of the service and product. Same as comparing a McD's hamburger to a Applebees burger. Big price difference, but you are there for the service and quality.
  • 5 months later...
Hello to all
BG Products: BG 44K, BG Super Charge 2, BG 244 Diesel, BG MOA, BG CF5
BG 44K, the best, fastest acting, safe, fuel injector cleaner. BG 44K cleans the entire fuel system including intake valves, piston tops and combustion chambers. If you have tried Techron, Sea Foam or other fuel system cleaners and want something better, try BG 44K.
BG Super Charge 2 is an excellent fuel system stabilizer. For lawn equipment, boats, recreational toys, or your treasured car and trucks that do not get much usage. The BG Supercharge 2 slows down the oxidizing of fuel and helps to keep it from turning to varnish.
BG CF5, 'Carbon Fighter 5', fuel additive. BG CF5 is a blend of the famous BG 44K and BG Supercharge. An excellent product for gasoline or diesel engines the CF5 will clean and stabilize your fuel system.
BG 244, everything that has been said about BG44K applies directly to BG 244. BG244 is BG44K specially blended for use in Diesel Engines. The ultimate cleaner for Diesel fuel.
BG MOA, motor oil additive, will stabilize the viscosity of your oil thru modern chemistry, it is not a thickener. MOA will keep oil from foaming at high rpm and will give it thermal stability. MOA is a real good idea if you still use petroleum engine oils, drive hard or use extended oil change intervals with synthetic oils.
Have a nice day
We use all the BG products and have every flush machine. We are sold on BG! Great product with great support.
Plus, they have the BG Lifetime protection and Saftrack Road Side Assistance program. All good stuff.
Joe i wonted to know were you got your flush machines.From BG.?
  • 9 years later...
      Introduction to the Episode (00:00:01) Brian Walker introduces the podcast and guest, Hallie Wassinger, discussing the importance of Google Local Services Ads. Overview of Google Local Services Ads (00:02:53)  Hallie explains the recent availability of Google Local Services Ads for auto repair shops across the U.S. Historical Context of Local Services Ads (00:03:25)  Discussion on the past availability of Google Guaranteed Ads and their expansion to auto repair shops. Current Availability and Limitations (00:04:38)  Hallie details the current state of Local Services Ads for tire shops and their limited availability. Cost Structure of Local Services Ads (00:05:34)  Introduction to the pay-per-lead model, highlighting its differences from traditional Google Ads. Service Categories for Auto Repair (00:06:45) Hallie outlines the specific services auto repair shops can advertise under Local Services Ads. Lead Generation Process (00:07:44)  Explanation of how leads are generated through phone calls or messages via the Local Services Ads dashboard. Ongoing Maintenance of Ads (00:08:31)  Discussion on the necessity of monitoring and rating leads to optimize the ad performance. Success Stories from Beta Testing (00:10:55)  Brian shares a success story from Chris Cotton, highlighting low lead costs achieved through Local Services Ads. Lead Cost Insights (00:11:39)  Hallie provides average lead cost data, emphasizing the effectiveness of the ads for auto repair shops. Visibility of Local Services Ads (00:12:18)  Brian describes how Local Services Ads appear prominently in search results, enhancing visibility. Google Screened vs. Google Guaranteed (00:13:02)  Hallie explains the differences between Google Screened and Google Guaranteed, focusing on their application processes. RepairPal Sponsorship Message (00:14:27)  Brian thanks RepairPal for sponsoring the episode and discusses the benefits of being in their certified network. App Fueled Sponsorship Message (00:15:32)  Brian introduces App Fueled, promoting their customer loyalty app for auto repair shops. Verification Process for Shops (00:16:33)  Hallie outlines the verification process for shops to join Google Local Services Ads, including necessary checks. Verification Steps for LSA (00:16:50)  Overview of the verification process for auto repair shops applying for Google Local Services Ads. Challenges with Specialty Shops (00:19:14)  Discussion on difficulties specialty shops face with Google Local Services Ads targeting. Specialization in Google Ads (00:20:03)  Insights on why specialized shops may benefit more from traditional Google Ads. Opportunities with LSA (00:22:05)  Exploration of the current opportunities available for shops using Google Local Services Ads. Cost Benefits of LSA (00:23:13)  Comparison of lead costs between Google Local Services Ads and traditional Google Ads. Importance of Google Business Profile (00:24:29)  Discussion on how optimizing Google Business Profiles impacts LSA ad performance. Role of Reviews in SEO (00:27:40)  Emphasis on the significance of keywords in customer reviews for improving visibility. Optimizing Photos for LSA (00:29:42)  Best practices for managing and updating photos in Google Local Services Ads. Pricing for LSA Management (00:31:01)  Details on the costs associated with managing Google Local Services Ads for shops. Introduction to LSA (00:33:47)  Discussion on the performance of Google Local Services Ads and how to get started. Discovery Call Process (00:34:15)  Details on scheduling a discovery call and assessing local competition for LSA. Final Thoughts on LSA (00:34:38)  Emphasis on the importance of early adoption of LSA for auto repair shops. Self-Management of LSA (00:34:40)  Advice on running LSA independently, highlighting the required time and dedication. Closing Remarks (00:35:29)  Thanking listeners and sponsors, and encouraging engagement with the podcast.
      Episode 209 - The Path to Becoming a Rock Star Service Advisor with Samantha Higdon
