BG Products
I would like some feedback from those who have been using BG products. Which ones should I start out with? Which ones are you using the most of? I have a customer who is bringing their car in for 45K service and it says "install BG service kit".
We do coolant, trans, power steering, differentials and transfer case. We sell coolant & transmission more often than the other flushes because customers have been informed more about them in the past. Power steering is really a profitable item because of the time it takes, 10 minutes or less in most cases. But, it does take some training of your customer to make the sale. Generally we add on a flush whenever a system is drained. Our customer's generally won't question a price when you tell them about the added service you are providing. Example: water pump with a coolant flush $xxx.
I agree with you Joe. One thing we try to do is set ourself apart from our competition. BG helps in most cases because of the protection plan. Some shops only sell the product when asked to do a flush. Our sales are from a maintenance view...same as oil change. When we incorporate them into a repair job that is what helps distinguish me from the guy next door. The quality of the service and product. Same as comparing a McD's hamburger to a Applebees burger. Big price difference, but you are there for the service and quality.
  • 5 months later...
Hello to all
BG Products: BG 44K, BG Super Charge 2, BG 244 Diesel, BG MOA, BG CF5
BG 44K, the best, fastest acting, safe, fuel injector cleaner. BG 44K cleans the entire fuel system including intake valves, piston tops and combustion chambers. If you have tried Techron, Sea Foam or other fuel system cleaners and want something better, try BG 44K.
BG Super Charge 2 is an excellent fuel system stabilizer. For lawn equipment, boats, recreational toys, or your treasured car and trucks that do not get much usage. The BG Supercharge 2 slows down the oxidizing of fuel and helps to keep it from turning to varnish.
BG CF5, 'Carbon Fighter 5', fuel additive. BG CF5 is a blend of the famous BG 44K and BG Supercharge. An excellent product for gasoline or diesel engines the CF5 will clean and stabilize your fuel system.
BG 244, everything that has been said about BG44K applies directly to BG 244. BG244 is BG44K specially blended for use in Diesel Engines. The ultimate cleaner for Diesel fuel.
BG MOA, motor oil additive, will stabilize the viscosity of your oil thru modern chemistry, it is not a thickener. MOA will keep oil from foaming at high rpm and will give it thermal stability. MOA is a real good idea if you still use petroleum engine oils, drive hard or use extended oil change intervals with synthetic oils.
Have a nice day
We use all the BG products and have every flush machine. We are sold on BG! Great product with great support.
Plus, they have the BG Lifetime protection and Saftrack Road Side Assistance program. All good stuff.
Joe i wonted to know were you got your flush machines.From BG.?
  • 9 years later...
      Do you believe that every shop has a culture, whether intentional or not? Discover how to define your desired culture and lean into empowering leadership and personal development. This episode is packed with actionable insights and real-life stories to help you transform your shop’s culture from the ground up. Whether you’re struggling with high turnover or just want to create a more positive work environment, this discussion has something for everyone. Dave Schedin, CompuTrek Automotive Management Systems. Dave’s previous episodes HERE Maryann, Small Biz Vantage. Maryann’s previous episodes HERE. Rick White, President and Lead Coach for 180BIZ, Listen to Rick’s previous episodes HERE. [email protected] Show Notes
      Rick White on Culture (00:04:55) Rick White challenges the idea of "no culture," emphasizing intentional versus unintentional culture. Maryann Croce on Defining Culture (00:06:59) Maryann Croce discusses the importance of defining desired culture for employee engagement and customer perception. Discussion on Culture's Impact (00:11:53) The panel discusses how culture affects profitability, sustainability, and enjoyment in the workplace. Unethical Practices and Culture (00:12:44) Carm emphasizes the connection between poor culture and unethical practices within a business. Personal Development (00:14:09) Dave discusses how personal development influences a shop owner's ability to cultivate a positive culture. Rick White on Wisdom vs. Knowledge (00:16:54) Rick contrasts knowledge and wisdom, stressing the importance of applying knowledge to create a strong culture. Poor Culture Indicators (00:17:55) Discussion on signs of a poor workplace culture, including low morale and unsafe environments. Lack of Trust and Engagement (00:18:35) Exploration of how absence of trust leads to employee disengagement and its negative impact. Leadership and Growth (00:19:07) Importance of strong leadership for shop success and personal investment in leadership development. Business Ownership Realities (00:24:02) Reflections on the challenges of business ownership and the unexpected demands it brings. Hope and Future Potential (00:27:19) Emphasizing the need for hope and setting high goals to maintain motivation in business. Cultural Shifts and Coaching (00:30:38) Encouragement for gradual cultural improvements and the importance of seeking guidance from coaches. Core Culture Ingredients (00:33:17) Identifying key elements of a positive culture, including leadership behavior and employee recognition. Understanding Culture (00:37:00) Discussion on the significance of culture in a shop and the difficulty of addressing toxic behaviors. Toxic Employees and Culture (00:37:37) Rick shares experiences with toxic employees and how their negative impact can be mitigated. Firing Toxic Behavior (00:38:41) Dave narrates a tough conversation where he separates an employee's behavior from their identity. Difficult Conversations (00:41:06) The importance of having tough conversations to maintain a positive workplace culture is discussed. Burnout and Culture (00:42:46) The effects of burnout on shop owners and the necessity of a supportive culture are highlighted. Culture Change in Teams (00:46:45) The need for team members to see themselves as part of a whole is emphasized through a TV show example.
      Thanks to our Partner, NAPA TRACS NAPA TRACS will move your shop into the SMS fast lane with onsite training and six days a week of support and local representation. Find NAPA TRACS on the Web at http://napatracs.com/ Thanks to our Partner, Auto-Fix Auto Shop Coaching Proven Auto Shop Coaching with Results. Over 61 Million in ROI with an Average ROI of 9x. Find Coach Chris Cotton at AutoFix Auto Shop Coaching on the Web at https://autoshopcoaching.com/ Thanks to our Partner, Today's Class Optimize training with Today's Class: In just 5 minutes daily, boost knowledge retention and improve team performance. Find Today's Class on the web at https://www.todaysclass.com/Connect with the Podcast: -The Aftermarket Radio Network: https://aftermarketradionetwork.com -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on X: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -Special episode collections: https://remarkableresults.biz/collections
      Understand the financial benefits of effective training for  Service Advisors and Customer Service Reps and the importance of networking and collaboration. November 9 - 10, 2024 in Detroit/Novi, MI Learn more at serviceadvisortraining.com
      Leigh Anne Best, Might Auto Pro, Medina, OH, trainer and co-founder of Brakes for Breasts Bill Hill, Might Auto Pro, Medina, OH, trainer and coach Maverick Shop Owners Laura Frank, former shop owner, trainer and co-founder of Brakes for Breasts Gerry Frank, former shop owner, trainer and coach for Maverick Shop Owners
      Importance of Owner Participation (00:03:00) Carm emphasizes the need for shop owners to participate in training alongside their customer service representatives. Networking Benefits (00:04:22) The significance of networking among attendees at the training event for shared learning experiences. Experience of the Trainers (00:05:34) Highlighting the extensive experience of the trainers and their practical knowledge in customer service. Financial Implications of Training (00:06:04) Discussion on the financial benefits of effective customer service and training for shop owners. Technician to Service Advisor Success Story (00:09:01) Bill shares a success story of a technician who transitioned to a service advisor role and excelled. Transparency in Business Practices (00:12:00) Jerry talks about the importance of transparency and ethical practices in customer service. Hiring for Customer Service (00:14:20) Discussion on effective hiring practices for customer service representatives based on personality traits. Upcoming Live Training Event (00:16:34) Announcement of the live service advisor training event scheduled for November 9th and 10th in Detroit. Building Customer Relationships (00:20:22) Emphasizes the importance of educating customers about their vehicle issues for better service. Importance of Follow-up (00:21:20) Highlights the significance of following up with customers to encourage repeat visits. Training for All Staff (00:21:51) Stresses that training should include anyone who interacts with customers, not just CSRs. Tracking Phone Call Success (00:22:31) Discusses the importance of tracking opportunity calls to measure conversion rates effectively. Utilizing Technology for Improvement (00:23:33) Mentions the benefits of using technology to analyze customer interactions and improve service. Identifying Underlying Problems (00:24:52) Explores how phone answering issues can be mistaken for marketing problems. Adapting to Change in Business (00:26:06) Encourages business owners to evolve with industry changes and invest in staff training. Challenges in Leadership (00:27:19) Discusses difficulties in communicating effectively with staff and the importance of peer learning.The Value of Training (00:31:53) Argues that investing in training can sustain or even improve business revenue. Setting Staff Up for Success (00:33:27) Emphasizes the responsibility of leaders to properly train staff for their roles. Motivation for Collaboration (00:34:23) Explains the drive behind the coaches to organize training sessions for struggling clients. Helping Others Succeed (00:35:50) Emphasis on the joy of witnessing others' success and mentorship in the industry. Overcoming Training Paralysis (00:36:27) Addressing confusion in training and providing guidance to help shop owners move forward. Value of Training (00:41:49) Discussion on the impact of trained salespeople on business success and owner satisfaction.
      Episode 182 - Customer Escalations and Unusual Finds in Car Trunks With Auto Shop Follow Up
    • Sell your car with CarBrain
      Thanks to our Partners, Shop Boss, and 360 Payments In this episode of For the Record, Maylan Newton tackles the pressing issue of the technician shortage in the automotive industry. Maylan emphasizes the importance of proactive involvement from shop owners and industry representatives in engaging with educational institutions and students. He highlights the need for better representation at vocational events and the necessity of running businesses that attract and retain skilled technicians. Maylan urges the industry to work together to create an inviting career path for the next generation. Maylan Newton, ESI- Educational Seminars Institute. Maylan’s previous Episodes HERE Show Notes
      Hiring Challenges in the Industry (00:00:30) Maylan discusses the full-time nature of hiring and the industry's struggles to attract technicians. Skills USA Event Insights (00:01:02) Maylan shares his experience at a Skills USA event, highlighting the lack of automotive representation. Engaging Young People (00:02:19) He emphasizes the need for the automotive industry to inform youth about career paths available. Personal Outreach to Schools (00:03:24) Maylan recounts his efforts speaking at high schools to promote automotive careers. Importance of Industry Visibility (00:05:25) Maylan urges industry members to actively engage with schools and promote career opportunities. Attracting and Retaining Technicians (00:06:17) He stresses the need for fair treatment and compensation for new technicians entering the field. Talent Acquisition Efforts (00:08:01) Maylan highlights the proactive approach of other industries in recruiting young talent. Call to Action for Shop Owners (00:09:38) He challenges shop owners to commit to engaging with local schools and vocational programs. Quotes for Inspiration (00:10:35) Mahlon shares motivational quotes to encourage industry involvement and improvement.
      Thanks to our Partners, Shop Boss and 360 Payments Shop Boss – Shop Management Software built by shop owners for shop owners. It works the way you need it to, right out of the box. Find on the web at https://shopboss.net Connect with the Podcast: -Follow on Facebook: https://www.facebook.com/RemarkableResultsRadioPodcast/ -Join Our Virtual Toastmasters Club: https://remarkableresults.biz/toastmasters -Join Our Private Facebook Community: https://www.facebook.com/groups/1734687266778976 -Subscribe on YouTube: https://www.youtube.com/carmcapriotto -Follow on LinkedIn: https://www.linkedin.com/in/carmcapriotto/ -Follow on Instagram: https://www.instagram.com/remarkableresultsradiopodcast/ -Follow on Twitter: https://twitter.com/RResultsBiz -Visit the Website: https://remarkableresults.biz/ -Join our Insider List: https://remarkableresults.biz/insider -All books mentioned on our podcasts: https://remarkableresults.biz/books -Our Classroom page for personal or team learning: https://remarkableresults.biz/classroom -Buy Me a Coffee: https://www.buymeacoffee.com/carm -The Aftermarket Radio Network: https://aftermarketradionetwork.com -Special episode collections: https://remarkableresults.biz/collections The Aftermarket Radio Network Remarkable Results Radio Podcast with Carm Capriotto: Advancing the Aftermarket by Facilitating Wisdom Through Story Telling and Open Discussion Diagnosing the Aftermarket A to Z with Matt Fanslow: From Diagnostics to Metallica and Mental Health, Matt Fanslow is Lifting the Hood on Life. The Auto Repair Marketing Podcast with Kim and Brian Walker: Marketing Experts Brian & Kim Walker Work with Shop Owners to Take it to the Next Level. The Weekly Blitz with Chris Cotton: Weekly Inspiration with Business Coach Chris Cotton from AutoFix - Auto Shop Coaching. Business by the Numbers with Hunt Demarest: Understand the Numbers of Your Business with CPA Hunt Demarest. Speak Up! Effective Communication with Craig O'Neill: Develop Interpersonal and Professional Communication Skills when Speaking to Audiences of Any Size.
