I think that it is very important for shops to check TPMS sensors BEFORE changing tires to avoid blame for defective sensors.
What equipment is your shop is presently using--how satisfied are you with it?
I'm considering the purchase of the following KTI tool: http://ktipst.com/index.php?page=press_release
And the following system (affordable universal replacement sensors that can be programmed to mimic OEM sensors) sounds great, but I don't know anyone who has used it: CUB Programmable Universal Replacement - TPMS Scan Tool ($650 from Tire Rack Wholesale) and TPMS Sensors ($28 each from Tire Rack Wholesale)
Thanks for your help!
We use the OTC 3833. Worked good for awhile then started having problems on G.M.'s. We called tech assist, they stated I needed another update. Update was on back order. Took about two months to get the update. Now it works fine. Has an RKE identifier, which we have found to be most of the problems with tpms. Make sure your customers leave the RKE with the vehicle.
  • 4 months later...
That's great information, we went a little nuts today on a lexus. We have the Bar Tech. It read the fault ok, but re-set was a pain.
Thanks again!
It is a well know fact that Japanese and other Asian vehicles are among the most difficult to reset, the reason is the availability of quality software. Being that ATEQ is the worlds largest OE manufacturer of TPMS equipment for new vehicles, for original vehicle setup at a factory, they have first access to software over all the other non OE tool suppliers. It's a know fact that many of the aftermarket re-set tool suppliers have to rely on buying sensors and then backward engineer them to try and retrieve the operating software.
ATEQ's VT55 tool can re-set and upload the TPMS data on more vehicles than any other tool on the market and at twice the speed. Better yet, the update subscription won't cost you an arm and a leg, it's less than half the yearly fee charged by Bartec.
www.ateqTPMStool.com
When you're ready for the OE TPMS tool, or deside to update limited equipment, we are able to offer special discounts to all ASO members through an in house program. Please call me for details, I'd be happy to explain how it works.
Thanks, Gary
1(800) 266-4497
www.GWRauto.com
P.S. I wanted to mention that we just finished our new TPMS Sensor Assortment Kit, this program is revolutionary. We have both OE replacement sensors and our patented Universal TPMS Sensor, so you have a choice for your customer. These are not the aftermarket versions so common at local auto parts stores, rather they are built by the OE supplier to many of the largest Asian car manufacturers. You won't have to wait for delivery and pay higher prices for the odd sensors not easily available.
www.universalTPMSsensor.com
  • 5 years later...
I am using the Bartec 400SD. Has worked on everything I have needed it for including reprograming sensors. Also a difficult Lexus IF.
ATEQ VT55. I have not had one vehicle I couldn't reprogram/reset with it.
I also have a cradle to program the Dorman Multi-Fit sensors. I can actually program these Multi-Fit sensors with the original sensor ID's. By doing that, there is no need to reprogram the module for the new sensor ID. Pretty slick.
I've used an AUTEL ts401 for years, then... just the other day, I had a 09 Mits. Eclipse to do. I could read the tire sensors but it would not register the sensors to the ECU. Called Autel and asked them "Hey, this here tpms tool says on the first page... Does ALL cars...but it won't do this one." They told me I have to buy a new tool. The MS905 and hook the ts 401 tool to it with the USB that comes with the tool and then I can. Great...another 1500 bucks to do the same thing I did last year without this new tool. hate it hate it hate it hate it. friggin tool manufacturers are like car manufacturers... "Obsolete the parts and change things so you have to buy new"
Apparently, ALL doesn't mean ALL,,,, only I suppose.... up to the manufacturing date of the tool. go figure.
Napa has a great deal right now with an entire tpms kit, it ateqs tool, cabinet repair kit and sensors. I have not had a single car unable to program or relearn, including Aston Martin, Maserati and bentleys
Lately we've been using cloned sensors from auto plus. I call, give them the FCC id#, a programmed one shows up in a few minutes. It saves me time and $.
I see dorman makes a 315mhz kit for about $300, at least the industry is heading in the right direction.
Ironically the easiest sensors to program are the brown Mercedes Benz units, they are plug and play. Try that with a scion sensor. Ha!
      Getting involved in your community is powerful, but how do you share your efforts without sounding boastful? There’s a fine line between successful and selfish self-promotion, and in this episode, Brian and Kim Walker discuss how to highlight your work with authenticity and gratitude—not ego.
      We’ll discuss framing your message to focus on the cause, aligning community service with your company culture and purpose, and sharing stories that connect and inspire rather than just promote. Plus, we’ll share real-life examples—like our team’s work with Our Daily Bread Food Bank—and how to encourage others to get involved.
      Tune in now to learn how to support your community while staying humble and making a real impact!
      Start with Why - By Simon Sinek
      Commission Mankind
      Introduction to the Episode (00:00:10) Brian introduces the podcast and the topic of community involvement. Topic Suggestion Acknowledgment (00:00:34) Brian mentions Doug DeLuca's suggestion for the episode topic. Sponsor Acknowledgment (00:01:00) Brian thanks RepairPal for sponsoring the episode. Technical Issues Discussion (00:01:30) Brian and Kim discuss technical issues and Brian's experience with braces. Community Involvement Concerns (00:03:44) Kim shares a friend's hesitation about promoting community involvement due to fear of appearing boastful. Successful vs. Selfish Promotion (00:05:44) Discussion about the fine line between effective promotion and self-promotion. Promoting Community Engagement (00:07:24) Kim emphasizes the importance of spacing out promotional posts about community involvement. Starting with Gratitude (00:07:46) Kim suggests starting messages about community involvement with expressions of gratitude. Importance of "Why" (00:09:09) Discussion on the significance of explaining the reasons behind community involvement. Examples of Community Involvement (00:09:15) Brian and Kim share experiences of their community service activities. Promoting Community Work (00:11:25) Brian discusses the importance of promoting community service to demonstrate business values. Messaging about Community Involvement (00:12:21) Kim provides examples of how they communicate their community involvement on social media. Team Engagement in Community Work (00:14:20) Brian reflects on the team's connection with community members during service activities.  Closing Sponsor Acknowledgment (00:15:14) Brian thanks RepairPal again for supporting the episode. Community Engagement Strategies (00:15:26)   Discussion on how RepairPal helps auto shops gain customers through certification and fair pricing. Customer Loyalty Apps (00:16:25)  Introduction of App Fueled, a customer loyalty app designed for auto service shops. Highlighting Community Work (00:17:11)  Tips on emphasizing organizational missions instead of personal achievements in community involvement. Authentic Community Involvement (00:17:54)   The importance of sharing community efforts without seeking personal recognition or return. Sharing GoFundMe Campaigns (00:18:51)  Encouragement to promote charitable causes without boasting about personal donations. Industry-Specific Support (00:19:16)  Discussion on giving back to the auto repair industry and local communities. Respecting Privacy in Sharing (00:19:39)  The balance between sharing community involvement and respecting the privacy of those served. Educating Marketing Teams (00:22:43)  The need to guide marketing teams on how to portray community involvement authentically. Collaborating with Other Organizations (00:24:17)  Benefits of partnering with local businesses for community service efforts. Celebrating Local Teams (00:25:38)  Highlighting local sports teams and community events to promote goodwill. Telling the Story of Donations (00:27:40)  Importance of sharing the personal connection behind charitable contributions. Personal Anecdotes from Mission Trips (00:28:28)  Sharing impactful stories from mission trips to illustrate the importance of community support. Personal Anecdote on Community Support (00:29:29)  Kim shares a personal story about supporting organizations that assist her brother with disabilities. Encouragement to Join Facebook Group (00:30:44)  Kim invites listeners to join their Facebook group for further engagement and community building. Request for Podcast Reviews (00:31:03)  Brian asks listeners to leave reviews for the podcast, emphasizing the importance of feedback. Closing Remarks and Sponsorship Acknowledgment (00:31:36)  Brian concludes the episode, thanking sponsors and encouraging listeners to tune in next week.
      Episode 205 - Preserving Lost Arts in a Changing Industry With Jeff Eddy
