Candice and Jesse Beuttenmuller come every March from WaKeeney, KS. to the Vision KC Hi Tech Expo. Vision KC, they say, is their Happy Place, therefore shutting down the shop to attend. Their town is so small it doesn’t even have a stoplight! Since we recorded the episode they changed the name of their business to ‘Old 40 Auto Care’. We also discuss the importance of communication with their customers. As a side note, we had a lot of laughs and fun while recording this episode.
Candice and Jesse Beuttenmuller, Old 40 Auto Care Listen to their previous episodes HERE
Key Talking Points
The whole county is 900 square miles Leaving Vision- Use the time the best way you can, debrief after classes together, you need to make a plan to use the information when you go back to your business. Pick 1-2 things to implement first while it’s fresh on your mind. Let their customers know ahead of time they will be closed for Vision and schedule around it Their 2 young boys help out in the shop after school Has business coach- networking with the other clients together at Vision. Reviewing what you know has its benefits giving you peace of mind you’re on the right track.
Subscribe on YouTube
Visit us on the Web
Follow on Facebook
Become an Insider
Buy me a coffee
Important Books
Check out today's partner:
Learn more about NAPA AutoCare and the benefits of being part of the NAPA family by visiting www.NAPAAutoCare.com
By Gonzo
Picture This
Years ago my younger brother came to work for me. He didn’t know a thing about cars, but was willing to learn all he could. Teaching new techs is an art that most shop owners have to learn to do, but teaching your little brother can be a chore and can test your patience. I muddled thru it all and taught him what I could. I was sure at some point in time the two of us would butt heads like brothers will do, and he would take his new found skills and move up in the rank and files of the automotive technical world, but in the meantime it was his turn to learn from his older brother.
When he first started I would walk him through each step of how to diagnose a certain system in a car. A lot of times he would have questions, and I’d do my best to answer them. He learned quickly and was really sharp at picking up some of those little details that are harder to teach. You know things like how you held a certain wrench or used a certain tool, to you and me it’s no big deal. But to a novice, it’s a revelation, then you (I) tend to forget to mention those certain traits while you’re teaching. Mainly because you are trying to get to the solution as efficiently as possible, and you neglect to bring it up. Such as: “always test your test light connection before testing what you’re testing, or don’t forget to check for all your tools before you pull the car out of the shop….” Things like that.
One day we had a truck come in with dual fuel tanks on it. The gas gauge wasn’t working and needed some attention. This was a perfect opportunity for Junior to learn a few of my short cuts on these old models. It was an older Ford, in which the tank gauge ran thru the tank switchover button. It was rather easy to pull it out of the dash and connect to the gauge from the back of the switch.
Luckily it was the typical problem I’ve seen a hundred times in the past. The switch connections would melt and the tank wouldn’t switch from the front tank to the rear, and of course the gauge wouldn’t move either.
After locating the correct leads to the gauge and to the tanks I decided to show him how the gauge worked. I hooked up the one of the tanks to the crossover lead that would supply the signal from the tank to the gauge.
“Ya see this, that’s the lead to the fuel gauge in the dash, and this is one of the tank wires. I’ll connect these together and we should get a reading on the dash,” I told him.
He was watching intently, taking in all the wiring diagram information, the location of the wires, and how I was bypassing the switch. He was fascinated with the flow of the current and the way the gauge would respond. I even went as far as moving the gauge from full to empty by opening and closing it to a ground signal. While I had his attention I filled him in on the two types of gauges that were used back then (bimetallic and magnetic) and how low resistance on a bimetal type gauge would read near a full tank, while a magnetic gauge would read close to empty. Change the resistance and the gauge would/should read accordingly.
“So, if we put gas in the tank the gauge should move right? That way we could check the sending units in the tanks too,” he asked me.
“Great idea, grab a gas can and let’s add a few gallons,” I said, excited that he was so interested in the project.
He grabbed a can of gas and poured a few gallons in the tank. I was watching the gas guage carefully, but there was no movement. I knew I was on the right wires, but nothing was happening. Now what? Are there more problems?
“Crawl under there, and check to be sure the wire color is correct,” I yelled from the cab to him.
“Yep, it’s the right wire on the tank.”
“Well, we might have to pull the tank; it’s not changing the gauge readings up here.”
“Before we do that let’s add some more gas, maybe we didn’t add enough,” Junior tells me.
I thought I better go back and help hold the funnel, while he poured the gas in the tank. Unknowing to me, all this time my wife (who was the office manager) was listening in on the whole thing. She likes to keep tabs on me, and make sure I’m not going into one of my usual rants or having a fit because I had to explain something over and over again to little brother. This time she was standing at the corner of the shop just behind the truck with a camera. “CLICK”, I heard the camera shutter go off and she was back there laughing like there was no tomorrow.
“What’s so funny?” I asked her.
“You two idiots have been putting gas in the wrong tank. You’re on the front tank, and you’re putting gas in the rear tank,” my wife answers, laughing hysterically.
About then the camera “clicked” again… this time it was an action shot taken at precisely the exact moment when these two idiots had that dumb struck look on their faces and realized what they just did. The shot had both of us on our knees, one holding a funnel and the other with the half empty gas can, and both of us staring right into the camera lens. Couldn’t have set it up any better if you tried.
The picture clearly showed the side of the truck with both fuel tank doors visible and there was no doubt which tank we were putting in the extra gas. I guess it was one of those things I should have mentioned when we were checking the tank senders… make sure we are both on the same tank.
For years that picture hung over her desk, and anytime I thought I was so smart she would point at the photo. Usually with that typical smirk, usually shaking her finger at me and of course the laugh… she had to laugh, but it wasn’t all that funny until she had me laughing about it too. Ok, Ok, I’m not perfect... and now my little brother knows it too.
These days he’s a top notch tech at a dealership, and I have to call him on occasions for some help on how to solve things once in a while. Oh the photo… uhmmm… what photo?? Somehow it’s missing… haven’t seen the darn thing in years. But I guess I really don’t need to see the photo … the wife has a pretty good memory... she reminds me just how smart I think I am every chance she gets.
By OOOooo
A customer came in with a 2002 Mercedes C230 and my "C" mechanic took it for a test drive. For some reason (he says accidentally) he hit the sun roof and the interior part opened and will not close. The customer tells us that it was broken when she bought the car and she took it some where to have them put it back and she has not messed with it since them. I feel that we should fix it but my head mechanic says he will not mess with it because he has no experience with it. I can tell him to do it anyway but don't want to end up in a bigger mess than I am in right now. I would like to hear how you guys have dealt with situations like that.
By PARKSINDUST
First off customer okay'd job on 11/21, advised what needed to be done and customer kept avoiding my calls. Called her about every week, then about two weeks ago called her and left a message (she didnt answer, surprise surprise) and advised that if she didn't pay the remaining bill what we did on the vehicle and pick it up, then we would have it towed at the end of the day on Friday two weeks from then. Never called, never showed, had it in our shop for 3 months. The towing company had to contact the authorities in so many days so its not considered a stolen vehicle, then customer calls my tow guy and bit#@%S out his son, then they call the police. So now do I have to call the police or take it to small claims court??
Does the mechanics lien actually work or stand up to authorities or the court?
How much can one shop charge for storage fees? its been in our shop since November, I could charge that, it has taken up our 2nd rack and lost us money.
Now they dont want to pay the bill or the tow fee, how do I go about this, please help
Thanks
AK
- 0 comments
- 0 comments
- 0 comments
- 58 views
- 0 comments
